[root@katello ~]# journalctl -xe -u pulpcore-worker@2.service
Dec 20 07:13:30 katello pulpcore-worker-2[651548]: return self.cursor.execute(sql, params)
Dec 20 07:13:30 katello pulpcore-worker-2[651548]: File "/usr/local/lib/python3.9/site-packages/psycopg/cursor.py", line 97, in execute
Dec 20 07:13:30 katello pulpcore-worker-2[651548]: raise ex.with_traceback(None)
Dec 20 07:13:30 katello pulpcore-worker-2[651548]: psycopg.errors.UndefinedColumn: column core_task.immediate does not exist
Dec 20 07:13:30 katello pulpcore-worker-2[651548]: LINE 1: ...e_task"."pulp_domain_id", "core_task"."versions", "core_task...
Dec 20 07:13:30 katello pulpcore-worker-2[651548]: ^
Dec 20 07:13:30 katello pulpcore-worker-2[651548]: The above exception was the direct cause of the following exception:
Dec 20 07:13:30 katello pulpcore-worker-2[651548]: Traceback (most recent call last):
Dec 20 07:13:30 katello pulpcore-worker-2[651548]: File "/usr/local/bin/pulpcore-worker", line 8, in <module>
Dec 20 07:13:30 katello pulpcore-worker-2[651548]: sys.exit(worker())
Dec 20 07:13:30 katello pulpcore-worker-2[651548]: File "/usr/local/lib/python3.9/site-packages/click/core.py", line 1157, in __call__
Dec 20 07:13:30 katello pulpcore-worker-2[651548]: return self.main(*args, **kwargs)
Dec 20 07:13:30 katello pulpcore-worker-2[651548]: File "/usr/local/lib/python3.9/site-packages/click/core.py", line 1078, in main
Dec 20 07:13:30 katello pulpcore-worker-2[651548]: rv = self.invoke(ctx)
Dec 20 07:13:30 katello pulpcore-worker-2[651548]: File "/usr/local/lib/python3.9/site-packages/click/core.py", line 1434, in invoke
Dec 20 07:13:30 katello pulpcore-worker-2[651548]: return ctx.invoke(self.callback, **ctx.params)
Dec 20 07:13:30 katello pulpcore-worker-2[651548]: File "/usr/local/lib/python3.9/site-packages/click/core.py", line 783, in invoke
Dec 20 07:13:30 katello pulpcore-worker-2[651548]: return __callback(*args, **kwargs)
Dec 20 07:13:30 katello pulpcore-worker-2[651548]: File "/usr/local/lib/python3.9/site-packages/pulpcore/tasking/entrypoint.py", line 43, in worker
Dec 20 07:13:30 katello pulpcore-worker-2[651548]: PulpcoreWorker().run(burst=burst)
Dec 20 07:13:30 katello pulpcore-worker-2[651548]: File "/usr/local/lib/python3.9/site-packages/pulpcore/tasking/worker.py", line 531, in run
Dec 20 07:13:30 katello pulpcore-worker-2[651548]: self.handle_available_tasks()
Dec 20 07:13:30 katello pulpcore-worker-2[651548]: File "/usr/local/lib/python3.9/site-packages/pulpcore/tasking/worker.py", line 471, in handle_available_tasks
Dec 20 07:13:30 katello pulpcore-worker-2[651548]: keep_looping = self.unblock_tasks()
Dec 20 07:13:30 katello pulpcore-worker-2[651548]: File "/usr/local/lib/python3.9/site-packages/pulpcore/tasking/worker.py", line 255, in unblock_tasks
Dec 20 07:13:30 katello pulpcore-worker-2[651548]: for task in (
Dec 20 07:13:30 katello pulpcore-worker-2[651548]: File "/usr/local/lib/python3.9/site-packages/django/db/models/query.py", line 398, in __iter__
Dec 20 07:13:30 katello pulpcore-worker-2[651548]: self._fetch_all()
Dec 20 07:13:30 katello pulpcore-worker-2[651548]: File "/usr/local/lib/python3.9/site-packages/django/db/models/query.py", line 1881, in _fetch_all
Dec 20 07:13:30 katello pulpcore-worker-2[651548]: self._result_cache = list(self._iterable_class(self))
Dec 20 07:13:30 katello pulpcore-worker-2[651548]: File "/usr/local/lib/python3.9/site-packages/django/db/models/query.py", line 91, in __iter__
Dec 20 07:13:30 katello pulpcore-worker-2[651548]: results = compiler.execute_sql(
Dec 20 07:13:30 katello pulpcore-worker-2[651548]: File "/usr/local/lib/python3.9/site-packages/django/db/models/sql/compiler.py", line 1562, in execute_sql
Dec 20 07:13:30 katello pulpcore-worker-2[651548]: cursor.execute(sql, params)
Dec 20 07:13:30 katello pulpcore-worker-2[651548]: File "/usr/local/lib/python3.9/site-packages/django/db/backends/utils.py", line 67, in execute
Dec 20 07:13:30 katello pulpcore-worker-2[651548]: return self._execute_with_wrappers(
Dec 20 07:13:30 katello pulpcore-worker-2[651548]: File "/usr/local/lib/python3.9/site-packages/django/db/backends/utils.py", line 80, in _execute_with_wrappers
Dec 20 07:13:30 katello pulpcore-worker-2[651548]: return executor(sql, params, many, context)
Dec 20 07:13:30 katello pulpcore-worker-2[651548]: File "/usr/local/lib/python3.9/site-packages/django/db/backends/utils.py", line 89, in _execute
Dec 20 07:13:30 katello pulpcore-worker-2[651548]: File "/usr/local/lib/python3.9/site-packages/django/db/utils.py", line 91, in __exit__
Dec 20 07:13:30 katello pulpcore-worker-2[651548]: raise dj_exc_value.with_traceback(traceback) from exc_value
Dec 20 07:13:30 katello pulpcore-worker-2[651548]: django.db.utils.ProgrammingError: column core_task.immediate does not exist
Dec 20 07:13:30 katello systemd[1]: pulpcore-worker@2.service: Main process exited, code=exited, status=1/FAILURE
Dec 20 07:13:30 katello systemd[1]: pulpcore-worker@2.service: Failed with result 'exit-code'.
foreman doesnât install anything into /usr/local/
Someone must have installed and outdated version of pulpcore using python3.9 into /usr/local/ and that is pulled before the version from the official packages.
You have to remove that local installation. I guess someone used pip and installed pulpcore. It doesnât work. It will only break the system. Everything for foreman/katello comes out of the rpms.
On my foreman server all sub-directories in /usr/local/ are basically empty.
Uninstall any pip package you have installed into /usr/local/
Then run foreman-installer again.
You are Right!!! There was something weird true it was showing it is shwing python 3.9 used but it is python 3.11 i have it . Also i was having the error for /usr/lib packages and fixed it
# pip3 list --format=columns | awk '{print $1}' | while read package; do
pip3 show "$package" | grep -q '/usr/local/' && echo "$package";
done
no such option: ----------------------------------------
ERROR: Pipe to stdout was broken
Exception ignored in: <_io.TextIOWrapper name='<stdout>' mode='w' encoding='utf-8'>
BrokenPipeError: [Errno 32] Broken pipe
cffi
pip
pycparser
pyOpenSSL
Then i uninstalled it but now after that when i ran the foreman-installer i had another error
2024-12-20 08:16:58 [ERROR ] [configure] 'pulpcore-manager migrate --noinput' returned 1 instead of one of [0]
2024-12-20 08:16:58 [ERROR ] [configure] /Stage[main]/Pulpcore::Database/Pulpcore::Admin[migrate --noinput]/Exec[pulpcore-manager migrate --noinput]/returns: change from 'notrun' to ['0'] failed: 'pulpcore-manager migrate --noinput' returned 1 instead of one of [0]
2024-12-20 08:16:59 [NOTICE] [configure] 1750 configuration steps out of 1795 steps complete.
2024-12-20 08:17:03 [NOTICE] [configure] System configuration has finished.
Error 1: Puppet Exec resource 'pulpcore-manager migrate --noinput' failed. Logs:
Adding autorequire relationship with File[/var/lib/pulp]
Adding autorequire relationship with User[pulp]
Starting to evaluate the resource (1640 of 1795)
Evaluated in 0.40 seconds
Exec[pulpcore-manager migrate --noinput](provider=posix)
Executing 'pulpcore-manager migrate --noinput'
File "/usr/bin/pulpcore-manager", line 33, in <module>
sys.exit(load_entry_point('pulpcore==3.49.22', 'console_scripts', 'pulpcore-manager')())
File "/usr/lib/python3.11/site-packages/pulpcore/app/manage.py", line 11, in manage
execute_from_command_line(sys.argv)
File "/usr/lib/python3.11/site-packages/django/core/management/__init__.py", line 442, in execute_from_command_line
utility.execute()
File "/usr/lib/python3.11/site-packages/django/core/management/__init__.py", line 382, in execute
settings.INSTALLED_APPS
File "/usr/lib/python3.11/site-packages/django/conf/__init__.py", line 102, in __getattr__
self._setup(name)
File "/usr/lib/python3.11/site-packages/django/conf/__init__.py", line 89, in _setup
self._wrapped = Settings(settings_module)
File "/usr/lib/python3.11/site-packages/django/conf/__init__.py", line 217, in __init__
mod = importlib.import_module(self.SETTINGS_MODULE)
File "/usr/lib64/python3.11/importlib/__init__.py", line 126, in import_module
return _bootstrap._gcd_import(name[level:], package, level)
File "<frozen importlib._bootstrap>", line 1204, in _gcd_import
File "<frozen importlib._bootstrap>", line 1176, in _find_and_load
File "<frozen importlib._bootstrap>", line 1147, in _find_and_load_unlocked
File "<frozen importlib._bootstrap>", line 690, in _load_unlocked
File "<frozen importlib._bootstrap_external>", line 940, in exec_module
File "<frozen importlib._bootstrap>", line 241, in _call_with_frames_removed
File "/usr/lib/python3.11/site-packages/pulpcore/app/settings.py", line 17, in <module>
from pkg_resources import iter_entry_points
File "/usr/lib/python3.11/site-packages/pkg_resources/__init__.py", line 3259, in <module>
@_call_aside
File "/usr/lib/python3.11/site-packages/pkg_resources/__init__.py", line 3234, in _call_aside
f(*args, **kwargs)
File "/usr/lib/python3.11/site-packages/pkg_resources/__init__.py", line 3272, in _initialize_master_working_set
working_set = WorkingSet._build_master()
File "/usr/lib/python3.11/site-packages/pkg_resources/__init__.py", line 581, in _build_master
ws.require(__requires__)
File "/usr/lib/python3.11/site-packages/pkg_resources/__init__.py", line 909, in require
needed = self.resolve(parse_requirements(requirements))
File "/usr/lib/python3.11/site-packages/pkg_resources/__init__.py", line 795, in resolve
raise DistributionNotFound(req, requirers)
pkg_resources.DistributionNotFound: The 'PyOpenSSL<25.0' distribution was not found and is required by pulpcore
1 error was detected during installation.
fixed it by
pip3 install 'PyOpenSSL<25.0'
[root@katello ~]# systemctl show pulpcore-worker@2.service | grep EnvironmentFile
EnvironmentFiles=/etc/default/pulp-workers (ignore_errors=yes)
EnvironmentFiles=/etc/default/pulp-workers-2 (ignore_errors=yes)
[root@katello ~]# head -n 1 /usr/local/bin/pulpcore-worker
#!/bin/python3.9
[root@katello ~]# ps aux | grep pulpcore-worker
pulp 676723 159 0.4 247540 106236 ? Rs 08:34 0:01 /bin/python3.9 /usr/local/bin/pulpcore-worker
root 676728 0.0 0.0 12216 1176 pts/0 S+ 08:34 0:00 grep --color=auto pulpcore-worker
[root@katello ~]# sed -i '1s|#!/bin/python3.9|#!/usr/bin/python3.11|' /usr/local/bin/pulpcore-worker
#!/bin/python3.11
[root@katello ~]# systemctl restart pulpcore-worker@2.service
[root@katello ~]# journalctl -u pulpcore-worker@2.service -f
Dec 20 08:35:24 katello systemd[1]: Started Pulp Worker.
Dec 20 08:35:26 katello pulpcore-worker-2[676834]: pulp [None]: pulpcore.tasking.entrypoint:INFO: Starting distributed type worker
Dec 20 08:35:26 katello pulpcore-worker-2[676834]: pulp [None]: pulpcore.tasking.worker:INFO: New worker '676834@katello.zxx.rocks' discovered
Dec 20 08:41:56 katello pulpcore-worker-2[676834]: pulp [None]: pulpcore.tasking.worker:INFO: Clean missing content worker 196256@katello.
Dec 20 08:41:56 katello pulpcore-worker-2[676834]: pulp [None]: pulpcore.tasking.worker:INFO: Clean missing content worker 7189@katello.
Dec 20 08:41:56 katello pulpcore-worker-2[676834]: pulp [None]: pulpcore.tasking.worker:INFO: Clean missing content worker 686192@katello.
Dec 20 08:41:56 katello pulpcore-worker-2[676834]: pulp [None]: pulpcore.tasking.worker:INFO: Clean missing content worker 511511@katello.
Dec 20 08:41:56 katello pulpcore-worker-2[676834]: pulp [None]: pulpcore.tasking.worker:INFO: Clean missing content worker 3523@katello.
Dec 20 08:41:56 katello pulpcore-worker-2[676834]: pulp [None]: pulpcore.tasking.worker:INFO: Clean missing content worker 511470@katello.
Dec 20 08:41:56 katello pulpcore-worker-2[676834]: pulp [None]: pulpcore.tasking.worker:INFO: Clean missing content worker 7146@katello.
Dec 20 08:41:56 katello pulpcore-worker-2[676834]: pulp [None]: pulpcore.tasking.worker:INFO: Clean missing content worker 511501@katello.
Dec 20 08:41:56 katello pulpcore-worker-2[676834]: pulp [None]: pulpcore.tasking.worker:INFO: Clean missing content worker 511495@katello.
Dec 20 08:41:56 katello pulpcore-worker-2[676834]: pulp [None]: pulpcore.tasking.worker:INFO: Clean missing content worker 1920@katello.
wohoo!!! Now everything is working with pulpcore i can see
now
https://katello.zzzz.rocks/foreman_tasks/dynflow/worlds/2fbda827-934b-4c79-81cd-ff5bbca7d9a4/check
invalidated the invalid ones and it is now resolved looks like .
No. Your system is still broken. You are still using /usr/local/bin/pulpcore-worker for instance. This wonât work. The next update will break again because your local pulpcore installation doesnât match the one which katello expects.
You really have to remove ALL pip packages you have locally installed, i.e. which installed into /usr/local/. As I wrote before: on a normal katello installation the sub-directories there are empty. If you have /usr/local/bin/pulpcore-worker you still have a local installation and your system is still broken. Maybe it works at the moment.
Same here:
you broke the system. The correct version will be installed by foreman rpm packages. The fact that a new version is there is already a sign that your system is broken. Downgrading doesnât help, because the next upgrade will break it again.
Whatever you have installed with pip breaks the system!
Please post
# pip3 list -v
Itâll show what you have installed and which paths. Anything in /usr/local will break your system. Maybe it works right now, but itâll soon stop working. And you definitively wonât be able to leapp upgrade that system to el9, in case you didnât plan a complete new installation for 3.13 on el9.
Again: absolutely wrong. You have to uninstall pulpcore with pip. It must remove the pulpcore-worker and other scripts in /usr/local/. Modifying the script in /usr/local/bin doesnât help. And it doesnât help running a python 3.9 script with 3.11 even if it works.
Currently, you just making it worse. You will never be able to upgrade this system to 3.13 and EL9 nor will it work reliably.
[root@katello bin]# pip3 list -v
Package Version Location Installer
aiodns 3.0.0 /usr/lib/python3.11/site-packages
aiofiles 22.1.0 /usr/lib/python3.11/site-packages
aiohttp 3.9.4 /usr/lib64/python3.11/site-packages
aiohttp-socks 0.7.1 /usr/lib/python3.11/site-packages
aiohttp-xmlrpc 1.5.0 /usr/lib/python3.11/site-packages
aioredis 2.0.1 /usr/lib/python3.11/site-packages
aiosignal 1.3.1 /usr/lib/python3.11/site-packages
asgiref 3.6.0 /usr/lib/python3.11/site-packages
async-timeout 4.0.2 /usr/lib/python3.11/site-packages
asyncio-throttle 1.0.2 /usr/lib/python3.11/site-packages
attrs 22.1.0 /usr/lib/python3.11/site-packages
backoff 2.2.1 /usr/lib/python3.11/site-packages
bandersnatch 6.1.0 /usr/lib/python3.11/site-packages
beautifulsoup4 4.11.2 /usr/lib/python3.11/site-packages
Brotli 1.0.9 /usr/lib64/python3.11/site-packages
certifi 2022.12.7 /usr/lib/python3.11/site-packages
cffi 1.17.1 /usr/lib/python3.11/site-packages pip
charset-normalizer 2.1.1 /usr/lib/python3.11/site-packages
click 8.1.3 /usr/lib/python3.11/site-packages
click-shell 2.1 /usr/lib/python3.11/site-packages
contextlib2 21.6.0 /usr/lib/python3.11/site-packages
createrepo-c 1.1.3 /usr/lib64/python3.11/site-packages
cryptography 42.0.8 /usr/lib64/python3.11/site-packages rpm
defusedxml 0.7.1 /usr/lib/python3.11/site-packages
Deprecated 1.2.13 /usr/lib/python3.11/site-packages
diff-match-patch 20200713 /usr/lib/python3.11/site-packages
Django 4.2.15 /usr/lib/python3.11/site-packages
django-filter 23.2 /usr/lib/python3.11/site-packages
django-guid 3.3.0 /usr/lib/python3.11/site-packages
django-import-export 3.1.0 /usr/lib/python3.11/site-packages
django-lifecycle 1.0.0 /usr/lib/python3.11/site-packages
django-readonly-field 1.1.2 /usr/lib/python3.11/site-packages
djangorestframework 3.14.0 /usr/lib/python3.11/site-packages
djangorestframework-queryfields 1.0.0 /usr/lib/python3.11/site-packages
drf-access-policy 1.3.0 /usr/lib/python3.11/site-packages
drf-nested-routers 0.93.4 /usr/lib/python3.11/site-packages
drf-spectacular 0.26.5 /usr/lib/python3.11/site-packages
dynaconf 3.1.12 /usr/lib/python3.11/site-packages
et-xmlfile 1.1.0 /usr/lib/python3.11/site-packages
filelock 3.8.0 /usr/lib/python3.11/site-packages
frozenlist 1.3.3 /usr/lib64/python3.11/site-packages
googleapis-common-protos 1.59.1 /usr/lib/python3.11/site-packages
grpcio 1.65.4 /usr/lib64/python3.11/site-packages
gunicorn 22.0.0 /usr/lib/python3.11/site-packages rpm
humanfriendly 10.0 /usr/lib/python3.11/site-packages
idna 3.4 /usr/lib/python3.11/site-packages
importlib-metadata 6.0.1 /usr/lib/python3.11/site-packages
inflection 0.5.1 /usr/lib/python3.11/site-packages
iniparse 0.4 /usr/lib/python3.11/site-packages
Jinja2 3.1.4 /usr/lib/python3.11/site-packages rpm
jq 1.6.0 /usr/lib64/python3.11/site-packages
json-stream 2.3.2 /usr/lib/python3.11/site-packages rpm
json-stream-rs-tokenizer 0.4.25 /usr/lib64/python3.11/site-packages
jsonschema 4.10.3 /usr/lib/python3.11/site-packages
libcomps 0.1.21 /usr/lib64/python3.11/site-packages
lxml 4.9.2 /usr/lib64/python3.11/site-packages
MarkupPy 1.14 /usr/lib/python3.11/site-packages
MarkupSafe 2.1.3 /usr/lib64/python3.11/site-packages rpm
multidict 6.0.4 /usr/lib64/python3.11/site-packages
odfpy 1.4.1 /usr/lib/python3.11/site-packages
openpyxl 3.1.0 /usr/lib/python3.11/site-packages
opentelemetry-api 1.19.0 /usr/lib/python3.11/site-packages rpm
opentelemetry-distro 0.40b0 /usr/lib/python3.11/site-packages rpm
opentelemetry-exporter-otlp 1.19.0 /usr/lib/python3.11/site-packages rpm
opentelemetry-exporter-otlp-proto-common 1.19.0 /usr/lib/python3.11/site-packages rpm
opentelemetry-exporter-otlp-proto-grpc 1.19.0 /usr/lib/python3.11/site-packages rpm
opentelemetry-exporter-otlp-proto-http 1.19.0 /usr/lib/python3.11/site-packages rpm
opentelemetry-instrumentation 0.40b0 /usr/lib/python3.11/site-packages rpm
opentelemetry-instrumentation-django 0.40b0 /usr/lib/python3.11/site-packages rpm
opentelemetry-instrumentation-wsgi 0.40b0 /usr/lib/python3.11/site-packages rpm
opentelemetry-proto 1.19.0 /usr/lib/python3.11/site-packages rpm
opentelemetry-sdk 1.19.0 /usr/lib/python3.11/site-packages rpm
opentelemetry-semantic-conventions 0.40b0 /usr/lib/python3.11/site-packages rpm
opentelemetry-util-http 0.40b0 /usr/lib/python3.11/site-packages rpm
packaging 21.3 /usr/lib/python3.11/site-packages
pip 22.3.1 /usr/lib/python3.11/site-packages rpm
pkginfo 1.11.0 /usr/lib/python3.11/site-packages
productmd 1.33 /usr/lib/python3.11/site-packages
protobuf 4.21.6 /usr/lib/python3.11/site-packages
psycopg 3.2.3 /usr/lib/python3.11/site-packages
psycopg-c 3.2.3 /usr/lib64/python3.11/site-packages
pulp-cli 0.29.2 /usr/lib/python3.11/site-packages rpm
pulp-glue 0.29.2 /usr/lib/python3.11/site-packages rpm
pulp-python 3.11.3 /usr/lib/python3.11/site-packages
pulp-rpm 3.26.1 /usr/lib/python3.11/site-packages
pulpcore 3.49.22 /usr/lib/python3.11/site-packages
pycairo 1.20.1 /usr/lib64/python3.11/site-packages
pycares 4.1.2 /usr/lib64/python3.11/site-packages
pycparser 2.22 /usr/lib/python3.11/site-packages pip
Pygments 2.17.0 /usr/lib/python3.11/site-packages rpm
PyGObject 3.40.1 /usr/lib64/python3.11/site-packages
pygtrie 2.5.0 /usr/lib/python3.11/site-packages
pyOpenSSL 24.3.0 /usr/lib/python3.11/site-packages pip
pyparsing 3.1.1 /usr/lib/python3.11/site-packages rpm
pypi-simple 0.9.0 /usr/lib/python3.11/site-packages
pyrsistent 0.18.1 /usr/lib64/python3.11/site-packages
python-dateutil 2.8.2 /usr/lib/python3.11/site-packages rpm
python-gnupg 0.5.0 /usr/lib/python3.11/site-packages
python-socks 2.0.3 /usr/lib/python3.11/site-packages
pytz 2024.1 /usr/lib/python3.11/site-packages
PyYAML 6.0 /usr/lib64/python3.11/site-packages
redis 4.3.4 /usr/lib/python3.11/site-packages
requests 2.32.3 /usr/lib/python3.11/site-packages rpm
rhsm 1.19.2 /usr/lib64/python3.11/site-packages
rq 1.9.0 /usr/lib/python3.11/site-packages
schema 0.7.5 /usr/lib/python3.11/site-packages
setuptools 65.5.1 /usr/lib/python3.11/site-packages pip
six 1.16.0 /usr/lib/python3.11/site-packages
soupsieve 2.3.1 /usr/lib/python3.11/site-packages
sqlparse 0.5.0 /usr/lib/python3.11/site-packages rpm
tablib 3.3.0 /usr/lib/python3.11/site-packages
toml 0.10.2 /usr/lib/python3.11/site-packages
typing_extensions 4.7.1 /usr/lib/python3.11/site-packages rpm
uritemplate 4.1.1 /usr/lib/python3.11/site-packages
url-normalize 1.4.3 /usr/lib/python3.11/site-packages
urllib3 2.2.3 /usr/lib/python3.11/site-packages rpm
urlman 2.0.1 /usr/lib/python3.11/site-packages
uuid6 2023.5.2 /usr/lib/python3.11/site-packages
whitenoise 6.0.0 /usr/lib/python3.11/site-packages
wrapt 1.14.1 /usr/lib64/python3.11/site-packages
xlrd 2.0.1 /usr/lib/python3.11/site-packages
xlwt 1.3.0 /usr/lib/python3.11/site-packages
yarl 1.8.2 /usr/lib64/python3.11/site-packages
zipp 3.4.0 /usr/lib/python3.11/site-packages
[root@katello bin]#
Or maybe can i delete everything in /usr/local?
And you are right . Now even though my katello works i try to execute normal update for one of the hosts . and i get that completed however there are lot of errors popping up . maybe the system is broken as you mentioned.
Updating Subscription Management repositories.
2:
Docker CE - EL8 27 kB/s | 1.5 kB 00:00
3:
Percona Tools - EL8 28 kB/s | 1.5 kB 00:00
4:
Google Cloud SDK - EL8 28 kB/s | 1.5 kB 00:00
5:
Rocky Linux 9.2 - AppStream 59 kB/s | 2.6 kB 00:00
6:
Rocky Linux 9 - PowerTools 57 kB/s | 2.6 kB 00:00
7:
EPEL-8 42 kB/s | 2.3 kB 00:00
8:
Rocky Linux 9 - AppStream 58 kB/s | 2.6 kB 00:00
9:
Rocky Linux 9 - BaseOS 50 kB/s | 2.3 kB 00:00
10:
Remi EL8 - PHP 7.4 27 kB/s | 1.5 kB 00:00
11:
InfluxDB - EL8 28 kB/s | 1.5 kB 00:00
12:
Gitlab Runner - EL8 27 kB/s | 1.5 kB 00:00
13:
Rocky Linux 8.7 - AppStream 47 kB/s | 2.6 kB 00:00
14:
Jenkins 27 kB/s | 1.5 kB 00:00
15:
Rocky Linux 8 - AppStream 45 kB/s | 2.6 kB 00:00
16:
Grafana 27 kB/s | 1.5 kB 00:00
17:
Modular dependency problems:
18:
19:
Problem 1: conflicting requests
20:
- nothing provides module(platform:el8) needed by module jaxb:4:8080020230516204132:9d367344.x86_64 from kci_Rocky_Linux_8_Rocky_Linux_8_-_AppStream
21:
Problem 2: cannot install the best candidate for the job
22:
- nothing provides module(platform:el8) needed by module ant:1.10:8100020240212164931:417e5c08.x86_64 from kci_Rocky_Linux_8_Rocky_Linux_8_-_AppStream
23:
Problem 3: cannot install the best candidate for the job
24:
- nothing provides module(platform:el8) needed by module container-tools:rhel8:8100020241126171315:82888897.x86_64 from kci_Rocky_Linux_8_Rocky_Linux_8_-_AppStream
25:
Problem 4: cannot install the best candidate for the job
26:
- nothing provides module(platform:el8) needed by module eclipse:rhel8:8060020220512074252:ae9e1765.x86_64 from kci_Rocky_Linux_8_Rocky_Linux_8_7_-_AppStream
27:
Problem 5: cannot install the best candidate for the job
28:
- nothing provides module(platform:el8) needed by module freeradius:3.0:8100020240731133810:6702075b.x86_64 from kci_Rocky_Linux_8_Rocky_Linux_8_-_AppStream
29:
Problem 6: cannot install the best candidate for the job
30:
- nothing provides module(platform:el8) needed by module gimp:2.8:8090020240219182222:0ef2f6ef.x86_64 from kci_Rocky_Linux_8_Rocky_Linux_8_-_AppStream
31:
Problem 7: cannot install the best candidate for the job
32:
- nothing provides module(platform:el8) needed by module go-toolset:rhel8:8100020241217184058:7e2b282f.x86_64 from kci_Rocky_Linux_8_Rocky_Linux_8_-_AppStream
33:
Problem 8: cannot install the best candidate for the job
34:
- nothing provides module(platform:el8) needed by module httpd:2.4:8100020241105193728:e155f54d.x86_64 from kci_Rocky_Linux_8_Rocky_Linux_8_-_AppStream
35:
Problem 9: cannot install the best candidate for the job
36:
- nothing provides module(platform:el8) needed by module idm:client:8100020241217184056:6d180cd9.x86_64 from kci_Rocky_Linux_8_Rocky_Linux_8_-_AppStream
37:
Problem 10: cannot install the best candidate for the job
38:
- nothing provides module(platform:el8) needed by module inkscape:0.92.3:8060020220510152652:b951fd09.x86_64 from kci_Rocky_Linux_8_Rocky_Linux_8_7_-_AppStream
39:
Problem 11: cannot install the best candidate for the job
40:
- nothing provides module(platform:el8) needed by module jmc:rhel8:8050020211109115703:6392b1f8.x86_64 from kci_Rocky_Linux_8_Rocky_Linux_8_7_-_AppStream
41:
Problem 12: cannot install the best candidate for the job
42:
- nothing provides module(platform:el8) needed by module llvm-toolset:rhel8:8100020241107055603:bfa2b8ad.x86_64 from kci_Rocky_Linux_8_Rocky_Linux_8_-_AppStream
43:
Problem 13: cannot install the best candidate for the job
44:
- nothing provides module(platform:el8) needed by module log4j:2:8080020230330060023:9d367344.x86_64 from kci_Rocky_Linux_8_Rocky_Linux_8_-_AppStream
45:
Problem 14: cannot install the best candidate for the job
46:
- nothing provides module(platform:el8) needed by module mailman:2.1:8090020230727144346:0ef2f6ef.x86_64 from kci_Rocky_Linux_8_Rocky_Linux_8_-_AppStream
47:
Problem 15: cannot install the best candidate for the job
48:
- nothing provides module(platform:el8) needed by module mariadb:10.3:8080020230920001707:fd72936b.x86_64 from kci_Rocky_Linux_8_Rocky_Linux_8_-_AppStream
49:
Problem 16: cannot install the best candidate for the job
50:
- nothing provides module(platform:el8) needed by module maven:3.5:8060020220530151437:c0229ad2.x86_64 from kci_Rocky_Linux_8_Rocky_Linux_8_7_-_AppStream
51:
Problem 17: cannot install the best candidate for the job
52:
- nothing provides module(platform:el8) needed by module mercurial:4.8:8030020210428123809:c307c522.x86_64 from kci_Rocky_Linux_8_Rocky_Linux_8_7_-_AppStream
53:
Problem 18: cannot install the best candidate for the job
54:
- nothing provides module(platform:el8) needed by module mod_auth_openidc:2.3:8100020240813202238:e155f54d.x86_64 from kci_Rocky_Linux_8_Rocky_Linux_8_-_AppStream
55:
Problem 19: cannot install the best candidate for the job
56:
- nothing provides module(platform:el8) needed by module mysql:8.0:8100020240126202301:e155f54d.x86_64 from kci_Rocky_Linux_8_Rocky_Linux_8_-_AppStream
57:
Problem 20: cannot install the best candidate for the job
58:
- nothing provides module(platform:el8) needed by module nginx:1.14:8040020210610090123:9f9e2e7e.x86_64 from kci_Rocky_Linux_8_Rocky_Linux_8_7_-_AppStream
59:
Problem 21: cannot install the best candidate for the job
60:
- nothing provides module(platform:el8) needed by module nodejs:10:8030020210426100849:30b713e6.x86_64 from kci_Rocky_Linux_8_Rocky_Linux_8_7_-_AppStream
61:
Problem 22: cannot install the best candidate for the job
62:
- nothing provides module(platform:el8) needed by module perl:5.26:8050020211109115414:b4937e53.x86_64 from kci_Rocky_Linux_8_Rocky_Linux_8_7_-_AppStream
63:
Problem 23: cannot install the best candidate for the job
64:
- nothing provides module(platform:el8) needed by module php:7.2:8040020210530192442:02bae935.x86_64 from kci_Rocky_Linux_8_Rocky_Linux_8_7_-_AppStream
65:
Problem 24: cannot install the best candidate for the job
66:
- nothing provides module(platform:el8) needed by module postgresql:10:8090020240226072208:b46abd14.x86_64 from kci_Rocky_Linux_8_Rocky_Linux_8_-_AppStream
67:
Problem 25: cannot install the best candidate for the job
68:
- nothing provides module(platform:el8) needed by module python27:2.7:8100020240523105808:5f0f67de.x86_64 from kci_Rocky_Linux_8_Rocky_Linux_8_-_AppStream
69:
Problem 26: cannot install the best candidate for the job
70:
- nothing provides module(platform:el8) needed by module python36:3.6:8100020241211202209:5ae887d0.x86_64 from kci_Rocky_Linux_8_Rocky_Linux_8_-_AppStream
71:
Problem 27: cannot install the best candidate for the job
72:
- nothing provides module(platform:el8) needed by module python38:3.8:8090020230810162531:71b83295.x86_64 from kci_Rocky_Linux_8_Rocky_Linux_8_-_AppStream
73:
Problem 28: cannot install the best candidate for the job
74:
- nothing provides module(platform:el8) needed by module python39:3.9:8100020241023123552:e3a3f2fc.x86_64 from kci_Rocky_Linux_8_Rocky_Linux_8_-_AppStream
75:
Problem 29: cannot install the best candidate for the job
76:
- nothing provides module(platform:el8) needed by module redis:5:8050020211020202418:b4937e53.x86_64 from kci_Rocky_Linux_8_Rocky_Linux_8_7_-_AppStream
77:
Problem 30: cannot install the best candidate for the job
78:
- nothing provides module(platform:el8) needed by module rhn-tools:1.0:8030020210429021554:a66e5355.x86_64 from kci_Rocky_Linux_8_Rocky_Linux_8_7_-_AppStream
79:
Problem 31: cannot install the best candidate for the job
80:
- nothing provides module(platform:el8) needed by module ruby:2.5:8100020241205174934:e155f54d.x86_64 from kci_Rocky_Linux_8_Rocky_Linux_8_-_AppStream
81:
Problem 32: cannot install the best candidate for the job
82:
- nothing provides module(platform:el8) needed by module rust-toolset:rhel8:8100020241209081607:f4e2ccb8.x86_64 from kci_Rocky_Linux_8_Rocky_Linux_8_-_AppStream
83:
Problem 33: cannot install the best candidate for the job
84:
- nothing provides module(platform:el8) needed by module satellite-5-client:1.0:8030020210428035500:30b713e6.x86_64 from kci_Rocky_Linux_8_Rocky_Linux_8_7_-_AppStream
85:
Problem 34: cannot install the best candidate for the job
86:
- nothing provides module(platform:el8) needed by module squid:4:8100020241114152439:e155f54d.x86_64 from kci_Rocky_Linux_8_Rocky_Linux_8_-_AppStream
87:
Problem 35: cannot install the best candidate for the job
88:
- nothing provides module(platform:el8) needed by module subversion:1.10:8070020221108111308:78111232.x86_64 from kci_Rocky_Linux_8_Rocky_Linux_8_7_-_AppStream
89:
Problem 36: cannot install the best candidate for the job
90:
- nothing provides module(platform:el8) needed by module swig:3.0:8040020210530171044:9f9e2e7e.x86_64 from kci_Rocky_Linux_8_Rocky_Linux_8_7_-_AppStream
91:
Problem 37: cannot install the best candidate for the job
92:
- nothing provides module(platform:el8) needed by module varnish:6:8090020240408150337:b46abd14.x86_64 from kci_Rocky_Linux_8_Rocky_Linux_8_-_AppStream
93:
Problem 38: cannot install the best candidate for the job
94:
- nothing provides module(platform:el8) needed by module virt:rhel:8100020241217184058:e155f54d.x86_64 from kci_Rocky_Linux_8_Rocky_Linux_8_-_AppStream
95:
Problem 39: cannot install the best candidate for the job
96:
- nothing provides module(platform:el8) needed by module perl-libwww-perl:6.34:8090020231016070052:718bf150.x86_64 from kci_Rocky_Linux_8_Rocky_Linux_8_-_AppStream
97:
- nothing provides module(platform:el8) needed by module perl-libwww-perl:6.34:8090020231016070052:8af8375c.x86_64 from kci_Rocky_Linux_8_Rocky_Linux_8_-_AppStream
98:
- nothing provides module(platform:el8) needed by module perl-libwww-perl:6.34:8090020231016070052:a1e5d4b7.x86_64 from kci_Rocky_Linux_8_Rocky_Linux_8_-_AppStream
99:
- nothing provides module(platform:el8) needed by module perl-libwww-perl:6.34:8090020231016070052:ce7a7462.x86_64 from kci_Rocky_Linux_8_Rocky_Linux_8_-_AppStream
100:
Problem 40: cannot install the best candidate for the job
101:
- nothing provides module(platform:el8) needed by module perl-IO-Socket-SSL:2.066:8090020231016070024:88fd4976.x86_64 from kci_Rocky_Linux_8_Rocky_Linux_8_-_AppStream
102:
- nothing provides module(platform:el8) needed by module perl-IO-Socket-SSL:2.066:8090020231016070024:b1365f21.x86_64 from kci_Rocky_Linux_8_Rocky_Linux_8_-_AppStream
103:
- nothing provides module(platform:el8) needed by module perl-IO-Socket-SSL:2.066:8090020231016070024:bc707b4e.x86_64 from kci_Rocky_Linux_8_Rocky_Linux_8_-_AppStream
104:
- nothing provides module(platform:el8) needed by module perl-IO-Socket-SSL:2.066:8090020231016070024:ed8f85ad.x86_64 from kci_Rocky_Linux_8_Rocky_Linux_8_-_AppStream
105:
Problem 41: cannot install the best candidate for the job
106:
- nothing provides module(platform:el8) needed by module perl-FCGI:0.78:8090020231016065951:88fd4976.x86_64 from kci_Rocky_Linux_8_Rocky_Linux_8_-_AppStream
107:
- nothing provides module(platform:el8) needed by module perl-FCGI:0.78:8090020231016065951:b1365f21.x86_64 from kci_Rocky_Linux_8_Rocky_Linux_8_-_AppStream
108:
- nothing provides module(platform:el8) needed by module perl-FCGI:0.78:8090020231016065951:bc707b4e.x86_64 from kci_Rocky_Linux_8_Rocky_Linux_8_-_AppStream
109:
- nothing provides module(platform:el8) needed by module perl-FCGI:0.78:8090020231016065951:ed8f85ad.x86_64 from kci_Rocky_Linux_8_Rocky_Linux_8_-_AppStream
110:
Problem 42: cannot install the best candidate for the job
111:
- nothing provides module(platform:el8) needed by module perl-DBI:1.641:8090020231016030935:88fd4976.x86_64 from kci_Rocky_Linux_8_Rocky_Linux_8_-_AppStream
112:
- nothing provides module(platform:el8) needed by module perl-DBI:1.641:8090020231016030935:b1365f21.x86_64 from kci_Rocky_Linux_8_Rocky_Linux_8_-_AppStream
113:
- nothing provides module(platform:el8) needed by module perl-DBI:1.641:8090020231016030935:bc707b4e.x86_64 from kci_Rocky_Linux_8_Rocky_Linux_8_-_AppStream
114:
- nothing provides module(platform:el8) needed by module perl-DBI:1.641:8090020231016030935:ed8f85ad.x86_64 from kci_Rocky_Linux_8_Rocky_Linux_8_-_AppStream
115:
Problem 43: cannot install the best candidate for the job
116:
- nothing provides module(platform:el8) needed by module perl-DBD-SQLite:1.58:8090020231016064426:074499c9.x86_64 from kci_Rocky_Linux_8_Rocky_Linux_8_-_AppStream
117:
- nothing provides module(platform:el8) needed by module perl-DBD-SQLite:1.58:8090020231016064426:0aad9023.x86_64 from kci_Rocky_Linux_8_Rocky_Linux_8_-_AppStream
118:
- nothing provides module(platform:el8) needed by module perl-DBD-SQLite:1.58:8090020231016064426:9ffcca46.x86_64 from kci_Rocky_Linux_8_Rocky_Linux_8_-_AppStream
119:
- nothing provides module(platform:el8) needed by module perl-DBD-SQLite:1.58:8090020231016064426:a4359c37.x86_64 from kci_Rocky_Linux_8_Rocky_Linux_8_-_AppStream
120:
Problem 44: cannot install the best candidate for the job
121:
- nothing provides module(platform:el8) needed by module perl-DBD-Pg:3.7:8090020231016064233:3ece9ff6.x86_64 from kci_Rocky_Linux_8_Rocky_Linux_8_-_AppStream
122:
- nothing provides module(platform:el8) needed by module perl-DBD-Pg:3.7:8090020231016064233:8db488fd.x86_64 from kci_Rocky_Linux_8_Rocky_Linux_8_-_AppStream
123:
- nothing provides module(platform:el8) needed by module perl-DBD-Pg:3.7:8090020231016064233:b3d03cf6.x86_64 from kci_Rocky_Linux_8_Rocky_Linux_8_-_AppStream
124:
- nothing provides module(platform:el8) needed by module perl-DBD-Pg:3.7:8090020231016064233:d706c26f.x86_64 from kci_Rocky_Linux_8_Rocky_Linux_8_-_AppStream
125:
Problem 45: cannot install the best candidate for the job
126:
- nothing provides module(platform:el8) needed by module perl-DBD-MySQL:4.046:8090020231016064114:074499c9.x86_64 from kci_Rocky_Linux_8_Rocky_Linux_8_-_AppStream
127:
- nothing provides module(platform:el8) needed by module perl-DBD-MySQL:4.046:8090020231016064114:0aad9023.x86_64 from kci_Rocky_Linux_8_Rocky_Linux_8_-_AppStream
128:
- nothing provides module(platform:el8) needed by module perl-DBD-MySQL:4.046:8090020231016064114:9ffcca46.x86_64 from kci_Rocky_Linux_8_Rocky_Linux_8_-_AppStream
129:
- nothing provides module(platform:el8) needed by module perl-DBD-MySQL:4.046:8090020231016064114:a4359c37.x86_64 from kci_Rocky_Linux_8_Rocky_Linux_8_-_AppStream
130:
Problem 46: cannot install the best candidate for the job
131:
- nothing provides module(platform:el8) needed by module perl-App-cpanminus:1.7044:8100020241125223922:38eff273.x86_64 from kci_Rocky_Linux_8_Rocky_Linux_8_-_AppStream
132:
- nothing provides module(platform:el8) needed by module perl-App-cpanminus:1.7044:8100020241125223922:8ab8f36f.x86_64 from kci_Rocky_Linux_8_Rocky_Linux_8_-_AppStream
133:
- nothing provides module(platform:el8) needed by module perl-App-cpanminus:1.7044:8100020241125223922:a1fb8cd9.x86_64 from kci_Rocky_Linux_8_Rocky_Linux_8_-_AppStream
134:
- nothing provides module(platform:el8) needed by module perl-App-cpanminus:1.7044:8100020241125223922:c259baed.x86_64 from kci_Rocky_Linux_8_Rocky_Linux_8_-_AppStream
135:
Problem 47: cannot install the best candidate for the job
136:
- nothing provides module(platform:el8) needed by module perl-YAML:1.24:8060020220513063607:369bdfc6.x86_64 from kci_Rocky_Linux_8_Rocky_Linux_8_7_-_AppStream
137:
- nothing provides module(platform:el8) needed by module perl-YAML:1.24:8060020220513063607:6a1d53c5.x86_64 from kci_Rocky_Linux_8_Rocky_Linux_8_7_-_AppStream
138:
- nothing provides module(platform:el8) needed by module perl-YAML:1.24:8060020220513063607:e4fef011.x86_64 from kci_Rocky_Linux_8_Rocky_Linux_8_7_-_AppStream
139:
- nothing provides module(platform:el8) needed by module perl-YAML:1.24:8060020220513063607:f7485d8d.x86_64 from kci_Rocky_Linux_8_Rocky_Linux_8_7_-_AppStream
140:
Dependencies resolved.
141:
Nothing to do.
142:
Complete!
143:
Exit status: 0
O.K. Thatâs even worse: itâs showing 3.11 packages. The default pip3 should show the system python3.9 packages and be python3.9. It seems the default python version has been changed. Now the question is, how badly is was changed, i.e. if it was done using system tools or if someone just changed the symlinks manually.
# which pip3
/bin/pip3
# rpm -qf /bin/pip3
python3-pip-21.3.1-1.el9.noarch
# ls -la /bin/pip3
-rwxr-xr-x. 1 root root 648 Oct 2 21:13 /bin/pip3
# alternatives --list | grep py
python auto /usr/bin/python3
python3 auto /usr/bin/python3.12
For the pip3 list for python3.11 you have posted you should definitively uninstall all packages which have been installed from pip, i.e. those:
and then reinstall the rpm packages from the repositories which provide them.
pulpcore:
python3.11-cffi-1.15.1-5.el8.x86_64.rpm
python3.11-pycparser-2.21-6.el8.noarch.rpm
python3.11-pyOpenSSL-24.1.0-1.el8.noarch.rpm
python3.11-setuptools is in AppStream or PowerTools and it seems that is always listed as coming from pip, i.e. you donât have to remove that. You can verify the installation with rpm -V:
# rpm -qa *setuptools\*
python3-setuptools-wheel-53.0.0-13.el9.noarch
python3-setuptools-53.0.0-13.el9.noarch
python3.11-setuptools-wheel-65.5.1-3.el9.noarch
python3.11-setuptools-65.5.1-3.el9.noarch
# rpm -qa *setuptools\* | xargs rpm -V
If the second command with rpm -V does not list any changes then itâs fine.
To get rid of the installed pip packages in /usr/local you should check with the pip3.9. If the system was not messed with too badly, you should be able to access pip3.9:
# pip3.9 list -v
pip 20.2.4 /usr/lib/python3.9/site-packages rpm
setuptools 50.3.2 /usr/lib/python3.9/site-packages pip
I suspect you still see those pulpcore and other packages there. You can then uninstall them with pip3.9. This will hopefully get rid of those /usr/local/ files without manually removal or manipulation and get the clean state youâll need.
If not, itâs probably necessary to review what files are still in the /usr/local directory tree and then find out why there are still there and delete them manually if they are abandoned.
Seeing your current python interpreters could help, too:
# ls -la /usr/bin/python*
lrwxrwxrwx. 1 root root 36 Jan 11 2023 /usr/bin/python -> /etc/alternatives/unversioned-python
lrwxrwxrwx. 1 root root 25 Jan 11 2023 /usr/bin/python3 -> /etc/alternatives/python3
lrwxrwxrwx. 1 root root 31 Apr 7 2024 /usr/bin/python3.6 -> /usr/libexec/platform-python3.6
lrwxrwxrwx. 1 root root 17 Apr 7 2024 /usr/bin/python3.6-config -> python3.6m-config
lrwxrwxrwx. 1 root root 32 Apr 7 2024 /usr/bin/python3.6m -> /usr/libexec/platform-python3.6m
lrwxrwxrwx. 1 root root 39 Apr 7 2024 /usr/bin/python3.6m-config -> /usr/libexec/platform-python3.6m-config
lrwxrwxrwx. 1 root root 46 Apr 7 2024 /usr/bin/python3.6m-x86_64-config -> /usr/libexec/platform-python3.6m-x86_64-config
-rwxr-xr-x. 1 root root 7776 Oct 23 15:36 /usr/bin/python3.9
-rwxr-xr-x. 1 root root 57 Oct 23 15:36 /usr/bin/python3.9-config
-rwxr-xr-x. 1 root root 3616 Oct 23 15:29 /usr/bin/python3.9-x86_64-config
lrwxrwxrwx. 1 root root 32 Nov 28 2023 /usr/bin/python3-config -> /etc/alternatives/python3-config
And the rpms for those:
# rpm -qf /usr/bin/python*
file /usr/bin/python is not owned by any package
python36-3.6.8-39.module_el8.10.0+3769+3838165b.x86_64
python39-3.9.20-1.module_el8.10.0+3902+1690be06.x86_64
python36-devel-3.6.8-39.module_el8.10.0+3769+3838165b.x86_64
python39-devel-3.9.20-1.module_el8.10.0+3902+1690be06.x86_64
And checking if they have been messed with:
# rpm -qf /usr/bin/python* | grep ^py | sort | uniq | xargs rpm -V
If the system has been messed with pretty badly, you may have to review all RPMs:
# rpm -Va
That takes a while and probably lists a lot of things, mostly configuration files, but possibly something else, too.
[root@katello ~]# which pip3
/bin/pip3
[root@katello ~]# rpm -qf /bin/pip3
python38-pip-19.3.1-7.module+el8.9.0+1418+f0d66789.noarch
python39-pip-20.2.4-9.module+el8.10.0+1860+afcc1c71.noarch
python36-3.6.8-39.module+el8.10.0+1910+234ad790.x86_64
python3.11-pip-22.3.1-5.el8.noarch
[root@katello ~]# ls -la /bin/pip3
lrwxrwxrwx. 1 root root 22 Dec 18 14:30 /bin/pip3 -> /etc/alternatives/pip3
[root@katello ~]# alternatives --list | grep py
python auto /usr/libexec/no-python
python3 manual /usr/bin/python3.11
[root@katello ~]# pip3 uninstall cffi pycparser pyOpenSSL setuptools
Found existing installation: cffi 1.17.1
Uninstalling cffi-1.17.1:
Would remove:
/usr/lib/python3.11/site-packages/_cffi_backend.cpython-311-x86_64-linux-gnu.so
/usr/lib/python3.11/site-packages/cffi-1.17.1.dist-info/*
/usr/lib/python3.11/site-packages/cffi/*
Proceed (Y/n)? Successfully uninstalled cffi-1.17.1
Found existing installation: pycparser 2.22
Uninstalling pycparser-2.22:
Would remove:
/usr/lib/python3.11/site-packages/pycparser-2.22.dist-info/*
/usr/lib/python3.11/site-packages/pycparser/*
Proceed (Y/n)? Y
Successfully uninstalled pycparser-2.22
Found existing installation: pyOpenSSL 24.3.0
Uninstalling pyOpenSSL-24.3.0:
Would remove:
/usr/lib/python3.11/site-packages/OpenSSL/*
/usr/lib/python3.11/site-packages/pyOpenSSL-24.3.0.dist-info/*
Proceed (Y/n)? Y
Successfully uninstalled pyOpenSSL-24.3.0
Found existing installation: setuptools 65.5.1
Uninstalling setuptools-65.5.1:
Would remove:
/usr/lib/python3.11/site-packages/_distutils_hack/*
/usr/lib/python3.11/site-packages/distutils-precedence.pth
/usr/lib/python3.11/site-packages/pkg_resources/*
/usr/lib/python3.11/site-packages/setuptools-65.5.1.dist-info/*
/usr/lib/python3.11/site-packages/setuptools/*
Proceed (Y/n)? Y
Successfully uninstalled setuptools-65.5.1
[root@katello ~]# sudo dnf install python3.11-cffi python3.11-pycparser python3.11-pyOpenSSL
Last metadata expiration check: 0:23:48 ago on Mon 23 Dec 2024 06:47:39 AM UTC.
Package python3.11-cffi-1.15.1-5.el8.x86_64 is already installed.
Package python3.11-pycparser-2.21-6.el8.noarch is already installed.
Package python3.11-pyOpenSSL-24.1.0-1.el8.noarch is already installed.
Nothing to do.
python2-setuptools-wheel-39.0.1-14.module+el8.10.0+1813+4b021305.noarch
platform-python-setuptools-39.2.0-8.el8_10.noarch
python3-setuptools-39.2.0-8.el8_10.noarch
python38-setuptools-wheel-41.6.0-5.module+el8.9.0+1418+f0d66789.noarch
python3-setuptools-wheel-39.2.0-8.el8_10.noarch
python3.11-setuptools-wheel-65.5.1-3.el8_10.noarch
python39-setuptools-50.3.2-6.module+el8.10.0+1861+0f5e39ec.noarch
python2-setuptools-39.0.1-14.module+el8.10.0+1813+4b021305.noarch
python39-setuptools-wheel-50.3.2-6.module+el8.10.0+1861+0f5e39ec.noarch
python3.11-setuptools-65.5.1-3.el8_10.noarch
python38-setuptools-41.6.0-5.module+el8.9.0+1418+f0d66789.noarch
[root@katello ~]# rpm -qa *setuptools\* | xargs rpm -V
[root@katello ~]# pip3.9 list -v
aiosignal 1.2.0 /usr/lib/python3.9/site-packages
asgiref 3.5.0 /usr/lib/python3.9/site-packages
async-timeout 4.0.2 /usr/lib/python3.9/site-packages
attrs 21.4.0 /usr/lib/python3.9/site-packages
Brotli 1.0.9 /usr/lib64/python3.9/site-packages
cchardet 2.1.7 /usr/lib64/python3.9/site-packages
certifi 2020.6.20 /usr/lib/python3.9/site-packages
cffi 1.15.0 /usr/lib64/python3.9/site-packages
charset-normalizer 2.0.11 /usr/lib/python3.9/site-packages
click 8.1.2 /usr/lib/python3.9/site-packages
click-shell 2.1 /usr/lib/python3.9/site-packages
colorama 0.4.4 /usr/lib/python3.9/site-packages
contextlib2 21.6.0 /usr/lib/python3.9/site-packages
cryptography 3.4.8 /usr/lib64/python3.9/site-packages
defusedxml 0.7.1 /usr/lib/python3.9/site-packages
diff-match-patch 20200713 /usr/lib/python3.9/site-packages
et-xmlfile 1.1.0 /usr/lib/python3.9/site-packages
filelock 3.0.12 /usr/lib/python3.9/site-packages
frozenlist 1.3.0 /usr/lib64/python3.9/site-packages
idna 3.3 /usr/lib/python3.9/site-packages
idna-ssl 1.1.0 /usr/lib/python3.9/site-packages
importlib-metadata 4.10.1 /usr/lib/python3.9/site-packages
inflection 0.5.1 /usr/lib/python3.9/site-packages
lxml 4.7.1 /usr/lib64/python3.9/site-packages
MarkupPy 1.14 /usr/lib/python3.9/site-packages
multidict 6.0.2 /usr/lib64/python3.9/site-packages
odfpy 1.4.1 /usr/lib/python3.9/site-packages
openpyxl 3.0.9 /usr/lib/python3.9/site-packages
packaging 21.3 /usr/lib/python3.9/site-packages
pycares 4.1.2 /usr/lib64/python3.9/site-packages
pycparser 2.21 /usr/lib/python3.9/site-packages
pyOpenSSL 19.1.0 /usr/lib/python3.9/site-packages
pyparsing 2.4.7 /usr/lib/python3.9/site-packages
pyrsistent 0.18.1 /usr/lib64/python3.9/site-packages
python-socks 2.0.3 /usr/lib/python3.9/site-packages
pytz 2021.3 /usr/lib/python3.9/site-packages
PyYAML 5.4.1 /usr/lib64/python3.9/site-packages
redis 3.5.3 /usr/lib/python3.9/site-packages
schema 0.7.5 /usr/lib/python3.9/site-packages
six 1.16.0 /usr/lib/python3.9/site-packages
tablib 3.2.0 /usr/lib/python3.9/site-packages
toml 0.10.2 /usr/lib/python3.9/site-packages
typing-extensions 3.10.0.2 /usr/lib/python3.9/site-packages
uritemplate 4.1.1 /usr/lib/python3.9/site-packages
urllib3 1.26.8 /usr/lib/python3.9/site-packages
urlman 1.4.0 /usr/lib/python3.9/site-packages
xlrd 2.0.1 /usr/lib/python3.9/site-packages
xlwt 1.3.0 /usr/lib/python3.9/site-packages
yarl 1.7.2 /usr/lib64/python3.9/site-packages
zipp 3.4.0 /usr/lib/python3.9/site-packages
I dont see pulpcore here
[root@katello ~]# # rpm -qf /usr/bin/python* | grep ^py | sort | uniq | xargs rpm -V
[root@katello ~]#
This shows many packages missing ![]()
rpm -Va | grep missing
missing c /etc/foreman/dynflow/worker.yml
missing /usr/bin/jsonschema
missing /usr/bin/dynaconf
missing /usr/lib64/python3.11/site-packages/cffi
missing /usr/lib64/python3.11/site-packages/cffi-1.15.1-py3.11.egg-info
missing /usr/lib64/python3.11/site-packages/cffi-1.15.1-py3.11.egg-info/PKG-INFO
missing /usr/lib64/python3.11/site-packages/cffi-1.15.1-py3.11.egg-info/SOURCES.txt
missing /usr/lib64/python3.11/site-packages/cffi-1.15.1-py3.11.egg-info/dependency_links.txt
missing /usr/lib64/python3.11/site-packages/cffi-1.15.1-py3.11.egg-info/entry_points.txt
missing /usr/lib64/python3.11/site-packages/cffi-1.15.1-py3.11.egg-info/not-zip-safe
missing /usr/lib64/python3.11/site-packages/cffi-1.15.1-py3.11.egg-info/requires.txt
missing /usr/lib64/python3.11/site-packages/cffi-1.15.1-py3.11.egg-info/top_level.txt
missing /usr/lib64/python3.11/site-packages/cffi/__init__.py
missing /usr/lib64/python3.11/site-packages/cffi/__pycache__
missing /usr/lib64/python3.11/site-packages/cffi/__pycache__/__init__.cpython-311.opt-1.pyc
missing /usr/lib64/python3.11/site-packages/cffi/__pycache__/__init__.cpython-311.pyc
missing /usr/lib64/python3.11/site-packages/cffi/__pycache__/api.cpython-311.opt-1.pyc
missing /usr/lib64/python3.11/site-packages/cffi/__pycache__/api.cpython-311.pyc
missing /usr/lib64/python3.11/site-packages/cffi/__pycache__/backend_ctypes.cpython-311.opt-1.pyc
missing /usr/lib64/python3.11/site-packages/cffi/__pycache__/backend_ctypes.cpython-311.pyc
missing /usr/lib64/python3.11/site-packages/cffi/__pycache__/cffi_opcode.cpython-311.opt-1.pyc
missing /usr/lib64/python3.11/site-packages/cffi/__pycache__/cffi_opcode.cpython-311.pyc
missing /usr/lib64/python3.11/site-packages/cffi/__pycache__/commontypes.cpython-311.opt-1.pyc
missing /usr/lib64/python3.11/site-packages/cffi/__pycache__/commontypes.cpython-311.pyc
missing /usr/lib64/python3.11/site-packages/cffi/__pycache__/cparser.cpython-311.opt-1.pyc
missing /usr/lib64/python3.11/site-packages/cffi/__pycache__/cparser.cpython-311.pyc
missing /usr/lib64/python3.11/site-packages/cffi/__pycache__/error.cpython-311.opt-1.pyc
missing /usr/lib64/python3.11/site-packages/cffi/__pycache__/error.cpython-311.pyc
missing /usr/lib64/python3.11/site-packages/cffi/__pycache__/ffiplatform.cpython-311.opt-1.pyc
missing /usr/lib64/python3.11/site-packages/cffi/__pycache__/ffiplatform.cpython-311.pyc
missing /usr/lib64/python3.11/site-packages/cffi/__pycache__/lock.cpython-311.opt-1.pyc
missing /usr/lib64/python3.11/site-packages/cffi/__pycache__/lock.cpython-311.pyc
missing /usr/lib64/python3.11/site-packages/cffi/__pycache__/model.cpython-311.opt-1.pyc
missing /usr/lib64/python3.11/site-packages/cffi/__pycache__/model.cpython-311.pyc
missing /usr/lib64/python3.11/site-packages/cffi/__pycache__/pkgconfig.cpython-311.opt-1.pyc
missing /usr/lib64/python3.11/site-packages/cffi/__pycache__/pkgconfig.cpython-311.pyc
missing /usr/lib64/python3.11/site-packages/cffi/__pycache__/recompiler.cpython-311.opt-1.pyc
missing /usr/lib64/python3.11/site-packages/cffi/__pycache__/recompiler.cpython-311.pyc
missing /usr/lib64/python3.11/site-packages/cffi/__pycache__/setuptools_ext.cpython-311.opt-1.pyc
missing /usr/lib64/python3.11/site-packages/cffi/__pycache__/setuptools_ext.cpython-311.pyc
missing /usr/lib64/python3.11/site-packages/cffi/__pycache__/vengine_cpy.cpython-311.opt-1.pyc
missing /usr/lib64/python3.11/site-packages/cffi/__pycache__/vengine_cpy.cpython-311.pyc
missing /usr/lib64/python3.11/site-packages/cffi/__pycache__/vengine_gen.cpython-311.opt-1.pyc
missing /usr/lib64/python3.11/site-packages/cffi/__pycache__/vengine_gen.cpython-311.pyc
missing /usr/lib64/python3.11/site-packages/cffi/__pycache__/verifier.cpython-311.opt-1.pyc
missing /usr/lib64/python3.11/site-packages/cffi/__pycache__/verifier.cpython-311.pyc
missing /usr/lib64/python3.11/site-packages/cffi/_cffi_errors.h
missing /usr/lib64/python3.11/site-packages/cffi/_cffi_include.h
missing /usr/lib64/python3.11/site-packages/cffi/_embedding.h
missing /usr/lib64/python3.11/site-packages/cffi/api.py
missing /usr/lib64/python3.11/site-packages/cffi/backend_ctypes.py
missing /usr/lib64/python3.11/site-packages/cffi/cffi_opcode.py
missing /usr/lib64/python3.11/site-packages/cffi/commontypes.py
missing /usr/lib64/python3.11/site-packages/cffi/cparser.py
missing /usr/lib64/python3.11/site-packages/cffi/error.py
missing /usr/lib64/python3.11/site-packages/cffi/ffiplatform.py
missing /usr/lib64/python3.11/site-packages/cffi/lock.py
missing /usr/lib64/python3.11/site-packages/cffi/model.py
missing /usr/lib64/python3.11/site-packages/cffi/parse_c_type.h
missing /usr/lib64/python3.11/site-packages/cffi/pkgconfig.py
missing /usr/lib64/python3.11/site-packages/cffi/recompiler.py
missing /usr/lib64/python3.11/site-packages/cffi/setuptools_ext.py
missing /usr/lib64/python3.11/site-packages/cffi/vengine_cpy.py
missing /usr/lib64/python3.11/site-packages/cffi/vengine_gen.py
missing /usr/lib64/python3.11/site-packages/cffi/verifier.py
missing /usr/bin/django-admin
missing c /etc/httpd/conf.modules.d/10-h2.conf
missing c /etc/httpd/conf.modules.d/10-proxy_h2.conf
missing c /etc/systemd/system/redis.service.d/limit.conf
missing /usr/lib/python3.9/site-packages/OpenSSL
missing /usr/lib/python3.9/site-packages/OpenSSL/SSL.py
missing /usr/lib/python3.9/site-packages/OpenSSL/__init__.py
missing /usr/lib/python3.9/site-packages/OpenSSL/__pycache__
missing /usr/lib/python3.9/site-packages/OpenSSL/__pycache__/SSL.cpython-39.opt-1.pyc
missing /usr/lib/python3.9/site-packages/OpenSSL/__pycache__/SSL.cpython-39.pyc
missing /usr/lib/python3.9/site-packages/OpenSSL/__pycache__/__init__.cpython-39.opt-1.pyc
missing /usr/lib/python3.9/site-packages/OpenSSL/__pycache__/__init__.cpython-39.pyc
missing /usr/lib/python3.9/site-packages/OpenSSL/__pycache__/_util.cpython-39.opt-1.pyc
missing /usr/lib/python3.9/site-packages/OpenSSL/__pycache__/_util.cpython-39.pyc
missing /usr/lib/python3.9/site-packages/OpenSSL/__pycache__/crypto.cpython-39.opt-1.pyc
missing /usr/lib/python3.9/site-packages/OpenSSL/__pycache__/crypto.cpython-39.pyc
missing /usr/lib/python3.9/site-packages/OpenSSL/__pycache__/debug.cpython-39.opt-1.pyc
missing /usr/lib/python3.9/site-packages/OpenSSL/__pycache__/debug.cpython-39.pyc
missing /usr/lib/python3.9/site-packages/OpenSSL/__pycache__/rand.cpython-39.opt-1.pyc
missing /usr/lib/python3.9/site-packages/OpenSSL/__pycache__/rand.cpython-39.pyc
missing /usr/lib/python3.9/site-packages/OpenSSL/__pycache__/tsafe.cpython-39.opt-1.pyc
missing /usr/lib/python3.9/site-packages/OpenSSL/__pycache__/tsafe.cpython-39.pyc
missing /usr/lib/python3.9/site-packages/OpenSSL/__pycache__/version.cpython-39.opt-1.pyc
missing /usr/lib/python3.9/site-packages/OpenSSL/__pycache__/version.cpython-39.pyc
missing /usr/lib/python3.9/site-packages/OpenSSL/_util.py
missing /usr/lib/python3.9/site-packages/OpenSSL/crypto.py
missing /usr/lib/python3.9/site-packages/OpenSSL/debug.py
missing /usr/lib/python3.9/site-packages/OpenSSL/rand.py
missing /usr/lib/python3.9/site-packages/OpenSSL/tsafe.py
missing /usr/lib/python3.9/site-packages/OpenSSL/version.py
missing c /etc/httpd/conf.d/autoindex.conf
missing c /etc/httpd/conf.d/userdir.conf
missing c /etc/httpd/conf.d/welcome.conf
missing c /etc/httpd/conf.modules.d/00-base.conf
missing c /etc/httpd/conf.modules.d/00-dav.conf
missing c /etc/httpd/conf.modules.d/00-lua.conf
missing c /etc/httpd/conf.modules.d/00-mpm.conf
missing c /etc/httpd/conf.modules.d/00-optional.conf
missing c /etc/httpd/conf.modules.d/00-proxy.conf
missing c /etc/httpd/conf.modules.d/00-systemd.conf
missing c /etc/httpd/conf.modules.d/01-cgi.conf
missing /etc/httpd/conf.modules.d/README
missing /usr/lib/python3.11/site-packages/pycparser
missing /usr/lib/python3.11/site-packages/pycparser-2.21-py3.11.egg-info
missing /usr/lib/python3.11/site-packages/pycparser-2.21-py3.11.egg-info/PKG-INFO
missing /usr/lib/python3.11/site-packages/pycparser-2.21-py3.11.egg-info/SOURCES.txt
missing /usr/lib/python3.11/site-packages/pycparser-2.21-py3.11.egg-info/dependency_links.txt
missing /usr/lib/python3.11/site-packages/pycparser-2.21-py3.11.egg-info/top_level.txt
missing /usr/lib/python3.11/site-packages/pycparser/__init__.py
missing /usr/lib/python3.11/site-packages/pycparser/__pycache__
missing /usr/lib/python3.11/site-packages/pycparser/__pycache__/__init__.cpython-311.opt-1.pyc
missing /usr/lib/python3.11/site-packages/pycparser/__pycache__/__init__.cpython-311.pyc
missing /usr/lib/python3.11/site-packages/pycparser/__pycache__/_ast_gen.cpython-311.opt-1.pyc
missing /usr/lib/python3.11/site-packages/pycparser/__pycache__/_ast_gen.cpython-311.pyc
missing /usr/lib/python3.11/site-packages/pycparser/__pycache__/_build_tables.cpython-311.opt-1.pyc
missing /usr/lib/python3.11/site-packages/pycparser/__pycache__/_build_tables.cpython-311.pyc
missing /usr/lib/python3.11/site-packages/pycparser/__pycache__/ast_transforms.cpython-311.opt-1.pyc
missing /usr/lib/python3.11/site-packages/pycparser/__pycache__/ast_transforms.cpython-311.pyc
missing /usr/lib/python3.11/site-packages/pycparser/__pycache__/c_ast.cpython-311.opt-1.pyc
missing /usr/lib/python3.11/site-packages/pycparser/__pycache__/c_ast.cpython-311.pyc
missing /usr/lib/python3.11/site-packages/pycparser/__pycache__/c_generator.cpython-311.opt-1.pyc
missing /usr/lib/python3.11/site-packages/pycparser/__pycache__/c_generator.cpython-311.pyc
missing /usr/lib/python3.11/site-packages/pycparser/__pycache__/c_lexer.cpython-311.opt-1.pyc
missing /usr/lib/python3.11/site-packages/pycparser/__pycache__/c_lexer.cpython-311.pyc
missing /usr/lib/python3.11/site-packages/pycparser/__pycache__/c_parser.cpython-311.opt-1.pyc
missing /usr/lib/python3.11/site-packages/pycparser/__pycache__/c_parser.cpython-311.pyc
missing /usr/lib/python3.11/site-packages/pycparser/__pycache__/lextab.cpython-311.opt-1.pyc
missing /usr/lib/python3.11/site-packages/pycparser/__pycache__/lextab.cpython-311.pyc
missing /usr/lib/python3.11/site-packages/pycparser/__pycache__/plyparser.cpython-311.opt-1.pyc
missing /usr/lib/python3.11/site-packages/pycparser/__pycache__/plyparser.cpython-311.pyc
missing /usr/lib/python3.11/site-packages/pycparser/__pycache__/yacctab.cpython-311.opt-1.pyc
missing /usr/lib/python3.11/site-packages/pycparser/__pycache__/yacctab.cpython-311.pyc
missing /usr/lib/python3.11/site-packages/pycparser/_ast_gen.py
missing /usr/lib/python3.11/site-packages/pycparser/_build_tables.py
missing /usr/lib/python3.11/site-packages/pycparser/_c_ast.cfg
missing /usr/lib/python3.11/site-packages/pycparser/ast_transforms.py
missing /usr/lib/python3.11/site-packages/pycparser/c_ast.py
missing /usr/lib/python3.11/site-packages/pycparser/c_generator.py
missing /usr/lib/python3.11/site-packages/pycparser/c_lexer.py
missing /usr/lib/python3.11/site-packages/pycparser/c_parser.py
missing /usr/lib/python3.11/site-packages/pycparser/lextab.py
missing /usr/lib/python3.11/site-packages/pycparser/ply
missing /usr/lib/python3.11/site-packages/pycparser/ply/__init__.py
missing /usr/lib/python3.11/site-packages/pycparser/ply/__pycache__
missing /usr/lib/python3.11/site-packages/pycparser/ply/__pycache__/__init__.cpython-311.opt-1.pyc
missing /usr/lib/python3.11/site-packages/pycparser/ply/__pycache__/__init__.cpython-311.pyc
missing /usr/lib/python3.11/site-packages/pycparser/ply/__pycache__/cpp.cpython-311.opt-1.pyc
missing /usr/lib/python3.11/site-packages/pycparser/ply/__pycache__/cpp.cpython-311.pyc
missing /usr/lib/python3.11/site-packages/pycparser/ply/__pycache__/ctokens.cpython-311.opt-1.pyc
missing /usr/lib/python3.11/site-packages/pycparser/ply/__pycache__/ctokens.cpython-311.pyc
missing /usr/lib/python3.11/site-packages/pycparser/ply/__pycache__/lex.cpython-311.opt-1.pyc
missing /usr/lib/python3.11/site-packages/pycparser/ply/__pycache__/lex.cpython-311.pyc
missing /usr/lib/python3.11/site-packages/pycparser/ply/__pycache__/yacc.cpython-311.opt-1.pyc
missing /usr/lib/python3.11/site-packages/pycparser/ply/__pycache__/yacc.cpython-311.pyc
missing /usr/lib/python3.11/site-packages/pycparser/ply/__pycache__/ygen.cpython-311.opt-1.pyc
missing /usr/lib/python3.11/site-packages/pycparser/ply/__pycache__/ygen.cpython-311.pyc
missing /usr/lib/python3.11/site-packages/pycparser/ply/cpp.py
missing /usr/lib/python3.11/site-packages/pycparser/ply/ctokens.py
missing /usr/lib/python3.11/site-packages/pycparser/ply/lex.py
missing /usr/lib/python3.11/site-packages/pycparser/ply/yacc.py
missing /usr/lib/python3.11/site-packages/pycparser/ply/ygen.py
missing /usr/lib/python3.11/site-packages/pycparser/plyparser.py
missing /usr/lib/python3.11/site-packages/pycparser/yacctab.py
missing /usr/bin/gunicorn
missing /usr/lib/python3.11/site-packages/OpenSSL
missing /usr/lib/python3.11/site-packages/OpenSSL/SSL.py
missing /usr/lib/python3.11/site-packages/OpenSSL/__init__.py
missing /usr/lib/python3.11/site-packages/OpenSSL/__pycache__
missing /usr/lib/python3.11/site-packages/OpenSSL/__pycache__/SSL.cpython-311.opt-1.pyc
missing /usr/lib/python3.11/site-packages/OpenSSL/__pycache__/SSL.cpython-311.pyc
missing /usr/lib/python3.11/site-packages/OpenSSL/__pycache__/__init__.cpython-311.opt-1.pyc
missing /usr/lib/python3.11/site-packages/OpenSSL/__pycache__/__init__.cpython-311.pyc
missing /usr/lib/python3.11/site-packages/OpenSSL/__pycache__/_util.cpython-311.opt-1.pyc
missing /usr/lib/python3.11/site-packages/OpenSSL/__pycache__/_util.cpython-311.pyc
missing /usr/lib/python3.11/site-packages/OpenSSL/__pycache__/crypto.cpython-311.opt-1.pyc
missing /usr/lib/python3.11/site-packages/OpenSSL/__pycache__/crypto.cpython-311.pyc
missing /usr/lib/python3.11/site-packages/OpenSSL/__pycache__/debug.cpython-311.opt-1.pyc
missing /usr/lib/python3.11/site-packages/OpenSSL/__pycache__/debug.cpython-311.pyc
missing /usr/lib/python3.11/site-packages/OpenSSL/__pycache__/rand.cpython-311.opt-1.pyc
missing /usr/lib/python3.11/site-packages/OpenSSL/__pycache__/rand.cpython-311.pyc
missing /usr/lib/python3.11/site-packages/OpenSSL/__pycache__/version.cpython-311.opt-1.pyc
missing /usr/lib/python3.11/site-packages/OpenSSL/__pycache__/version.cpython-311.pyc
missing /usr/lib/python3.11/site-packages/OpenSSL/_util.py
missing /usr/lib/python3.11/site-packages/OpenSSL/crypto.py
missing /usr/lib/python3.11/site-packages/OpenSSL/debug.py
missing /usr/lib/python3.11/site-packages/OpenSSL/rand.py
missing /usr/lib/python3.11/site-packages/OpenSSL/version.py
missing /usr/lib/python3.11/site-packages/pyOpenSSL-24.1.0-py3.11.egg-info
missing /usr/lib/python3.11/site-packages/pyOpenSSL-24.1.0-py3.11.egg-info/PKG-INFO
missing /usr/lib/python3.11/site-packages/pyOpenSSL-24.1.0-py3.11.egg-info/SOURCES.txt
missing /usr/lib/python3.11/site-packages/pyOpenSSL-24.1.0-py3.11.egg-info/dependency_links.txt
missing /usr/lib/python3.11/site-packages/pyOpenSSL-24.1.0-py3.11.egg-info/requires.txt
missing /usr/lib/python3.11/site-packages/pyOpenSSL-24.1.0-py3.11.egg-info/top_level.txt
missing /etc/httpd/conf.d/README
missing /usr/lib/python3.11/site-packages/_distutils_hack/__init__.py
missing /usr/lib/python3.11/site-packages/_distutils_hack/__pycache__/__init__.cpython-311.pyc
missing /usr/lib/python3.11/site-packages/_distutils_hack/__pycache__/override.cpython-311.pyc
missing /usr/lib/python3.11/site-packages/_distutils_hack/override.py
missing /usr/lib/python3.11/site-packages/distutils-precedence.pth
missing /usr/lib/python3.11/site-packages/pkg_resources/__init__.py
missing /usr/lib/python3.11/site-packages/pkg_resources/__pycache__/__init__.cpython-311.pyc
missing /usr/lib/python3.11/site-packages/pkg_resources/_vendor/__init__.py
missing /usr/lib/python3.11/site-packages/pkg_resources/_vendor/__pycache__/__init__.cpython-311.pyc
missing /usr/lib/python3.11/site-packages/pkg_resources/_vendor/__pycache__/appdirs.cpython-311.pyc
missing /usr/lib/python3.11/site-packages/pkg_resources/_vendor/__pycache__/zipp.cpython-311.pyc
missing /usr/lib/python3.11/site-packages/pkg_resources/_vendor/appdirs.py
missing /usr/lib/python3.11/site-packages/pkg_resources/_vendor/importlib_resources/__init__.py
missing /usr/lib/python3.11/site-packages/pkg_resources/_vendor/importlib_resources/__pycache__/__init__.cpython-311.pyc
missing /usr/lib/python3.11/site-packages/pkg_resources/_vendor/importlib_resources/__pycache__/_adapters.cpython-311.pyc
missing /usr/lib/python3.11/site-packages/pkg_resources/_vendor/importlib_resources/__pycache__/_common.cpython-311.pyc
missing /usr/lib/python3.11/site-packages/pkg_resources/_vendor/importlib_resources/__pycache__/_compat.cpython-311.pyc
missing /usr/lib/python3.11/site-packages/pkg_resources/_vendor/importlib_resources/__pycache__/_itertools.cpython-311.pyc
missing /usr/lib/python3.11/site-packages/pkg_resources/_vendor/importlib_resources/__pycache__/_legacy.cpython-311.pyc
missing /usr/lib/python3.11/site-packages/pkg_resources/_vendor/importlib_resources/__pycache__/abc.cpython-311.pyc
missing /usr/lib/python3.11/site-packages/pkg_resources/_vendor/importlib_resources/__pycache__/readers.cpython-311.pyc
missing /usr/lib/python3.11/site-packages/pkg_resources/_vendor/importlib_resources/__pycache__/simple.cpython-311.pyc
missing /usr/lib/python3.11/site-packages/pkg_resources/_vendor/importlib_resources/_adapters.py
missing /usr/lib/python3.11/site-packages/pkg_resources/_vendor/importlib_resources/_common.py
missing /usr/lib/python3.11/site-packages/pkg_resources/_vendor/importlib_resources/_compat.py
missing /usr/lib/python3.11/site-packages/pkg_resources/_vendor/importlib_resources/_itertools.py
missing /usr/lib/python3.11/site-packages/pkg_resources/_vendor/importlib_resources/_legacy.py
missing /usr/lib/python3.11/site-packages/pkg_resources/_vendor/importlib_resources/abc.py
missing /usr/lib/python3.11/site-packages/pkg_resources/_vendor/importlib_resources/readers.py
missing /usr/lib/python3.11/site-packages/pkg_resources/_vendor/importlib_resources/simple.py
missing /usr/lib/python3.11/site-packages/pkg_resources/_vendor/jaraco/__init__.py
missing /usr/lib/python3.11/site-packages/pkg_resources/_vendor/jaraco/__pycache__/__init__.cpython-311.pyc
missing /usr/lib/python3.11/site-packages/pkg_resources/_vendor/jaraco/__pycache__/context.cpython-311.pyc
missing /usr/lib/python3.11/site-packages/pkg_resources/_vendor/jaraco/__pycache__/functools.cpython-311.pyc
missing /usr/lib/python3.11/site-packages/pkg_resources/_vendor/jaraco/context.py
missing /usr/lib/python3.11/site-packages/pkg_resources/_vendor/jaraco/functools.py
missing /usr/lib/python3.11/site-packages/pkg_resources/_vendor/jaraco/text/__init__.py
missing /usr/lib/python3.11/site-packages/pkg_resources/_vendor/jaraco/text/__pycache__/__init__.cpython-311.pyc
missing /usr/lib/python3.11/site-packages/pkg_resources/_vendor/more_itertools/__init__.py
missing /usr/lib/python3.11/site-packages/pkg_resources/_vendor/more_itertools/__pycache__/__init__.cpython-311.pyc
missing /usr/lib/python3.11/site-packages/pkg_resources/_vendor/more_itertools/__pycache__/more.cpython-311.pyc
missing /usr/lib/python3.11/site-packages/pkg_resources/_vendor/more_itertools/__pycache__/recipes.cpython-311.pyc
missing /usr/lib/python3.11/site-packages/pkg_resources/_vendor/more_itertools/more.py
missing /usr/lib/python3.11/site-packages/pkg_resources/_vendor/more_itertools/recipes.py
missing /usr/lib/python3.11/site-packages/pkg_resources/_vendor/packaging/__about__.py
missing /usr/lib/python3.11/site-packages/pkg_resources/_vendor/packaging/__init__.py
missing /usr/lib/python3.11/site-packages/pkg_resources/_vendor/packaging/__pycache__/__about__.cpython-311.pyc
missing /usr/lib/python3.11/site-packages/pkg_resources/_vendor/packaging/__pycache__/__init__.cpython-311.pyc
missing /usr/lib/python3.11/site-packages/pkg_resources/_vendor/packaging/__pycache__/_manylinux.cpython-311.pyc
missing /usr/lib/python3.11/site-packages/pkg_resources/_vendor/packaging/__pycache__/_musllinux.cpython-311.pyc
missing /usr/lib/python3.11/site-packages/pkg_resources/_vendor/packaging/__pycache__/_structures.cpython-311.pyc
missing /usr/lib/python3.11/site-packages/pkg_resources/_vendor/packaging/__pycache__/markers.cpython-311.pyc
missing /usr/lib/python3.11/site-packages/pkg_resources/_vendor/packaging/__pycache__/requirements.cpython-311.pyc
missing /usr/lib/python3.11/site-packages/pkg_resources/_vendor/packaging/__pycache__/specifiers.cpython-311.pyc
missing /usr/lib/python3.11/site-packages/pkg_resources/_vendor/packaging/__pycache__/tags.cpython-311.pyc
missing /usr/lib/python3.11/site-packages/pkg_resources/_vendor/packaging/__pycache__/utils.cpython-311.pyc
missing /usr/lib/python3.11/site-packages/pkg_resources/_vendor/packaging/__pycache__/version.cpython-311.pyc
missing /usr/lib/python3.11/site-packages/pkg_resources/_vendor/packaging/_manylinux.py
missing /usr/lib/python3.11/site-packages/pkg_resources/_vendor/packaging/_musllinux.py
missing /usr/lib/python3.11/site-packages/pkg_resources/_vendor/packaging/_structures.py
missing /usr/lib/python3.11/site-packages/pkg_resources/_vendor/packaging/markers.py
missing /usr/lib/python3.11/site-packages/pkg_resources/_vendor/packaging/requirements.py
missing /usr/lib/python3.11/site-packages/pkg_resources/_vendor/packaging/specifiers.py
missing /usr/lib/python3.11/site-packages/pkg_resources/_vendor/packaging/tags.py
missing /usr/lib/python3.11/site-packages/pkg_resources/_vendor/packaging/utils.py
missing /usr/lib/python3.11/site-packages/pkg_resources/_vendor/packaging/version.py
missing /usr/lib/python3.11/site-packages/pkg_resources/_vendor/pyparsing/__init__.py
missing /usr/lib/python3.11/site-packages/pkg_resources/_vendor/pyparsing/__pycache__/__init__.cpython-311.pyc
missing /usr/lib/python3.11/site-packages/pkg_resources/_vendor/pyparsing/__pycache__/actions.cpython-311.pyc
missing /usr/lib/python3.11/site-packages/pkg_resources/_vendor/pyparsing/__pycache__/common.cpython-311.pyc
missing /usr/lib/python3.11/site-packages/pkg_resources/_vendor/pyparsing/__pycache__/core.cpython-311.pyc
missing /usr/lib/python3.11/site-packages/pkg_resources/_vendor/pyparsing/__pycache__/exceptions.cpython-311.pyc
missing /usr/lib/python3.11/site-packages/pkg_resources/_vendor/pyparsing/__pycache__/helpers.cpython-311.pyc
missing /usr/lib/python3.11/site-packages/pkg_resources/_vendor/pyparsing/__pycache__/results.cpython-311.pyc
missing /usr/lib/python3.11/site-packages/pkg_resources/_vendor/pyparsing/__pycache__/testing.cpython-311.pyc
missing /usr/lib/python3.11/site-packages/pkg_resources/_vendor/pyparsing/__pycache__/unicode.cpython-311.pyc
missing /usr/lib/python3.11/site-packages/pkg_resources/_vendor/pyparsing/__pycache__/util.cpython-311.pyc
missing /usr/lib/python3.11/site-packages/pkg_resources/_vendor/pyparsing/actions.py
missing /usr/lib/python3.11/site-packages/pkg_resources/_vendor/pyparsing/common.py
missing /usr/lib/python3.11/site-packages/pkg_resources/_vendor/pyparsing/core.py
missing /usr/lib/python3.11/site-packages/pkg_resources/_vendor/pyparsing/diagram/__init__.py
missing /usr/lib/python3.11/site-packages/pkg_resources/_vendor/pyparsing/diagram/__pycache__/__init__.cpython-311.pyc
missing /usr/lib/python3.11/site-packages/pkg_resources/_vendor/pyparsing/exceptions.py
missing /usr/lib/python3.11/site-packages/pkg_resources/_vendor/pyparsing/helpers.py
missing /usr/lib/python3.11/site-packages/pkg_resources/_vendor/pyparsing/results.py
missing /usr/lib/python3.11/site-packages/pkg_resources/_vendor/pyparsing/testing.py
missing /usr/lib/python3.11/site-packages/pkg_resources/_vendor/pyparsing/unicode.py
missing /usr/lib/python3.11/site-packages/pkg_resources/_vendor/pyparsing/util.py
missing /usr/lib/python3.11/site-packages/pkg_resources/_vendor/zipp.py
missing /usr/lib/python3.11/site-packages/pkg_resources/extern/__init__.py
missing /usr/lib/python3.11/site-packages/pkg_resources/extern/__pycache__/__init__.cpython-311.pyc
missing /usr/lib/python3.11/site-packages/setuptools-65.5.1.dist-info
missing /usr/lib/python3.11/site-packages/setuptools-65.5.1.dist-info/INSTALLER
missing /usr/lib/python3.11/site-packages/setuptools-65.5.1.dist-info/LICENSE
missing /usr/lib/python3.11/site-packages/setuptools-65.5.1.dist-info/METADATA
missing /usr/lib/python3.11/site-packages/setuptools-65.5.1.dist-info/RECORD
missing /usr/lib/python3.11/site-packages/setuptools-65.5.1.dist-info/REQUESTED
missing /usr/lib/python3.11/site-packages/setuptools-65.5.1.dist-info/WHEEL
missing /usr/lib/python3.11/site-packages/setuptools-65.5.1.dist-info/entry_points.txt
missing /usr/lib/python3.11/site-packages/setuptools-65.5.1.dist-info/top_level.txt
missing /usr/lib/python3.11/site-packages/setuptools/__init__.py
missing /usr/lib/python3.11/site-packages/setuptools/__pycache__/__init__.cpython-311.pyc
missing /usr/lib/python3.11/site-packages/setuptools/__pycache__/_deprecation_warning.cpython-311.pyc
missing /usr/lib/python3.11/site-packages/setuptools/__pycache__/_entry_points.cpython-311.pyc
missing /usr/lib/python3.11/site-packages/setuptools/__pycache__/_imp.cpython-311.pyc
missing /usr/lib/python3.11/site-packages/setuptools/__pycache__/_importlib.cpython-311.pyc
missing /usr/lib/python3.11/site-packages/setuptools/__pycache__/_itertools.cpython-311.pyc
missing /usr/lib/python3.11/site-packages/setuptools/__pycache__/_path.cpython-311.pyc
missing /usr/lib/python3.11/site-packages/setuptools/__pycache__/_reqs.cpython-311.pyc
missing /usr/lib/python3.11/site-packages/setuptools/__pycache__/archive_util.cpython-311.pyc
missing /usr/lib/python3.11/site-packages/setuptools/__pycache__/build_meta.cpython-311.pyc
missing /usr/lib/python3.11/site-packages/setuptools/__pycache__/dep_util.cpython-311.pyc
missing /usr/lib/python3.11/site-packages/setuptools/__pycache__/depends.cpython-311.pyc
missing /usr/lib/python3.11/site-packages/setuptools/__pycache__/discovery.cpython-311.pyc
missing /usr/lib/python3.11/site-packages/setuptools/__pycache__/dist.cpython-311.pyc
missing /usr/lib/python3.11/site-packages/setuptools/__pycache__/errors.cpython-311.pyc
missing /usr/lib/python3.11/site-packages/setuptools/__pycache__/extension.cpython-311.pyc
missing /usr/lib/python3.11/site-packages/setuptools/__pycache__/glob.cpython-311.pyc
missing /usr/lib/python3.11/site-packages/setuptools/__pycache__/installer.cpython-311.pyc
missing /usr/lib/python3.11/site-packages/setuptools/__pycache__/launch.cpython-311.pyc
missing /usr/lib/python3.11/site-packages/setuptools/__pycache__/logging.cpython-311.pyc
missing /usr/lib/python3.11/site-packages/setuptools/__pycache__/monkey.cpython-311.pyc
missing /usr/lib/python3.11/site-packages/setuptools/__pycache__/msvc.cpython-311.pyc
missing /usr/lib/python3.11/site-packages/setuptools/__pycache__/namespaces.cpython-311.pyc
missing /usr/lib/python3.11/site-packages/setuptools/__pycache__/package_index.cpython-311.pyc
missing /usr/lib/python3.11/site-packages/setuptools/__pycache__/py34compat.cpython-311.pyc
missing /usr/lib/python3.11/site-packages/setuptools/__pycache__/sandbox.cpython-311.pyc
missing /usr/lib/python3.11/site-packages/setuptools/__pycache__/unicode_utils.cpython-311.pyc
missing /usr/lib/python3.11/site-packages/setuptools/__pycache__/version.cpython-311.pyc
missing /usr/lib/python3.11/site-packages/setuptools/__pycache__/wheel.cpython-311.pyc
missing /usr/lib/python3.11/site-packages/setuptools/__pycache__/windows_support.cpython-311.pyc
missing /usr/lib/python3.11/site-packages/setuptools/_deprecation_warning.py
missing /usr/lib/python3.11/site-packages/setuptools/_distutils/__init__.py
missing /usr/lib/python3.11/site-packages/setuptools/_distutils/__pycache__/__init__.cpython-311.pyc
missing /usr/lib/python3.11/site-packages/setuptools/_distutils/__pycache__/_collections.cpython-311.pyc
missing /usr/lib/python3.11/site-packages/setuptools/_distutils/__pycache__/_functools.cpython-311.pyc
missing /usr/lib/python3.11/site-packages/setuptools/_distutils/__pycache__/_macos_compat.cpython-311.pyc
missing /usr/lib/python3.11/site-packages/setuptools/_distutils/__pycache__/_msvccompiler.cpython-311.pyc
missing /usr/lib/python3.11/site-packages/setuptools/_distutils/__pycache__/archive_util.cpython-311.pyc
missing /usr/lib/python3.11/site-packages/setuptools/_distutils/__pycache__/bcppcompiler.cpython-311.pyc
missing /usr/lib/python3.11/site-packages/setuptools/_distutils/__pycache__/ccompiler.cpython-311.pyc
missing /usr/lib/python3.11/site-packages/setuptools/_distutils/__pycache__/cmd.cpython-311.pyc
missing /usr/lib/python3.11/site-packages/setuptools/_distutils/__pycache__/config.cpython-311.pyc
missing /usr/lib/python3.11/site-packages/setuptools/_distutils/__pycache__/core.cpython-311.pyc
missing /usr/lib/python3.11/site-packages/setuptools/_distutils/__pycache__/cygwinccompiler.cpython-311.pyc
missing /usr/lib/python3.11/site-packages/setuptools/_distutils/__pycache__/debug.cpython-311.pyc
missing /usr/lib/python3.11/site-packages/setuptools/_distutils/__pycache__/dep_util.cpython-311.pyc
missing /usr/lib/python3.11/site-packages/setuptools/_distutils/__pycache__/dir_util.cpython-311.pyc
missing /usr/lib/python3.11/site-packages/setuptools/_distutils/__pycache__/dist.cpython-311.pyc
missing /usr/lib/python3.11/site-packages/setuptools/_distutils/__pycache__/errors.cpython-311.pyc
missing /usr/lib/python3.11/site-packages/setuptools/_distutils/__pycache__/extension.cpython-311.pyc
missing /usr/lib/python3.11/site-packages/setuptools/_distutils/__pycache__/fancy_getopt.cpython-311.pyc
missing /usr/lib/python3.11/site-packages/setuptools/_distutils/__pycache__/file_util.cpython-311.pyc
missing /usr/lib/python3.11/site-packages/setuptools/_distutils/__pycache__/filelist.cpython-311.pyc
missing /usr/lib/python3.11/site-packages/setuptools/_distutils/__pycache__/log.cpython-311.pyc
missing /usr/lib/python3.11/site-packages/setuptools/_distutils/__pycache__/msvc9compiler.cpython-311.pyc
missing /usr/lib/python3.11/site-packages/setuptools/_distutils/__pycache__/msvccompiler.cpython-311.pyc
missing /usr/lib/python3.11/site-packages/setuptools/_distutils/__pycache__/py38compat.cpython-311.pyc
missing /usr/lib/python3.11/site-packages/setuptools/_distutils/__pycache__/py39compat.cpython-311.pyc
missing /usr/lib/python3.11/site-packages/setuptools/_distutils/__pycache__/spawn.cpython-311.pyc
missing /usr/lib/python3.11/site-packages/setuptools/_distutils/__pycache__/sysconfig.cpython-311.pyc
missing /usr/lib/python3.11/site-packages/setuptools/_distutils/__pycache__/text_file.cpython-311.pyc
missing /usr/lib/python3.11/site-packages/setuptools/_distutils/__pycache__/unixccompiler.cpython-311.pyc
missing /usr/lib/python3.11/site-packages/setuptools/_distutils/__pycache__/util.cpython-311.pyc
missing /usr/lib/python3.11/site-packages/setuptools/_distutils/__pycache__/version.cpython-311.pyc
missing /usr/lib/python3.11/site-packages/setuptools/_distutils/__pycache__/versionpredicate.cpython-311.pyc
missing /usr/lib/python3.11/site-packages/setuptools/_distutils/_collections.py
missing /usr/lib/python3.11/site-packages/setuptools/_distutils/_functools.py
missing /usr/lib/python3.11/site-packages/setuptools/_distutils/_macos_compat.py
missing /usr/lib/python3.11/site-packages/setuptools/_distutils/_msvccompiler.py
missing /usr/lib/python3.11/site-packages/setuptools/_distutils/archive_util.py
missing /usr/lib/python3.11/site-packages/setuptools/_distutils/bcppcompiler.py
missing /usr/lib/python3.11/site-packages/setuptools/_distutils/ccompiler.py
missing /usr/lib/python3.11/site-packages/setuptools/_distutils/cmd.py
missing /usr/lib/python3.11/site-packages/setuptools/_distutils/command/__init__.py
missing /usr/lib/python3.11/site-packages/setuptools/_distutils/command/__pycache__/__init__.cpython-311.pyc
missing /usr/lib/python3.11/site-packages/setuptools/_distutils/command/__pycache__/_framework_compat.cpython-311.pyc
missing /usr/lib/python3.11/site-packages/setuptools/_distutils/command/__pycache__/bdist.cpython-311.pyc
missing /usr/lib/python3.11/site-packages/setuptools/_distutils/command/__pycache__/bdist_dumb.cpython-311.pyc
missing /usr/lib/python3.11/site-packages/setuptools/_distutils/command/__pycache__/bdist_rpm.cpython-311.pyc
missing /usr/lib/python3.11/site-packages/setuptools/_distutils/command/__pycache__/build.cpython-311.pyc
missing /usr/lib/python3.11/site-packages/setuptools/_distutils/command/__pycache__/build_clib.cpython-311.pyc
missing /usr/lib/python3.11/site-packages/setuptools/_distutils/command/__pycache__/build_ext.cpython-311.pyc
missing /usr/lib/python3.11/site-packages/setuptools/_distutils/command/__pycache__/build_py.cpython-311.pyc
missing /usr/lib/python3.11/site-packages/setuptools/_distutils/command/__pycache__/build_scripts.cpython-311.pyc
missing /usr/lib/python3.11/site-packages/setuptools/_distutils/command/__pycache__/check.cpython-311.pyc
missing /usr/lib/python3.11/site-packages/setuptools/_distutils/command/__pycache__/clean.cpython-311.pyc
missing /usr/lib/python3.11/site-packages/setuptools/_distutils/command/__pycache__/config.cpython-311.pyc
missing /usr/lib/python3.11/site-packages/setuptools/_distutils/command/__pycache__/install.cpython-311.pyc
missing /usr/lib/python3.11/site-packages/setuptools/_distutils/command/__pycache__/install_data.cpython-311.pyc
missing /usr/lib/python3.11/site-packages/setuptools/_distutils/command/__pycache__/install_egg_info.cpython-311.pyc
missing /usr/lib/python3.11/site-packages/setuptools/_distutils/command/__pycache__/install_headers.cpython-311.pyc
missing /usr/lib/python3.11/site-packages/setuptools/_distutils/command/__pycache__/install_lib.cpython-311.pyc
missing /usr/lib/python3.11/site-packages/setuptools/_distutils/command/__pycache__/install_scripts.cpython-311.pyc
missing /usr/lib/python3.11/site-packages/setuptools/_distutils/command/__pycache__/py37compat.cpython-311.pyc
missing /usr/lib/python3.11/site-packages/setuptools/_distutils/command/__pycache__/register.cpython-311.pyc
missing /usr/lib/python3.11/site-packages/setuptools/_distutils/command/__pycache__/sdist.cpython-311.pyc
missing /usr/lib/python3.11/site-packages/setuptools/_distutils/command/__pycache__/upload.cpython-311.pyc
missing /usr/lib/python3.11/site-packages/setuptools/_distutils/command/_framework_compat.py
missing /usr/lib/python3.11/site-packages/setuptools/_distutils/command/bdist.py
missing /usr/lib/python3.11/site-packages/setuptools/_distutils/command/bdist_dumb.py
missing /usr/lib/python3.11/site-packages/setuptools/_distutils/command/bdist_rpm.py
missing /usr/lib/python3.11/site-packages/setuptools/_distutils/command/build.py
missing /usr/lib/python3.11/site-packages/setuptools/_distutils/command/build_clib.py
missing /usr/lib/python3.11/site-packages/setuptools/_distutils/command/build_ext.py
missing /usr/lib/python3.11/site-packages/setuptools/_distutils/command/build_py.py
missing /usr/lib/python3.11/site-packages/setuptools/_distutils/command/build_scripts.py
missing /usr/lib/python3.11/site-packages/setuptools/_distutils/command/check.py
missing /usr/lib/python3.11/site-packages/setuptools/_distutils/command/clean.py
missing /usr/lib/python3.11/site-packages/setuptools/_distutils/command/config.py
missing /usr/lib/python3.11/site-packages/setuptools/_distutils/command/install.py
missing /usr/lib/python3.11/site-packages/setuptools/_distutils/command/install_data.py
missing /usr/lib/python3.11/site-packages/setuptools/_distutils/command/install_egg_info.py
missing /usr/lib/python3.11/site-packages/setuptools/_distutils/command/install_headers.py
missing /usr/lib/python3.11/site-packages/setuptools/_distutils/command/install_lib.py
missing /usr/lib/python3.11/site-packages/setuptools/_distutils/command/install_scripts.py
missing /usr/lib/python3.11/site-packages/setuptools/_distutils/command/py37compat.py
missing /usr/lib/python3.11/site-packages/setuptools/_distutils/command/register.py
missing /usr/lib/python3.11/site-packages/setuptools/_distutils/command/sdist.py
missing /usr/lib/python3.11/site-packages/setuptools/_distutils/command/upload.py
missing /usr/lib/python3.11/site-packages/setuptools/_distutils/config.py
missing /usr/lib/python3.11/site-packages/setuptools/_distutils/core.py
missing /usr/lib/python3.11/site-packages/setuptools/_distutils/cygwinccompiler.py
missing /usr/lib/python3.11/site-packages/setuptools/_distutils/debug.py
missing /usr/lib/python3.11/site-packages/setuptools/_distutils/dep_util.py
missing /usr/lib/python3.11/site-packages/setuptools/_distutils/dir_util.py
missing /usr/lib/python3.11/site-packages/setuptools/_distutils/dist.py
missing /usr/lib/python3.11/site-packages/setuptools/_distutils/errors.py
missing /usr/lib/python3.11/site-packages/setuptools/_distutils/extension.py
missing /usr/lib/python3.11/site-packages/setuptools/_distutils/fancy_getopt.py
missing /usr/lib/python3.11/site-packages/setuptools/_distutils/file_util.py
missing /usr/lib/python3.11/site-packages/setuptools/_distutils/filelist.py
missing /usr/lib/python3.11/site-packages/setuptools/_distutils/log.py
missing /usr/lib/python3.11/site-packages/setuptools/_distutils/msvc9compiler.py
missing /usr/lib/python3.11/site-packages/setuptools/_distutils/msvccompiler.py
missing /usr/lib/python3.11/site-packages/setuptools/_distutils/py38compat.py
missing /usr/lib/python3.11/site-packages/setuptools/_distutils/py39compat.py
missing /usr/lib/python3.11/site-packages/setuptools/_distutils/spawn.py
missing /usr/lib/python3.11/site-packages/setuptools/_distutils/sysconfig.py
missing /usr/lib/python3.11/site-packages/setuptools/_distutils/text_file.py
missing /usr/lib/python3.11/site-packages/setuptools/_distutils/unixccompiler.py
missing /usr/lib/python3.11/site-packages/setuptools/_distutils/util.py
missing /usr/lib/python3.11/site-packages/setuptools/_distutils/version.py
missing /usr/lib/python3.11/site-packages/setuptools/_distutils/versionpredicate.py
missing /usr/lib/python3.11/site-packages/setuptools/_entry_points.py
missing /usr/lib/python3.11/site-packages/setuptools/_imp.py
missing /usr/lib/python3.11/site-packages/setuptools/_importlib.py
missing /usr/lib/python3.11/site-packages/setuptools/_itertools.py
missing /usr/lib/python3.11/site-packages/setuptools/_path.py
missing /usr/lib/python3.11/site-packages/setuptools/_reqs.py
missing /usr/lib/python3.11/site-packages/setuptools/_vendor/__init__.py
missing /usr/lib/python3.11/site-packages/setuptools/_vendor/__pycache__/__init__.cpython-311.pyc
missing /usr/lib/python3.11/site-packages/setuptools/_vendor/__pycache__/ordered_set.cpython-311.pyc
missing /usr/lib/python3.11/site-packages/setuptools/_vendor/__pycache__/typing_extensions.cpython-311.pyc
missing /usr/lib/python3.11/site-packages/setuptools/_vendor/__pycache__/zipp.cpython-311.pyc
missing /usr/lib/python3.11/site-packages/setuptools/_vendor/importlib_metadata/__init__.py
missing /usr/lib/python3.11/site-packages/setuptools/_vendor/importlib_metadata/__pycache__/__init__.cpython-311.pyc
missing /usr/lib/python3.11/site-packages/setuptools/_vendor/importlib_metadata/__pycache__/_adapters.cpython-311.pyc
missing /usr/lib/python3.11/site-packages/setuptools/_vendor/importlib_metadata/__pycache__/_collections.cpython-311.pyc
missing /usr/lib/python3.11/site-packages/setuptools/_vendor/importlib_metadata/__pycache__/_compat.cpython-311.pyc
missing /usr/lib/python3.11/site-packages/setuptools/_vendor/importlib_metadata/__pycache__/_functools.cpython-311.pyc
missing /usr/lib/python3.11/site-packages/setuptools/_vendor/importlib_metadata/__pycache__/_itertools.cpython-311.pyc
missing /usr/lib/python3.11/site-packages/setuptools/_vendor/importlib_metadata/__pycache__/_meta.cpython-311.pyc
missing /usr/lib/python3.11/site-packages/setuptools/_vendor/importlib_metadata/__pycache__/_text.cpython-311.pyc
missing /usr/lib/python3.11/site-packages/setuptools/_vendor/importlib_metadata/_adapters.py
missing /usr/lib/python3.11/site-packages/setuptools/_vendor/importlib_metadata/_collections.py
missing /usr/lib/python3.11/site-packages/setuptools/_vendor/importlib_metadata/_compat.py
missing /usr/lib/python3.11/site-packages/setuptools/_vendor/importlib_metadata/_functools.py
missing /usr/lib/python3.11/site-packages/setuptools/_vendor/importlib_metadata/_itertools.py
missing /usr/lib/python3.11/site-packages/setuptools/_vendor/importlib_metadata/_meta.py
missing /usr/lib/python3.11/site-packages/setuptools/_vendor/importlib_metadata/_text.py
missing /usr/lib/python3.11/site-packages/setuptools/_vendor/importlib_resources/__init__.py
missing /usr/lib/python3.11/site-packages/setuptools/_vendor/importlib_resources/__pycache__/__init__.cpython-311.pyc
missing /usr/lib/python3.11/site-packages/setuptools/_vendor/importlib_resources/__pycache__/_adapters.cpython-311.pyc
missing /usr/lib/python3.11/site-packages/setuptools/_vendor/importlib_resources/__pycache__/_common.cpython-311.pyc
missing /usr/lib/python3.11/site-packages/setuptools/_vendor/importlib_resources/__pycache__/_compat.cpython-311.pyc
missing /usr/lib/python3.11/site-packages/setuptools/_vendor/importlib_resources/__pycache__/_itertools.cpython-311.pyc
missing /usr/lib/python3.11/site-packages/setuptools/_vendor/importlib_resources/__pycache__/_legacy.cpython-311.pyc
missing /usr/lib/python3.11/site-packages/setuptools/_vendor/importlib_resources/__pycache__/abc.cpython-311.pyc
missing /usr/lib/python3.11/site-packages/setuptools/_vendor/importlib_resources/__pycache__/readers.cpython-311.pyc
missing /usr/lib/python3.11/site-packages/setuptools/_vendor/importlib_resources/__pycache__/simple.cpython-311.pyc
missing /usr/lib/python3.11/site-packages/setuptools/_vendor/importlib_resources/_adapters.py
missing /usr/lib/python3.11/site-packages/setuptools/_vendor/importlib_resources/_common.py
missing /usr/lib/python3.11/site-packages/setuptools/_vendor/importlib_resources/_compat.py
missing /usr/lib/python3.11/site-packages/setuptools/_vendor/importlib_resources/_itertools.py
missing /usr/lib/python3.11/site-packages/setuptools/_vendor/importlib_resources/_legacy.py
missing /usr/lib/python3.11/site-packages/setuptools/_vendor/importlib_resources/abc.py
missing /usr/lib/python3.11/site-packages/setuptools/_vendor/importlib_resources/readers.py
missing /usr/lib/python3.11/site-packages/setuptools/_vendor/importlib_resources/simple.py
missing /usr/lib/python3.11/site-packages/setuptools/_vendor/jaraco/__init__.py
missing /usr/lib/python3.11/site-packages/setuptools/_vendor/jaraco/__pycache__/__init__.cpython-311.pyc
missing /usr/lib/python3.11/site-packages/setuptools/_vendor/jaraco/__pycache__/context.cpython-311.pyc
missing /usr/lib/python3.11/site-packages/setuptools/_vendor/jaraco/__pycache__/functools.cpython-311.pyc
missing /usr/lib/python3.11/site-packages/setuptools/_vendor/jaraco/context.py
missing /usr/lib/python3.11/site-packages/setuptools/_vendor/jaraco/functools.py
missing /usr/lib/python3.11/site-packages/setuptools/_vendor/jaraco/text/__init__.py
missing /usr/lib/python3.11/site-packages/setuptools/_vendor/jaraco/text/__pycache__/__init__.cpython-311.pyc
missing /usr/lib/python3.11/site-packages/setuptools/_vendor/more_itertools/__init__.py
missing /usr/lib/python3.11/site-packages/setuptools/_vendor/more_itertools/__pycache__/__init__.cpython-311.pyc
missing /usr/lib/python3.11/site-packages/setuptools/_vendor/more_itertools/__pycache__/more.cpython-311.pyc
missing /usr/lib/python3.11/site-packages/setuptools/_vendor/more_itertools/__pycache__/recipes.cpython-311.pyc
missing /usr/lib/python3.11/site-packages/setuptools/_vendor/more_itertools/more.py
missing /usr/lib/python3.11/site-packages/setuptools/_vendor/more_itertools/recipes.py
missing /usr/lib/python3.11/site-packages/setuptools/_vendor/ordered_set.py
missing /usr/lib/python3.11/site-packages/setuptools/_vendor/packaging/__about__.py
missing /usr/lib/python3.11/site-packages/setuptools/_vendor/packaging/__init__.py
missing /usr/lib/python3.11/site-packages/setuptools/_vendor/packaging/__pycache__/__about__.cpython-311.pyc
missing /usr/lib/python3.11/site-packages/setuptools/_vendor/packaging/__pycache__/__init__.cpython-311.pyc
missing /usr/lib/python3.11/site-packages/setuptools/_vendor/packaging/__pycache__/_manylinux.cpython-311.pyc
missing /usr/lib/python3.11/site-packages/setuptools/_vendor/packaging/__pycache__/_musllinux.cpython-311.pyc
missing /usr/lib/python3.11/site-packages/setuptools/_vendor/packaging/__pycache__/_structures.cpython-311.pyc
missing /usr/lib/python3.11/site-packages/setuptools/_vendor/packaging/__pycache__/markers.cpython-311.pyc
missing /usr/lib/python3.11/site-packages/setuptools/_vendor/packaging/__pycache__/requirements.cpython-311.pyc
missing /usr/lib/python3.11/site-packages/setuptools/_vendor/packaging/__pycache__/specifiers.cpython-311.pyc
missing /usr/lib/python3.11/site-packages/setuptools/_vendor/packaging/__pycache__/tags.cpython-311.pyc
missing /usr/lib/python3.11/site-packages/setuptools/_vendor/packaging/__pycache__/utils.cpython-311.pyc
missing /usr/lib/python3.11/site-packages/setuptools/_vendor/packaging/__pycache__/version.cpython-311.pyc
missing /usr/lib/python3.11/site-packages/setuptools/_vendor/packaging/_manylinux.py
missing /usr/lib/python3.11/site-packages/setuptools/_vendor/packaging/_musllinux.py
missing /usr/lib/python3.11/site-packages/setuptools/_vendor/packaging/_structures.py
missing /usr/lib/python3.11/site-packages/setuptools/_vendor/packaging/markers.py
missing /usr/lib/python3.11/site-packages/setuptools/_vendor/packaging/requirements.py
missing /usr/lib/python3.11/site-packages/setuptools/_vendor/packaging/specifiers.py
missing /usr/lib/python3.11/site-packages/setuptools/_vendor/packaging/tags.py
missing /usr/lib/python3.11/site-packages/setuptools/_vendor/packaging/utils.py
missing /usr/lib/python3.11/site-packages/setuptools/_vendor/packaging/version.py
missing /usr/lib/python3.11/site-packages/setuptools/_vendor/pyparsing/__init__.py
missing /usr/lib/python3.11/site-packages/setuptools/_vendor/pyparsing/__pycache__/__init__.cpython-311.pyc
missing /usr/lib/python3.11/site-packages/setuptools/_vendor/pyparsing/__pycache__/actions.cpython-311.pyc
missing /usr/lib/python3.11/site-packages/setuptools/_vendor/pyparsing/__pycache__/common.cpython-311.pyc
missing /usr/lib/python3.11/site-packages/setuptools/_vendor/pyparsing/__pycache__/core.cpython-311.pyc
missing /usr/lib/python3.11/site-packages/setuptools/_vendor/pyparsing/__pycache__/exceptions.cpython-311.pyc
missing /usr/lib/python3.11/site-packages/setuptools/_vendor/pyparsing/__pycache__/helpers.cpython-311.pyc
missing /usr/lib/python3.11/site-packages/setuptools/_vendor/pyparsing/__pycache__/results.cpython-311.pyc
missing /usr/lib/python3.11/site-packages/setuptools/_vendor/pyparsing/__pycache__/testing.cpython-311.pyc
missing /usr/lib/python3.11/site-packages/setuptools/_vendor/pyparsing/__pycache__/unicode.cpython-311.pyc
missing /usr/lib/python3.11/site-packages/setuptools/_vendor/pyparsing/__pycache__/util.cpython-311.pyc
missing /usr/lib/python3.11/site-packages/setuptools/_vendor/pyparsing/actions.py
missing /usr/lib/python3.11/site-packages/setuptools/_vendor/pyparsing/common.py
missing /usr/lib/python3.11/site-packages/setuptools/_vendor/pyparsing/core.py
missing /usr/lib/python3.11/site-packages/setuptools/_vendor/pyparsing/diagram/__init__.py
missing /usr/lib/python3.11/site-packages/setuptools/_vendor/pyparsing/diagram/__pycache__/__init__.cpython-311.pyc
missing /usr/lib/python3.11/site-packages/setuptools/_vendor/pyparsing/exceptions.py
missing /usr/lib/python3.11/site-packages/setuptools/_vendor/pyparsing/helpers.py
missing /usr/lib/python3.11/site-packages/setuptools/_vendor/pyparsing/results.py
missing /usr/lib/python3.11/site-packages/setuptools/_vendor/pyparsing/testing.py
missing /usr/lib/python3.11/site-packages/setuptools/_vendor/pyparsing/unicode.py
missing /usr/lib/python3.11/site-packages/setuptools/_vendor/pyparsing/util.py
missing /usr/lib/python3.11/site-packages/setuptools/_vendor/tomli/__init__.py
missing /usr/lib/python3.11/site-packages/setuptools/_vendor/tomli/__pycache__/__init__.cpython-311.pyc
missing /usr/lib/python3.11/site-packages/setuptools/_vendor/tomli/__pycache__/_parser.cpython-311.pyc
missing /usr/lib/python3.11/site-packages/setuptools/_vendor/tomli/__pycache__/_re.cpython-311.pyc
missing /usr/lib/python3.11/site-packages/setuptools/_vendor/tomli/__pycache__/_types.cpython-311.pyc
missing /usr/lib/python3.11/site-packages/setuptools/_vendor/tomli/_parser.py
missing /usr/lib/python3.11/site-packages/setuptools/_vendor/tomli/_re.py
missing /usr/lib/python3.11/site-packages/setuptools/_vendor/tomli/_types.py
missing /usr/lib/python3.11/site-packages/setuptools/_vendor/typing_extensions.py
missing /usr/lib/python3.11/site-packages/setuptools/_vendor/zipp.py
missing /usr/lib/python3.11/site-packages/setuptools/archive_util.py
missing /usr/lib/python3.11/site-packages/setuptools/build_meta.py
missing /usr/lib/python3.11/site-packages/setuptools/command/__init__.py
missing /usr/lib/python3.11/site-packages/setuptools/command/__pycache__/__init__.cpython-311.pyc
missing /usr/lib/python3.11/site-packages/setuptools/command/__pycache__/alias.cpython-311.pyc
missing /usr/lib/python3.11/site-packages/setuptools/command/__pycache__/bdist_egg.cpython-311.pyc
missing /usr/lib/python3.11/site-packages/setuptools/command/__pycache__/bdist_rpm.cpython-311.pyc
missing /usr/lib/python3.11/site-packages/setuptools/command/__pycache__/build.cpython-311.pyc
missing /usr/lib/python3.11/site-packages/setuptools/command/__pycache__/build_clib.cpython-311.pyc
missing /usr/lib/python3.11/site-packages/setuptools/command/__pycache__/build_ext.cpython-311.pyc
missing /usr/lib/python3.11/site-packages/setuptools/command/__pycache__/build_py.cpython-311.pyc
missing /usr/lib/python3.11/site-packages/setuptools/command/__pycache__/develop.cpython-311.pyc
missing /usr/lib/python3.11/site-packages/setuptools/command/__pycache__/dist_info.cpython-311.pyc
missing /usr/lib/python3.11/site-packages/setuptools/command/__pycache__/easy_install.cpython-311.pyc
missing /usr/lib/python3.11/site-packages/setuptools/command/__pycache__/editable_wheel.cpython-311.pyc
missing /usr/lib/python3.11/site-packages/setuptools/command/__pycache__/egg_info.cpython-311.pyc
missing /usr/lib/python3.11/site-packages/setuptools/command/__pycache__/install.cpython-311.pyc
missing /usr/lib/python3.11/site-packages/setuptools/command/__pycache__/install_egg_info.cpython-311.pyc
missing /usr/lib/python3.11/site-packages/setuptools/command/__pycache__/install_lib.cpython-311.pyc
missing /usr/lib/python3.11/site-packages/setuptools/command/__pycache__/install_scripts.cpython-311.pyc
missing /usr/lib/python3.11/site-packages/setuptools/command/__pycache__/py36compat.cpython-311.pyc
missing /usr/lib/python3.11/site-packages/setuptools/command/__pycache__/register.cpython-311.pyc
missing /usr/lib/python3.11/site-packages/setuptools/command/__pycache__/rotate.cpython-311.pyc
missing /usr/lib/python3.11/site-packages/setuptools/command/__pycache__/saveopts.cpython-311.pyc
missing /usr/lib/python3.11/site-packages/setuptools/command/__pycache__/sdist.cpython-311.pyc
missing /usr/lib/python3.11/site-packages/setuptools/command/__pycache__/setopt.cpython-311.pyc
missing /usr/lib/python3.11/site-packages/setuptools/command/__pycache__/test.cpython-311.pyc
missing /usr/lib/python3.11/site-packages/setuptools/command/__pycache__/upload.cpython-311.pyc
missing /usr/lib/python3.11/site-packages/setuptools/command/__pycache__/upload_docs.cpython-311.pyc
missing /usr/lib/python3.11/site-packages/setuptools/command/alias.py
missing /usr/lib/python3.11/site-packages/setuptools/command/bdist_egg.py
missing /usr/lib/python3.11/site-packages/setuptools/command/bdist_rpm.py
missing /usr/lib/python3.11/site-packages/setuptools/command/build.py
missing /usr/lib/python3.11/site-packages/setuptools/command/build_clib.py
missing /usr/lib/python3.11/site-packages/setuptools/command/build_ext.py
missing /usr/lib/python3.11/site-packages/setuptools/command/build_py.py
missing /usr/lib/python3.11/site-packages/setuptools/command/develop.py
missing /usr/lib/python3.11/site-packages/setuptools/command/dist_info.py
missing /usr/lib/python3.11/site-packages/setuptools/command/easy_install.py
missing /usr/lib/python3.11/site-packages/setuptools/command/editable_wheel.py
missing /usr/lib/python3.11/site-packages/setuptools/command/egg_info.py
missing /usr/lib/python3.11/site-packages/setuptools/command/install.py
missing /usr/lib/python3.11/site-packages/setuptools/command/install_egg_info.py
missing /usr/lib/python3.11/site-packages/setuptools/command/install_lib.py
missing /usr/lib/python3.11/site-packages/setuptools/command/install_scripts.py
missing /usr/lib/python3.11/site-packages/setuptools/command/launcher manifest.xml
missing /usr/lib/python3.11/site-packages/setuptools/command/py36compat.py
missing /usr/lib/python3.11/site-packages/setuptools/command/register.py
missing /usr/lib/python3.11/site-packages/setuptools/command/rotate.py
missing /usr/lib/python3.11/site-packages/setuptools/command/saveopts.py
missing /usr/lib/python3.11/site-packages/setuptools/command/sdist.py
missing /usr/lib/python3.11/site-packages/setuptools/command/setopt.py
missing /usr/lib/python3.11/site-packages/setuptools/command/test.py
missing /usr/lib/python3.11/site-packages/setuptools/command/upload.py
missing /usr/lib/python3.11/site-packages/setuptools/command/upload_docs.py
missing /usr/lib/python3.11/site-packages/setuptools/config/__init__.py
missing /usr/lib/python3.11/site-packages/setuptools/config/__pycache__/__init__.cpython-311.pyc
missing /usr/lib/python3.11/site-packages/setuptools/config/__pycache__/_apply_pyprojecttoml.cpython-311.pyc
missing /usr/lib/python3.11/site-packages/setuptools/config/__pycache__/expand.cpython-311.pyc
missing /usr/lib/python3.11/site-packages/setuptools/config/__pycache__/pyprojecttoml.cpython-311.pyc
missing /usr/lib/python3.11/site-packages/setuptools/config/__pycache__/setupcfg.cpython-311.pyc
missing /usr/lib/python3.11/site-packages/setuptools/config/_apply_pyprojecttoml.py
missing /usr/lib/python3.11/site-packages/setuptools/config/_validate_pyproject/__init__.py
missing /usr/lib/python3.11/site-packages/setuptools/config/_validate_pyproject/__pycache__/__init__.cpython-311.pyc
missing /usr/lib/python3.11/site-packages/setuptools/config/_validate_pyproject/__pycache__/error_reporting.cpython-311.pyc
missing /usr/lib/python3.11/site-packages/setuptools/config/_validate_pyproject/__pycache__/extra_validations.cpython-311.pyc
missing /usr/lib/python3.11/site-packages/setuptools/config/_validate_pyproject/__pycache__/fastjsonschema_exceptions.cpython-311.pyc
missing /usr/lib/python3.11/site-packages/setuptools/config/_validate_pyproject/__pycache__/fastjsonschema_validations.cpython-311.pyc
missing /usr/lib/python3.11/site-packages/setuptools/config/_validate_pyproject/__pycache__/formats.cpython-311.pyc
missing /usr/lib/python3.11/site-packages/setuptools/config/_validate_pyproject/error_reporting.py
missing /usr/lib/python3.11/site-packages/setuptools/config/_validate_pyproject/extra_validations.py
missing /usr/lib/python3.11/site-packages/setuptools/config/_validate_pyproject/fastjsonschema_exceptions.py
missing /usr/lib/python3.11/site-packages/setuptools/config/_validate_pyproject/fastjsonschema_validations.py
missing /usr/lib/python3.11/site-packages/setuptools/config/_validate_pyproject/formats.py
missing /usr/lib/python3.11/site-packages/setuptools/config/expand.py
missing /usr/lib/python3.11/site-packages/setuptools/config/pyprojecttoml.py
missing /usr/lib/python3.11/site-packages/setuptools/config/setupcfg.py
missing /usr/lib/python3.11/site-packages/setuptools/dep_util.py
missing /usr/lib/python3.11/site-packages/setuptools/depends.py
missing /usr/lib/python3.11/site-packages/setuptools/discovery.py
missing /usr/lib/python3.11/site-packages/setuptools/dist.py
missing /usr/lib/python3.11/site-packages/setuptools/errors.py
missing /usr/lib/python3.11/site-packages/setuptools/extension.py
missing /usr/lib/python3.11/site-packages/setuptools/extern/__init__.py
missing /usr/lib/python3.11/site-packages/setuptools/extern/__pycache__/__init__.cpython-311.pyc
missing /usr/lib/python3.11/site-packages/setuptools/glob.py
missing /usr/lib/python3.11/site-packages/setuptools/installer.py
missing /usr/lib/python3.11/site-packages/setuptools/launch.py
missing /usr/lib/python3.11/site-packages/setuptools/logging.py
missing /usr/lib/python3.11/site-packages/setuptools/monkey.py
missing /usr/lib/python3.11/site-packages/setuptools/msvc.py
missing /usr/lib/python3.11/site-packages/setuptools/namespaces.py
missing /usr/lib/python3.11/site-packages/setuptools/package_index.py
missing /usr/lib/python3.11/site-packages/setuptools/py34compat.py
missing /usr/lib/python3.11/site-packages/setuptools/sandbox.py
missing /usr/lib/python3.11/site-packages/setuptools/script (dev).tmpl
missing /usr/lib/python3.11/site-packages/setuptools/script.tmpl
missing /usr/lib/python3.11/site-packages/setuptools/unicode_utils.py
missing /usr/lib/python3.11/site-packages/setuptools/version.py
missing /usr/lib/python3.11/site-packages/setuptools/wheel.py
missing /usr/lib/python3.11/site-packages/setuptools/windows_support.py
missing c /etc/httpd/conf.d/ssl.conf
missing c /etc/httpd/conf.modules.d/00-ssl.conf
I would suggest to reset python3 to the default to avoid situations like the current one, unless you actually use python3.11 specifically for some other applications.
# alternatives --auto python3
should reset it to python3.6 on el8.
You should not have removed setuptools as thatâs from the system rpm. Either way, now that you have removed the overwritten files, youâll have to reinstall those RPMs which originally installed the packages:
# dnf reinstall python3.11-cffi python3.11-pycparser python3.11-pyOpenSSL python3.11-setuptools
That should restore a valid, consistent state for those packages.
As you donât see any installed pip3.9 packages for pulpcore youâll have to review the content of /usr/local to see whatâs inside there. pulpcore in /usr/local are probably remnants of a previous installation which was not properly uninstalled with pip but removed manually by deleting files.
Check with rpm and reinstall:
# rpm -qf /usr/bin/jsonschema /usr/bin/dynaconf
# dnf reinstall ...
All those expect for the python3.9 OpenSSL you have reinstalled above. Restore that, too:
# rpm -qf /usr/lib/python3.9/site-packages/OpenSSL
# dnf reinstall ...
Same here.
# rpm -qf /usr/bin/gunicorn
# dnf reinstall ...
After you have restored all that, rpm -Va output should be much shorter than and almost only consist of configuration files. Run foreman-installer again to configure the system correctly.
unfortunately even after doing that i am still seeing like
rpm -Va
S.5....T. c /etc/yum.repos.d/epel.repo
missing /usr/lib/python3.6/site-packages/__pycache__/easy_install.cpython-36.pyc
missing /usr/lib/python3.6/site-packages/easy_install.py
missing /usr/lib/python3.6/site-packages/pkg_resources/__init__.py
missing /usr/lib/python3.6/site-packages/pkg_resources/__pycache__/__init__.cpython-36.pyc
missing /usr/lib/python3.6/site-packages/pkg_resources/__pycache__/py31compat.cpython-36.pyc
missing /usr/lib/python3.6/site-packages/pkg_resources/_vendor/__init__.py
missing /usr/lib/python3.6/site-packages/pkg_resources/_vendor/__pycache__/__init__.cpython-36.pyc
missing /usr/lib/python3.6/site-packages/pkg_resources/_vendor/__pycache__/appdirs.cpython-36.pyc
missing /usr/lib/python3.6/site-packages/pkg_resources/_vendor/__pycache__/pyparsing.cpython-36.pyc
missing /usr/lib/python3.6/site-packages/pkg_resources/_vendor/__pycache__/six.cpython-36.pyc
missing /usr/lib/python3.6/site-packages/pkg_resources/_vendor/appdirs.py
missing /usr/lib/python3.6/site-packages/pkg_resources/_vendor/packaging/__about__.py
missing /usr/lib/python3.6/site-packages/pkg_resources/_vendor/packaging/__init__.py
missing /usr/lib/python3.6/site-packages/pkg_resources/_vendor/packaging/__pycache__/__about__.cpython-36.pyc
missing /usr/lib/python3.6/site-packages/pkg_resources/_vendor/packaging/__pycache__/__init__.cpython-36.pyc
missing /usr/lib/python3.6/site-packages/pkg_resources/_vendor/packaging/__pycache__/_compat.cpython-36.pyc
missing /usr/lib/python3.6/site-packages/pkg_resources/_vendor/packaging/__pycache__/_structures.cpython-36.pyc
missing /usr/lib/python3.6/site-packages/pkg_resources/_vendor/packaging/__pycache__/markers.cpython-36.pyc
missing /usr/lib/python3.6/site-packages/pkg_resources/_vendor/packaging/__pycache__/requirements.cpython-36.pyc
missing /usr/lib/python3.6/site-packages/pkg_resources/_vendor/packaging/__pycache__/specifiers.cpython-36.pyc
missing /usr/lib/python3.6/site-packages/pkg_resources/_vendor/packaging/__pycache__/utils.cpython-36.pyc
missing /usr/lib/python3.6/site-packages/pkg_resources/_vendor/packaging/__pycache__/version.cpython-36.pyc
missing /usr/lib/python3.6/site-packages/pkg_resources/_vendor/packaging/_compat.py
missing /usr/lib/python3.6/site-packages/pkg_resources/_vendor/packaging/_structures.py
missing /usr/lib/python3.6/site-packages/pkg_resources/_vendor/packaging/markers.py
missing /usr/lib/python3.6/site-packages/pkg_resources/_vendor/packaging/requirements.py
missing /usr/lib/python3.6/site-packages/pkg_resources/_vendor/packaging/specifiers.py
missing /usr/lib/python3.6/site-packages/pkg_resources/_vendor/packaging/utils.py
missing /usr/lib/python3.6/site-packages/pkg_resources/_vendor/packaging/version.py
missing /usr/lib/python3.6/site-packages/pkg_resources/_vendor/pyparsing.py
missing /usr/lib/python3.6/site-packages/pkg_resources/_vendor/six.py
missing /usr/lib/python3.6/site-packages/pkg_resources/extern/__init__.py
missing /usr/lib/python3.6/site-packages/pkg_resources/extern/__pycache__/__init__.cpython-36.pyc
missing /usr/lib/python3.6/site-packages/pkg_resources/py31compat.py
missing /usr/lib/python3.6/site-packages/setuptools-39.2.0.dist-info
missing /usr/lib/python3.6/site-packages/setuptools-39.2.0.dist-info/DESCRIPTION.rst
missing /usr/lib/python3.6/site-packages/setuptools-39.2.0.dist-info/INSTALLER
missing /usr/lib/python3.6/site-packages/setuptools-39.2.0.dist-info/LICENSE.txt
missing /usr/lib/python3.6/site-packages/setuptools-39.2.0.dist-info/METADATA
missing /usr/lib/python3.6/site-packages/setuptools-39.2.0.dist-info/RECORD
missing /usr/lib/python3.6/site-packages/setuptools-39.2.0.dist-info/WHEEL
missing /usr/lib/python3.6/site-packages/setuptools-39.2.0.dist-info/dependency_links.txt
missing /usr/lib/python3.6/site-packages/setuptools-39.2.0.dist-info/entry_points.txt
missing /usr/lib/python3.6/site-packages/setuptools-39.2.0.dist-info/metadata.json
missing /usr/lib/python3.6/site-packages/setuptools-39.2.0.dist-info/top_level.txt
missing /usr/lib/python3.6/site-packages/setuptools-39.2.0.dist-info/zip-safe
missing /usr/lib/python3.6/site-packages/setuptools/__init__.py
missing /usr/lib/python3.6/site-packages/setuptools/__pycache__/__init__.cpython-36.pyc
missing /usr/lib/python3.6/site-packages/setuptools/__pycache__/archive_util.cpython-36.pyc
missing /usr/lib/python3.6/site-packages/setuptools/__pycache__/build_meta.cpython-36.pyc
missing /usr/lib/python3.6/site-packages/setuptools/__pycache__/config.cpython-36.pyc
missing /usr/lib/python3.6/site-packages/setuptools/__pycache__/dep_util.cpython-36.pyc
missing /usr/lib/python3.6/site-packages/setuptools/__pycache__/depends.cpython-36.pyc
missing /usr/lib/python3.6/site-packages/setuptools/__pycache__/dist.cpython-36.pyc
missing /usr/lib/python3.6/site-packages/setuptools/__pycache__/extension.cpython-36.pyc
missing /usr/lib/python3.6/site-packages/setuptools/__pycache__/glibc.cpython-36.pyc
missing /usr/lib/python3.6/site-packages/setuptools/__pycache__/glob.cpython-36.pyc
missing /usr/lib/python3.6/site-packages/setuptools/__pycache__/launch.cpython-36.pyc
missing /usr/lib/python3.6/site-packages/setuptools/__pycache__/lib2to3_ex.cpython-36.pyc
missing /usr/lib/python3.6/site-packages/setuptools/__pycache__/monkey.cpython-36.pyc
missing /usr/lib/python3.6/site-packages/setuptools/__pycache__/msvc.cpython-36.pyc
missing /usr/lib/python3.6/site-packages/setuptools/__pycache__/namespaces.cpython-36.pyc
missing /usr/lib/python3.6/site-packages/setuptools/__pycache__/package_index.cpython-36.pyc
missing /usr/lib/python3.6/site-packages/setuptools/__pycache__/pep425tags.cpython-36.pyc
missing /usr/lib/python3.6/site-packages/setuptools/__pycache__/py27compat.cpython-36.pyc
missing /usr/lib/python3.6/site-packages/setuptools/__pycache__/py31compat.cpython-36.pyc
missing /usr/lib/python3.6/site-packages/setuptools/__pycache__/py33compat.cpython-36.pyc
missing /usr/lib/python3.6/site-packages/setuptools/__pycache__/py36compat.cpython-36.pyc
missing /usr/lib/python3.6/site-packages/setuptools/__pycache__/sandbox.cpython-36.pyc
missing /usr/lib/python3.6/site-packages/setuptools/__pycache__/site-patch.cpython-36.pyc
missing /usr/lib/python3.6/site-packages/setuptools/__pycache__/ssl_support.cpython-36.pyc
missing /usr/lib/python3.6/site-packages/setuptools/__pycache__/unicode_utils.cpython-36.pyc
missing /usr/lib/python3.6/site-packages/setuptools/__pycache__/version.cpython-36.pyc
missing /usr/lib/python3.6/site-packages/setuptools/__pycache__/wheel.cpython-36.pyc
missing /usr/lib/python3.6/site-packages/setuptools/__pycache__/windows_support.cpython-36.pyc
missing /usr/lib/python3.6/site-packages/setuptools/_vendor/__init__.py
missing /usr/lib/python3.6/site-packages/setuptools/_vendor/__pycache__/__init__.cpython-36.pyc
missing /usr/lib/python3.6/site-packages/setuptools/_vendor/__pycache__/pyparsing.cpython-36.pyc
missing /usr/lib/python3.6/site-packages/setuptools/_vendor/__pycache__/six.cpython-36.pyc
missing /usr/lib/python3.6/site-packages/setuptools/_vendor/packaging/__about__.py
missing /usr/lib/python3.6/site-packages/setuptools/_vendor/packaging/__init__.py
missing /usr/lib/python3.6/site-packages/setuptools/_vendor/packaging/__pycache__/__about__.cpython-36.pyc
missing /usr/lib/python3.6/site-packages/setuptools/_vendor/packaging/__pycache__/__init__.cpython-36.pyc
missing /usr/lib/python3.6/site-packages/setuptools/_vendor/packaging/__pycache__/_compat.cpython-36.pyc
missing /usr/lib/python3.6/site-packages/setuptools/_vendor/packaging/__pycache__/_structures.cpython-36.pyc
missing /usr/lib/python3.6/site-packages/setuptools/_vendor/packaging/__pycache__/markers.cpython-36.pyc
missing /usr/lib/python3.6/site-packages/setuptools/_vendor/packaging/__pycache__/requirements.cpython-36.pyc
missing /usr/lib/python3.6/site-packages/setuptools/_vendor/packaging/__pycache__/specifiers.cpython-36.pyc
missing /usr/lib/python3.6/site-packages/setuptools/_vendor/packaging/__pycache__/utils.cpython-36.pyc
missing /usr/lib/python3.6/site-packages/setuptools/_vendor/packaging/__pycache__/version.cpython-36.pyc
missing /usr/lib/python3.6/site-packages/setuptools/_vendor/packaging/_compat.py
missing /usr/lib/python3.6/site-packages/setuptools/_vendor/packaging/_structures.py
missing /usr/lib/python3.6/site-packages/setuptools/_vendor/packaging/markers.py
missing /usr/lib/python3.6/site-packages/setuptools/_vendor/packaging/requirements.py
missing /usr/lib/python3.6/site-packages/setuptools/_vendor/packaging/specifiers.py
missing /usr/lib/python3.6/site-packages/setuptools/_vendor/packaging/utils.py
missing /usr/lib/python3.6/site-packages/setuptools/_vendor/packaging/version.py
missing /usr/lib/python3.6/site-packages/setuptools/_vendor/pyparsing.py
missing /usr/lib/python3.6/site-packages/setuptools/_vendor/six.py
missing /usr/lib/python3.6/site-packages/setuptools/archive_util.py
missing /usr/lib/python3.6/site-packages/setuptools/build_meta.py
missing /usr/lib/python3.6/site-packages/setuptools/command/__init__.py
missing /usr/lib/python3.6/site-packages/setuptools/command/__pycache__/__init__.cpython-36.pyc
missing /usr/lib/python3.6/site-packages/setuptools/command/__pycache__/alias.cpython-36.pyc
missing /usr/lib/python3.6/site-packages/setuptools/command/__pycache__/bdist_egg.cpython-36.pyc
missing /usr/lib/python3.6/site-packages/setuptools/command/__pycache__/bdist_rpm.cpython-36.pyc
missing /usr/lib/python3.6/site-packages/setuptools/command/__pycache__/bdist_wininst.cpython-36.pyc
missing /usr/lib/python3.6/site-packages/setuptools/command/__pycache__/build_clib.cpython-36.pyc
missing /usr/lib/python3.6/site-packages/setuptools/command/__pycache__/build_ext.cpython-36.pyc
missing /usr/lib/python3.6/site-packages/setuptools/command/__pycache__/build_py.cpython-36.pyc
missing /usr/lib/python3.6/site-packages/setuptools/command/__pycache__/develop.cpython-36.pyc
missing /usr/lib/python3.6/site-packages/setuptools/command/__pycache__/dist_info.cpython-36.pyc
missing /usr/lib/python3.6/site-packages/setuptools/command/__pycache__/easy_install.cpython-36.pyc
missing /usr/lib/python3.6/site-packages/setuptools/command/__pycache__/egg_info.cpython-36.pyc
missing /usr/lib/python3.6/site-packages/setuptools/command/__pycache__/install.cpython-36.pyc
missing /usr/lib/python3.6/site-packages/setuptools/command/__pycache__/install_egg_info.cpython-36.pyc
missing /usr/lib/python3.6/site-packages/setuptools/command/__pycache__/install_lib.cpython-36.pyc
missing /usr/lib/python3.6/site-packages/setuptools/command/__pycache__/install_scripts.cpython-36.pyc
missing /usr/lib/python3.6/site-packages/setuptools/command/__pycache__/py36compat.cpython-36.pyc
missing /usr/lib/python3.6/site-packages/setuptools/command/__pycache__/register.cpython-36.pyc
missing /usr/lib/python3.6/site-packages/setuptools/command/__pycache__/rotate.cpython-36.pyc
missing /usr/lib/python3.6/site-packages/setuptools/command/__pycache__/saveopts.cpython-36.pyc
missing /usr/lib/python3.6/site-packages/setuptools/command/__pycache__/sdist.cpython-36.pyc
missing /usr/lib/python3.6/site-packages/setuptools/command/__pycache__/setopt.cpython-36.pyc
missing /usr/lib/python3.6/site-packages/setuptools/command/__pycache__/test.cpython-36.pyc
missing /usr/lib/python3.6/site-packages/setuptools/command/__pycache__/upload.cpython-36.pyc
missing /usr/lib/python3.6/site-packages/setuptools/command/__pycache__/upload_docs.cpython-36.pyc
missing /usr/lib/python3.6/site-packages/setuptools/command/alias.py
missing /usr/lib/python3.6/site-packages/setuptools/command/bdist_egg.py
missing /usr/lib/python3.6/site-packages/setuptools/command/bdist_rpm.py
missing /usr/lib/python3.6/site-packages/setuptools/command/bdist_wininst.py
missing /usr/lib/python3.6/site-packages/setuptools/command/build_clib.py
missing /usr/lib/python3.6/site-packages/setuptools/command/build_ext.py
missing /usr/lib/python3.6/site-packages/setuptools/command/build_py.py
missing /usr/lib/python3.6/site-packages/setuptools/command/develop.py
missing /usr/lib/python3.6/site-packages/setuptools/command/dist_info.py
missing /usr/lib/python3.6/site-packages/setuptools/command/easy_install.py
missing /usr/lib/python3.6/site-packages/setuptools/command/egg_info.py
missing /usr/lib/python3.6/site-packages/setuptools/command/install.py
missing /usr/lib/python3.6/site-packages/setuptools/command/install_egg_info.py
missing /usr/lib/python3.6/site-packages/setuptools/command/install_lib.py
missing /usr/lib/python3.6/site-packages/setuptools/command/install_scripts.py
missing /usr/lib/python3.6/site-packages/setuptools/command/launcher manifest.xml
missing /usr/lib/python3.6/site-packages/setuptools/command/py36compat.py
missing /usr/lib/python3.6/site-packages/setuptools/command/register.py
missing /usr/lib/python3.6/site-packages/setuptools/command/rotate.py
missing /usr/lib/python3.6/site-packages/setuptools/command/saveopts.py
missing /usr/lib/python3.6/site-packages/setuptools/command/sdist.py
missing /usr/lib/python3.6/site-packages/setuptools/command/setopt.py
missing /usr/lib/python3.6/site-packages/setuptools/command/test.py
missing /usr/lib/python3.6/site-packages/setuptools/command/upload.py
missing /usr/lib/python3.6/site-packages/setuptools/command/upload_docs.py
missing /usr/lib/python3.6/site-packages/setuptools/config.py
missing /usr/lib/python3.6/site-packages/setuptools/dep_util.py
missing /usr/lib/python3.6/site-packages/setuptools/depends.py
missing /usr/lib/python3.6/site-packages/setuptools/dist.py
missing /usr/lib/python3.6/site-packages/setuptools/extension.py
missing /usr/lib/python3.6/site-packages/setuptools/extern/__init__.py
missing /usr/lib/python3.6/site-packages/setuptools/extern/__pycache__/__init__.cpython-36.pyc
missing /usr/lib/python3.6/site-packages/setuptools/glibc.py
missing /usr/lib/python3.6/site-packages/setuptools/glob.py
missing /usr/lib/python3.6/site-packages/setuptools/launch.py
missing /usr/lib/python3.6/site-packages/setuptools/lib2to3_ex.py
missing /usr/lib/python3.6/site-packages/setuptools/monkey.py
missing /usr/lib/python3.6/site-packages/setuptools/msvc.py
missing /usr/lib/python3.6/site-packages/setuptools/namespaces.py
missing /usr/lib/python3.6/site-packages/setuptools/package_index.py
missing /usr/lib/python3.6/site-packages/setuptools/pep425tags.py
missing /usr/lib/python3.6/site-packages/setuptools/py27compat.py
missing /usr/lib/python3.6/site-packages/setuptools/py31compat.py
missing /usr/lib/python3.6/site-packages/setuptools/py33compat.py
missing /usr/lib/python3.6/site-packages/setuptools/py36compat.py
missing /usr/lib/python3.6/site-packages/setuptools/sandbox.py
missing /usr/lib/python3.6/site-packages/setuptools/script (dev).tmpl
missing /usr/lib/python3.6/site-packages/setuptools/script.tmpl
missing /usr/lib/python3.6/site-packages/setuptools/site-patch.py
missing /usr/lib/python3.6/site-packages/setuptools/ssl_support.py
missing /usr/lib/python3.6/site-packages/setuptools/unicode_utils.py
missing /usr/lib/python3.6/site-packages/setuptools/version.py
missing /usr/lib/python3.6/site-packages/setuptools/wheel.py
missing /usr/lib/python3.6/site-packages/setuptools/windows_support.py
S.5....T. c /etc/foreman-installer/scenarios.d/foreman-answers.yaml
S.5....T. c /etc/foreman-installer/scenarios.d/foreman-migrations-applied
S.5....T. c /etc/foreman-installer/scenarios.d/foreman.yaml
SM5...GT. c /etc/foreman/database.yml
S.5...GT. c /etc/foreman/dynflow/orchestrator.yml
missing c /etc/foreman/dynflow/worker.yml
SM5...GT. c /etc/foreman/settings.yaml
.M....... /var/run/foreman
S.5....T. c /etc/foreman-proxy/settings.d/remote_execution_ssh.yml
I guess it is completely broken . I will rebuild the katello alltogether and get it going from there.
Thanks much for the effort in assisting me for this issue
Where are those coming from? Those havenât been there before. You did not post the commands nor the output you have done, so I can only guess that either the output before was cut or one of the reinstalls did more then expected. It seems the pip uninstall removed some of the platform python files.
Either way, you can always follow the same pattern again to fix missing files from rpm installations:
# rpm -qf /usr/lib/python3.6/site-packages/easy_install.py
platform-python-setuptools-39.2.0-8.el8_10.noarch
# dnf reinstall platform-python-setuptools-39.2.0-8.el8_10.noarch
That should fix he remaining missing python files.
If you do that remember to start on el9. el8 support has been deprecated.
