Whilst deploying various Linux os (6/7/8) up until now, initial pxe network config is used to successfully provision a server, then further down the kickstart process, snippet kickstart_network_setup neatly creates a few ifcfg files, which come into play during reboot - all good… that is, up to and including rh and rocky8. However, when deploying rh or rocky9, we note that ifcfg files are still delivered correctly; but new style ‘nmconnection key files’ are also delivered (to /etc/NetworkManager/system-connections), which represent the network configuration in play during initial pxe build (which in our case makes use of a bond / single nic). Upon reboot, our rh / rocky9 server then has conflicts between the two network configuration types, which can sometimes mean network connections don’t get made (e.g. which may include additional connections to other subnets etc).
Server provisioned, upon post build reboot, with all networking configured in foreman server entry in play.
Foreman 3.3.1
foreman-tasks 6.0.2
foreman_puppet 4.0.4
foreman_remote_execution 7.2.2
katello 4.5.1
keh?
For anyone else who experiences the same issue… We are able to work around simply by removing all nmconnection files under /etc/NetworkManager/system-connections during kickstart, prior to reboot. Also we have considered running ‘nmcli connection migrate’ at this point; but prefer to wait and see if foreman provisioning templates will take the new ‘9’ NetworkManager way of using key files into account in the future? (hint - it looks like the days of ifcfg files is numbered and will not be in use at all when Redhat10 and derivatives are released (518 days time and counting at time of writing
