Qpidd [System] error Error reading socket:
Hi again,
I spotted something else, my /var/log/messages is filling up with a
continuous stream of these errors:
Feb 16 08:40:04 foremantest qpidd[1053]: 2015-02-16 08:40:04
[System] error Error reading socket: Success(0)
Feb 16 08:40:09 foremantest qpidd: 2015-02-16 08:40:09 [System]
Feb 16 08:40:09 foremantest qpidd[1053]: 2015-02-16 08:40:09
Feb 16 08:40:14 foremantest qpidd: 2015-02-16 08:40:14 [System]
Feb 16 08:40:14 foremantest qpidd[1053]: 2015-02-16 08:40:14
Feb 16 08:40:19 foremantest qpidd: 2015-02-16 08:40:19 [System]
Feb 16 08:40:19 foremantest qpidd[1053]: 2015-02-16 08:40:19
Feb 16 08:40:25 foremantest qpidd: 2015-02-16 08:40:25 [System]
Feb 16 08:40:25 foremantest qpidd[1053]: 2015-02-16 08:40:25
Feb 16 08:40:30 foremantest qpidd: 2015-02-16 08:40:30 [System]
Feb 16 08:40:30 foremantest qpidd[1053]: 2015-02-16 08:40:30
Feb 16 08:40:35 foremantest qpidd: 2015-02-16 08:40:35 [System]
Any idea of how to get rid of these? Running fresh install of Katello
2.1 with foreman 1.7.2 on Centos 7
Met vriendelijke groet, With kind regards,
Jorick Astrego
Netbulae Virtualization Experts
Tel: 053 20 30 270 	info@netbulae.eu 	Staalsteden 4-3A 	KvK 08198180
Fax: 053 20 30 271 	www.netbulae.eu 	7547 TA Enschede 	BTW NL821234584B01
> Hi again,
Could it be this? Do you see the corresponding logs in
/var/log/foreman/production.log?
That may explain your other question as well.
Jorick Astrego
Ah yes, thanks!
I see:
step 5115e046-32cd-4e7a-ba4b-1f68502fb658:2 dropping event
Dynflow::Executors::Abstract::Event[execution_plan_id:
5115e046-32cd-4e7a-ba4b-1f68502fb658, step_id: 2, event:
Actions::Candlepin::ListenOnCandlepinEvents::NotConnected[message:
Failed to connect (reconnect disabled)], result:
#<Dynflow::Future:0x0000000ad2da48>]
step e7f04d42-51ff-4a48-9746-f6a9f026b1b1:2 dropping event
e7f04d42-51ff-4a48-9746-f6a9f026b1b1, step_id: 2, event:
#<Dynflow::Future:0x0000000f2bfe80>]
step ed89b1a4-9a27-42f4-a7f4-2449416c2a02:2 dropping event
ed89b1a4-9a27-42f4-a7f4-2449416c2a02, step_id: 2, event:
#<Dynflow::Future:0x0000000ee24e48>]
step 00e57fba-05da-469a-926a-c10a31bb8901:2 dropping event
00e57fba-05da-469a-926a-c10a31bb8901, step_id: 2, event:
#<Dynflow::Future:0x0000000ef38370>]
So I guess the only way to fix it for now is redeploy on Centos 6…
Jorick Astrego
··· On 02/16/2015 09:00 AM, Stephen Benjamin wrote: > On Mon, Feb 16, 2015 at 08:49:04AM +0100, Jorick Astrego wrote: >> Hi again, >> >> I spotted something else, my /var/log/messages is filling up with a >> continuous stream of these errors: >> >> Feb 16 08:40:04 foremantest qpidd[1053]: 2015-02-16 08:40:04 >> [System] error Error reading socket: Success(0) >> Feb 16 08:40:09 foremantest qpidd: 2015-02-16 08:40:09 [System] >> error Error reading socket: Success(0) >> Feb 16 08:40:09 foremantest qpidd[1053]: 2015-02-16 08:40:09 >> [System] error Error reading socket: Success(0) >> Feb 16 08:40:14 foremantest qpidd: 2015-02-16 08:40:14 [System] >> error Error reading socket: Success(0) >> Feb 16 08:40:14 foremantest qpidd[1053]: 2015-02-16 08:40:14 >> [System] error Error reading socket: Success(0) >> Feb 16 08:40:19 foremantest qpidd: 2015-02-16 08:40:19 [System] >> error Error reading socket: Success(0) >> Feb 16 08:40:19 foremantest qpidd[1053]: 2015-02-16 08:40:19 >> [System] error Error reading socket: Success(0) >> Feb 16 08:40:25 foremantest qpidd: 2015-02-16 08:40:25 [System] >> error Error reading socket: Success(0) >> Feb 16 08:40:25 foremantest qpidd[1053]: 2015-02-16 08:40:25 >> [System] error Error reading socket: Success(0) >> Feb 16 08:40:30 foremantest qpidd: 2015-02-16 08:40:30 [System] >> error Error reading socket: Success(0) >> Feb 16 08:40:30 foremantest qpidd[1053]: 2015-02-16 08:40:30 >> [System] error Error reading socket: Success(0) >> Feb 16 08:40:35 foremantest qpidd: 2015-02-16 08:40:35 [System] >> error Error reading socket: Success(0) >> >> >> Any idea of how to get rid of these? Running fresh install of Katello >> 2.1 with foreman 1.7.2 on Centos 7 > > Could it be this? Do you see the corresponding logs in > /var/log/foreman/production.log? > > That may explain your other question as well. > > http://projects.theforeman.org/issues/9068 > ----------------
Hi jorick,
Had the same problem on Centos 6.6… Have you successfully deployed on
lower versions of Centos 6?
··· On Monday, February 16, 2015 at 4:59:38 PM UTC+8, Jorick Astrego wrote: > > > On 02/16/2015 09:00 AM, Stephen Benjamin wrote: > > On Mon, Feb 16, 2015 at 08:49:04AM +0100, Jorick Astrego wrote: > >> Hi again, > >> > >> I spotted something else, my /var/log/messages is filling up with a > >> continuous stream of these errors: > >> > >> Feb 16 08:40:04 foremantest qpidd[1053]: 2015-02-16 08:40:04 > >> [System] error Error reading socket: Success(0) > >> Feb 16 08:40:09 foremantest qpidd: 2015-02-16 08:40:09 [System] > >> error Error reading socket: Success(0) > >> Feb 16 08:40:09 foremantest qpidd[1053]: 2015-02-16 08:40:09 > >> [System] error Error reading socket: Success(0) > >> Feb 16 08:40:14 foremantest qpidd: 2015-02-16 08:40:14 [System] > >> error Error reading socket: Success(0) > >> Feb 16 08:40:14 foremantest qpidd[1053]: 2015-02-16 08:40:14 > >> [System] error Error reading socket: Success(0) > >> Feb 16 08:40:19 foremantest qpidd: 2015-02-16 08:40:19 [System] > >> error Error reading socket: Success(0) > >> Feb 16 08:40:19 foremantest qpidd[1053]: 2015-02-16 08:40:19 > >> [System] error Error reading socket: Success(0) > >> Feb 16 08:40:25 foremantest qpidd: 2015-02-16 08:40:25 [System] > >> error Error reading socket: Success(0) > >> Feb 16 08:40:25 foremantest qpidd[1053]: 2015-02-16 08:40:25 > >> [System] error Error reading socket: Success(0) > >> Feb 16 08:40:30 foremantest qpidd: 2015-02-16 08:40:30 [System] > >> error Error reading socket: Success(0) > >> Feb 16 08:40:30 foremantest qpidd[1053]: 2015-02-16 08:40:30 > >> [System] error Error reading socket: Success(0) > >> Feb 16 08:40:35 foremantest qpidd: 2015-02-16 08:40:35 [System] > >> error Error reading socket: Success(0) > >> > >> > >> Any idea of how to get rid of these? Running fresh install of Katello > >> 2.1 with foreman 1.7.2 on Centos 7 > > > > Could it be this? Do you see the corresponding logs in > > /var/log/foreman/production.log? > > > > That may explain your other question as well. > > > > http://projects.theforeman.org/issues/9068 > > > Ah yes, thanks! > > I see: > > step 5115e046-32cd-4e7a-ba4b-1f68502fb658:2 dropping event > Dynflow::Executors::Abstract::Event[execution_plan_id: > 5115e046-32cd-4e7a-ba4b-1f68502fb658, step_id: 2, event: > Actions::Candlepin::ListenOnCandlepinEvents::NotConnected[message: Failed > to connect (reconnect disabled)], result: > #] > step e7f04d42-51ff-4a48-9746-f6a9f026b1b1:2 dropping event > Dynflow::Executors::Abstract::Event[execution_plan_id: > e7f04d42-51ff-4a48-9746-f6a9f026b1b1, step_id: 2, event: > Actions::Candlepin::ListenOnCandlepinEvents::NotConnected[message: Failed > to connect (reconnect disabled)], result: > #] > step ed89b1a4-9a27-42f4-a7f4-2449416c2a02:2 dropping event > Dynflow::Executors::Abstract::Event[execution_plan_id: > ed89b1a4-9a27-42f4-a7f4-2449416c2a02, step_id: 2, event: > Actions::Candlepin::ListenOnCandlepinEvents::NotConnected[message: Failed > to connect (reconnect disabled)], result: > #] > step 00e57fba-05da-469a-926a-c10a31bb8901:2 dropping event > Dynflow::Executors::Abstract::Event[execution_plan_id: > 00e57fba-05da-469a-926a-c10a31bb8901, step_id: 2, event: > Actions::Candlepin::ListenOnCandlepinEvents::NotConnected[message: Failed > to connect (reconnect disabled)], result: > #] > > So I guess the only way to fix it for now is redeploy on Centos 6.... > > > > > > > > > Met vriendelijke groet, With kind regards, > > Jorick Astrego > > *Netbulae Virtualization Experts * > ------------------------------ > Tel: 053 20 30 270 in...@netbulae.eu Staalsteden 4-3A KvK > 08198180 Fax: 053 20 30 271 www.netbulae.eu 7547 TA Enschede BTW > NL821234584B01 > ------------------------------ > >
> Hi jorick,
> on lower versions of Centos 6?
Nope I do the following after every reboot:
"service tomcat6 restart && service foreman restart"
Don't feel much for downgrading.
Regards,
Jorick
>> Hi again,
Katello
<http://projects.theforeman.org/issues/9068>
Ah yes, thanks!
I see:
Jorick Astrego*
Tel: 053 20 30 270 	in...@netbulae.eu <javascript:> 	Staalsteden
4-3A 	KvK 08198180
Fax: 053 20 30 271 	www.netbulae.eu <http://www.netbulae.eu> 	7547
Jorick Astrego
>> Hi jorick,
> Regards,
> Jorick
And sometimes when tasks get stuck it's the same fix, check the
catalina.out log for errors.
Regards,
Jorick
>> >> Hi again,
>> with a
>> [System]
>> [System]
>> [System]
>> [System]
>> [System]
>> [System]
>> Katello
>> > Bug #9068: foreman-tasks qpid connection seems broken - Katello - Foreman
>> <Bug #9068: foreman-tasks qpid connection seems broken - Katello - Foreman>
>> Ah yes, thanks!
>> I see:
>> Jorick Astrego*
>> 4-3A KvK 08198180
>> Groups "Foreman users" group.
>> <mailto:foreman-users+unsubscribe@googlegroups.com>.
>> <mailto:foreman-users@googlegroups.com>.
>> Visit this group at http://groups.google.com/group/foreman-users.
> Jorick Astrego*
Jorick Astrego
··· On 03/09/2015 11:13 AM, Jorick Astrego wrote: > On 03/09/2015 07:43 AM, Peter Santiago wrote: >> On Monday, February 16, 2015 at 4:59:38 PM UTC+8, Jorick Astrego wrote: >> On 02/16/2015 09:00 AM, Stephen Benjamin wrote: >> > On Mon, Feb 16, 2015 at 08:49:04AM +0100, Jorick Astrego wrote:
