After updating to Foreman 3.0 / Katello 4.2, with Puppet ENC enabled, Environment is no longer inherited through hostgroups and “Inherit from paren” is no longer an option.
Environment inheritance in hostgroups works as it did before
Foreman 3.0
Katello 4.2
CentOS 7
@birkirf Which version of the Puppet plugin are you using? Do you mean that when you are creating a host, the Inherit button next to the Environment selection is not showing up?
Puppet plugin is whatever came default with the update from 2.5.4 → 3.0.0 which i believe to be Puppet 3.0.0
What I mean is when you go to edit a hostgroup (or create a new one) there is no option to “inherit parent” as there used to be for enviroment prior to puppet being extracted from Core.
Understood, thank you! @ezr-ondrej Is there a particular reason this is not there or shall we open a ticket to re-add the functionality?
No, this is definitelly a bug. The field should be the same as it was prior the puppet plugin extraction.
Thanks for reporting @birkirf !
The fix is basically only this line: https://github.com/theforeman/foreman_puppet/pull/220/files#diff-8b201884358a605eb996c7060bc4368e88d694cfb2eca1d73fe954f5187323b2R51
I’ve added bunch of tests to make sure this won’t get broken in the future, but if you want to patch your environment, just get that line
