ekohl
August 27, 2024, 3:42pm
1
Currently there’s an issue with the PR processor application. I think GitHub changed their webhooks and the framework we use isn’t able to deal with it so I opened an issue:
opened 03:33PM - 27 Aug 24 UTC
At 2024-08-27 14:00:25 I saw the last successful webhook delivery. After that it… has started to fail with:
File "/opt/app-root/src/app.py", line 5, in <module>
run_prprocessor_app()
File "/opt/app-root/src/prprocessor/__main__.py", line 513, in run_prprocessor_app
run_app(
File "/opt/app-root/lib64/python3.9/site-packages/octomachinery/app/server/runner.py", line 71, in run
run_until_complete(run_server_forever, config, event_routers)
File "/opt/app-root/lib64/python3.9/site-packages/anyio/__init__.py", line 72, in run
return asynclib.run(func, *args, **backend_options) # type: ignore
File "/opt/app-root/lib64/python3.9/site-packages/anyio/_backends/_asyncio.py", line 114, in run
raise exception
File "/opt/app-root/lib64/python3.9/site-packages/anyio/_backends/_asyncio.py", line 76, in wrapper
retval = await func(*args)
File "/opt/app-root/lib64/python3.9/site-packages/octomachinery/utils/asynctools.py", line 15, in async_func_wrapper
return await async_func(*args, **kwargs)
File "/opt/app-root/lib64/python3.9/site-packages/octomachinery/app/server/machinery.py", line 134, in run_forever
await _prepare_github_app(github_app)
File "/opt/app-root/lib64/python3.9/site-packages/octomachinery/app/server/machinery.py", line 64, in _prepare_github_app
await github_app.log_installs_list()
File "/opt/app-root/lib64/python3.9/site-packages/octomachinery/github/api/app_client.py", line 71, in log_installs_list
installations = await self.get_installations()
File "/opt/app-root/lib64/python3.9/site-packages/octomachinery/github/api/app_client.py", line 133, in get_installations
async for install in amap(
File "/opt/app-root/lib64/python3.9/site-packages/octomachinery/utils/asynctools.py", line 83, in amap
yield await try_await(callback(async_value))
File "/opt/app-root/lib64/python3.9/site-packages/octomachinery/utils/asynctools.py", line 68, in try_await
return await potentially_awaitable
File "/opt/app-root/lib64/python3.9/site-packages/octomachinery/utils/asynctools.py", line 89, in callback_wrapper
return await try_await(callback(**args_dict))
TypeError: __init__() got an unexpected keyword argument 'client_id'
The container was built 25 days ago and runs https://github.com/theforeman/prprocessor. I've seen this happen before when GitHub changed their webhooks, but from the trace it's not obvious to me where it's failing.
## Upvote & Fund
- We're using [Polar.sh](https://polar.sh/sanitizers) so you can upvote and help fund this issue.
- We receive the funding once the issue is completed & confirmed by you.
- Thank you in advance for helping prioritize & fund our backlog.
<a href="https://polar.sh/sanitizers/octomachinery/issues/66">
<picture>
<source media="(prefers-color-scheme: dark)" srcset="https://polar.sh/api/github/sanitizers/octomachinery/issues/66/pledge.svg?darkmode=1">
<img alt="Fund with Polar" src="https://polar.sh/api/github/sanitizers/octomachinery/issues/66/pledge.svg">
</picture>
</a>
I understand this is inconvenient and we’ll try to get this sorted.
ekohl
August 28, 2024, 9:59am
2
The issue has been resolved:
theforeman:app ← ekohl:require-working-octomachinery
opened 09:44AM - 28 Aug 24 UTC
As mentioned in https://github.com/sanitizers/octomachinery/issues/66#issuecomme… nt-2313673606, this contains fixes needed to work with how GitHub sends their webhooks now.
Redelivering failed webhooks via the GitHub UI doesn’t scale well (there’s no bulk option) so if you’re stuck then I’d recommend pushing a new commit to retrigger the check.
