Release notes for 2.3
This section will be updated prior to the next release.
Headline features
Release Notes
Deprecations
Upgrade warnings
- Index and column named
digeston SQL tablesmessagesandsourceswill be dropped duringdb:migratestep and replaced by more effective hash index on column namedvalue. While we are working on redesigning how reports are stored in the SQL database, hash indices are faster and use significantly less memory storage than btree in this case. Our tests indicate that on a standard VM, index creation rate is at 18 million records per minute, this step should be from seconds to several minutes depending on size of the tables. - Report creation via
/api/v2/config_reports/REST POST no longer returns the full report for performance reasons. Only basic metadata like database ID is returned, when full report is needed query the same REST resource via HTTP GET method to fetch it. More info at https://github.com/theforeman/foreman/pull/7987
Contributors
We’d like to thank the following people who contributed to the Foreman {{page.version}} release:
update scripts/committers.rb with the correct versions and dates and fill this in
As well as all users who helped test releases, report bugs and provide feedback on the project.
THIS PAGE IS A WIKI, FEEL FREE TO EDIT IT.
