Puppet with splay=true
I have just noticed that the foreman-installer uses the splay setting from puppet.conf. I have splay=true set on all our servers including a server running a katello content proxy (only the main foreman/katello server has splay=false). I was wondering why the foreman-installer run on the proxy server wasn’t progressing until I have noticed that it is “hanging” on a puppet call. Due to the splay setting in puppet.conf it was sleeping.
I guess it would be good if foreman-installer would use the --no-splay option for all puppet runs…
Perhaps this is a feature noone noticed yet as it came with puppet 4.2 that apply takes splay into account.
Interesting and a good find. Which version of rubygem-kafo (or tfm-rubygem-kafo) is installed? I thought I had isolated it by using a separate conf file, but this would suggest it’s not.
tfm-rubygem-kafo-4.1.0-3.el7.noarch
That should include:
https://github.com/theforeman/kafo/commit/29999419d8ef5288c3a87708e3cbabd896422576
I wonder why the default puppet.conf still leaks.
If you want to always configure it, I think here would be the correct place to do so:
Otherwise here:
Perhaps in the latter it always needs to pass --config but point it to /dev/null?
Just made a test run with splay set. First time it “hangs”, these processes are running:
root      79916  79886  4 17:32 pts/1    00:00:01 ruby /sbin/foreman-installer
root      80289  79916  0 17:32 pts/1    00:00:00 sh -c echo "package { ['crane-selinux']: ensure => installed }" | /opt/puppetlabs/bin/puppet apply --detailed-exitcodes
root      80294  80289  9 17:32 pts/1    00:00:01 /opt/puppetlabs/puppet/bin/ruby /opt/puppetlabs/puppet/bin/puppet apply --detailed-exitcodes
Aha! It’s here:
That doesn’t use the isolated execution environment so it ‘leaks’.
A 100% untested patch:
https://github.com/theforeman/foreman-installer/pull/584
If nobody beat me to it, I’ll try to test this tomorrow.
Sorry to bother: any chance to get this into the installer? I am still having this problem with my content proxy which has splay=true set in puppet.conf.
@ehelms what are your thoughts here? It may be easier (and safer) to always configure kafo’s Puppet run with splay=false. We never want that so we might as well be explicit about it. It’d be a safe cherry pick as well.
@ekohl @ehelms I just ran into this issue again while setting up a new content proxy: foreman-installer still uses the splay setting from puppet.conf…
