Problem: After upgrading katello version to 4.14 i had some issues /conflicts with pulp core along with python 39so i thought will reset it but did not help then i did remove the pulpcore but unfortunately now even after i install with python3.11 it is not available as module when i list it hence i am unable to enable it . Eventually my pulp core api and pulp worker services are failing. Can someone help me here
Foreman and Proxy versions: 3.12.1
Foreman and Proxy plugin versions: 3.12.1
ulpcore-content.service - Pulp Content App
Loaded: loaded (/etc/systemd/system/pulpcore-content.service; enabled; vendor preset: disabled)
Active: active (running) since Wed 2024-12-18 12:51:35 UTC; 5min ago
Main PID: 108437 (pulpcore-conten)
Status: "Gunicorn arbiter booted"
Tasks: 28 (limit: 152216)
Memory: 363.3M
CGroup: /system.slice/pulpcore-content.service
├─108437 /usr/bin/python3.11 /usr/bin/pulpcore-content --preload --timeout 90 --workers 9 --access-logfile -
├─108482 /usr/bin/python3.11 /usr/bin/pulpcore-content --preload --timeout 90 --workers 9 --access-logfile -
├─108485 /usr/bin/python3.11 /usr/bin/pulpcore-content --preload --timeout 90 --workers 9 --access-logfile -
├─108488 /usr/bin/python3.11 /usr/bin/pulpcore-content --preload --timeout 90 --workers 9 --access-logfile -
├─108493 /usr/bin/python3.11 /usr/bin/pulpcore-content --preload --timeout 90 --workers 9 --access-logfile -
├─108496 /usr/bin/python3.11 /usr/bin/pulpcore-content --preload --timeout 90 --workers 9 --access-logfile -
├─108499 /usr/bin/python3.11 /usr/bin/pulpcore-content --preload --timeout 90 --workers 9 --access-logfile -
├─108502 /usr/bin/python3.11 /usr/bin/pulpcore-content --preload --timeout 90 --workers 9 --access-logfile -
├─108505 /usr/bin/python3.11 /usr/bin/pulpcore-content --preload --timeout 90 --workers 9 --access-logfile -
└─108508 /usr/bin/python3.11 /usr/bin/pulpcore-content --preload --timeout 90 --workers 9 --access-logfile -
Dec 18 12:55:23 katello pulpcore-content[108505]: [18/Dec/2024:12:55:23 +0000] "GET /pulp/content/xxx/Library/custom/Percona-Tools/Percona_Tools_-_EL8/repodata/repomd.xml HTTP/1.1" 200 298 "-" "libdnf (Rocky Linux 8.10; generic; Linux.x86_64)"
Dec 18 12:57:18 katello pulpcore-content[108505]: [18/Dec/2024:12:57:18 +0000] "GET /pulp/content/xxx/Library/custom/Rocky_Linux_8/Rocky_Linux_8_-_AppStream/repodata/repomd.xml HTTP/1.1" 200 298 "-" "libdnf (Rocky Linux 8.8; generic; Linux.x86_64)"
Dec 18 12:57:18 katello pulpcore-content[108505]: [18/Dec/2024:12:57:18 +0000] "GET /pulp/content/xxx/Library/custom/Jenkins/Jenkins/repodata/repomd.xml HTTP/1.1" 200 298 "-" "libdnf (Rocky Linux 8.8; generic; Linux.x86_64)"
Dec 18 12:57:18 katello pulpcore-content[108499]: [18/Dec/2024:12:57:18 +0000] "GET /pulp/content/xxx/Library/custom/Google_Cloud_-_EL8/Google_Cloud_SDK_-_EL8/repodata/repomd.xml HTTP/1.1" 200 298 "-" "libdnf (Rocky Linux 8.8; generic; Linux.x86_64)"
Dec 18 12:57:18 katello pulpcore-content[108493]: [18/Dec/2024:12:57:18 +0000] "GET /pulp/content/xxx/Library/custom/Remi_EL8/Remi_EL8_-_PHP_7_4/repodata/repomd.xml HTTP/1.1" 200 298 "-" "libdnf (Rocky Linux 8.8; generic; Linux.x86_64)"
Dec 18 12:57:18 katello pulpcore-content[108488]: [18/Dec/2024:12:57:18 +0000] "GET /pulp/content/xxx/Library/custom/EPEL-8/EPEL-8/repodata/repomd.xml HTTP/1.1" 200 298 "-" "libdnf (Rocky Linux 8.8; generic; Linux.x86_64)"
Dec 18 12:57:19 katello pulpcore-content[108505]: [18/Dec/2024:12:57:19 +0000] "GET /pulp/content/xxx/Library/custom/Grafana/Grafana/repodata/repomd.xml HTTP/1.1" 200 298 "-" "libdnf (Rocky Linux 8.8; generic; Linux.x86_64)"
Dec 18 12:57:19 katello pulpcore-content[108485]: [18/Dec/2024:12:57:19 +0000] "GET /pulp/content/xxx/Library/custom/Docker_CE_-_EL8/Docker_CE_-_EL8/repodata/repomd.xml HTTP/1.1" 200 298 "-" "libdnf (Rocky Linux 8.8; generic; Linux.x86_64)"
Dec 18 12:57:19 katello pulpcore-content[108505]: [18/Dec/2024:12:57:19 +0000] "GET /pulp/content/xxx/Library/custom/InfluxDB_-_EL8/InfluxDB_-_EL8/repodata/repomd.xml HTTP/1.1" 200 298 "-" "libdnf (Rocky Linux 8.8; generic; Linux.x86_64)"
Dec 18 12:57:19 katello pulpcore-content[108502]: [18/Dec/2024:12:57:19 +0000] "GET /pulp/content/xxx/Library/custom/Rocky_Linux_8/Rocky_Linux_8_7_-_AppStream/repodata/repomd.xml HTTP/1.1" 200 298 "-" "libdnf (Rocky Linux 8.8; generic; Linux.x86_64)"
/ displaying pulpcore-worker@1.service
â—Ź pulpcore-worker@1.service - Pulp Worker
Loaded: loaded (/etc/systemd/system/pulpcore-worker@.service; enabled; vendor preset: disabled)
Active: activating (auto-restart) (Result: exit-code) since Wed 2024-12-18 12:57:30 UTC; 1s ago
Process: 110026 ExecStart=/usr/libexec/pulpcore/pulpcore-worker (code=exited, status=1/FAILURE)
Main PID: 110026 (code=exited, status=1/FAILURE)
Dec 18 12:57:30 katello systemd[1]: pulpcore-worker@1.service: Main process exited, code=exited, status=1/FAILURE
Dec 18 12:57:30 katello systemd[1]: pulpcore-worker@1.service: Failed with result 'exit-code'.
/ displaying pulpcore-worker@2.service
â—Ź pulpcore-worker@2.service - Pulp Worker
Process: 110027 ExecStart=/usr/libexec/pulpcore/pulpcore-worker (code=exited, status=1/FAILURE)
Main PID: 110027 (code=exited, status=1/FAILURE)
Am kind of new to it . can someone help me here
