Provisioning Ubuntu 22.04 with multiple network interfaces - problem with deprecated gateway4 netplan property
When provisioning an Ubuntu 22.04 Host with multiple network interfaces, only the primary network interface is functional.
Additional specified network interfaces are present and functional after deployment.
  • foreman-tasks: 9.0.1
  • foreman_ansible: 13.0.2
  • foreman_bootdisk: 21.2.1
  • foreman_remote_execution: 12.0.2
  • katello: 4.11.0
AlmaLinux 8.9
After provisioning, the additional network interface is present, but not working. I was able to get it working manually by fiddling with /etc/netplan/00-installer-config.yaml
The issue seems to be with the deprecated gateway4: property. Instead, the system wants a routes: property configured for each network interface.
I am not confident in my ability to modify the preseed_netplan_generic_interface provisioning template, to replace gateway4: with a properly configured routes:. Hopefully somebody else is already working on this, or can provide some advice/guidance?
Forgot to mention, there’s also an issue with the MAC address. It seems to take the MAC address of the first Network Interface, and put it into the match: property of the bottom interface. I think this is something else that needs to be fixed in preseed_netplan_generic_interface.
Do you know the required changes to the generated file?
If yes, you can probably reverse-engineer what needs to be changed and can do a PR on https://github.com/theforeman/foreman/blob/develop/app/views/unattended/provisioning_templates/snippet/preseed_netplan_generic_interface.erb
If I understand correctly, the current state is:
<%-   if static_v4 && @subnet.gateway.present? -%>
        gateway4: <%= @subnet.gateway %>
<%-   end -%>
<%-   if static_v6 && @subnet6.gateway.present? -%>
        gateway6: "<%= @subnet6.gateway %>"
<%-   end -%>
And it has to be changed to something like this:
<%- if @interface.ip == @host.primary_interface.ip -%>
<%-   if (static_v4 && @subnet.gateway.present?) || (static_v6 && @subnet6.gateway.present?) -%>
       routes:
        - to: 0.0.0.0/0
          via: <%= @subnet.gateway %>
<%-     end -%>
        - to: ::/0
          via: "<%= @subnet6.gateway %>"
<%-     end -%>
<%-   end -%>
<%- end -%>
At least this is my understanding that the routes need only be set to the default routes for the primary interface.
