Remote execution not using jump host/bastion host configuration
Remote execution tasks should use the local SSH configuration to jump through bastion hosts to reach the client host
Foreman - 3.5.1
Katello - 4.7
Foreman and Proxy plugin versions: 3.5.1
Distribution and version: Rocky Linux 8.7
  • My organisation uses bastion hosts to access our suite of servers and I have added the following configuration in /etc/ssh/ssh_config.d/06-platbot.conf (so that the configuration becomes system-wide):
CheckHostIP no
ForwardAgent yes
AddKeysToAgent yes
StrictHostKeyChecking=no
HostKeyAlgorithms +ssh-dss
Ciphers +aes256-cbc,3des-cbc
KexAlgorithms +diffie-hellman-group1-sha1
IdentityFile /usr/share/foreman-proxy/.ssh/id_rsa_foreman_proxy
Host *.platform.is !bastion.platform.is !<My bastion host FQDN>
    ProxyJump platbot@<My bastion host FQDN>
  • I have used the pub/private key for a user that we use for automation which exists on all our client hosts, and placed it in /usr/share/foreman-proxy/.ssh/:
# ls -al ~foreman-proxy/.ssh/id*
-rw-------. 1 foreman-proxy foreman-proxy 3381 Nov 30 09:01 /usr/share/foreman-proxy/.ssh/id_rsa_foreman_proxy
-rw-r--r--. 1 foreman-proxy foreman-proxy  737 Nov 30 09:02 /usr/share/foreman-proxy/.ssh/id_rsa_foreman_proxy.pub
  • The user under Administer → Settings → Remote Execution → SSH User has been changed to the user “platbot”
  • When executing the SSH command below which utilizes the appropriate configuration listed above, as the root user, the connection is successful:
# ssh -vv -i /usr/share/foreman-proxy/.ssh/id_rsa_foreman_proxy platbot@bootstrap01-stage-bry.okd4-stage.platform.is
OpenSSH_8.0p1, OpenSSL 1.1.1k  FIPS 25 Mar 2021
debug1: Reading configuration data /etc/ssh/ssh_config
debug1: Reading configuration data /etc/ssh/ssh_config.d/05-redhat.conf
debug2: checking match for 'final all' host bootstrap01-stage-bry.okd4-stage.platform.is originally bootstrap01-stage-bry.okd4-stage.platform.is
debug2: match not found
debug1: Reading configuration data /etc/crypto-policies/back-ends/openssh.config
debug1: Reading configuration data /etc/ssh/ssh_config.d/06-platbot.conf
debug1: /etc/ssh/ssh_config.d/06-platbot.conf line 11: Applying options for *.platform.is
debug1: configuration requests final Match pass
debug1: re-parsing configuration
debug2: match found
debug2: add_identity_file: ignoring duplicate key /usr/share/foreman-proxy/.ssh/id_rsa_foreman_proxy
debug1: Setting implicit ProxyCommand from ProxyJump: ssh -l platbot -vv -W '[%h]:%p' <My bastion host FQDN>
debug1: Executing proxy command: exec ssh -l platbot -vv -W '[bootstrap01-stage-bry.okd4-stage.platform.is]:22' <My bastion host FQDN>
debug1: identity file /usr/share/foreman-proxy/.ssh/id_rsa_foreman_proxy type 0
debug1: identity file /usr/share/foreman-proxy/.ssh/id_rsa_foreman_proxy-cert type -1
debug1: Local version string SSH-2.0-OpenSSH_8.0
debug2: checking match for 'final all' host <My bastion host FQDN> originally <My bastion host FQDN>
debug1: /etc/ssh/ssh_config.d/06-platbot.conf line 11: Skipping Host block because of negated match for <My bastion host FQDN>
debug2: match found
debug2: resolving "<My bastion host FQDN>" port 22
debug2: ssh_connect_direct
debug1: Connecting to <My bastion host FQDN> [172.21.0.2] port 22.
debug1: Connection established.
debug1: Remote protocol version 2.0, remote software version OpenSSH_7.2 FreeBSD-20160310
debug1: match: OpenSSH_7.2 FreeBSD-20160310 pat OpenSSH_7.0*,OpenSSH_7.1*,OpenSSH_7.2*,OpenSSH_7.3*,OpenSSH_7.4*,OpenSSH_7.5*,OpenSSH_7.6*,OpenSSH_7.7* compat 0x04000002
debug2: fd 3 setting O_NONBLOCK
debug1: Authenticating to <My bastion host FQDN>:22 as 'platbot'
debug1: SSH2_MSG_KEXINIT sent
debug1: SSH2_MSG_KEXINIT received
debug2: local client KEXINIT proposal
debug2: KEX algorithms: curve25519-sha256,curve25519-sha256@libssh.org,ecdh-sha2-nistp256,ecdh-sha2-nistp384,ecdh-sha2-nistp521,diffie-hellman-group-exchange-sha256,diffie-hellman-group16-sha512,diffie-hellman-group18-sha512,diffie-hellman-group14-sha256,diffie-hellman-group14-sha1,diffie-hellman-group1-sha1,ext-info-c
debug2: host key algorithms: ecdsa-sha2-nistp256-cert-v01@openssh.com,ecdsa-sha2-nistp384-cert-v01@openssh.com,ecdsa-sha2-nistp521-cert-v01@openssh.com,ssh-ed25519-cert-v01@openssh.com,rsa-sha2-512-cert-v01@openssh.com,rsa-sha2-256-cert-v01@openssh.com,ssh-rsa-cert-v01@openssh.com,ecdsa-sha2-nistp256,ecdsa-sha2-nistp384,ecdsa-sha2-nistp521,ssh-ed25519,rsa-sha2-512,rsa-sha2-256,ssh-rsa,ssh-dss
debug2: ciphers ctos: chacha20-poly1305@openssh.com,aes128-ctr,aes192-ctr,aes256-ctr,aes128-gcm@openssh.com,aes256-gcm@openssh.com,aes256-cbc,3des-cbc
debug2: ciphers stoc: chacha20-poly1305@openssh.com,aes128-ctr,aes192-ctr,aes256-ctr,aes128-gcm@openssh.com,aes256-gcm@openssh.com,aes256-cbc,3des-cbc
debug2: MACs ctos: hmac-sha2-256-etm@openssh.com,hmac-sha1-etm@openssh.com,umac-128-etm@openssh.com,hmac-sha2-512-etm@openssh.com,hmac-sha2-256,hmac-sha1,umac-128@openssh.com,hmac-sha2-512
debug2: MACs stoc: hmac-sha2-256-etm@openssh.com,hmac-sha1-etm@openssh.com,umac-128-etm@openssh.com,hmac-sha2-512-etm@openssh.com,hmac-sha2-256,hmac-sha1,umac-128@openssh.com,hmac-sha2-512
debug2: compression ctos: none,zlib@openssh.com,zlib
debug2: compression stoc: none,zlib@openssh.com,zlib
debug2: languages ctos:
debug2: languages stoc:
debug2: first_kex_follows 0
debug2: reserved 0
debug2: peer server KEXINIT proposal
debug2: KEX algorithms: curve25519-sha256@libssh.org,ecdh-sha2-nistp521,ecdh-sha2-nistp384,ecdh-sha2-nistp256,diffie-hellman-group-exchange-sha256
debug2: host key algorithms: ssh-rsa,rsa-sha2-512,rsa-sha2-256,ssh-dss,ecdsa-sha2-nistp256,ssh-ed25519
debug2: ciphers ctos: chacha20-poly1305@openssh.com,aes256-gcm@openssh.com,aes128-gcm@openssh.com,aes256-ctr,aes192-ctr,aes128-ctr
debug2: ciphers stoc: chacha20-poly1305@openssh.com,aes256-gcm@openssh.com,aes128-gcm@openssh.com,aes256-ctr,aes192-ctr,aes128-ctr
debug2: MACs ctos: hmac-sha2-512-etm@openssh.com,hmac-sha2-256-etm@openssh.com,umac-128-etm@openssh.com,hmac-sha2-512,hmac-sha2-256,umac-128@openssh.com
debug2: MACs stoc: hmac-sha2-512-etm@openssh.com,hmac-sha2-256-etm@openssh.com,umac-128-etm@openssh.com,hmac-sha2-512,hmac-sha2-256,umac-128@openssh.com
debug2: reserved 0
debug1: kex: algorithm: curve25519-sha256@libssh.org
debug1: kex: host key algorithm: ecdsa-sha2-nistp256
debug1: kex: server->client cipher: chacha20-poly1305@openssh.com MAC: <implicit> compression: none
debug1: kex: client->server cipher: chacha20-poly1305@openssh.com MAC: <implicit> compression: none
debug1: kex: curve25519-sha256@libssh.org need=64 dh_need=64
debug1: expecting SSH2_MSG_KEX_ECDH_REPLY
debug1: Server host key: ecdsa-sha2-nistp256 SHA256:PVLEk5jJrifM1ykaiU8ryb5Wu63rnwUoJRw54BkJAS0
debug1: Host '<My bastion host FQDN>' is known and matches the ECDSA host key.
debug1: Found key in /root/.ssh/known_hosts:1
debug2: set_newkeys: mode 1
debug1: rekey out after 134217728 blocks
debug1: SSH2_MSG_NEWKEYS sent
debug1: expecting SSH2_MSG_NEWKEYS
debug1: SSH2_MSG_NEWKEYS received
debug2: set_newkeys: mode 0
debug1: rekey in after 134217728 blocks
debug1: Will attempt key: /usr/share/foreman-proxy/.ssh/id_rsa_foreman_proxy RSA SHA256:oHEDJ+/Zs1x/YYU7YE9s1lxt9Crhniyf/htec1ukCLs
debug2: pubkey_prepare: done
debug1: SSH2_MSG_EXT_INFO received
debug1: kex_input_ext_info: server-sig-algs=<rsa-sha2-256,rsa-sha2-512>
debug2: service_accept: ssh-userauth
debug1: SSH2_MSG_SERVICE_ACCEPT received
debug1: Authentications that can continue: publickey
debug1: Next authentication method: publickey
debug1: Offering public key: /usr/share/foreman-proxy/.ssh/id_rsa_foreman_proxy RSA SHA256:oHEDJ+/Zs1x/YYU7YE9s1lxt9Crhniyf/htec1ukCLs
debug2: we sent a publickey packet, wait for reply
debug1: Server accepts key: /usr/share/foreman-proxy/.ssh/id_rsa_foreman_proxy RSA SHA256:oHEDJ+/Zs1x/YYU7YE9s1lxt9Crhniyf/htec1ukCLs
debug1: Authentication succeeded (publickey).
Authenticated to <My bastion host FQDN> ([172.21.0.2]:22).
debug1: channel_connect_stdio_fwd bootstrap01-stage-bry.okd4-stage.platform.is:22
debug2: fd 4 setting O_NONBLOCK
debug1: channel 0: new [stdio-forward]
debug2: fd 6 setting O_NONBLOCK
debug1: getpeername failed: Bad file descriptor
debug2: fd 3 setting TCP_NODELAY
debug1: Requesting no-more-sessions@openssh.com
debug1: Entering interactive session.
debug1: pledge: network
debug1: client_input_global_request: rtype hostkeys-00@openssh.com want_reply 0
debug2: channel_input_open_confirmation: channel 0: callback start
debug2: channel_input_open_confirmation: channel 0: callback done
debug2: channel 0: open confirm rwindow 2097152 rmax 32768
debug1: Remote protocol version 2.0, remote software version OpenSSH_8.0
debug1: match: OpenSSH_8.0 pat OpenSSH* compat 0x04000000
debug1: Authenticating to bootstrap01-stage-bry.okd4-stage.platform.is:22 as 'platbot'
debug2: reserved 0
debug2: KEX algorithms: curve25519-sha256,curve25519-sha256@libssh.org,ecdh-sha2-nistp256,ecdh-sha2-nistp384,ecdh-sha2-nistp521,diffie-hellman-group-exchange-sha256,diffie-hellman-group14-sha256,diffie-hellman-group16-sha512,diffie-hellman-group18-sha512,diffie-hellman-group-exchange-sha1,diffie-hellman-group14-sha1
debug2: host key algorithms: rsa-sha2-512,rsa-sha2-256,ssh-rsa,ecdsa-sha2-nistp256,ssh-ed25519
debug2: ciphers ctos: aes256-gcm@openssh.com,chacha20-poly1305@openssh.com,aes256-ctr,aes256-cbc,aes128-gcm@openssh.com,aes128-ctr,aes128-cbc
debug2: ciphers stoc: aes256-gcm@openssh.com,chacha20-poly1305@openssh.com,aes256-ctr,aes256-cbc,aes128-gcm@openssh.com,aes128-ctr,aes128-cbc
debug2: reserved 0
debug1: kex: curve25519-sha256 need=64 dh_need=64
debug1: Server host key: ecdsa-sha2-nistp256 SHA256:E0Ou/LKhoMDbRMm4Kgi7DPzG6CwDUF5yXppm5rps0Xo
debug1: Host 'bootstrap01-stage-bry.okd4-stage.platform.is' is known and matches the ECDSA host key.
debug1: Found key in /root/.ssh/known_hosts:4
debug1: Will attempt key: /usr/share/foreman-proxy/.ssh/id_rsa_foreman_proxy RSA SHA256:oHEDJ+/Zs1x/YYU7YE9s1lxt9Crhniyf/htec1ukCLs explicit
debug1: kex_input_ext_info: server-sig-algs=<ssh-ed25519,ssh-rsa,rsa-sha2-256,rsa-sha2-512,ssh-dss,ecdsa-sha2-nistp256,ecdsa-sha2-nistp384,ecdsa-sha2-nistp521>
debug1: Offering public key: /usr/share/foreman-proxy/.ssh/id_rsa_foreman_proxy RSA SHA256:oHEDJ+/Zs1x/YYU7YE9s1lxt9Crhniyf/htec1ukCLs explicit
debug1: Server accepts key: /usr/share/foreman-proxy/.ssh/id_rsa_foreman_proxy RSA SHA256:oHEDJ+/Zs1x/YYU7YE9s1lxt9Crhniyf/htec1ukCLs explicit
Authenticated to bootstrap01-stage-bry.okd4-stage.platform.is (via proxy).
debug1: channel 0: new [client-session]
debug2: channel 0: send open
debug1: pledge: proc
debug1: Remote: /home/platbot/.ssh/authorized_keys:2: key options: agent-forwarding port-forwarding pty user-rc x11-forwarding
debug2: client_session2_setup: id 0
debug2: channel 0: request pty-req confirm 1
debug1: Sending environment.
debug1: Sending env LC_ALL = en_US.UTF-8
debug2: channel 0: request env confirm 0
debug1: Sending env LANG = en_ZA.UTF-8
debug1: Sending env LC_CTYPE = UTF-8
debug2: channel 0: request shell confirm 1
debug2: channel 0: open confirm rwindow 0 rmax 32768
debug2: channel_input_status_confirm: type 99 id 0
debug2: PTY allocation request accepted on channel 0
debug2: channel 0: rcvd adjust 2097152
debug2: shell request accepted on channel 0
Last login: Wed Feb  1 08:39:51 2023 from 172.21.0.2
[platbot@bootstrap01-stage-bry ~]$
  • I can su to the foreman-proxy user and SSH to the target host, which jumps through my bastion host:
# su - foreman-proxy -c /bin/bash
bash: cannot set terminal process group (-1): Inappropriate ioctl for device
bash: no job control in this shell
bash-4.4$ id
uid=295(foreman-proxy) gid=296(foreman-proxy) groups=296(foreman-proxy) context=unconfined_u:unconfined_r:unconfined_t:s0-s0:c0.c1023
bash-4.4$ ssh  -vv platbot@bootstrap01-stage-bry.okd4-stage.platform.is
debug2: match found
debug2: match found
debug2: reserved 0
debug2: reserved 0
debug1: Found key in /usr/share/foreman-proxy/.ssh/known_hosts:2
debug2: reserved 0
debug2: reserved 0
debug1: Found key in /usr/share/foreman-proxy/.ssh/known_hosts:4
debug1: Sending env LANG = en_US.UTF-8
Last login: Wed Feb  1 09:22:29 2023 from 172.21.0.2
  • I first attempted to execute a simple command via the GUI (Hosts → All Hosts → Selected the tickbox for the host → Select Action → Schedule Remote Job, against a client host in the same IP range as the master host. While this should still use the SSH bastion config, it will still work if it doesn’t as it is in the same range, and it works. So I assume that the remote execution plugin and the SSH key’s and SSH user are all good.
  • However, when attempting to execute a job against the same host in the snippets above (the access for which worked manually using the system-wide configuration), the job times out.
  • The debug level settings were increased in verbosity in the following files:
# grep -i debug /etc/foreman-proxy/settings.yml
# WARN, DEBUG, ERROR, FATAL, INFO, UNKNOWN
:log_level: DEBUG
# grep -i debug /etc/foreman-proxy/settings.d/remote_execution_ssh.yml
:ssh_log_level: debug
When rerunning the job with these increased debug levels, the output in /var/log/foreman-proxy is as follows:
2023-02-01T09:20:06  [D] Executor heartbeat
2023-02-01T09:20:19  [D] accept: 172.20.9.26:56414
2023-02-01T09:20:19  [D] Rack::Handler::WEBrick is invoked.
2023-02-01T09:20:19 b70782e9 [I] Started GET /dynflow/tasks/count state=running
2023-02-01T09:20:19 b70782e9 [D] verifying remote client 172.20.9.26 against trusted_hosts ["forekat-master01-stage-bry.platform.is"]
2023-02-01T09:20:19 b70782e9 [I] Finished GET /dynflow/tasks/count with 200 (1.03 ms)
2023-02-01T09:20:19  [D] close: 172.20.9.26:56414
2023-02-01T09:20:19  [D] accept: 172.20.9.26:56430
2023-02-01T09:20:19 b70782e9 [I] Started POST /dynflow/tasks/launch
2023-02-01T09:20:19 b70782e9 [D] ExecutionPlan e1f3b9f6-ea5c-4c47-95a0-94d79f2d171c      pending >>  planning
2023-02-01T09:20:19 b70782e9 [D]          Step e1f3b9f6-ea5c-4c47-95a0-94d79f2d171c: 1   pending >>   running in phase     Plan Proxy::Dynflow::Action::Batch
2023-02-01T09:20:19 b70782e9 [D]          Step e1f3b9f6-ea5c-4c47-95a0-94d79f2d171c: 1   running >>   success in phase     Plan Proxy::Dynflow::Action::Batch
2023-02-01T09:20:19 b70782e9 [D] ExecutionPlan e1f3b9f6-ea5c-4c47-95a0-94d79f2d171c     planning >>   planned
2023-02-01T09:20:19  [D] ExecutionPlan e1f3b9f6-ea5c-4c47-95a0-94d79f2d171c      planned >>   running
2023-02-01T09:20:19 b70782e9 [I] Finished POST /dynflow/tasks/launch with 200 (21.25 ms)
2023-02-01T09:20:19  [D]          Step e1f3b9f6-ea5c-4c47-95a0-94d79f2d171c: 2   pending >>   running in phase      Run Proxy::Dynflow::Action::Batch
2023-02-01T09:20:19 b70782e9 [D] ExecutionPlan 0b62997c-57f4-45d2-9204-f0ce70c5e6ec      pending >>  planning
2023-02-01T09:20:19 b70782e9 [D]          Step 0b62997c-57f4-45d2-9204-f0ce70c5e6ec: 1   pending >>   running in phase     Plan Proxy::RemoteExecution::Ssh::Actions::RunScript
2023-02-01T09:20:19 b70782e9 [D]          Step 0b62997c-57f4-45d2-9204-f0ce70c5e6ec: 2   pending >>   running in phase     Plan Proxy::RemoteExecution::Ssh::Actions::ScriptRunner
2023-02-01T09:20:19 b70782e9 [D]          Step 0b62997c-57f4-45d2-9204-f0ce70c5e6ec: 5   pending >>   running in phase     Plan Proxy::Dynflow::Callback::Action
2023-02-01T09:20:19 b70782e9 [D]          Step 0b62997c-57f4-45d2-9204-f0ce70c5e6ec: 5   running >>   success in phase     Plan Proxy::Dynflow::Callback::Action
2023-02-01T09:20:19 b70782e9 [D]          Step 0b62997c-57f4-45d2-9204-f0ce70c5e6ec: 2   running >>   success in phase     Plan Proxy::RemoteExecution::Ssh::Actions::ScriptRunner
2023-02-01T09:20:19 b70782e9 [D]          Step 0b62997c-57f4-45d2-9204-f0ce70c5e6ec: 1   running >>   success in phase     Plan Proxy::RemoteExecution::Ssh::Actions::RunScript
2023-02-01T09:20:19 b70782e9 [D] ExecutionPlan 0b62997c-57f4-45d2-9204-f0ce70c5e6ec     planning >>   planned
2023-02-01T09:20:19  [D] close: 172.20.9.26:56430
2023-02-01T09:20:19 b70782e9 [D]          Step e1f3b9f6-ea5c-4c47-95a0-94d79f2d171c: 2   running >> suspended in phase      Run Proxy::Dynflow::Action::Batch
2023-02-01T09:20:19  [D] ExecutionPlan 0b62997c-57f4-45d2-9204-f0ce70c5e6ec      planned >>   running
2023-02-01T09:20:19  [D]          Step 0b62997c-57f4-45d2-9204-f0ce70c5e6ec: 3   pending >>   running in phase      Run Proxy::RemoteExecution::Ssh::Actions::ScriptRunner
2023-02-01T09:20:19 b70782e9 [D]          Step 0b62997c-57f4-45d2-9204-f0ce70c5e6ec: 3   running >> suspended in phase      Run Proxy::RemoteExecution::Ssh::Actions::ScriptRunner
2023-02-01T09:20:19  [D] start runner d80ceb13-779f-4aee-baed-6f403fcf71a3
2023-02-01T09:20:19  [D] Checking if private key has passphrase: ssh-keygen -y -f /var/lib/foreman-proxy/ssh/id_rsa_foreman_proxy
2023-02-01T09:20:19  [D] Private key is not protected with a passphrase
2023-02-01T09:20:19  [D] Running: ssh -o User=platbot -o Port=22 -o IdentityFile=/var/lib/foreman-proxy/ssh/id_rsa_foreman_proxy -o IdentitiesOnly=yes -o StrictHostKeyChecking=no -o LogLevel=debug -o ControlMaster=auto -o ControlPath=/var/tmp/d80ceb13-779f-4aee-baed-6f403fcf71a3 -o ControlPersist=yes -o ProxyCommand=none -o PreferredAuthentications=publickey -o NumberOfPasswordPrompts=0 bootstrap01-stage-bry.okd4-stage.platform.is true
2023-02-01T09:20:19  [D] debug1: Reading configuration data /etc/ssh/ssh_config
2023-02-01T09:20:19  [D] debug1: Reading configuration data /etc/ssh/ssh_config.d/05-redhat.conf
2023-02-01T09:20:19  [D] debug1: Reading configuration data /etc/crypto-policies/back-ends/openssh.config
2023-02-01T09:20:19  [D] debug1: Reading configuration data /etc/ssh/ssh_config.d/06-platbot.conf
2023-02-01T09:20:19  [D] debug1: /etc/ssh/ssh_config.d/06-platbot.conf line 11: Applying options for *.platform.is
2023-02-01T09:20:19  [D] debug1: configuration requests final Match pass
2023-02-01T09:20:19  [D] debug1: re-parsing configuration
2023-02-01T09:20:19  [D] debug1: auto-mux: Trying existing master
2023-02-01T09:20:19  [D] debug1: Control socket "/var/tmp/d80ceb13-779f-4aee-baed-6f403fcf71a3" does not exist
2023-02-01T09:20:19  [D] debug1: Connecting to bootstrap01-stage-bry.okd4-stage.platform.is [172.20.8.253] port 22.
2023-02-01T09:20:21  [D] Executor heartbeat
2023-02-01T09:20:29  [D]          Step e1f3b9f6-ea5c-4c47-95a0-94d79f2d171c: 2 got event Dynflow::Action::WithPollingSubPlans::Poll
2023-02-01T09:20:29  [D]          Step e1f3b9f6-ea5c-4c47-95a0-94d79f2d171c: 2 suspended >>   running in phase      Run Proxy::Dynflow::Action::Batch
2023-02-01T09:20:29 b70782e9 [D]          Step e1f3b9f6-ea5c-4c47-95a0-94d79f2d171c: 2   running >> suspended in phase      Run Proxy::Dynflow::Action::Batch
2023-02-01T09:20:36  [D] Executor heartbeat
2023-02-01T09:20:39  [D]          Step e1f3b9f6-ea5c-4c47-95a0-94d79f2d171c: 2 got event Dynflow::Action::WithPollingSubPlans::Poll
2023-02-01T09:20:39  [D]          Step e1f3b9f6-ea5c-4c47-95a0-94d79f2d171c: 2 suspended >>   running in phase      Run Proxy::Dynflow::Action::Batch
2023-02-01T09:20:39 b70782e9 [D]          Step e1f3b9f6-ea5c-4c47-95a0-94d79f2d171c: 2   running >> suspended in phase      Run Proxy::Dynflow::Action::Batch
2023-02-01T09:20:49  [D]          Step e1f3b9f6-ea5c-4c47-95a0-94d79f2d171c: 2 got event Dynflow::Action::WithPollingSubPlans::Poll
2023-02-01T09:20:49  [D]          Step e1f3b9f6-ea5c-4c47-95a0-94d79f2d171c: 2 suspended >>   running in phase      Run Proxy::Dynflow::Action::Batch
2023-02-01T09:20:49 b70782e9 [D]          Step e1f3b9f6-ea5c-4c47-95a0-94d79f2d171c: 2   running >> suspended in phase      Run Proxy::Dynflow::Action::Batch
2023-02-01T09:20:51  [D] Executor heartbeat
2023-02-01T09:20:59  [D]          Step e1f3b9f6-ea5c-4c47-95a0-94d79f2d171c: 2 got event Dynflow::Action::WithPollingSubPlans::Poll
2023-02-01T09:20:59  [D]          Step e1f3b9f6-ea5c-4c47-95a0-94d79f2d171c: 2 suspended >>   running in phase      Run Proxy::Dynflow::Action::Batch
2023-02-01T09:20:59 b70782e9 [D]          Step e1f3b9f6-ea5c-4c47-95a0-94d79f2d171c: 2   running >> suspended in phase      Run Proxy::Dynflow::Action::Batch
2023-02-01T09:21:06  [D] Executor heartbeat
2023-02-01T09:21:09  [D]          Step e1f3b9f6-ea5c-4c47-95a0-94d79f2d171c: 2 got event Dynflow::Action::WithPollingSubPlans::Poll
2023-02-01T09:21:09  [D]          Step e1f3b9f6-ea5c-4c47-95a0-94d79f2d171c: 2 suspended >>   running in phase      Run Proxy::Dynflow::Action::Batch
2023-02-01T09:21:09 b70782e9 [D]          Step e1f3b9f6-ea5c-4c47-95a0-94d79f2d171c: 2   running >> suspended in phase      Run Proxy::Dynflow::Action::Batch
2023-02-01T09:21:19  [D]          Step e1f3b9f6-ea5c-4c47-95a0-94d79f2d171c: 2 got event Dynflow::Action::WithPollingSubPlans::Poll
2023-02-01T09:21:19  [D]          Step e1f3b9f6-ea5c-4c47-95a0-94d79f2d171c: 2 suspended >>   running in phase      Run Proxy::Dynflow::Action::Batch
2023-02-01T09:21:19 b70782e9 [D]          Step e1f3b9f6-ea5c-4c47-95a0-94d79f2d171c: 2   running >> suspended in phase      Run Proxy::Dynflow::Action::Batch
2023-02-01T09:21:21  [D] Executor heartbeat
2023-02-01T09:21:29  [D]          Step e1f3b9f6-ea5c-4c47-95a0-94d79f2d171c: 2 got event Dynflow::Action::WithPollingSubPlans::Poll
2023-02-01T09:21:29  [D]          Step e1f3b9f6-ea5c-4c47-95a0-94d79f2d171c: 2 suspended >>   running in phase      Run Proxy::Dynflow::Action::Batch
2023-02-01T09:21:29 b70782e9 [D]          Step e1f3b9f6-ea5c-4c47-95a0-94d79f2d171c: 2   running >> suspended in phase      Run Proxy::Dynflow::Action::Batch
2023-02-01T09:21:36  [D] Executor heartbeat
2023-02-01T09:21:39  [D]          Step e1f3b9f6-ea5c-4c47-95a0-94d79f2d171c: 2 got event Dynflow::Action::WithPollingSubPlans::Poll
2023-02-01T09:21:39  [D]          Step e1f3b9f6-ea5c-4c47-95a0-94d79f2d171c: 2 suspended >>   running in phase      Run Proxy::Dynflow::Action::Batch
2023-02-01T09:21:39 b70782e9 [D]          Step e1f3b9f6-ea5c-4c47-95a0-94d79f2d171c: 2   running >> suspended in phase      Run Proxy::Dynflow::Action::Batch
2023-02-01T09:21:49  [D]          Step e1f3b9f6-ea5c-4c47-95a0-94d79f2d171c: 2 got event Dynflow::Action::WithPollingSubPlans::Poll
2023-02-01T09:21:49  [D]          Step e1f3b9f6-ea5c-4c47-95a0-94d79f2d171c: 2 suspended >>   running in phase      Run Proxy::Dynflow::Action::Batch
2023-02-01T09:21:49 b70782e9 [D]          Step e1f3b9f6-ea5c-4c47-95a0-94d79f2d171c: 2   running >> suspended in phase      Run Proxy::Dynflow::Action::Batch
2023-02-01T09:21:51  [D] Executor heartbeat
2023-02-01T09:21:59  [D]          Step e1f3b9f6-ea5c-4c47-95a0-94d79f2d171c: 2 got event Dynflow::Action::WithPollingSubPlans::Poll
2023-02-01T09:21:59  [D]          Step e1f3b9f6-ea5c-4c47-95a0-94d79f2d171c: 2 suspended >>   running in phase      Run Proxy::Dynflow::Action::Batch
2023-02-01T09:21:59 b70782e9 [D]          Step e1f3b9f6-ea5c-4c47-95a0-94d79f2d171c: 2   running >> suspended in phase      Run Proxy::Dynflow::Action::Batch
2023-02-01T09:22:06  [D] Executor heartbeat
2023-02-01T09:22:09  [D]          Step e1f3b9f6-ea5c-4c47-95a0-94d79f2d171c: 2 got event Dynflow::Action::WithPollingSubPlans::Poll
2023-02-01T09:22:09  [D]          Step e1f3b9f6-ea5c-4c47-95a0-94d79f2d171c: 2 suspended >>   running in phase      Run Proxy::Dynflow::Action::Batch
2023-02-01T09:22:09 b70782e9 [D]          Step e1f3b9f6-ea5c-4c47-95a0-94d79f2d171c: 2   running >> suspended in phase      Run Proxy::Dynflow::Action::Batch
2023-02-01T09:22:19  [D]          Step e1f3b9f6-ea5c-4c47-95a0-94d79f2d171c: 2 got event Dynflow::Action::WithPollingSubPlans::Poll
2023-02-01T09:22:19  [D]          Step e1f3b9f6-ea5c-4c47-95a0-94d79f2d171c: 2 suspended >>   running in phase      Run Proxy::Dynflow::Action::Batch
2023-02-01T09:22:19 b70782e9 [D]          Step e1f3b9f6-ea5c-4c47-95a0-94d79f2d171c: 2   running >> suspended in phase      Run Proxy::Dynflow::Action::Batch
2023-02-01T09:22:21  [D] Executor heartbeat
2023-02-01T09:22:29  [D]          Step e1f3b9f6-ea5c-4c47-95a0-94d79f2d171c: 2 got event Dynflow::Action::WithPollingSubPlans::Poll
2023-02-01T09:22:29  [D]          Step e1f3b9f6-ea5c-4c47-95a0-94d79f2d171c: 2 suspended >>   running in phase      Run Proxy::Dynflow::Action::Batch
2023-02-01T09:22:29 b70782e9 [D]          Step e1f3b9f6-ea5c-4c47-95a0-94d79f2d171c: 2   running >> suspended in phase      Run Proxy::Dynflow::Action::Batch
2023-02-01T09:22:31  [D] debug1: connect to address 172.20.8.253 port 22: Connection timed out
2023-02-01T09:22:31  [D] ssh: connect to host bootstrap01-stage-bry.okd4-stage.platform.is port 22: Connection timed out
2023-02-01T09:22:31  [D] Failed to establish connection using authentication method publickey
2023-02-01T09:22:31  [E] error while initializing command RuntimeError Could not establish connection to remote host using any available authentication method, tried publickey:
 /usr/share/gems/gems/smart_proxy_remote_execution_ssh-0.9.0/lib/smart_proxy_remote_execution_ssh/multiplexed_ssh_connection.rb:75:in `establish!'
/usr/share/gems/gems/smart_proxy_remote_execution_ssh-0.9.0/lib/smart_proxy_remote_execution_ssh/runners/script_runner.rb:149:in `start'
/usr/share/gems/gems/smart_proxy_dynflow-0.9.0/lib/smart_proxy_dynflow/runner/dispatcher.rb:32:in `start_runner'
/usr/share/gems/gems/dynflow-1.6.8/lib/dynflow/actor.rb:13:in `on_message'
/usr/share/gems/gems/concurrent-ruby-edge-0.6.0/lib/concurrent-ruby-edge/concurrent/actor/context.rb:46:in `on_envelope'
/usr/share/gems/gems/smart_proxy_dynflow-0.9.0/lib/smart_proxy_dynflow/runner/dispatcher.rb:24:in `on_envelope'
/usr/share/gems/gems/concurrent-ruby-edge-0.6.0/lib/concurrent-ruby-edge/concurrent/actor/behaviour/executes_context.rb:7:in `on_envelope'
/usr/share/gems/gems/concurrent-ruby-edge-0.6.0/lib/concurrent-ruby-edge/concurrent/actor/behaviour/abstract.rb:25:in `pass'
/usr/share/gems/gems/dynflow-1.6.8/lib/dynflow/actor.rb:122:in `on_envelope'
/usr/share/gems/gems/concurrent-ruby-edge-0.6.0/lib/concurrent-ruby-edge/concurrent/actor/behaviour/awaits.rb:15:in `on_envelope'
/usr/share/gems/gems/concurrent-ruby-edge-0.6.0/lib/concurrent-ruby-edge/concurrent/actor/behaviour/sets_results.rb:14:in `on_envelope'
/usr/share/gems/gems/dynflow-1.6.8/lib/dynflow/actor.rb:56:in `on_envelope'
/usr/share/gems/gems/concurrent-ruby-edge-0.6.0/lib/concurrent-ruby-edge/concurrent/actor/behaviour/buffer.rb:38:in `process_envelope'
/usr/share/gems/gems/concurrent-ruby-edge-0.6.0/lib/concurrent-ruby-edge/concurrent/actor/behaviour/buffer.rb:31:in `process_envelopes?'
/usr/share/gems/gems/concurrent-ruby-edge-0.6.0/lib/concurrent-ruby-edge/concurrent/actor/behaviour/buffer.rb:20:in `on_envelope'
/usr/share/gems/gems/concurrent-ruby-edge-0.6.0/lib/concurrent-ruby-edge/concurrent/actor/behaviour/termination.rb:55:in `on_envelope'
/usr/share/gems/gems/concurrent-ruby-edge-0.6.0/lib/concurrent-ruby-edge/concurrent/actor/behaviour/removes_child.rb:10:in `on_envelope'
/usr/share/gems/gems/concurrent-ruby-edge-0.6.0/lib/concurrent-ruby-edge/concurrent/actor/core.rb:162:in `process_envelope'
/usr/share/gems/gems/concurrent-ruby-edge-0.6.0/lib/concurrent-ruby-edge/concurrent/actor/core.rb:96:in `block in on_envelope'
/usr/share/gems/gems/concurrent-ruby-edge-0.6.0/lib/concurrent-ruby-edge/concurrent/actor/core.rb:119:in `block (2 levels) in schedule_execution'
/usr/share/gems/gems/concurrent-ruby-1.1.10/lib/concurrent-ruby/concurrent/synchronization/mutex_lockable_object.rb:47:in `block in synchronize'
/usr/share/gems/gems/concurrent-ruby-1.1.10/lib/concurrent-ruby/concurrent/synchronization/mutex_lockable_object.rb:47:in `synchronize'
/usr/share/gems/gems/concurrent-ruby-edge-0.6.0/lib/concurrent-ruby-edge/concurrent/actor/core.rb:116:in `block in schedule_execution'
/usr/share/gems/gems/concurrent-ruby-1.1.10/lib/concurrent-ruby/concurrent/executor/serialized_execution.rb:18:in `call'
/usr/share/gems/gems/concurrent-ruby-1.1.10/lib/concurrent-ruby/concurrent/executor/serialized_execution.rb:96:in `work'
/usr/share/gems/gems/concurrent-ruby-1.1.10/lib/concurrent-ruby/concurrent/executor/serialized_execution.rb:77:in `block in call_job'
/usr/share/gems/gems/concurrent-ruby-1.1.10/lib/concurrent-ruby/concurrent/executor/ruby_thread_pool_executor.rb:352:in `run_task'
/usr/share/gems/gems/concurrent-ruby-1.1.10/lib/concurrent-ruby/concurrent/executor/ruby_thread_pool_executor.rb:343:in `block (3 levels) in create_worker'
/usr/share/gems/gems/concurrent-ruby-1.1.10/lib/concurrent-ruby/concurrent/executor/ruby_thread_pool_executor.rb:334:in `loop'
/usr/share/gems/gems/concurrent-ruby-1.1.10/lib/concurrent-ruby/concurrent/executor/ruby_thread_pool_executor.rb:334:in `block (2 levels) in create_worker'
/usr/share/gems/gems/concurrent-ruby-1.1.10/lib/concurrent-ruby/concurrent/executor/ruby_thread_pool_executor.rb:333:in `catch'
/usr/share/gems/gems/concurrent-ruby-1.1.10/lib/concurrent-ruby/concurrent/executor/ruby_thread_pool_executor.rb:333:in `block in create_worker'
/usr/share/gems/gems/logging-2.3.1/lib/logging/diagnostic_context.rb:474:in `block in create_with_logging_context'
2023-02-01T09:22:31  [E] Error initializing command - RuntimeError Could not establish connection to remote host using any available authentication method, tried publickey:
2023-02-01T09:22:31  [D] refresh runner d80ceb13-779f-4aee-baed-6f403fcf71a3
2023-02-01T09:22:31  [D] refreshing runner
2023-02-01T09:22:31  [D] finish runner d80ceb13-779f-4aee-baed-6f403fcf71a3
2023-02-01T09:22:31  [D] closing session for command [d80ceb13-779f-4aee-baed-6f403fcf71a3],0 actors left
2023-02-01T09:22:31  [D] terminate d80ceb13-779f-4aee-baed-6f403fcf71a3
2023-02-01T09:22:31  [D]          Step 0b62997c-57f4-45d2-9204-f0ce70c5e6ec: 3 got event #<Proxy::Dynflow::Runner::Update:0x000055de1c111908>
2023-02-01T09:22:31  [D]          Step 0b62997c-57f4-45d2-9204-f0ce70c5e6ec: 3 suspended >>   running in phase      Run Proxy::RemoteExecution::Ssh::Actions::ScriptRunner
2023-02-01T09:22:31 b70782e9 [D]          Step 0b62997c-57f4-45d2-9204-f0ce70c5e6ec: 3   running >>   success in phase      Run Proxy::RemoteExecution::Ssh::Actions::ScriptRunner
2023-02-01T09:22:31  [D]          Step 0b62997c-57f4-45d2-9204-f0ce70c5e6ec: 6   pending >>   running in phase      Run Proxy::Dynflow::Callback::Action
2023-02-01T09:22:31 b70782e9 [D]          Step 0b62997c-57f4-45d2-9204-f0ce70c5e6ec: 6   running >>   success in phase      Run Proxy::Dynflow::Callback::Action
2023-02-01T09:22:31  [D]          Step 0b62997c-57f4-45d2-9204-f0ce70c5e6ec: 4   pending >>   running in phase Finalize Proxy::RemoteExecution::Ssh::Actions::ScriptRunner
2023-02-01T09:22:31 b70782e9 [E] Script execution failed
2023-02-01T09:22:31 b70782e9 [D]          Step 0b62997c-57f4-45d2-9204-f0ce70c5e6ec: 4   running >>     error in phase Finalize Proxy::RemoteExecution::Ssh::Actions::ScriptRunner
2023-02-01T09:22:31  [D] ExecutionPlan 0b62997c-57f4-45d2-9204-f0ce70c5e6ec      running >>   stopped
2023-02-01T09:22:36  [D] Executor heartbeat
2023-02-01T09:22:39  [D]          Step e1f3b9f6-ea5c-4c47-95a0-94d79f2d171c: 2 got event Dynflow::Action::WithPollingSubPlans::Poll
2023-02-01T09:22:39  [D]          Step e1f3b9f6-ea5c-4c47-95a0-94d79f2d171c: 2 suspended >>   running in phase      Run Proxy::Dynflow::Action::Batch
2023-02-01T09:22:39 b70782e9 [E] <Dynflow::Action::WithSubPlans::SubtaskFailedException> A sub task failed
2023-02-01T09:22:39 b70782e9 [D]          Step e1f3b9f6-ea5c-4c47-95a0-94d79f2d171c: 2   running >>     error in phase      Run Proxy::Dynflow::Action::Batch
2023-02-01T09:22:39  [D] ExecutionPlan e1f3b9f6-ea5c-4c47-95a0-94d79f2d171c      running >>   stopped
  • The job appears to time out due to the destination host being unreachable, due to the connection not jumping through the bastion host. I does appear to be parsing the SSH configuration file:
  • I also noticed the ProxyCommand=none portion of this line:
I feel like I’m being a muppet and missing something basic here and any assistance would be appreciated!
Edit:
I’ve also added the following ProxyCommand statement in the global SSH configuration file, which had no effect:
    ProxyCommand ssh -W %h:%p platbot@bastion01.platform.is
Putting this into the global section of ssh_config is evil. The foreman-proxy remote execution picks the correct identity file on the command line. Don’t refer to it in ssh_config. All other users except root and foreman-proxy may not be able to use ssh anymore because they cannot read the identify file…
I think the easiest way to find out what is happening is to run this exact command as foreman-proxy user.
If you rely on setting a ProxyCommand then it won’t work. foreman-proxy user intentionally has no shell configured to prevent logins. It cannot execute the ProxyCommand. That’s why the ssh call explicitly sets ProxyCommand=none. See All remote execution jobs fail immediately with exception
Good day, @gvde and thank you for the quick response! My apologies for the delay in replying, I was on leave.
Some actions taken, based on your response above:
  • I’ve removed the explicit call to the SSH priv key
  • I’ve removed the “ProxyCommand” entry as well
  • Output of running the SSH command listed below:
[root@forekat-master01-stage-bry ssh_config.d]# su - foreman-proxy -c /bin/bash
bash-4.4$ set-o vi
bash: set-o: command not found
bash-4.4$ set -o vi
bash-4.4$ ssh -vvv -o User=platbot -o Port=22 -o IdentityFile=/var/lib/foreman-proxy/ssh/id_rsa_foreman_proxy -o IdentitiesOnly=yes -o StrictHostKeyChecking=no -o LogLevel=debug -o ControlMaster=auto -o ControlPath=/var/tmp/d80ceb13-779f-4aee-baed-6f403fcf71a3 -o ControlPersist=yes -o ProxyCommand=none -o PreferredAuthentications=publickey -o NumberOfPasswordPrompts=0 bootstrap01-stage-bry.okd4-stage.platform.is true
debug3: /etc/ssh/ssh_config line 52: Including file /etc/ssh/ssh_config.d/05-redhat.conf depth 0
debug3: /etc/ssh/ssh_config.d/05-redhat.conf line 3: not matched 'final'
debug3: /etc/ssh/ssh_config.d/05-redhat.conf line 5: Including file /etc/crypto-policies/back-ends/openssh.config depth 1 (parse only)
debug3: gss kex names ok: [gss-curve25519-sha256-,gss-nistp256-sha256-,gss-group14-sha256-,gss-group16-sha512-,gss-gex-sha1-,gss-group14-sha1-]
debug3: kex names ok: [curve25519-sha256,curve25519-sha256@libssh.org,ecdh-sha2-nistp256,ecdh-sha2-nistp384,ecdh-sha2-nistp521,diffie-hellman-group-exchange-sha256,diffie-hellman-group14-sha256,diffie-hellman-group16-sha512,diffie-hellman-group18-sha512,diffie-hellman-group-exchange-sha1,diffie-hellman-group14-sha1]
debug3: /etc/ssh/ssh_config line 52: Including file /etc/ssh/ssh_config.d/06-platbot.conf depth 0
debug3: kex names ok: [diffie-hellman-group1-sha1]
debug3: /etc/ssh/ssh_config.d/05-redhat.conf line 3: matched 'final'
debug2: match found
debug2: resolving "bootstrap01-stage-bry.okd4-stage.platform.is" port 22
Again, it appears to parse my /etc/ssh/ssh_config.d/06-platbot.conf file:
# cat /etc/ssh/ssh_config.d/06-platbot.conf
CheckHostIP no
ForwardAgent yes
AddKeysToAgent yes
#IdentityFile /usr/share/foreman-proxy/.ssh/id_rsa_foreman_proxy
#IdentityFile /etc/ssh/id_rsa_foreman_proxy
Host *.platform.is
    ProxyJump platbot@bastion01.platform.is
It appears NOT to honour the Host match and doesn’t use the jumphost, instead attempting to connect directly to the target host.
And as a test, I attempted a more basic command in a similar manner: # sudo -u foreman-proxy ssh -vv -o IdentityFile=/var/lib/foreman-proxy/ssh/id_rsa_foreman_proxy platbot@bootstrap01-stage-bry.okd4-stage.platform.is
And that worked:
debug2: match found
debug1: Setting implicit ProxyCommand from ProxyJump: ssh -l platbot -vv -W '[%h]:%p' bastion01.platform.is
debug1: Executing proxy command: exec ssh -l platbot -vv -W '[bootstrap01-stage-bry.okd4-stage.platform.is]:22' bastion01.platform.is
debug1: identity file /var/lib/foreman-proxy/ssh/id_rsa_foreman_proxy type 0
debug1: identity file /var/lib/foreman-proxy/ssh/id_rsa_foreman_proxy-cert type -1
debug2: checking match for 'final all' host bastion01.platform.is originally bastion01.platform.is
debug1: /etc/ssh/ssh_config.d/06-platbot.conf line 11: Skipping Host block because of negated match for bastion01.platform.is
debug2: match found
debug2: resolving "bastion01.platform.is" port 22
debug1: Connecting to bastion01.platform.is [172.21.0.2] port 22.
debug1: identity file /usr/share/foreman-proxy/.ssh/id_rsa type 0
debug1: identity file /usr/share/foreman-proxy/.ssh/id_rsa-cert type -1
debug1: identity file /usr/share/foreman-proxy/.ssh/id_dsa type -1
debug1: identity file /usr/share/foreman-proxy/.ssh/id_dsa-cert type -1
debug1: identity file /usr/share/foreman-proxy/.ssh/id_ecdsa type -1
debug1: identity file /usr/share/foreman-proxy/.ssh/id_ecdsa-cert type -1
debug1: identity file /usr/share/foreman-proxy/.ssh/id_ed25519 type -1
debug1: identity file /usr/share/foreman-proxy/.ssh/id_ed25519-cert type -1
debug1: identity file /usr/share/foreman-proxy/.ssh/id_xmss type -1
debug1: identity file /usr/share/foreman-proxy/.ssh/id_xmss-cert type -1
debug1: Authenticating to bastion01.platform.is:22 as 'platbot'
debug2: reserved 0
debug2: reserved 0
debug1: Host 'bastion01.platform.is' is known and matches the ECDSA host key.
debug1: Will attempt key: /usr/share/foreman-proxy/.ssh/id_rsa RSA SHA256:oHEDJ+/Zs1x/YYU7YE9s1lxt9Crhniyf/htec1ukCLs
debug1: Will attempt key: /usr/share/foreman-proxy/.ssh/id_dsa
debug1: Will attempt key: /usr/share/foreman-proxy/.ssh/id_ecdsa
debug1: Will attempt key: /usr/share/foreman-proxy/.ssh/id_ed25519
debug1: Will attempt key: /usr/share/foreman-proxy/.ssh/id_xmss
debug1: Offering public key: /usr/share/foreman-proxy/.ssh/id_rsa RSA SHA256:oHEDJ+/Zs1x/YYU7YE9s1lxt9Crhniyf/htec1ukCLs
debug1: Server accepts key: /usr/share/foreman-proxy/.ssh/id_rsa RSA SHA256:oHEDJ+/Zs1x/YYU7YE9s1lxt9Crhniyf/htec1ukCLs
Authenticated to bastion01.platform.is ([172.21.0.2]:22).
debug2: reserved 0
debug2: reserved 0
debug1: Will attempt key: /var/lib/foreman-proxy/ssh/id_rsa_foreman_proxy RSA SHA256:oHEDJ+/Zs1x/YYU7YE9s1lxt9Crhniyf/htec1ukCLs explicit
debug1: Offering public key: /var/lib/foreman-proxy/ssh/id_rsa_foreman_proxy RSA SHA256:oHEDJ+/Zs1x/YYU7YE9s1lxt9Crhniyf/htec1ukCLs explicit
debug1: Server accepts key: /var/lib/foreman-proxy/ssh/id_rsa_foreman_proxy RSA SHA256:oHEDJ+/Zs1x/YYU7YE9s1lxt9Crhniyf/htec1ukCLs explicit
Last login: Wed Mar  1 09:10:13 2023 from 172.21.0.2
Notably, I observed this in the verbose output of the basic command:
So, what else might I attempt?
Thank you in advance!
It does honor the Host match:
However, I think it works as intended. From the ssh_config man page:
Note that this option will compete with the ProxyCommand option - whichever is specified first will prevent later instances of the other from taking effect.
The -o ProxyCommand=none will take precedence and void the ProxyJump configuration.
Yes. That works because it does not set ProxyCommand and thus ProxyJump is used.
I think at this time you cannot use ProxyJump. The explicit ProxyCommand was added by Bug #35245: Remote execution fails for SSH Default when Remote Execution configured for Kerberos Authentication - Foreman Remote Execution - Foreman
At the moment, you can only deploy a foreman proxy on your jump host and use the foreman proxy to relay the command.
Otherwise, I would suggest to open a bug at Issues - Foreman Remote Execution - Foreman
Or maybe @aruzicka can add something to this. He created the patch to add the ProxyCommand option…
Thank you very much for the assistance thus far!
Apologies for the poor wording on my “Host” matching comment, I meant that it did not appear to honour the jumphost portion of the “Host” match. However, you’ve explained that it appears to be overridden later in the sequence.
I’ll see if @aruzicka might be able to suggest something, failing which I will create a bug.
No suggestions, this will need a code change.
