I am having some issues provisioning hosts through foreman REST API (more
exactly using foreman-python). Once the host is created it does not boot
automatically, I need to send the start command. This workaround works with
provision_method=build, but with provision_method=image it doesn't because
the POST host doesn't return after the host is created, instead the
following error is received:
Failed to login via SSH to client07072015130432.lab.primarydata.com:
execution expired
Is there some flag I'm missing that will indicate to immediately boot the
host after creation?
> execution expired
I don't think there's any flag, the host should boot automatically.
Could you give us some logs (/var/log/foreman/production.log) to see
what happens when you send this POST request?
Best,
On 07/07, AG wrote: > > -- > You received this message because you are subscribed to the Google Groups "Foreman users" group. > To unsubscribe from this group and stop receiving emails from it, send an email to foreman-users+unsubscribe@googlegroups.com. > To post to this group, send email to foreman-users@googlegroups.com. > Visit this group at http://groups.google.com/group/foreman-users. > For more options, visit https://groups.google.com/d/optout.–
Daniel Lobato Garcia
@eLobatoss
blog.daniellobato.me
daniellobato.me
Keybase: https://keybase.io/elobato
You must provide "boot": "true" otherwise we default to false. Reported
a bug:
http://projects.theforeman.org/issues/11099
Example JSON:
"host": {
"name": "hostapi1",
"build": "true",
"environment_id": "1",
"domain_id": "1",
"ip": "192.168.122.1",
"mac": "52:53:00:aa:bb:cc",
"ptable_id": "55",
"medium_id": "8",
"architecture_id": "1",
"operatingsystem_id": "1",
"root_pass": "changeme",
"location_id": "1",
"organization_id": "1"
-- Later, Lukas #lzap Zapletal> Is there some flag I'm missing that will indicate to immediately boot the
What kind of hypervisor is this one?
-- Later, Lukas #lzap Zapletal2015-07-07 10:57:17 [I] About to start post launch script on
2015-07-07 10:57:17 [I] Completed 200 OK in 970ms (Views: 832.3ms |
ActiveRecord: 77.8ms)
2015-07-07 10:57:18 [I] generating template to upload to
2015-07-07 10:57:18 [I] Starting SSH provisioning script
2015-07-07 11:03:18 [W] Failed to login via SSH to client07072015130432:
execution expired/opt/rh/ruby193/root/usr/share/gems/gems/net-ssh-2.6.7/lib/
net/ssh/transport/session.rb:67:i
n `initialize'
/opt/rh/ruby193/root/usr/share/gems/gems/net-ssh-2.6.7/lib/net/ssh/transport/session.rb:67:in
`open'
`block in initialize'
/opt/rh/ruby193/root/usr/share/ruby/timeout.rb:69:in `timeout'
/opt/rh/ruby193/root/usr/share/ruby/timeout.rb:100:in `timeout'
`initialize'
/opt/rh/ruby193/root/usr/share/gems/gems/net-ssh-2.6.7/lib/net/ssh.rb:192:in `new'
`start'
/opt/rh/ruby193/root/usr/share/gems/gems/fog-core-1.29.0/lib/fog/core/ssh.rb:63:in
`run'
/usr/share/foreman/app/services/foreman/provision/ssh.rb:83:in `block (2
levels) in initiate_connection!'
/usr/share/foreman/app/services/foreman/provision/ssh.rb:82:in `block in
/usr/share/foreman/app/services/foreman/provision/ssh.rb:80:in `initiate_connection!'
/usr/share/foreman/app/services/foreman/provision/ssh.rb:21:in `initialize'
/usr/share/foreman/app/models/concerns/orchestration/ssh_provision.rb:55:in
`new'
/usr/share/foreman/app/models/concerns/orchestration/ssh_provision.rb:55:in `setSSHWaitForResponse'
/usr/share/foreman/app/models/concerns/orchestration.rb:141:in `execute'
/usr/share/foreman/app/models/concerns/orchestration.rb:86:in `block in
process'
/usr/share/foreman/app/models/concerns/orchestration.rb:78:in `each'
/usr/share/foreman/app/models/concerns/orchestration.rb:78:in `process'
/usr/share/foreman/app/models/concerns/orchestration.rb:23:in `post_commit'
/opt/rh/ruby193/root/usr/share/gems/gems/activesupport-3.2.8/lib/
active_support/callbacks.rb:405:in `_run__3891664409900489917__commit__3907139994587051005__callbacks'
/opt/rh/ruby193/root/usr/share/gems/gems/activesupport-3.2.8/lib/active_support/callbacks.rb:405:in
`__run_callback'
/opt/rh/ruby193/root/usr/share/gems/gems/activesupport-3.2.8/lib/active_support/callbacks.rb:385:in
`_run_commit_callbacks'
active_support/callbacks.rb:81:in `run_callbacks'
/opt/rh/ruby193/root/usr/share/gems/gems/activerecord-3.2.8/lib/active_record/transactions.rb:263:in
`committed!'
/opt/rh/ruby193/root/usr/share/gems/gems/activerecord-3.2.8/lib/active_record/connection_adapters/abstract/database_statements.rb:372:in
`block in commit_transaction_records'
active_record/connection_adapters/abstract/database_statements.rb:370:in `each'
/opt/rh/ruby193/root/usr/share/gems/gems/activerecord-3.2.8/lib/active_record/connection_adapters/abstract/database_statements.rb:370:in
`commit_transaction_records'
/opt/rh/ruby193/root/usr/share/gems/gems/activerecord-3.2.8/lib/active_record/connection_adapters/abstract/database_statements.rb:218:in
`transaction'
active_record/transactions.rb:208:in `transaction'
/opt/rh/ruby193/root/usr/share/gems/gems/activerecord-3.2.8/lib/active_record/transactions.rb:293:in
`with_transaction_returning_status'
/opt/rh/ruby193/root/usr/share/gems/gems/activerecord-3.2.8/lib/active_record/transactions.rb:241:in
`block in save'
active_record/transactions.rb:252:in `rollback_active_record_state!'
/opt/rh/ruby193/root/usr/share/gems/gems/activerecord-3.2.8/lib/active_record/transactions.rb:240:in
`save'
/usr/share/foreman/app/models/concerns/foreman/sti.rb:29:in `save_with_type'
/usr/share/foreman/app/controllers/api/v2/hosts_controller.rb:87:in `create'
/opt/rh/ruby193/root/usr/share/gems/gems/actionpack-3.2.8/lib/action_controller/metal/implicit_render.rb:4:in
`send_action'
/opt/rh/ruby193/root/usr/share/gems/gems/actionpack-3.2.8/lib/abstract_controller/base.rb:167:in
`process_action'
action_controller/metal/rendering.rb:10:in `process_action'
/opt/rh/ruby193/root/usr/share/gems/gems/actionpack-3.2.8/lib/abstract_controller/callbacks.rb:18:in
`block in process_action'
/opt/rh/ruby193/root/usr/share/gems/gems/activesupport-3.2.8/lib/active_support/callbacks.rb:562:in
`block (5 levels) in
_run__1158342753634146888__process_action__3897775485187017792__callbacks'
active_support/callbacks.rb:215:in `block in
_conditional_callback_around_7499'
/usr/share/foreman/app/controllers/api/v2/base_controller.rb:151:in `
disable_json_root'
/opt/rh/ruby193/root/usr/share/gems/gems/activesupport-3.2.8/lib/active_support/callbacks.rb:214:in
`_conditional_callback_around_7499'
active_support/callbacks.rb:539:in `block (4 levels) in
/opt/rh/ruby193/root/usr/share/gems/gems/activesupport-3.2.8/lib/active_support/callbacks.rb:215:in
`block in _conditional_callback_around_7498'
/opt/rh/ruby193/root/usr/share/gems/gems/activesupport-3.2.8/lib/active_support/callbacks.rb:326:in
`around'
active_support/callbacks.rb:310:in `_callback_around_2287'
`_conditional_callback_around_7498'
/opt/rh/ruby193/root/usr/share/gems/gems/activesupport-3.2.8/lib/active_support/callbacks.rb:516:in
`block (3 levels) in
2015-07-07 11:03:18 [W] Rolling back due to a problem: [Wait for
client07072015130432 to come online 2001 failed
I have added part of the exception stack trace, please let me know if you
need more info
Thanks
On Tuesday, July 7, 2015 at 3:46:08 PM UTC+3, Daniel Lobato wrote: > > On 07/07, AG wrote: > > I am having some issues provisioning hosts through foreman REST API > (more > > exactly using foreman-python). Once the host is created it does not boot > > automatically, I need to send the start command. This workaround works > with > > provision_method=build, but with provision_method=image it doesn't > because > > the POST host doesn't return after the host is created, instead the > > following error is received: > > Failed to login via SSH to client07072015130432.lab.primarydata.com: > > execution expired > > Is there some flag I'm missing that will indicate to immediately boot > the > > host after creation? > I don't think there's any flag, the host should boot automatically. > > Could you give us some logs (/var/log/foreman/production.log) to see > what happens when you send this POST request? > > Best, > > > > -- > > You received this message because you are subscribed to the Google > Groups "Foreman users" group. > > To unsubscribe from this group and stop receiving emails from it, send > an email to foreman-user...@googlegroups.com . > > To post to this group, send email to forema...@googlegroups.com > . > > Visit this group at http://groups.google.com/group/foreman-users. > > For more options, visit https://groups.google.com/d/optout. > > > -- > Daniel Lobato Garcia > > @eLobatoss > blog.daniellobato.me > daniellobato.me > > GPG: http://keys.gnupg.net/pks/lookup?op=get&search=0x7A92D6DD38D6DE30 > Keybase: https://keybase.io/elobato >Do you mean hosts/power? If not, there is not boot attribute, getting this
error if I add boot to the input json:
"error": {"message":"unknown attribute: boot"}
On Mon, Jul 13, 2015 at 1:30 PM, Lukas Zapletal wrote:Is there some flag I’m missing that will indicate to immediately boot the
host after creation?You must provide “boot”: “true” otherwise we default to false. Reported
a bug:Bug #11099: Build mode not set by default for new hosts via API - Foreman
Example JSON:
“host”: {
“name”: “hostapi1”,
“build”: “true”,
“environment_id”: “1”,
“domain_id”: “1”,
“ip”: “192.168.122.1”,
“mac”: “52:53:00:aa:bb:cc”,
“ptable_id”: “55”,
“medium_id”: “8”,
“architecture_id”: “1”,
“operatingsystem_id”: “1”,
“root_pass”: “changeme”,
“location_id”: “1”,
“organization_id”: “1”
Later,
Lukas #lzap Zapletal–
https://groups.google.com/d/topic/foreman-users/YO6obzkdmVk/unsubscribe.
Best Regards
Adrian Ghidalovici
Automation and Infrastructure Engineer
We are working with vmware vsphere
On Mon, Jul 13, 2015 at 4:33 PM, Lukas Zapletal wrote:Is there some flag I’m missing that will indicate to immediately boot the
host after creation?What kind of hypervisor is this one?
Later,
Best Regards
Adrian Ghidalovici
Sorry I mean "build", that was a typo:
> > "build": "true",–
Later,
Thanks Lukas, build was always set, but it doesn't influence booting
behaviour.
On Mon, Jul 13, 2015 at 4:16 PM, Lukas Zapletal wrote:Sorry I mean “build”, that was a typo:
"build": "true",–
Later,
Best Regards
Adrian Ghidalovici
