"provisioning" IP for Puppet
Has anyone happened to already have written some code to get the "provisioning" IP (provision: true in the foreman_interfaces array) for a host for use in a Puppet ERB template?
j
I'm not aware of any puppet module for working with foreman_interfaces,
although that would be cool :slight_smile:
You could use something more generic (like https://github.com/voxpupuli/
puppet-network) and pass in data via the smart parameters - then you'd put
something like <%= @host.provision_interface.ip %> in your matcher
HTH
Greg
··· On Tuesday, 28 March 2017 23:04:09 BST 'Jason B. Nance' via Foreman users wrote: > Hello, > > Has anyone happened to already have written some code to get the > "provisioning" IP (provision: true in the foreman_interfaces array) for a > host for use in a Puppet ERB template?
The data needed for this is already in the YAML generated by Foreman (and hence, the host facts). I was just hoping that someone else had already gone through the work of parsing it as it is buried in hashes so you have to loop and test to pull it out. :smiley:
It turns out that Puppet (4, at least) does a good enough job at figuring out what the "primary" IP of a host is for my needs. So I can just use ::ipaddress.
Thanks for link to Vox, though. I'll see if there are any other goodies in there I could make use of.
j
··· ----- Original Message ----- From: "Greg Sutcliffe" To: "Foreman Users" Sent: Monday, April 3, 2017 6:49:39 AM Subject: Re: [foreman-users] "provisioning" IP for Puppet
On Tuesday, 28 March 2017 23:04:09 BST ‘Jason B. Nance’ via Foreman users wrote:
“provisioning” IP (provision: true in the foreman_interfaces array) for a
I’m not aware of any puppet module for working with foreman_interfaces,
You could use something more generic (like Vox Pupuli · GitHub
puppet-network) and pass in data via the smart parameters - then you’d put
HTH
Greg
