Puppet rdoc generate - undefined method `keys' for Array
I'm trying to set up the Puppet class browser<Puppet class browser - Foreman>in Foreman 1.1-1 so I can show some documentation about my puppet classes.
When I run the rake task I get the error "undefined method `keys' for
#<Array:0x7f97d3c953e8>. Here is the full trace:
me@myforemanserver:/usr/local/foreman-1.1-1> RAILS_ENV=development rake
puppet:rdoc:generate --trace
** Invoke puppet:rdoc:generate (first_time)
** Execute environment
** Invoke puppet:rdoc:prepare (first_time)
** Execute puppet:rdoc:prepare
** Execute puppet:rdoc:generate
rake aborted!
undefined method keys&#39; for #&lt;Array:0x7f97d3c953e8&gt; /usr/local/foreman-1.1-1/app/models/environment.rb:42:inpuppetEnvs'
/usr/lib/ruby/gems/1.8/gems/activesupport-3.0.20/lib/active_support/dependencies.rb:458:in
map&#39; /usr/local/foreman-1.1-1/app/models/environment.rb:41:ineach'
/usr/local/foreman-1.1-1/app/models/environment.rb:41:in map&#39; /usr/local/foreman-1.1-1/app/models/environment.rb:41:inpuppetEnvs'
/usr/local/foreman-1.1-1/app/models/environment.rb:40:in map&#39; /usr/local/foreman-1.1-1/app/models/environment.rb:40:inpuppetEnvs'
/usr/local/foreman-1.1-1/app/models/puppetclass.rb:80:in rdoc&#39; /usr/local/foreman-1.1-1/lib/tasks/puppet.rake:17 /usr/lib/ruby/gems/1.8/gems/rake-10.0.3/lib/rake/task.rb:228:incall'
/usr/lib/ruby/gems/1.8/gems/rake-10.0.3/lib/rake/task.rb:228:in execute&#39; /usr/lib/ruby/gems/1.8/gems/rake-10.0.3/lib/rake/task.rb:223:ineach'
/usr/lib/ruby/gems/1.8/gems/rake-10.0.3/lib/rake/task.rb:223:in execute&#39; /usr/lib/ruby/gems/1.8/gems/rake-10.0.3/lib/rake/task.rb:166:ininvoke_with_call_chain'
/usr/lib/ruby/1.8/monitor.rb:242:in synchronize&#39; /usr/lib/ruby/gems/1.8/gems/rake-10.0.3/lib/rake/task.rb:159:ininvoke_with_call_chain'
/usr/lib/ruby/gems/1.8/gems/rake-10.0.3/lib/rake/task.rb:152:in invoke&#39; /usr/lib/ruby/gems/1.8/gems/rake-10.0.3/lib/rake/application.rb:143:ininvoke_task'
/usr/lib/ruby/gems/1.8/gems/rake-10.0.3/lib/rake/application.rb:101:in
top_level&#39; /usr/lib/ruby/gems/1.8/gems/rake-10.0.3/lib/rake/application.rb:101:ineach'
top_level&#39; /usr/lib/ruby/gems/1.8/gems/rake-10.0.3/lib/rake/application.rb:110:inrun_with_threads'
/usr/lib/ruby/gems/1.8/gems/rake-10.0.3/lib/rake/application.rb:95:in
top_level&#39; /usr/lib/ruby/gems/1.8/gems/rake-10.0.3/lib/rake/application.rb:73:inrun'
/usr/lib/ruby/gems/1.8/gems/rake-10.0.3/lib/rake/application.rb:160:in
standard_exception_handling&#39; /usr/lib/ruby/gems/1.8/gems/rake-10.0.3/lib/rake/application.rb:70:inrun'
/usr/lib/ruby/gems/1.8/gems/rake-10.0.3/bin/rake:33
/usr/bin/rake:19:in `load'
/usr/bin/rake:19
Tasks: TOP => puppet:rdoc:generate
Foreman is running on CentOS 6.3 and served by Apache passenger.
me@myforemanserver:/usr/local/foreman-1.1-1> puppet --version
2.7.18
me@myforemanserver:/usr/local/foreman-1.1-1/config> cat settings.yaml
··· --- # You must restart the Rack server after changing either of these values # because they are cached at startup. # :unattended: true :login: true :require_ssl: false :locations_enabled: false :organizations_enabled: false #JSONP or "JSON with padding" is a complement to the base JSON data format. #It provides a method to request JSON data from a server in a different domain. :support_jsonp: false :puppetconfdir: /etc/puppet :puppetvardir: /var/lib/puppet :document_root: /usr/local/foreman/public
My ruby is not up to par, so it may be something obvious that I’m not
familiar with. Thanks for the help.
Jason
No, I was not able to get the Foreman rake task working, but I was able to
use the rdoc directly with puppet. Heres what I'm using. Your foreman
directory path and modules path may be different than mine. Note that
"development" should be replaced by whatever your environment name is.
*puppet doc --mode rdoc --outputdir
/usr/local/foreman/public/*puppet/rdoc/development
–modulepath /etc/puppet/modules/
··· On Fri, May 3, 2013 at 2:40 AM, yi ji wrote:
I also meet the same problem, do you solve this problem?
rake puppet:rdoc:generate RAILS_ENV=production --trace
rake aborted!
undefined method keys' for #<Array:0x2b02c25f1c08> /usr/share/foreman/app/models/environment.rb:42:inpuppetEnvs’
/usr/lib/ruby/gems/1.8/gems/activesupport-3.0.20/lib/active_support/dependencies.rb:242:in
map' /usr/share/foreman/app/models/environment.rb:41:ineach’
/usr/share/foreman/app/models/environment.rb:41:in map' /usr/share/foreman/app/models/environment.rb:41:inpuppetEnvs’
/usr/share/foreman/app/models/environment.rb:40:in map' /usr/share/foreman/app/models/environment.rb:40:inpuppetEnvs’
/usr/share/foreman/app/models/puppetclass.rb:80:in rdoc' /usr/share/foreman/lib/tasks/puppet.rake:17 /usr/lib/ruby/gems/1.8/gems/rake-0.9.2.2/lib/rake/task.rb:205:incall’
/usr/lib/ruby/gems/1.8/gems/rake-0.9.2.2/lib/rake/task.rb:205:in execute' /usr/lib/ruby/gems/1.8/gems/rake-0.9.2.2/lib/rake/task.rb:200:ineach’
/usr/lib/ruby/gems/1.8/gems/rake-0.9.2.2/lib/rake/task.rb:200:in execute' /usr/lib/ruby/gems/1.8/gems/rake-0.9.2.2/lib/rake/task.rb:158:ininvoke_with_call_chain’
/usr/lib/ruby/1.8/monitor.rb:242:in synchronize' /usr/lib/ruby/gems/1.8/gems/rake-0.9.2.2/lib/rake/task.rb:151:ininvoke_with_call_chain’
/usr/lib/ruby/gems/1.8/gems/rake-0.9.2.2/lib/rake/task.rb:144:in invoke' /usr/lib/ruby/gems/1.8/gems/rake-0.9.2.2/lib/rake/application.rb:116:ininvoke_task’
/usr/lib/ruby/gems/1.8/gems/rake-0.9.2.2/lib/rake/application.rb:94:in
top_level' /usr/lib/ruby/gems/1.8/gems/rake-0.9.2.2/lib/rake/application.rb:94:ineach’
top_level' /usr/lib/ruby/gems/1.8/gems/rake-0.9.2.2/lib/rake/application.rb:133:instandard_exception_handling’
/usr/lib/ruby/gems/1.8/gems/rake-0.9.2.2/lib/rake/application.rb:88:in
top_level' /usr/lib/ruby/gems/1.8/gems/rake-0.9.2.2/lib/rake/application.rb:66:inrun’
standard_exception_handling' /usr/lib/ruby/gems/1.8/gems/rake-0.9.2.2/lib/rake/application.rb:63:inrun’
/usr/lib/ruby/gems/1.8/gems/rake-0.9.2.2/bin/rake:33
/usr/bin/rake:19:in `load’
/usr/bin/rake:19
https://groups.google.com/d/topic/foreman-users/vjBHjTJJceE/unsubscribe?hl=en
Visit this group at http://groups.google.com/group/foreman-users?hl=en.
