Hi there,
I’m trying to manage lifecycle environments with python-foreman but I’m not able to, see https://github.com/david-caro/python-foreman/issues/98.
Just asking here in case someone has an idea?
Anthony
Hi there,
Anthony
I would recommend taking a look at apypie which is maintained by Foreman developers who need it for foreman-ansible-modules.
Thanks for the heads up, but I really need to use this python-foreman for contribution to https://github.com/adfinis-sygroup/foreman-yml.
If i had to guess, that library hasn’t implemented the api calls for lifecycle environment. it looks like it was last updated two years ago, and from a quick glance doesn’t seem to have support for any katello api endpoints.
Actually this library is built dynamically from the apidoc of the running foreman instance, see here https://github.com/david-caro/python-foreman/blob/master/doc/definitions.rst. It works fine for all other katello objects, so I’m wondering if it could be a conflict between puppet env and lifecycle env…
Looking at foreman-yml, I wonder if foreman-ansible-modules isn’t already a fully replacement for that. It tries to achieve the same goal.
https://github.com/adfinis-sygroup/foreman-yml/issues/71
There are also patches applied in foreman-ansible-module to work around issues:
My initial need is to:
1- Dump a running foreman instance in yaml format to track changes through gitlab diff
2- Provision a new foreman instance based on same files for DR or testing purpose
3- Optionally update or create objects through git merge requests
Is it something that could be achieved with foreman-ansible-modules?
If yes I will check it out!
Thanks
After a quick look to foreman-ansible-modules, I think I will miss the dump feature
