I have foreman 3.2 - katello 4.4 installed on an EC2 with Centos 7. I have installed remote execution but I am facing issues with executing scripts on remote servers. I have distributed the foreman proxy keys to the host (testing on one host). As it’s in aws, there is no ‘root user with a password’. To overcome this, I made changes to sshd_config and made root user login via public key only. I can login to the host EC2 from forman but when I try to run a command via remote execution, it fails.
I have few questions before providing the logs.
1: How can I avoid making changes to sshd_config and make root user login without password on each host as we have these in hundreds.
2: Can I login via another user? Do I have to copy it’s keys to foreman(this user is already present in all hosts, I won’t copy the keys to each host but is it a good idea?)?
3: How does remote execution work? Doesn’t it ssh into the remote host and execute the command? If yes, then why manually I can login without any issue but with remote execution I can’t?
A point to be noted here, i don’t see any failed attempts of login in the remote host when I run the remote job.
Here are the logs
2022-04-21T21:30:56 bd77cf62 [I] Started GET /dynflow/tasks/count state=running
2022-04-21T21:30:56 bd77cf62 [I] Finished GET /dynflow/tasks/count with 200 (10.09 ms)
2022-04-21T21:30:57 bd77cf62 [I] Started POST /dynflow/tasks/launch
2022-04-21T21:30:57 bd77cf62 [I] Finished POST /dynflow/tasks/launch with 200 (20.28 ms)
2022-04-21T21:30:57 [E] error while initializing command RuntimeError Unable to create directory on remote system /var/tmp/foreman-ssh-cmd-368659ce-0e89-42b7-a032-05004a8a73d1: exit code: 255
ssh_exchange_identification: Connection closed by remote host
/opt/theforeman/tfm/root/usr/share/gems/gems/smart_proxy_remote_execution_ssh-0.5.3/lib/smart_proxy_remote_execution_ssh/runners/script_runner.rb:387:in `ensure_remote_directory'
/opt/theforeman/tfm/root/usr/share/gems/gems/smart_proxy_remote_execution_ssh-0.5.3/lib/smart_proxy_remote_execution_ssh/runners/script_runner.rb:361:in `upload_data'
/opt/theforeman/tfm/root/usr/share/gems/gems/smart_proxy_remote_execution_ssh-0.5.3/lib/smart_proxy_remote_execution_ssh/runners/script_runner.rb:357:in `cp_script_to_remote'
/opt/theforeman/tfm/root/usr/share/gems/gems/smart_proxy_remote_execution_ssh-0.5.3/lib/smart_proxy_remote_execution_ssh/runners/script_runner.rb:158:in `prepare_start'
/opt/theforeman/tfm/root/usr/share/gems/gems/smart_proxy_remote_execution_ssh-0.5.3/lib/smart_proxy_remote_execution_ssh/runners/script_runner.rb:144:in `start'
/opt/theforeman/tfm/root/usr/share/gems/gems/smart_proxy_dynflow-0.7.0/lib/smart_proxy_dynflow/runner/dispatcher.rb:32:in `start_runner'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.6.4/lib/dynflow/actor.rb:13:in `on_message'
/opt/theforeman/tfm/root/usr/share/gems/gems/concurrent-ruby-edge-0.6.0/lib/concurrent-ruby-edge/concurrent/actor/context.rb:46:in `on_envelope'
/opt/theforeman/tfm/root/usr/share/gems/gems/smart_proxy_dynflow-0.7.0/lib/smart_proxy_dynflow/runner/dispatcher.rb:24:in `on_envelope'
/opt/theforeman/tfm/root/usr/share/gems/gems/concurrent-ruby-edge-0.6.0/lib/concurrent-ruby-edge/concurrent/actor/behaviour/executes_context.rb:7:in `on_envelope'
/opt/theforeman/tfm/root/usr/share/gems/gems/concurrent-ruby-edge-0.6.0/lib/concurrent-ruby-edge/concurrent/actor/behaviour/abstract.rb:25:in `pass'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.6.4/lib/dynflow/actor.rb:122:in `on_envelope'
/opt/theforeman/tfm/root/usr/share/gems/gems/concurrent-ruby-edge-0.6.0/lib/concurrent-ruby-edge/concurrent/actor/behaviour/awaits.rb:15:in `on_envelope'
/opt/theforeman/tfm/root/usr/share/gems/gems/concurrent-ruby-edge-0.6.0/lib/concurrent-ruby-edge/concurrent/actor/behaviour/sets_results.rb:14:in `on_envelope'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.6.4/lib/dynflow/actor.rb:56:in `on_envelope'
/opt/theforeman/tfm/root/usr/share/gems/gems/concurrent-ruby-edge-0.6.0/lib/concurrent-ruby-edge/concurrent/actor/behaviour/buffer.rb:38:in `process_envelope'
/opt/theforeman/tfm/root/usr/share/gems/gems/concurrent-ruby-edge-0.6.0/lib/concurrent-ruby-edge/concurrent/actor/behaviour/buffer.rb:31:in `process_envelopes?'
/opt/theforeman/tfm/root/usr/share/gems/gems/concurrent-ruby-edge-0.6.0/lib/concurrent-ruby-edge/concurrent/actor/behaviour/buffer.rb:20:in `on_envelope'
/opt/theforeman/tfm/root/usr/share/gems/gems/concurrent-ruby-edge-0.6.0/lib/concurrent-ruby-edge/concurrent/actor/behaviour/termination.rb:55:in `on_envelope'
/opt/theforeman/tfm/root/usr/share/gems/gems/concurrent-ruby-edge-0.6.0/lib/concurrent-ruby-edge/concurrent/actor/behaviour/removes_child.rb:10:in `on_envelope'
/opt/theforeman/tfm/root/usr/share/gems/gems/concurrent-ruby-edge-0.6.0/lib/concurrent-ruby-edge/concurrent/actor/core.rb:162:in `process_envelope'
/opt/theforeman/tfm/root/usr/share/gems/gems/concurrent-ruby-edge-0.6.0/lib/concurrent-ruby-edge/concurrent/actor/core.rb:96:in `block in on_envelope'
/opt/theforeman/tfm/root/usr/share/gems/gems/concurrent-ruby-edge-0.6.0/lib/concurrent-ruby-edge/concurrent/actor/core.rb:119:in `block (2 levels) in schedule_execution'
/opt/theforeman/tfm/root/usr/share/gems/gems/concurrent-ruby-1.1.6/lib/concurrent-ruby/concurrent/synchronization/mutex_lockable_object.rb:41:in `block in synchronize'
/opt/theforeman/tfm/root/usr/share/gems/gems/concurrent-ruby-1.1.6/lib/concurrent-ruby/concurrent/synchronization/mutex_lockable_object.rb:41:in `synchronize'
/opt/theforeman/tfm/root/usr/share/gems/gems/concurrent-ruby-edge-0.6.0/lib/concurrent-ruby-edge/concurrent/actor/core.rb:116:in `block in schedule_execution'
/opt/theforeman/tfm/root/usr/share/gems/gems/concurrent-ruby-1.1.6/lib/concurrent-ruby/concurrent/executor/serialized_execution.rb:18:in `call'
/opt/theforeman/tfm/root/usr/share/gems/gems/concurrent-ruby-1.1.6/lib/concurrent-ruby/concurrent/executor/serialized_execution.rb:96:in `work'
/opt/theforeman/tfm/root/usr/share/gems/gems/concurrent-ruby-1.1.6/lib/concurrent-ruby/concurrent/executor/serialized_execution.rb:77:in `block in call_job'
/opt/theforeman/tfm/root/usr/share/gems/gems/concurrent-ruby-1.1.6/lib/concurrent-ruby/concurrent/executor/ruby_thread_pool_executor.rb:353:in `run_task'
/opt/theforeman/tfm/root/usr/share/gems/gems/concurrent-ruby-1.1.6/lib/concurrent-ruby/concurrent/executor/ruby_thread_pool_executor.rb:342:in `block (3 levels) in create_worker'
/opt/theforeman/tfm/root/usr/share/gems/gems/concurrent-ruby-1.1.6/lib/concurrent-ruby/concurrent/executor/ruby_thread_pool_executor.rb:325:in `loop'
/opt/theforeman/tfm/root/usr/share/gems/gems/concurrent-ruby-1.1.6/lib/concurrent-ruby/concurrent/executor/ruby_thread_pool_executor.rb:325:in `block (2 levels) in create_worker'
/opt/theforeman/tfm/root/usr/share/gems/gems/concurrent-ruby-1.1.6/lib/concurrent-ruby/concurrent/executor/ruby_thread_pool_executor.rb:324:in `catch'
/opt/theforeman/tfm/root/usr/share/gems/gems/concurrent-ruby-1.1.6/lib/concurrent-ruby/concurrent/executor/ruby_thread_pool_executor.rb:324:in `block in create_worker'
/opt/theforeman/tfm/root/usr/share/gems/gems/logging-2.3.0/lib/logging/diagnostic_context.rb:474:in `block in create_with_logging_context'
2022-04-21T21:30:57 [E] Error initializing command - RuntimeError Unable to create directory on remote system /var/tmp/foreman-ssh-cmd-368659ce-0e89-42b7-a032-05004a8a73d1: exit code: 255
2022-04-21T21:30:57 [E] error while dispatching request to runner 368659ce-0e89-42b7-a032-05004a8a73d1:RuntimeError Control socket file does not exist:
/opt/theforeman/tfm/root/usr/share/gems/gems/smart_proxy_remote_execution_ssh-0.5.3/lib/smart_proxy_remote_execution_ssh/runners/script_runner.rb:201:in `close_session'
/opt/theforeman/tfm/root/usr/share/gems/gems/smart_proxy_remote_execution_ssh-0.5.3/lib/smart_proxy_remote_execution_ssh/runners/script_runner.rb:215:in `close'
/opt/theforeman/tfm/root/usr/share/gems/gems/smart_proxy_dynflow-0.7.0/lib/smart_proxy_dynflow/runner/dispatcher.rb:78:in `start_termination'
2022-04-21T21:30:59 bd77cf62 [E] Script execution failed
2022-04-21T21:31:07 bd77cf62 [E] <RuntimeError> A sub task failed
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.6.4/lib/dynflow/action/with_sub_plans.rb:231:in `check_for_errors!'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.6.4/lib/dynflow/action/with_sub_plans.rb:137:in `try_to_finish'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.6.4/lib/dynflow/action/with_polling_sub_plans.rb:19:in `poll'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.6.4/lib/dynflow/action/with_polling_sub_plans.rb:11:in `run'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.6.4/lib/dynflow/action.rb:582:in `block (3 levels) in execute_run'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.6.4/lib/dynflow/middleware/stack.rb:27:in `pass'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.6.4/lib/dynflow/middleware.rb:19:in `pass'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.6.4/lib/dynflow/action/progress.rb:31:in `with_progress_calculation'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.6.4/lib/dynflow/action/progress.rb:17:in `run'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.6.4/lib/dynflow/middleware/stack.rb:23:in `call'
/opt/theforeman/tfm/root/usr/share/gems/gems/smart_proxy_dynflow-0.7.0/lib/smart_proxy_dynflow/middleware/keep_current_request_id.rb:15:in `block in run'
/opt/theforeman/tfm/root/usr/share/gems/gems/smart_proxy_dynflow-0.7.0/lib/smart_proxy_dynflow/middleware/keep_current_request_id.rb:49:in `restore_current_request_id'
/opt/theforeman/tfm/root/usr/share/gems/gems/smart_proxy_dynflow-0.7.0/lib/smart_proxy_dynflow/middleware/keep_current_request_id.rb:15:in `run'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.6.4/lib/dynflow/middleware.rb:32:in `run'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.6.4/lib/dynflow/middleware/world.rb:31:in `execute'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.6.4/lib/dynflow/action.rb:581:in `block (2 levels) in execute_run'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.6.4/lib/dynflow/action.rb:580:in `catch'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.6.4/lib/dynflow/action.rb:580:in `block in execute_run'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.6.4/lib/dynflow/action.rb:483:in `block in with_error_handling'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.6.4/lib/dynflow/action.rb:483:in `catch'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.6.4/lib/dynflow/action.rb:483:in `with_error_handling'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.6.4/lib/dynflow/action.rb:575:in `execute_run'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.6.4/lib/dynflow/action.rb:296:in `execute'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.6.4/lib/dynflow/execution_plan/steps/abstract_flow_step.rb:18:in `block (2 levels) in execute'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.6.4/lib/dynflow/execution_plan/steps/abstract.rb:167:in `with_meta_calculation'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.6.4/lib/dynflow/execution_plan/steps/abstract_flow_step.rb:17:in `block in execute'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.6.4/lib/dynflow/execution_plan/steps/abstract_flow_step.rb:32:in `open_action'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.6.4/lib/dynflow/execution_plan/steps/abstract_flow_step.rb:16:in `execute'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.6.4/lib/dynflow/director.rb:94:in `execute'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.6.4/lib/dynflow/executors/parallel/worker.rb:15:in `block in on_message'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.6.4/lib/dynflow/executors.rb:18:in `run_user_code'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.6.4/lib/dynflow/executors/parallel/worker.rb:14:in `on_message'
Please let me know if you need more information.
