hi:
I follow foreman manual to deploy foreman. I have imported from Puppet and
Puppet CA with Smart Proxy Puppet.It works good. But The foreman can't find
puppet client auto.
Here is my config file,please tell me where is wrong.How to debug these
problems to reslove it?
my puppet server version : 3.8.4
my foreman server version : 1.9.3
my foreman Smart Proxy version : 1.9.3
puppet client:
[agent]
classfile = $vardir/classes.txt
localconfig = $vardir/localconfig
runinterval = 600
how_diff=true
report = true
environment = production
server = puppet.server.com
ca_server = puppetca.server.com
puppet server:
[main]
logdir = /var/log/puppet
vardir = /var/lib/puppet/
rundir = /var/run/puppet/
ssldir = /var/lib/puppet/ssl
pluginsync = true
[master]
certname = puppet.server.com
ca = false
reports= log,foreman
ssl_client_verify_header = HTTP_X_CLIENT_VERIFY
ssl_client_header = HTTP_X_CLIENT_DN
[agent]
runinterval = 600
how_diff=true
report = true
on puppet master:
/etc/puppet/foreman.yaml
--- :url: "https://foreman.server.com" :ssl_ca: "/var/lib/puppet/ssl/certs/ca.pem" :ssl_cert: "/var/lib/puppet/ssl/certs/foreman.server.com.pem" :ssl_key: "/var/lib/puppet/ssl/private_keys/foreman.server.com.pem":puppetdir: “/var/lib/puppet”
:puppetuser: “puppet”
:facts: true
:timeout: 10
:threads: null
on pupet master:
the foreman.rb is from site: https://raw.githubusercontent.com/theforeman/puppet-foreman/master/files/foreman-report_v2.rb
the foreman.rb dir is:
ll /usr/local/rvm/gems/ruby-1.9.3-p551/gems/puppet-3.8.4/lib/puppet/reports
-rw-r–r-- 1 root rvm 6346 Dec 14 18:20 foreman.rb
-rw-r–r-- 1 root rvm 1044 Dec 10 15:28 http.rb
-rw-r–r-- 1 root rvm 326 Dec 10 15:28 log.rb
-rw-r–r-- 1 root rvm 4265 Dec 10 15:28 rrdgraph.rb
-rw-r–r-- 1 root rvm 1886 Dec 10 15:28 store.rb
-rw-r–r-- 1 root rvm 5915 Dec 10 15:28 tagmail.rb
please help me,thank you.
