In our org we have a backend infra team and a frontend helpdesk team. The frontend team would like to be able to run remote execution jobs, however I’m trying (for several days unsuccessfully) to impose the following constraints:
- They only have the ability to run jobs against desktop systems
- They have to use their user credentials
- They should not have the ability to use the global SSH user and foreman-proxy SSH private key
I’ve shared the latest role config below, but is this even possible? Unless I mark the Template Invocation resource as unlimited, job submissions fail with the reported error.
Foreman and Proxy versions: 3.9.1 (single node)
Foreman and Proxy plugin versions: Katello 4.11.0
Distribution and version: Rocky Linux 8.9
Error message:
PG::NotNullViolation: ERROR: null value in column "template_id" violates not-null constraint
Role filter config:
$ hammer --output base filter list --search role_id=30 --order resource --fields "resource type,search,unlimited?,permissions" --per-page "all"
Resource type: (Miscellaneous)
Search: none
Unlimited?: yes
Permissions: access_dashboard, view_statuses, generate_ansible_inventory
Resource type: Architecture
Search: none
Unlimited?: yes
Permissions: view_architectures
Resource type: Audit
Search: none
Unlimited?: yes
Permissions: view_audit_logs
Resource type: Bookmark
Search: none
Unlimited?: yes
Permissions: edit_bookmarks, create_bookmarks
Resource type: ComputeProfile
Search: none
Unlimited?: yes
Permissions: view_compute_profiles, create_compute_profiles, destroy_compute_profiles, edit_compute_profiles
Resource type: ComputeResource
Search: none
Unlimited?: yes
Permissions: destroy_vm_compute_resources, create_compute_resources_vms, destroy_compute_resources_vms, edit_compute_resources_vms, power_compute_resources_vms, power_vm_compute_resources, view_compute_resources, view_compute_resources_vms
Resource type: ConfigReport
Search: none
Unlimited?: yes
Permissions: view_config_reports
Resource type: Domain
Search: none
Unlimited?: yes
Permissions: view_domains
Resource type: FactValue
Search: none
Unlimited?: yes
Permissions: view_facts
Resource type: ForemanTasks::RecurringLogic
Search: none
Unlimited?: yes
Permissions: edit_recurring_logics, create_recurring_logics, view_recurring_logics
Resource type: ForemanTasks::Task
Search: none
Unlimited?: yes
Permissions: view_foreman_tasks
Resource type: Host
Search: hostgroup_fullname ~ Desktops
Unlimited?: no
Permissions: create_hosts, view_hosts, power_hosts, edit_hosts, destroy_hosts, build_hosts
Resource type: Hostgroup
Search: name ~ Desktops or title ~ Desktops
Unlimited?: no
Permissions: view_hostgroups
Resource type: Image
Search: none
Unlimited?: yes
Permissions: view_images
Resource type: JobInvocation
Search: none
Unlimited?: yes
Permissions: view_job_invocations, execute_jobs_on_infrastructure_hosts, create_job_invocations, cancel_job_invocations
Resource type: JobTemplate
Search: none
Unlimited?: yes
Permissions: view_job_templates
Resource type: Katello::ActivationKey
Search: none
Unlimited?: yes
Permissions: view_activation_keys
Resource type: Katello::ContentCredential
Search: none
Unlimited?: yes
Permissions: view_content_credentials
Resource type: Katello::ContentView
Search: none
Unlimited?: yes
Permissions: view_content_views
Resource type: Katello::HostCollection
Search: none
Unlimited?: yes
Permissions: view_host_collections, create_host_collections, edit_host_collections
Resource type: Katello::KTEnvironment
Search: none
Unlimited?: yes
Permissions: view_lifecycle_environments
Resource type: Katello::Product
Search: none
Unlimited?: yes
Permissions: view_products
Resource type: Location
Search: none
Unlimited?: yes
Permissions: view_locations
Resource type: LookupValue
Search: none
Unlimited?: yes
Permissions: view_lookup_values
Resource type: Operatingsystem
Search: name ~ RockyLinux
Unlimited?: no
Permissions: view_operatingsystems
Resource type: Organization
Search: none
Unlimited?: yes
Permissions: view_organizations
Resource type: Parameter
Search: none
Unlimited?: yes
Permissions: edit_params, create_params, view_params
Resource type: ProvisioningTemplate
Search: none
Unlimited?: yes
Permissions: deploy_provisioning_templates, view_provisioning_templates
Resource type: Ptable
Search: none
Unlimited?: yes
Permissions: view_ptables
Resource type: ReportTemplate
Search: none
Unlimited?: yes
Permissions: create_report_templates, view_report_templates, generate_report_templates, edit_report_templates
Resource type: SmartProxy
Search: none
Unlimited?: yes
Permissions: view_smart_proxies
Resource type: Subnet
Search: none
Unlimited?: yes
Permissions: view_subnets
Resource type: TemplateInvocation
Search: host_group.name ~ Desktops
Unlimited?: no
Permissions: create_template_invocations, view_template_invocations, filter_autocompletion_for_template_invocation
Desktops are in nested hostgroups depending on deployment, i.e.:
- Desktops/<lifecycle>/Physical
- Desktops/<lifecycle>/Virtual
