Hi Again Dominic I feel I have you on speed dial here. The distro is Centos
6.4 puppet 3.2.1 ,I can see no posts for reports in the production.log
Puppet.conf ::-
[main]
# The Puppet log directory.
# The default value is '$vardir/log'.
logdir = /var/log/puppet
# Where Puppet PID files are kept.
# The default value is '$vardir/run'.
rundir = /var/run/puppet
vardir = /var/lib/puppet
# Where SSL certificates are kept.
# The default value is '$confdir/ssl'.
ssldir = $vardir/ssl
# Allow services in the 'puppet' group to access key (Foreman + proxy)
privatekeydir = $ssldir/private_keys { group = service }
hostprivkey = $privatekeydir/$certname.pem { mode = 640 }
# Puppet 3.0.x requires this in both [main] and [master] - harmless on
agents
autosign = $confdir/autosign.conf { mode = 664 }
reports = log, foreman
external_nodes = /etc/puppet/node.rb
node_terminus = exec
[agent]
# The file in which puppetd stores a list of the classes
# associated with the retrieved configuratiion. Can be loaded in
# the separate puppet
executable using the --loadclasses
# option.
# The default value is '$confdir/classes.txt'.
classfile = $vardir/classes.txt
# Where puppetd caches the local configuration. An
# extension indicating the cache format is added automatically.
# The default value is '$confdir/localconfig'.
localconfig = $vardir/localconfig
report = true
pluginsync = true
masterport = 8140
environment = production
certname = foreman.fqdn
server = foreman.fqdn
listen = false
Next part of the file is managed by a different template
Module: 'puppet'
Template source: 'MODULES/puppet/templates/server/puppet.conf.erb'
[development]
modulepath =
/etc/puppet/modules/development:/etc/puppet/modules/common:/usr/share/puppet/modules
[production]
modulepath =
/etc/puppet/modules/production:/etc/puppet/modules/common:/usr/share/puppet/modules
foreman.rb :-
File managed with puppet
Served by: ''
Module: 'foreman'
Template source: 'MODULES/foreman/templates/foreman-report.rb.erb'
copy this file to your report dir - e.g. /usr/lib/ruby/1.8/puppet/reports/
add this report in your puppetmaster reports - e.g, in your puppet.conf
add:
reports=log, foreman # (or any other reports you want)
URL of your Foreman installation
$foreman_url='https://foreman.fqdn
if CA is specified, remote Foreman host will be verified
$foreman_ssl_ca = "/var/lib/puppet/ssl/certs/ca.pem"
ssl_cert and key are required if require_ssl_puppetmasters is enabled in
Foreman
$foreman_ssl_cert = "/var/lib/puppet/ssl/certs/puppet.tsg.ts.pem"
$foreman_ssl_key = "/var/lib/puppet/ssl/private_keys/foreman.tsg.ts.pem"
require 'puppet'
require 'net/http'
require 'net/https'
require 'uri'
Puppet::Reports.register_report(:foreman) do
Puppet.settings.use(:reporting)
desc "Sends reports directly to Foreman"
def process
begin
uri = URI.parse($foreman_url)
http = Net::HTTP.new(uri.host, uri.port)
http.use_ssl = uri.scheme == 'https'
if http.use_ssl?
if $foreman_ssl_ca
http.ca_file = $foreman_ssl_ca
http.verify_mode = OpenSSL::SSL::VERIFY_PEER
else
http.verify_mode = OpenSSL::SSL::VERIFY_NONE
end
if $foreman_ssl_cert
http.cert =
OpenSSL::X509::Certificate.new(File.read($foreman_ssl_cert))
http.key = OpenSSL::PKey::RSA.new(File.read($foreman_ssl_key),
nil)
end
end
req = Net::HTTP::Post.new("#{uri.path}/reports/create?format=yml")
req.set_form_data({'report' => to_yaml})
response = http.request(req)
rescue Exception => e
raise Puppet::Error, "Could not send report to Foreman at
#{$foreman_url}/reports/create?format=yml: #{e}"
end
end
end
On Friday, 14 June 2013 11:57:03 UTC+1, Dominic Cleal wrote:
> On 14/06/13 10:10, Richie Rees wrote:
> > Hi,
> > Trying to work out why my foreman reports are not getting updated on the
> > dash board have followed the reports section in the manual. changed the
> > URL in foreman.rb as it was poiinting to the wrong system name. I
> > noticed that the puppetmaster daemon is not running I had always assumed
> > this was deliberate as foreman replaces the webrick web server with
> > apache/passenger can someone just confirm. As my built systems do get
> > the configurations and classes they just don't report back at the
> moment.
> A few more bits of info would be useful:
> Which version of Puppet, and which distro?
> Can you pastebin your master's puppet.conf?
> At what path have you installed the foreman.rb file? Can you pastebin
> the settings?
> Can you check /var/log/foreman/production.log and see if any
> /reports/create entries are logged when the agent runs? Do they end
> with a "OK 200" response?
> Dominic Cleal
> Red Hat Engineering
