Hello Gurus,
When I am trying to execute remote installation it fails with below error.
Failed to initialize: Dynflow::ExecutionPlan::Steps::Error - The only applicable proxy foreman01.testlab.local is down
Any assistance is appreciated
Regards/Bijith
Hello Gurus,
Does the foreman proxy service runs on that server?
Ohad
Regards/Bijith
On Dec 3, 2016 10:29 AM, "preetinaircr" wrote:
"Foreman users" group.
Was this ever solved? I'm having the same problem. I have a foreman
webserver that includes reports/ENC, and a separate foreman proxy running
on my puppet server.
On Saturday, December 3, 2016 at 2:29:14 AM UTC-6, preetinaircr wrote:
> Hello Gurus,
> Regards/Bijith
Also check if smart_proxy_dynflow_core service runs on that server. If
either this one or foreman-proxy is not running you'll get this error.
Adam
On Sat, Dec 3, 2016 at 11:12 AM, Ohad Levy wrote:
On Dec 3, 2016 10:29 AM, “preetinaircr” preetinaircr@gmail.com wrote:
Hello Gurus,
Ohad
Regards/Bijith
Please check that the smart proxy has ssh feature and service foreman-proxy
and smart_proxy_dynflow_core are running there. Bear with us and hopefully
we'll be able to find out why it is not working for you
Adam
On Sat, Dec 24, 2016 at 7:26 AM, Ben Howell wrote:
Was this ever solved? I’m having the same problem. I have a foreman
Hello Gurus,
Regards/Bijith
Hi Ben,
After the installation of smart_proxy_dynflow package, you'll find a script
'smart_proxy_dynflow_core' under /etc/init.d/, which you can use to start
the smart_proxy_dynflow_core service.
Additionally, please follow the
README(https://github.com/theforeman/smart_proxy_dynflow) to finish the
configuration of smart_proxy_dynflow_core.
Cheers,
> foreman-proxy and smart_proxy_dynflow_core are running there. Bear with us
> and hopefully we'll be able to find out why it is not working for you
> Adam
>>> Hello Gurus,
>>> error.
>>> Regards/Bijith
>> Visit this group at https://groups.google.com/group/foreman-users.
