I upgraded from 1.16.2 -> 1.17.1 and remote command execution stopped working.
I install via foreman-puppet module, and it throws an error that service foreman-tasks doesn’t exist.
Any thoughts?
Thank you
Any thoughts?
Thank you
Can you check if sudo systemctl start dynflowd
works ? The daemon was renamed and in my experience the rename worked fine at least on new installations, maybe we missed something and it does not work during upgrades, hopefully that’s not the case.
Anyway, let us know thanks!
Yeah, that made the trick, thanks!
