Are there specific redmine issues tracking the failing forklift devel
failure? This is impacting closing out work for releases.
Specifically, using koji repos in boxes.yaml:
cmd: foreman-installer -v --scenario "katello-devel"
–foreman-proxy-tftp=true --disable-system-checks
–katello-devel-github-username thomasmckay
start: 2017-05-05 19:52:26.544551
end: 2017-05-05 19:52:27.828586
delta: 0:00:01.284035
stderr: /usr/share/gems/gems/kafo-2.0.1/lib/kafo/puppet_module.rb:69:in
parse': No Puppet module parser is installed and no cache of the file /usr/share/katello-installer-base/modules/katello_devel/manifests/init.pp is available. Please check debug logs and install optional dependencies for the parser. (Kafo::ParserError) from /usr/share/gems/gems/kafo-2.0.1/lib/kafo/configuration.rb:97:in
block in modules'
map' from /usr/share/gems/gems/kafo-2.0.1/lib/kafo/configuration.rb:97:in
modules'
from /usr/share/gems/gems/kafo-2.0.1/lib/kafo/configuration.rb:207:in
params' from /usr/share/gems/gems/kafo-2.0.1/lib/kafo/configuration.rb:217:in
preset_defaults_from_puppet'
from /usr/share/gems/gems/kafo-2.0.1/lib/kafo/kafo_configure.rb:285:in
set_parameters' from /usr/share/gems/gems/kafo-2.0.1/lib/kafo/kafo_configure.rb:100:in
initialize'
from /usr/share/gems/gems/clamp-1.0.0/lib/clamp/command.rb:133:in new' from /usr/share/gems/gems/clamp-1.0.0/lib/clamp/command.rb:133:in
run'
from /usr/share/gems/gems/kafo-2.0.1/lib/kafo/kafo_configure.rb:163:in
run' from /sbin/foreman-installer:8:in
<main>'
to retry, use: --limit
@/home/thomasmckay/.ansible/retry-files/devel.retry
On Fri, May 5, 2017 at 3:54 PM, Tom McKay wrote:Are there specific redmine issues tracking the failing forklift devel
FYI: This happened because katello-installer nightlies were failing.
foreman-installer and katello-installer get out of sync resulting in
broken caches. The workaround is to install yard and puppet-strings:
/opt/puppetlabs/puppet/bin/gem install yard
/opt/puppetlabs/puppet/bin/gem install puppet-strings
Nightlies were fixed so this shouldn't happen anymore.
