Redmine: Multiple PRs logged per issue
All,
Today we merged and updated both Redmine and the prprocessor to support
multiple pull requests for a given issue. For those that use the pull
request field on Redmine issues, this means that if multiple pull requests
have targeted a given issue through fixes/refs, the pull request field
should now record and display all associated. If you see issues with this
functionality, or unexpected behavior from the prprocessor please let us
know!
··· -- Eric D. Helms Red Hat Engineering Ph.D. Student - North Carolina State University
I just had one of my issues reassigned to lzap because he added a PR that
refs it (Bug #8800: Table cells should clip with tooltip only if text actually overflows - Foreman), the prprocessor
should only assign the issue to the PR author if it's the first PR for the
issue.
··· On Fri, Oct 30, 2015 at 4:53 PM, Eric D Helms wrote:
All,
know!
Eric D. Helms
Red Hat Engineering
“foreman-dev” group.
Have a nice day,
Tomer Brisker
Red Hat Engineering
The service had a few errors over the weekend as it wasn't updating
Redmine tickets correctly.
I've now fixed this and redelivered all failed GitHub webhooks on
theforeman/foreman, but please check that your open PRs are correctly
labelled if you've recently updated them.
··· On 30/10/15 14:53, Eric D Helms wrote: > All, > > Today we merged and updated both Redmine and the prprocessor to support > multiple pull requests for a given issue. For those that use the pull > request field on Redmine issues, this means that if multiple pull > requests have targeted a given issue through fixes/refs, the pull > request field should now record and display all associated. If you see > issues with this functionality, or unexpected behavior from the > prprocessor please let us know!
Dominic Cleal
dominic@cleal.org
Thanks for pointing that case out! I've opened a PR to the prprocessor to
only set the assigned_to field if it is not already set:
Eric
should only assign the issue to the PR author if it’s the first PR for the
issue.
On Fri, Oct 30, 2015 at 4:53 PM, Eric D Helms ericdhelms@gmail.com > wrote:
All,
know!
Eric D. Helms
Red Hat Engineering
Have a nice day,
Tomer Brisker
Red Hat Engineering
Eric D. Helms
Red Hat Engineering
Is this a known issue of the PR processor? It looks like when you update a
PR it doesn’t get assigned or reassigned to the correct issue:
This PR should be assigned to this issue:
But it’s on this one instead:
David
All,
The service had a few errors over the weekend as it wasn’t updating
I’ve now fixed this and redelivered all failed GitHub webhooks on
labelled if you’ve recently updated them.
Dominic Cleal
dominic@cleal.org
The PR hasn't been updated (triggering a GitHub "synchronised" webhook)
since the title was changed. Change the title and then push to the
branch and it would have updated.
A couple of possible fixes:
a) update PR links on the PR closed event, prprocessor skips this now
(https://github.com/theforeman/prprocessor/blob/master/app.rb#L29)
b) change ticket number parsing to commit messages instead of PR titles
(https://github.com/theforeman/prprocessor/blob/master/github/pull_request.rb#L17)
··· On 17/11/15 20:11, David Davis wrote: > Is this a known issue of the PR processor? It looks like when you update > a PR it doesn’t get assigned or reassigned to the correct issue: > > https://github.com/Katello/katello/pull/5574 > > This PR should be assigned to this issue: > > http://projects.theforeman.org/issues/12331 > > But it’s on this one instead: > > http://projects.theforeman.org/issues/10970
Dominic Cleal
dominic@cleal.org
