"Proxy task gone missing from the smart proxy" if job takes more than 10m to finish
Running a standard job of type script just executing the sleep command. After 10m the job fails with message “Actions::ProxyAction::ProxyActionMissing: Proxy task gone missing from the smart proxy”. Although foreman marks the job has failed the script continues to run and I’m able to follow the execution in /var/tmp/foreman-ssh-cmd-<id>/output file.
The 10m (600 secs) come from the “POLL_INTERVAL = 600” constant in watch_delegated_proxy_sub_tasks.rb. I tried to do some debugging and discovered that the condition is triggered in the function process_task_results because the state of the parent job is returning as stopped (“state”=>“stopped”, “result”=>“success”), hence the job is considered missing. I don’t find the corresponding parent_task_id in the foreman_tasks_tasks table.
I’m trying to follow the code but I’m hoping someone here that is more knowledgeable about both ruby and the foreman code might help get to a conclusion a lot quicker.
Job to finish.
foreman-proxy-3.9.1-1.el8
rubygem-foreman-tasks-9.0.1-1.fm3_9.el8
RHEL 8.9
Thanks!
you’re not the first to run into this, see Failed tasks to update packages - proxy task gone missing - #20 by m-bucher for more details.
Well done on the analysis, you got pretty far in there
Thanks, that fix works for me as well!
@aruzicka - Just wanted to let you know that I am also hitting this issue, even with your fix in place. It seems to occur when using Concurrency level limited - so maybe something to do with it waiting, Im not sure. Im not really seeing anything in the logs at all that would provide any additional information.
Possibly related:
Is that specific to salt or are you getting this no matter if you use salt/ansible/script?
That thread is three years old. I’d be surprised if it was the same thing.
lol, ya me too.
We are only running salt commands, but I cant envision that the underlying command itself would be the issue? But Im no expert. We dont use ansible or ssh/scripts. And I think all the salt stuff just piggy backs off dynflow/remex/foreman-proxy?
Whats so curious to me is it just randomly happens, yet if I query dynflow the task is certainly there.
I could potentially setup some hosts with ssh and try to throw scripts through it.
production.log (server 2, this is a load balanced environment):
[root@10-222-206-158 jsparrow]# grep b1b11dff /var/log/foreman/production.log
2025-01-24T14:03:12 [I|app|b1b11dff] Started POST "/api/job_invocations" for 10.222.218.3 at 2025-01-24 14:03:12 +0000
2025-01-24T14:03:12 [I|app|b1b11dff] Processing by Api::V2::JobInvocationsController#create as JSON
2025-01-24T14:03:12 [I|app|b1b11dff]   Parameters: {"job_invocation"=>{"job_template_id"=>172, "targeting_type"=>"static_query", "randomized_ordering"=>nil, "inputs"=>{"state"=>"ssnc-foreman-saltcontrol"}, "ssh_user"=>nil, "ssh"=>{"effective_user"=>"root"}, "recurrence"=>nil, "scheduling"=>nil, "concurrency_control"=>{"concurrency_level"=>"4"}, "bookmark_id"=>nil, "search_query"=>"name ^ (10-213-48-11.ssnc-corp.cloud, 10-222-203-207.ssnc-corp.cloud, 10-222-45-187.ssnc-corp.cloud, 10-234-32-23.ssnc-corp.cloud, 10-234-61-47.ssnc-corp.cloud)", "description_format"=>"Salt: state.apply", "execution_timeout_interval"=>500, "time_to_pickup"=>""}, "apiv"=>"v2"}
2025-01-24T14:03:12 [I|aud|b1b11dff] JobInvocation (515) create event on job_category Salt
2025-01-24T14:03:12 [I|aud|b1b11dff] JobInvocation (515) create event on description Salt: state.apply
2025-01-24T14:03:12 [I|aud|b1b11dff] JobInvocation (515) create event on concurrency_level 4
2025-01-24T14:03:12 [I|aud|b1b11dff] JobInvocation (515) create event on execution_timeout_interval 500
2025-01-24T14:03:12 [I|aud|b1b11dff] JobInvocation (515) create event on password [redacted]
2025-01-24T14:03:12 [I|aud|b1b11dff] JobInvocation (515) create event on key_passphrase
2025-01-24T14:03:12 [I|aud|b1b11dff] JobInvocation (515) create event on remote_execution_feature_id
2025-01-24T14:03:12 [I|aud|b1b11dff] JobInvocation (515) create event on effective_user_password
2025-01-24T14:03:12 [I|aud|b1b11dff] JobInvocation (515) create event on ssh_user
2025-01-24T14:03:12 [I|aud|b1b11dff] JobInvocation (515) create event on time_to_pickup
2025-01-24T14:03:12 [I|bac|b1b11dff] Task {label: , execution_plan_id: a8122b1d-8609-434f-865a-61e3437ea9d4} state changed: pending
2025-01-24T14:03:12 [I|bac|b1b11dff] Task {label: Actions::RemoteExecution::RunHostsJob, id: 4743b44c-b39c-4a14-8695-c18f3283a17c, execution_plan_id: a8122b1d-8609-434f-865a-61e3437ea9d4} state changed: planning
2025-01-24T14:03:12 [I|bac|b1b11dff] Task {label: Actions::RemoteExecution::RunHostsJob, id: 4743b44c-b39c-4a14-8695-c18f3283a17c, execution_plan_id: a8122b1d-8609-434f-865a-61e3437ea9d4} state changed: planned
2025-01-24T14:03:12 [I|bac|b1b11dff] Task {label: Actions::RemoteExecution::RunHostsJob, id: 4743b44c-b39c-4a14-8695-c18f3283a17c, execution_plan_id: a8122b1d-8609-434f-865a-61e3437ea9d4} state changed: running
2025-01-24T14:03:12 [I|app|b1b11dff]   Rendered /usr/share/gems/gems/foreman_remote_execution-14.0.2/app/views/api/v2/job_invocations/create.json.rabl (Duration: 25.7ms | Allocations: 12859)
2025-01-24T14:03:12 [I|app|b1b11dff] Completed 201 Created in 266ms (Views: 27.6ms | ActiveRecord: 61.9ms | Allocations: 81674)
2025-01-24T14:03:12 [I|bac|b1b11dff] Task {label: , execution_plan_id: 1b2166d4-ea1c-4481-a77a-b62f8ad6e217} state changed: pending
2025-01-24T14:03:12 [I|bac|b1b11dff] Task {label: Actions::RemoteExecution::RunHostJob, id: 93ea47de-d47c-4ee8-8d55-c508156214a0, execution_plan_id: 1b2166d4-ea1c-4481-a77a-b62f8ad6e217} state changed: planning
2025-01-24T14:03:12 [I|bac|b1b11dff] Task {label: Actions::RemoteExecution::RunHostJob, id: 93ea47de-d47c-4ee8-8d55-c508156214a0, execution_plan_id: 1b2166d4-ea1c-4481-a77a-b62f8ad6e217} state changed: planned
2025-01-24T14:03:12 [I|bac|b1b11dff] Task {label: , execution_plan_id: d4e4d679-29e6-445c-b115-cd077f624b79} state changed: pending
2025-01-24T14:03:12 [I|bac|b1b11dff] Task {label: Actions::RemoteExecution::RunHostJob, id: 3a57096c-7f6a-492f-ad2d-9e1204c759de, execution_plan_id: d4e4d679-29e6-445c-b115-cd077f624b79} state changed: planning
2025-01-24T14:03:12 [I|bac|b1b11dff] Task {label: Actions::RemoteExecution::RunHostJob, id: 93ea47de-d47c-4ee8-8d55-c508156214a0, execution_plan_id: 1b2166d4-ea1c-4481-a77a-b62f8ad6e217} state changed: running
2025-01-24T14:03:13 [I|bac|b1b11dff] Task {label: Actions::RemoteExecution::RunHostJob, id: 3a57096c-7f6a-492f-ad2d-9e1204c759de, execution_plan_id: d4e4d679-29e6-445c-b115-cd077f624b79} state changed: planned
2025-01-24T14:03:13 [I|bac|b1b11dff] Task {label: , execution_plan_id: 1ba6a87a-872a-4f0d-b2a8-808a4e429e3a} state changed: pending
2025-01-24T14:03:13 [I|bac|b1b11dff] Task {label: Actions::RemoteExecution::RunHostJob, id: 3a57096c-7f6a-492f-ad2d-9e1204c759de, execution_plan_id: d4e4d679-29e6-445c-b115-cd077f624b79} state changed: running
2025-01-24T14:03:13 [I|bac|b1b11dff] Task {label: Actions::RemoteExecution::RunHostJob, id: 41523cc0-3a00-495f-bcb7-94a8c28d5dfa, execution_plan_id: 1ba6a87a-872a-4f0d-b2a8-808a4e429e3a} state changed: planning
2025-01-24T14:03:13 [I|bac|b1b11dff] Task {label: Actions::RemoteExecution::RunHostJob, id: 41523cc0-3a00-495f-bcb7-94a8c28d5dfa, execution_plan_id: 1ba6a87a-872a-4f0d-b2a8-808a4e429e3a} state changed: planned
2025-01-24T14:03:13 [I|bac|b1b11dff] Task {label: , execution_plan_id: ac996ea6-3236-4790-9d4a-8ca3f4ef9d01} state changed: pending
2025-01-24T14:03:13 [I|bac|b1b11dff] Task {label: Actions::RemoteExecution::RunHostJob, id: 41523cc0-3a00-495f-bcb7-94a8c28d5dfa, execution_plan_id: 1ba6a87a-872a-4f0d-b2a8-808a4e429e3a} state changed: running
2025-01-24T14:03:13 [I|bac|b1b11dff] Task {label: Actions::RemoteExecution::RunHostJob, id: fe025b84-a951-4f90-beef-97c4e9fec79b, execution_plan_id: ac996ea6-3236-4790-9d4a-8ca3f4ef9d01} state changed: planning
2025-01-24T14:03:13 [I|bac|b1b11dff] Task {label: Actions::RemoteExecution::RunHostJob, id: fe025b84-a951-4f90-beef-97c4e9fec79b, execution_plan_id: ac996ea6-3236-4790-9d4a-8ca3f4ef9d01} state changed: planned
2025-01-24T14:03:13 [I|bac|b1b11dff] Task {label: Actions::RemoteExecution::RunHostJob, id: fe025b84-a951-4f90-beef-97c4e9fec79b, execution_plan_id: ac996ea6-3236-4790-9d4a-8ca3f4ef9d01} state changed: running
2025-01-24T14:03:16 [I|bac|b1b11dff] Event delivered by request 5d607c96-0f2f-471d-bf09-da8b2887b0c9
2025-01-24T14:03:16 [I|bac|b1b11dff] Task {label: Actions::RemoteExecution::RunHostJob, id: fe025b84-a951-4f90-beef-97c4e9fec79b, execution_plan_id: ac996ea6-3236-4790-9d4a-8ca3f4ef9d01} state changed: stopped  result: error
2025-01-24T14:03:28 [I|bac|b1b11dff] Task {label: , execution_plan_id: 6268c0e3-d477-45be-a2c8-e9e7b0f11dd1} state changed: pending
2025-01-24T14:03:28 [I|bac|b1b11dff] Task {label: Actions::RemoteExecution::RunHostJob, id: 8b05b98a-f672-4581-8711-12b045790498, execution_plan_id: 6268c0e3-d477-45be-a2c8-e9e7b0f11dd1} state changed: planning
2025-01-24T14:03:28 [I|bac|b1b11dff] Task {label: Actions::RemoteExecution::RunHostJob, id: 8b05b98a-f672-4581-8711-12b045790498, execution_plan_id: 6268c0e3-d477-45be-a2c8-e9e7b0f11dd1} state changed: planned
2025-01-24T14:03:28 [I|bac|b1b11dff] Task {label: Actions::RemoteExecution::RunHostJob, id: 8b05b98a-f672-4581-8711-12b045790498, execution_plan_id: 6268c0e3-d477-45be-a2c8-e9e7b0f11dd1} state changed: running
2025-01-24T14:03:30 [E|bac|b1b11dff] Job execution failed
2025-01-24T14:03:31 [I|bac|b1b11dff] Task {label: Actions::RemoteExecution::RunHostJob, id: 8b05b98a-f672-4581-8711-12b045790498, execution_plan_id: 6268c0e3-d477-45be-a2c8-e9e7b0f11dd1} state changed: stopped  result: error
2025-01-24T14:03:40 [I|bac|b1b11dff] Event delivered by request dc0cf7db-77c5-4f27-b30f-bc1640579a2c
2025-01-24T14:03:40 [E|bac|b1b11dff] Job execution failed
2025-01-24T14:03:40 [I|bac|b1b11dff] Task {label: Actions::RemoteExecution::RunHostJob, id: 93ea47de-d47c-4ee8-8d55-c508156214a0, execution_plan_id: 1b2166d4-ea1c-4481-a77a-b62f8ad6e217} state changed: stopped  result: error
2025-01-24T14:13:12 [E|bac|b1b11dff] Proxy task gone missing from the smart proxy (Actions::ProxyAction::ProxyActionMissing)
 b1b11dff |
2025-01-24T14:13:12 [I|bac|b1b11dff] Task {label: Actions::RemoteExecution::RunHostJob, id: 3a57096c-7f6a-492f-ad2d-9e1204c759de, execution_plan_id: d4e4d679-29e6-445c-b115-cd077f624b79} state changed: stopped  result: error
2025-01-24T14:13:12 [I|bac|b1b11dff] Task {label: Actions::RemoteExecution::RunHostJob, id: 41523cc0-3a00-495f-bcb7-94a8c28d5dfa, execution_plan_id: 1ba6a87a-872a-4f0d-b2a8-808a4e429e3a} state changed: stopped  result: error
2025-01-24T14:13:14 [E|bac|b1b11dff] A sub task failed (Dynflow::Action::V2::WithSubPlans::SubtaskFailedException)
 b1b11dff |
2025-01-24T14:13:14 [I|bac|b1b11dff] Task {label: Actions::RemoteExecution::RunHostsJob, id: 4743b44c-b39c-4a14-8695-c18f3283a17c, execution_plan_id: a8122b1d-8609-434f-865a-61e3437ea9d4} state changed: stopped  result: warning
foreman-proxy for this job:
root@10-222-45-187:kc-saltmom-01:[/etc/foreman-proxy/settings.d]:
$ grep d4e4d679-29e6-445c-b115-cd077f624b79 /var/log/foreman-proxy/proxy.log
2025-01-24T14:11:11 1ba135ab [I] Started GET /dynflow/tasks/d4e4d679-29e6-445c-b115-cd077f624b79/status
2025-01-24T14:11:11 1ba135ab [I] Finished GET /dynflow/tasks/d4e4d679-29e6-445c-b115-cd077f624b79/status with 404 (2.47 ms)
2025-01-24T14:11:13 cc59fd2a [I] Started GET /dynflow/tasks/d4e4d679-29e6-445c-b115-cd077f624b79/status
2025-01-24T14:11:13 cc59fd2a [I] Finished GET /dynflow/tasks/d4e4d679-29e6-445c-b115-cd077f624b79/status with 404 (1.17 ms)
2025-01-24T14:11:14 8189b618 [I] Started GET /dynflow/tasks/d4e4d679-29e6-445c-b115-cd077f624b79/status
2025-01-24T14:11:14 8189b618 [I] Finished GET /dynflow/tasks/d4e4d679-29e6-445c-b115-cd077f624b79/status with 404 (1.34 ms)
2025-01-24T14:11:16 41cfd991 [I] Started GET /dynflow/tasks/d4e4d679-29e6-445c-b115-cd077f624b79/status
2025-01-24T14:11:16 41cfd991 [I] Finished GET /dynflow/tasks/d4e4d679-29e6-445c-b115-cd077f624b79/status with 404 (1.09 ms)
2025-01-24T14:11:18 bc8cc65a [I] Started GET /dynflow/tasks/d4e4d679-29e6-445c-b115-cd077f624b79/status
2025-01-24T14:11:18 bc8cc65a [I] Finished GET /dynflow/tasks/d4e4d679-29e6-445c-b115-cd077f624b79/status with 404 (1.17 ms)
repeated....
Do you want me to start a new thread for this?
It does, but there’s way too many subtle differences that can add up in the end.
Please do
Continued here - GET /dynflow/tasks/<taskid>/status with 404 & Proxy task gone missing from the smart proxy
