Since the start of this week Redmine has been consistently slow.
Console shows very high load (not dropping below 10, often above 20).
We haven't chnaged anyhting, so my suspicions are on the v2 sunset that
happened at the end of last week.
I've opened a support case to see what's going on, but for now treat
Redmine with care
Ohad mentioned this on our coffee meeting, but why we insist on
OpenShift? It's just a regular Rails app, we could easily drop it to
one of our web hosts and maybe the performance will be even better
than it was.
In other words, no OpenShift V3, our infra for now and forever. Not
sure how much work is to puppetize this, but this could be, I know
someone will eat me for these words, simply a pet server with no
automatization.
/me runs away!
LZ
Ā·Ā·Ā·
> Redmine with care ;)
> Greg
> You received this message because you are subscribed to the Google Groups "foreman-dev" group.
> To unsubscribe from this group and stop receiving emails from it, send an email to foreman-dev+unsubscribe@googlegroups.com.
Our infra is already overloaded (see other mials on this list), so
something else would have to give way for it. Openshift is free and a
good fit for anything "simple" and self-contained, which is why
Redmine, PrProcessor, and the Etherpad run on it.
If we cannot get this resolved, or if the extra v3 resources aren't
granted, then we'll have to do exactly that, but I'll take what free
handouts we can get
Current update BTW, the load is dropping (now sitting around 7) and
I've opened a support ticket. Preliminary feedback is that is likely
due to a large number of people upgrading their v2 accounts to Silver
to avoid the sunset, leading to increased load on the cluster.
Hopefully it'll settle down soon.
Greg
Ā·Ā·Ā·
> than it was.
> automatization.
> /me runs away! :-)
We deployed a new version but that took longer than expected. Now we use
bare git clones rather than doing full checkouts. This should save a lot
of IO which is generally a limiting factor. Hopefully this helps enough
until we can migrate to the new platform.
Ā·Ā·Ā·
On Tue, Oct 10, 2017 at 10:50:24AM -0400, Andrew Kofink wrote:
>Me as well. It's quite difficult to work this way.
>On Tue, Oct 10, 2017 at 10:40 AM, Dirk Gƶtz wrote:
>> Now Redmine seems to be down completely. Only getting 404 or 502 errors
>> since an half hour.
Openshift aren't saying much other than that this is mainly due to the
number of people that decided to upgrade to Silver Tier to avoid the
sunset of v2. That's putting a lot of load on the v2 cluster, which
obviously is hitting us.
As Ewoud said, we've made a change today in how we process the
underlying cron jobs that should reduce the amount of IO we were doing
if there's any kind of quota-ing going on, that should help. We're
seeing that bring the time taken to run the cron down to about 10mins
(starting at the top of the hour). That should improve things during
that period. Sadly I did make a mistake during a manual part of the
changes that impacted the DB, but that should be resolved now.
Base load now seems to be down to around 7-9 which is better but still
too high. Sadly the v3 resources are unlikely to be available before
November, which is a limiter. If things are not better in the next day
or two, then on Thu or Fri I may migrate it to our Scaleway account
anyway, as we have capacity there, although I'd rather not migrate
twiceā¦
Greg
Ā·Ā·Ā·
If things go terribly wrong, we still have an account on EC2 where we
run our koji.
Ā·Ā·Ā·
> Yeah, I know :(
> - if there's any kind of quota-ing going on, that should help. We're
> twice...
> Greg
Things are no better today, and I'm out of patience with Openshift.
I've spun up an instance on Scaleway that should be able to cope and am
in the process of creating a copy of Redmine there. Once it's ready
I'll stop Openshift, re-import the db and cut over the DNS.
Continue to use Redmine as normal for now, I'll update when we're ready
to do the final cutover.
http://51.15.192.166 is now live for your testing pleasure, with a copy
of the DB from a few days ago. Email is currently disabled, so you
can't spam anyone. There's still a few small tasks to sort out that
will keep me busy, but if you want to see if you can break it, go
ahead.
Sadly, SMTP outbound is blocked by default on Scaleway, which I didn't
realise until about 20 mins ago. I've raised a ticket to lift this so
Redmine can send email, but until that's resolved we can't complete the
migration.
Once email is confirmed working, we'll schedule a maintenance window,
where I will stop the Openshift instance and make a final DB dump. Ohad
will then do a DNS switch, and as soon as it comes back you should all
be good to go.
Stay tuned for further updates. I'll announce the maintenance window
before I start.
ahead.
migration.
be good to go.
before I start.
Greg
Ā·Ā·Ā·
On Oct 11, 2017 5:40 PM, "Greg Sutcliffe" wrote:
>Update on migration:
>Any chance to update/enable https in the process?
That is the plan, but first we want to know it's working. If you can
create DNS records we can already test the process with letsencrypt:
Ā·Ā·Ā·
Thanks!
canāt spam anyone. Thereās still a few small tasks to sort out that
ahead.
Sadly, SMTP outbound is blocked by default on Scaleway, which I didnāt
realise until about 20 mins ago. Iāve raised a ticket to lift this so
Redmine can send email, but until thatās resolved we canāt complete the
migration.
Once email is confirmed working, weāll schedule a maintenance window,
be good to go.
Stay tuned for further updates. Iāll announce the maintenance window
before I start.
> redmine01.theforeman.org A 51.15.192.166
> redmine01.theforeman.org AAAA 2001:bc8:4400:2300::5:e03
both should be resolved.
Ohad
Ā·Ā·Ā·
On Wed, Oct 11, 2017 at 7:39 PM, Ewoud Kohl van Wijngaarden < ewoud@kohlvanwijngaarden.nl> wrote:
>> On Oct 11, 2017 5:40 PM, "Greg Sutcliffe" >> wrote:
Thanks!
ahead.
migration.
be good to go.
before I start.
SMTP is now unblocked and confirmed working, so we're ready to switch
over. As soon as I can get a timeframe from Ohad for when the DNS
change can be done, I'll arrange a maintenance window.
Hang in there guys, we're almost done
Greg
Ā·Ā·Ā·
We're ready to switch. I'll take Redmine offline in about 30mins (11.15
UK time) and we should be back up on the new host at 12 noon. Please
save your work
And we're back. Please test extensively and report issues
In particular, we're now on Ruby 2.0 (up from 1.9 on Openshift) so I
suspect the plugins might have issues. Any issues, please report them
here and we'll take a look. I checked quickly and didn't see any
errors, but I was in a hurry
Things still to do:
Add logrotate for the production.log files
Add HTTPS (ewoud is on that)
Upgrade to latest Redmine (I'm looking into it)
Puppetize it so we can migrate more easily in future
We'll monitor to see if the resources are enough, let me know if you
see any issues (no, Backlogs does not count, that thing is slow :P)
We did have to do some changes to the importing of git repos. If you
merge an issue with a keyword (refs or fixes) and it doesn't update the
issue in an hour then please let us know.
Ā·Ā·Ā·
On Thu, Oct 12, 2017 at 11:50:55AM +0100, Greg Sutcliffe wrote:
>And we're back. Please test extensively and report issues ;)
>errors, but I was in a hurry :P
>Things still to do:
>* Add logrotate for the production.log files
>* Add HTTPS (ewoud is on that)
>* Upgrade to latest Redmine (I'm looking into it)
>* Puppetize it so we can migrate more easily in future
>see any issues (no, Backlogs does not count, that thing is *slow* :P)
