Since upgrading to foreman 0.3 I've been having problems getting
puppetca + smart proxy to work. Prior to 0.3, everything was working
pretty smooth, so I'm not sure what I hosed. Here's something that
sticks out to me in the smart-proxy log (/tmp/proxy.log)
Failed to list certificates: Unable to find CA inventory file at /var/
lib/puppet/ssl/ca/inventory.txt
This file does exist and I do see all of my clients listed in the
file. In the meantime, I turned off SSL for my smart-proxy just to
reduce any 'extra complexity'.
Permissions? try adding the user which runs the proxy to the puppet group.
reduce any ‘extra complexity’.
Turns out I had duplicate certificate that was signed for my puppet
master. Once I removed that cert things were good.
> > You received this message because you are subscribed to the Google Groups
> > "Foreman users" group.
> > To post to this group, send email to foreman-users@googlegroups.com.
> > To unsubscribe from this group, send email to
> > foreman-users+unsubscribe@googlegroups.com.
> > For more options, visit this group at
> >http://groups.google.com/group/foreman-users?hl=en.
> Alright, I got this sorted out…
Could you explain a bit more? it does not make much sense to me…
in fact, you can have multiple certificates for your master (e.g. one CA
certificate and another puppet client certificate)…
On Mon, 2011-06-13 at 07:35 -0700, Luke Baker wrote:
Since upgrading to foreman 0.3 I’ve been having problems getting
pretty smooth, so I’m not sure what I hosed. Here’s something that
Well, I had a signed certificate for my puppetmaster - I also had
another signed certificate for the puppetmaster (the file name was
different). Once I deleted this certificate, 'things' just started
working. Not sure what was going on there.
> > Alright, I got this sorted out..
> Could you explain a bit more? it does not make much sense to me...
> certificate and another puppet client certificate)...
> Hi Luke, Ohad
> I am also getting the same error message, if I execute the puppetca
> command from cmd line its not throwing any error.
> D, [2011-06-17T08:04:24.665421 #17248] DEBUG – : Found puppetca at /
> usr/sbin/puppetca
> D, [2011-06-17T08:04:24.665731 #17248] DEBUG – : Found sudo at /usr/
> bin/sudo
> D, [2011-06-17T08:04:24.665908 #17248] DEBUG – : Executing /usr/bin/
> sudo -S /usr/sbin/puppetca --list --all
> E, [2011-06-17T08:04:25.547190 #17248] ERROR – : Failed to list
> certificates: Unable to find CA inventory file at /var/lib/puppet/ssl/
> ca/inventory.txt
> ^C
> [root@testvm1 ~]# /usr/bin/sudo -S /usr/sbin/puppetca --list --all
> + centos.apnonline.co.nz (09:8E:0C:54:42:2A:36:3D:2D:0E:58:39:CA:9A:
> 6B:ED)
are you running your smart proxy as root? I'm guessing not…
as the proxy user, try to run both the sudo command and to see if you can
see the content of /var/lib/puppet/ssl/
ca/inventory.txt.
most likely you simply need to add the foreman-proxy account to the puppet
group.
different). Once I deleted this certificate, ‘things’ just started
CA
working
that
/var/
group.
to
It was indeed a permission issue, your suggestion was right on the
money
> > Hi Luke, Ohad
> > D, [2011-06-17T08:04:24.665421 #17248] DEBUG -- : Found puppetca at /
> > usr/sbin/puppetca
> > D, [2011-06-17T08:04:24.665731 #17248] DEBUG -- : Found sudo at /usr/
> > bin/sudo
> > D, [2011-06-17T08:04:24.665908 #17248] DEBUG -- : Executing /usr/bin/
> > E, [2011-06-17T08:04:25.547190 #17248] ERROR -- : Failed to list
> > ca/inventory.txt
> > ^C
> > 6B:ED)
> are you running your smart proxy as root? I'm guessing not...
> ca/inventory.txt.
> group.
> > Any help would be appreciated.
> > Thanks
> > Bency
> > CA
> > working
> > that
> > /var/
> > group.
> > to
> > Google Groups
