Question about module stream
After update Foreman 3.6.1 + Katello 4.8
I lost tab “Module Stream” on Content tab.
Now problem with restart
  1. WEBUI: Service unavailable ERF64-6496 [Foreman::MaintenanceException]: There are migrations pending in the system.
  2. foreman-rake db:migrate
== 20221026065954 FixMonitoringSettingsCategoryToDsl: migrating ===============
rake aborted!
StandardError: An error has occurred, this and all later migrations canceled:
PG::UndefinedColumn: ERROR:  column settings.category does not exist
LINE 1: ... IN (SELECT "settings"."id" FROM "settings" WHERE "settings"...
/usr/share/gems/gems/activerecord-6.1.7.3/lib/active_record/connection_adapters/postgresql_adapter.rb:672:in `exec_params'
/usr/share/gems/gems/activerecord-6.1.7.3/lib/active_record/connection_adapters/postgresql_adapter.rb:672:in `block (2 levels) in exec_no_cache'
/usr/share/gems/gems/activesupport-6.1.7.3/lib/active_support/dependencies/interlock.rb:48:in `block in permit_concurrent_loads'
/usr/share/gems/gems/activesupport-6.1.7.3/lib/active_support/concurrency/share_lock.rb:187:in `yield_shares'
/usr/share/gems/gems/activesupport-6.1.7.3/lib/active_support/dependencies/interlock.rb:47:in `permit_concurrent_loads'
/usr/share/gems/gems/activerecord-6.1.7.3/lib/active_record/connection_adapters/postgresql_adapter.rb:671:in `block in exec_no_cache'
/usr/share/gems/gems/activerecord-6.1.7.3/lib/active_record/connection_adapters/abstract_adapter.rb:696:in `block (2 levels) in log'
/usr/share/gems/gems/activesupport-6.1.7.3/lib/active_support/concurrency/load_interlock_aware_monitor.rb:26:in `block (2 levels) in synchronize'
/usr/share/gems/gems/activesupport-6.1.7.3/lib/active_support/concurrency/load_interlock_aware_monitor.rb:25:in `handle_interrupt'
/usr/share/gems/gems/activesupport-6.1.7.3/lib/active_support/concurrency/load_interlock_aware_monitor.rb:25:in `block in synchronize'
/usr/share/gems/gems/activesupport-6.1.7.3/lib/active_support/concurrency/load_interlock_aware_monitor.rb:21:in `handle_interrupt'
/usr/share/gems/gems/activesupport-6.1.7.3/lib/active_support/concurrency/load_interlock_aware_monitor.rb:21:in `synchronize'
/usr/share/gems/gems/activerecord-6.1.7.3/lib/active_record/connection_adapters/abstract_adapter.rb:695:in `block in log'
/usr/share/gems/gems/activesupport-6.1.7.3/lib/active_support/notifications/instrumenter.rb:24:in `instrument'
/usr/share/gems/gems/activerecord-6.1.7.3/lib/active_record/connection_adapters/abstract_adapter.rb:687:in `log'
/usr/share/gems/gems/activerecord-6.1.7.3/lib/active_record/connection_adapters/postgresql_adapter.rb:670:in `exec_no_cache'
/usr/share/gems/gems/activerecord-6.1.7.3/lib/active_record/connection_adapters/postgresql_adapter.rb:649:in `execute_and_clear'
/usr/share/gems/gems/activerecord-6.1.7.3/lib/active_record/connection_adapters/postgresql/database_statements.rb:72:in `exec_delete'
/usr/share/gems/gems/activerecord-6.1.7.3/lib/active_record/connection_adapters/abstract/database_statements.rb:179:in `update'
/usr/share/gems/gems/activerecord-6.1.7.3/lib/active_record/connection_adapters/abstract/query_cache.rb:22:in `update'
/usr/share/gems/gems/activerecord-6.1.7.3/lib/active_record/relation.rb:466:in `update_all'
/usr/share/gems/gems/foreman_monitoring-3.0.0/db/migrate/20221026065954_fix_monitoring_settings_category_to_dsl.rb:6:in `up'
/usr/share/gems/gems/activerecord-6.1.7.3/lib/active_record/migration.rb:870:in `public_send'
/usr/share/gems/gems/activerecord-6.1.7.3/lib/active_record/migration.rb:870:in `exec_migration'
/usr/share/gems/gems/activerecord-6.1.7.3/lib/active_record/migration.rb:851:in `block (2 levels) in migrate'
/usr/share/gems/gems/activerecord-6.1.7.3/lib/active_record/migration.rb:850:in `block in migrate'
/usr/share/gems/gems/activerecord-6.1.7.3/lib/active_record/connection_adapters/abstract/connection_pool.rb:462:in `with_connection'
/usr/share/gems/gems/activerecord-6.1.7.3/lib/active_record/migration.rb:849:in `migrate'
/usr/share/gems/gems/activerecord-6.1.7.3/lib/active_record/migration.rb:1037:in `migrate'
/usr/share/gems/gems/activerecord-6.1.7.3/lib/active_record/migration.rb:1329:in `block in execute_migration_in_transaction'
/usr/share/gems/gems/activerecord-6.1.7.3/lib/active_record/migration.rb:1380:in `block in ddl_transaction'
/usr/share/gems/gems/activerecord-6.1.7.3/lib/active_record/connection_adapters/abstract/database_statements.rb:320:in `block in transaction'
/usr/share/gems/gems/activerecord-6.1.7.3/lib/active_record/connection_adapters/abstract/transaction.rb:319:in `block in within_new_transaction'
/usr/share/gems/gems/activerecord-6.1.7.3/lib/active_record/connection_adapters/abstract/transaction.rb:317:in `within_new_transaction'
/usr/share/gems/gems/activerecord-6.1.7.3/lib/active_record/connection_adapters/abstract/database_statements.rb:320:in `transaction'
/usr/share/gems/gems/activerecord-6.1.7.3/lib/active_record/transactions.rb:209:in `transaction'
/usr/share/gems/gems/activerecord-6.1.7.3/lib/active_record/migration.rb:1380:in `ddl_transaction'
/usr/share/gems/gems/activerecord-6.1.7.3/lib/active_record/migration.rb:1328:in `execute_migration_in_transaction'
/usr/share/gems/gems/activerecord-6.1.7.3/lib/active_record/migration.rb:1302:in `each'
/usr/share/gems/gems/activerecord-6.1.7.3/lib/active_record/migration.rb:1302:in `migrate_without_lock'
/usr/share/gems/gems/activerecord-6.1.7.3/lib/active_record/migration.rb:1251:in `block in migrate'
/usr/share/gems/gems/activerecord-6.1.7.3/lib/active_record/migration.rb:1401:in `block in with_advisory_lock'
/usr/share/gems/gems/activerecord-6.1.7.3/lib/active_record/migration.rb:1416:in `block in with_advisory_lock_connection'
/usr/share/gems/gems/activerecord-6.1.7.3/lib/active_record/migration.rb:1416:in `with_advisory_lock_connection'
/usr/share/gems/gems/activerecord-6.1.7.3/lib/active_record/migration.rb:1397:in `with_advisory_lock'
/usr/share/gems/gems/activerecord-6.1.7.3/lib/active_record/migration.rb:1251:in `migrate'
/usr/share/gems/gems/activerecord-6.1.7.3/lib/active_record/migration.rb:1086:in `up'
/usr/share/gems/gems/activerecord-6.1.7.3/lib/active_record/migration.rb:1061:in `migrate'
/usr/share/gems/gems/activerecord-6.1.7.3/lib/active_record/tasks/database_tasks.rb:237:in `migrate'
/usr/share/gems/gems/activerecord-6.1.7.3/lib/active_record/railties/databases.rake:92:in `block (3 levels) in <top (required)>'
/usr/share/gems/gems/activerecord-6.1.7.3/lib/active_record/railties/databases.rake:90:in `each'
/usr/share/gems/gems/activerecord-6.1.7.3/lib/active_record/railties/databases.rake:90:in `block (2 levels) in <top (required)>'
/usr/share/gems/gems/rake-13.0.1/exe/rake:27:in `<top (required)>'
Caused by:
ActiveRecord::StatementInvalid: PG::UndefinedColumn: ERROR:  column settings.category does not exist
Caused by:
Tasks: TOP => db:migrate
  1. foreman-installer
2023-04-26 11:51:43 [NOTICE] [root] Loading installer configuration. This will take some time.
2023-04-26 11:51:47 [NOTICE] [root] Running installer with log based terminal output at level NOTICE.
2023-04-26 11:51:47 [NOTICE] [root] Use -l to set the terminal output log level to ERROR, WARN, NOTICE, INFO, or DEBUG. See --full-help for definitions.
2023-04-26 11:51:56 [NOTICE] [configure] Starting system configuration.
2023-04-26 11:52:09 [NOTICE] [configure] 250 configuration steps out of 1763 steps complete.
2023-04-26 11:52:12 [NOTICE] [configure] 500 configuration steps out of 1763 steps complete.
2023-04-26 11:52:16 [NOTICE] [configure] 750 configuration steps out of 1768 steps complete.
2023-04-26 11:52:17 [NOTICE] [configure] 1250 configuration steps out of 1775 steps complete.
2023-04-26 11:52:51 [ERROR ] [configure] '/usr/sbin/foreman-rake db:migrate' returned 1 instead of one of [0]
2023-04-26 11:52:51 [ERROR ] [configure] /Stage[main]/Foreman::Database/Foreman::Rake[db:migrate]/Exec[foreman-rake-db:migrate]/returns: change from 'notrun' to ['0'] failed: '/usr/sbin/foreman-rake db:migrate' returned 1 instead of one of [0]
2023-04-26 11:53:09 [NOTICE] [configure] 1500 configuration steps out of 1775 steps complete.
2023-04-26 11:53:20 [NOTICE] [configure] 1750 configuration steps out of 1775 steps complete.
2023-04-26 11:53:23 [NOTICE] [configure] System configuration has finished.
This seems to be a bug in the monitoring plugin, should be fixed by Migration error 'column settings.category does not exist' · theforeman/foreman_monitoring@f7aca84 · GitHub, but no release of that plugin has been done since that PR was merged.
cc @ekohl @lstejskal
This probably has nothing do with your initial problem, but that might have been caused by a missing restart of the foreman service after the upgrade.
Yes, after remove rubygem-foreman_monitoring-3.0.0-1.fm3_5.el8.noarch foreman working. But still problem with module stream.
After:
Now:
From what version of Foreman/Katello did you upgrade?
The only change I could find which caused that was this: Fixes #34973 - New host details: Hide module streams tab for EL7 hosts by lfu · Pull Request #10234 · Katello/katello · GitHub, this was introduced in Katello 4.7 so if you came from an older version, maybe this is the cause. From what I see, it looks to me this only works for RHEL and CentOS and only if the operatingsystem name matches the code’s expectations. So I would assume if you have Rocky/Alma/OEL/whatever-else-rhel-rebuild hosts or your OSes are not called “CentOS 8.X” or similar, this is maybe broken by design.
Damnn, i upgrade from 4.7 to 4.8 and i have Rocky Linux 8.7
@lfu @Chris_Roberts
I assume the potential impacts on other RHEL rebuilds than CentOS was missed in the initial PR for this.
This should probably be fixed, and maybe also changed to rely on OS family rather than OS name?
Module streams tab is displayed with Rocky 9.1.
I did the test.
Before:
After: (update host)
I migrate again to Alma Linux and again working. Only Rocky Linux have problem
Opened an issue: Bug #36338: Module streams on Content tab is missing for Rocky Linux 8.7 and 9 - Katello - Foreman
