Remote execution return error " 1:
Failed to initialize: NoMethodError - undefined method `enabled_taxonomies’ for #Class:0x000000000a1a89c0
2:
Did you mean? enable_auditing"
Success
Version 1.24.0-develop
logs
This should be fixed by Bug #27746: remove taxonomy enabled checks - Foreman Remote Execution - Foreman which will be in the upcoming remote execution 1.8.5 release
Which version remote execution do you recommend?
I’m afraid we still don’t have a remote execution release that is compatible with nightly releases (1.24-develop). Either go with foreman-1.23 which is the latest stable release, or also use the latest remote execution from the github repo.
Thank you for your help. I will reinstall with foreman-1.23.
