Problem: After Katello upgrade to 3.12, Remote Execution jobs still run, but eventually report as failed. This occurs running jobs as Ansible Commands or SSH commands.
Expected outcome: Remote Execution jobs should run and report as completed successfully.
katello-3.12.3-1.el7.noarch
foreman-1.22.1-1.el7.noarch
foreman-proxy-1.22.1-1.el7.noarch
tfm-rubygem-foreman_ansible-3.0.3-1.fm1_22.el7.noarch
tfm-rubygem-foreman_remote_execution_core-1.2.0-1.el7.noarch
tfm-rubygem-foreman-tasks-0.15.11-1.fm1_22.el7.noarch
tfm-rubygem-foreman_ansible_core-3.0.1-1.fm1_22.el7.noarch
tfm-rubygem-hammer_cli_foreman_tasks-0.0.13-1.fm1_22.el7.noarch
tfm-rubygem-foreman_remote_execution-1.8.2-1.fm1_22.el7.noarch
rubygem-smart_proxy_dynflow-0.2.3-1.el7.noarch
rubygem-smart_proxy_remote_execution_ssh-0.2.1-1.el7.noarch
rubygem-smart_proxy_pulp-1.4.1-1.el7.noarch
tfm-rubygem-smart_proxy_dynflow_core-0.2.2-1.fm1_22.el7.noarch
rubygem-smart_proxy_ansible-3.0.1-1.fm1_22.el7.noarch
Red Hat Enterprise Linux 7.7
Uname: 3.10.0-1062.4.1.el7.x86_64 #1 SMP Wed Sep 25 09:42:57 EDT 2019 x86_64 x86_64 x86_64 GNU/Linux
Server originally installed with documentation Foreman :: Plugin Manuals
Upgraded to 3.11, all functionality working.
Upgraded to 3.12, issues began.
**Processes and ports they are running on:
port 8000 and 9090
foreman+ 1974 ruby /usr/share/foreman-proxy/bin/smart-proxy --no-daemonize
port 8008
foreman+ 3287 ruby /usr/bin/smart_proxy_dynflow_core -d -p /var/run/foreman-proxy/smart_proxy_dynflow_core.pid
port 8443 and 8005
tomcat 1984 /usr/lib/jvm/jre/bin/java -Xms1024m -Xmx4096m -classpath /usr/share/tomcat/bin/bootstrap.jar:/usr/share/tomcat/bin/tomcat-juli.jar:/usr/share/java/commons-daemon.jar -Dcatalina.base=/usr/share/tomcat -Dcatalina.home=/usr/share/tomcat -Djava.endorsed.dirs= -Djava.io.tmpdir=/var/cache/tomcat/temp -Djava.util.logging.config.file=/usr/share/tomcat/conf/logging.properties -Djava.util.logging.manager=org.apache.juli.ClassLoaderLogManager org.apache.catalina.startup.Bootstrap start
port 80
root 2070 /usr/sbin/httpd -DFOREGROUND
port 8140
puppet 2082 /usr/bin/java -Xms2G -Xmx2G -Djruby.logger.class=com.puppetlabs.jruby_utils.jruby.Slf4jLogger -Djava.security.egd=file:/dev/urandom -XX:OnOutOfMemoryError=kill -9 %p -cp /opt/puppetlabs/server/apps/puppetserver/puppet-server-release.jar:/opt/puppetlabs/server/apps/puppetserver/jruby-1_7.jar:/opt/puppetlabs/server/data/puppetserver/jars/* clojure.main -m puppetlabs.trapperkeeper.main --config /etc/puppetlabs/puppetserver/conf.d --bootstrap-config /etc/puppetlabs/puppetserver/services.d/,/opt/puppetlabs/server/apps/puppetserver/config/services.d/ --restart-file /opt/puppetlabs/server/data/puppetserver/restartcounter
Settings
/etc/foreman-proxy/settings.yml
:ssl_ca_file: /etc/foreman-proxy/ssl_ca.pem
:ssl_certificate: /etc/foreman-proxy/ssl_cert.pem
:ssl_private_key: /etc/foreman-proxy/ssl_key.pem
:trusted_hosts:
Endpoint for reverse communication
:foreman_url: http://kat7.xxx.xxx.com
:bind_host: ‘*’
:https_port: 9090
:http_port: 8000
/etc/smart_proxy_dynflow_core/settings.yml
:listen: 170.xxx.xxx.xxx
Listen on port
:port: 8008
/etc/foreman-proxy/settings.d/dynflow.yml
:enabled: true
#:database: /var/lib/foreman-proxy/dynflow/dynflow.sqlite
:database:
:core_url: ‘http://kat7.xxx.xxx.com:8008’
/etc/foreman-proxy/settings.d/remote_execution_ssh.yml
:enabled: true
:ssh_identity_key_file: /var/lib/foreman-proxy/ssh/id_rsa_foreman_proxy
:local_working_dir: /var/tmp
:remote_working_dir: /var/tmp
:kerberos_auth: false
:async_ssh: false
Do I have any settings configured incorrectly?
