Remote execution plugin fails on smart-proxy
The remote execution plugin fails to execute.
This is how I installed the foreman-smart-proxy:
foreman-installer \
  --no-enable-foreman \
  --no-enable-foreman-cli \
  --enable-foreman-proxy \
  --enable-foreman-proxy-plugin-remote-execution-ssh \
  --enable-foreman-proxy-plugin-discovery \
  --foreman-proxy-puppet=true \
  --foreman-proxy-plugin-discovery-install-images=true \
  --foreman-proxy-templates=true \
  --foreman-proxy-template-url=http://foreman-proxy.example.com:8000 \
  --foreman-proxy-templates-listen-on=both \
  --foreman-proxy-puppetca=true \
  --foreman-proxy-tftp=true \
  --foreman-proxy-http=true \
  --foreman-proxy-foreman-ssl-ca=/etc/foreman-proxy/ca.pem \
  --foreman-proxy-foreman-ssl-cert=/etc/foreman-proxy/cert.pem \
  --foreman-proxy-foreman-ssl-key=/etc/foreman-proxy/key.pem \
  --foreman-proxy-foreman-base-url=https://foreman.example.com \
  --foreman-proxy-trusted-hosts=foreman.example.com \
  --foreman-proxy-oauth-consumer-key=... \
  --foreman-proxy-oauth-consumer-secret=...
If I am running a task on a host that is using the smart-proxy, it fails:
tailf /var/log/foreman-proxy/proxy.log shows:
/usr/share/ruby/webrick/server.rb:295:in `block in start_thread'
/usr/share/gems/gems/logging-2.2.2/lib/logging/diagnostic_context.rb:474:in `call'
/usr/share/gems/gems/logging-2.2.2/lib/logging/diagnostic_context.rb:474:in `block in create_with_logging_context'
2020-02-24T13:42:36 94d4b09f [I] Finished GET /dynflow/tasks/count with 500 (43.48 ms)
/var/log/foreman-proxy/smart_proxy_dynflow_core.log shows:
/opt/rh/rh-ruby25/root/usr/share/ruby/webrick/server.rb:297:in `block in start_thread'SSL_accept returned=1 errno=0 state=error: certificate verify failed (self signed certificate in certificate chain) (OpenSSL::SSL::SSLError)
/opt/rh/rh-ruby25/root/usr/share/ruby/webrick/server.rb:299:in `accept'
/opt/rh/rh-ruby25/root/usr/share/ruby/webrick/server.rb:299:in `block (2 levels) in start_thread'
/opt/rh/rh-ruby25/root/usr/share/ruby/webrick/utils.rb:263:in `timeout'
/opt/rh/rh-ruby25/root/usr/share/ruby/webrick/server.rb:297:in `block in start_thread'^C
The config seems fine to me:
vim /etc/smart_proxy_dynflow_core/settings.yml
# Path to dynflow database, leave blank for in-memory non-persistent database
:database:
:console_auth: true
# URL of the foreman, used for reporting back
:foreman_url: https://foreman.example.com
# SSL settings for client authentication against foreman.
:foreman_ssl_ca: /etc/foreman-proxy/ca.pem
:foreman_ssl_cert: /etc/foreman-proxy/cert.pem
:foreman_ssl_key: /etc/foreman-proxy/key.pem
# Listen on address
:listen: 0.0.0.0
# Listen on port
:port: 8008
:use_https: true
:ssl_ca_file: /etc/foreman-proxy/ca.pem
:ssl_certificate: /etc/foreman-proxy/cert.pem
:ssl_private_key: /etc/foreman-proxy/key.pem
# :ssl_ca_file: ssl/ca.pem
# :ssl_private_key: ssl/localhost.pem
# :ssl_certificate: ssl/certs/localhost.pem
# Use this option only if you need to disable certain cipher suites.
# Note: we use the OpenSSL suite name, take a look at:
# https://www.openssl.org/docs/manmaster/apps/ciphers.html#CIPHER-SUITE-NAMES
# for more information.
#:ssl_disabled_ciphers: [CIPHER-SUITE-1, CIPHER-SUITE-2]
# Use this option only if you need to strictly specify TLS versions to be
# disabled. SSLv3 and TLS v1.0 are always disabled and cannot be configured.
# Specify versions like: '1.1', or '1.2'
#:tls_disabled_versions: []
# File to log to, leave empty for logging to STDOUT
# :log_file: /var/log/foreman-proxy/smart_proxy_dynflow_core.log
# Log level, one of UNKNOWN, FATAL, ERROR, WARN, INFO, DEBUG
# :log_level: ERROR
Working task execution
Foreman (main)
Discovery
Version
1.0.5
Dynflow
Version
0.2.4
HTTPBoot
Version
1.24.2
SSH
Version
0.2.1
TFTP
Version
1.24.2
TFTP server
false
Foreman (Smart Proxy)
Discovery
Version
1.0.5
Dynflow
Version
0.2.4
HTTPBoot
Version
1.24.2
SSH
Version
0.2.1
TFTP
Version
1.24.2
TFTP server
false
Templates
Version
1.24.2
could you also post contents of /etc/foreman-proxy/settings.yml? Smart proxy dynflow core and smart proxy need to use the exact same certificate, which is probably not happening here.
Thanks for your reply :slight_smile:
On the smart-proxy (foreman-proxy.example.com):
### File managed with puppet ###
## Module:           'foreman_proxy'
:settings_directory: /etc/foreman-proxy/settings.d
# SSL Setup
# if enabled, all communication would be verified via SSL
# NOTE that both certificates need to be signed by the same CA in order for this to work
# see http://theforeman.org/projects/smart-proxy/wiki/SSL for more information
# Note: we use the OpenSSL suite name, such as "RC4-MD5".
# The complete list of cipher suite names can be found at:
# https://www.openssl.org/docs/manmaster/man1/ciphers.html#CIPHER-SUITE-NAMES
# the hosts which the proxy accepts connections from
# commenting the following lines would mean every verified SSL connection allowed
:trusted_hosts:
  - foreman.example.com
# Endpoint for reverse communication
# SSL settings for client authentication against Foreman. If undefined, the values
# from general SSL options are used instead. Mainly useful when Foreman uses
# different certificates for its web UI and for smart-proxy requests.
# by default smart_proxy runs in the foreground. To enable running as a daemon, uncomment 'daemon' setting
:daemon: true
# Only used when 'daemon' is set to true.
# Uncomment and modify if you want to change the default pid file '/var/run/foreman-proxy/foreman-proxy.pid'
#:daemon_pid: /var/run/foreman-proxy/foreman-proxy.pid
# host and ports configuration
# Host or IP to bind ports to (e.g. *, localhost, 0.0.0.0, ::, 192.168.1.20)
:bind_host: '::'
# http is disabled by default. To enable, uncomment 'http_port' setting
# https is enabled if certificate, CA certificate, and private key are present in locations specifed by
# ssl_certificate, ssl_ca_file, and ssl_private_key correspondingly
# default values for https_port is 8443
:https_port: 8443
:http_port: 8000
# Log configuration
# Uncomment and modify if you want to change the location of the log file or use STDOUT or SYSLOG values
:log_file: /var/log/foreman-proxy/proxy.log
# Uncomment and modify if you want to change the log level
# WARN, DEBUG, ERROR, FATAL, INFO, UNKNOWN
:log_level: INFO
# The maximum size of a log file before it's rolled (in MiB)
#:file_rolling_size: 100
# The maximum age of a log file before it's rolled (in seconds). Also accepts 'daily', 'weekly', or 'monthly'.
#:file_rolling_age: weekly
# Number of log files to keep
#:file_rolling_keep: 6
# Logging pattern for file-based loging
#:file_logging_pattern: '%d %.8X{request} [%.1l] %m'
# Logging pattern for syslog or journal loging
#:system_logging_pattern: '%.8X{request} [%.1l] %m'
# Log buffer size and extra buffer size (for errors). Defaults to 3000 messages in total,
# which is about 500 kB request.
:log_buffer: 2000
:log_buffer_errors: 1000
Hm, I don’t see anything suspicious there.
You had a foreman installation with a proxy, and then on another machine you ran the installer command you mentioned in the first post?
Correct - The first foreman-instance is using a default config - the second instance is a foreman-proxy I built with the config I mentioned above :slight_smile:
Where do the certificates used on the proxy machine come from?
I created them on the foreman master using puppetserver ca generate --certname foreman-proxy.example.com. After that I copied them to the foreman-proxy:
[root@hts-sys-forep1 foreman-proxy]# ll
insgesamt 20
-rw-r--r--. 1 puppet puppet        3870 20. Feb 14:08 ca.pem
-rw-r--r--. 1 puppet puppet        1972 20. Feb 14:08 cert.pem
-rw-r-----. 1 puppet puppet        3243 20. Feb 14:09 key.pem
-rw-r--r--. 1 root   root             0 21. Jan 22:17 migration_state
drwxr-xr-x. 2 root   root          4096 24. Feb 11:19 settings.d
-rw-r-----. 1 root   foreman-proxy 3372 24. Feb 08:47 settings.yml
I also checked the cert manually:
$ openssl x509 -in /etc/foreman-proxy/cert.pem -text
Certificate:
    Data:
        Version: 3 (0x2)
        Serial Number: 6 (0x6)
    Signature Algorithm: sha256WithRSAEncryption
        Issuer: CN=Puppet CA: foreman.example.com
        Validity
            Not Before: Feb 19 11:57:05 2020 GMT
            Not After : Feb 18 11:57:05 2025 GMT
        Subject: CN=foreman-proxy.example.com
        Subject Public Key Info:
            Public Key Algorithm: rsaEncryption
                Public-Key: (4096 bit)
                Modulus:
                    00:b9:22:5f:b5:8f:eb:89:61:5b:1c:b5:5d:bc:8a:
                    5e:6f:d9:95:30:05:2f:84:ba:9f:e0:2a:40:05:97:
                    76:52:54:65:dd:2e:04:72:5a:76:77:e4:8e:f0:4e:
                    64:b1:2b
                Exponent: 65537 (0x10001)
        X509v3 extensions:
            Netscape Comment:
                Puppet Server Internal Certificate
            X509v3 Authority Key Identifier:
                keyid:99:3E:3E:EB:45:BE:A4:E2:B6:7B:33:54:BA:0A:96:44:06:83:53:F6
            X509v3 Subject Key Identifier:
                04:02:72:5E:1F:4A:00:C7:90:A2:2C:19:90:73:A1:B8:07:65:5B:74
            X509v3 Basic Constraints: critical
                CA:FALSE
            X509v3 Extended Key Usage: critical
                TLS Web Server Authentication, TLS Web Client Authentication
            X509v3 Key Usage: critical
                Digital Signature, Key Encipherment
         20:7c:38:00:2e:85:34:fa:84:d9:3b:dd:eb:11:4e:5b:0c:e0:
         b5:eb:c6:d2:77:bf:8d:52
-----BEGIN CERTIFICATE-----
MIIFhDCCA2ygAwIBAgIBBjANBgkqhkiG9w0BAQsFADAuMSwwKgYDVQQDDCNQdXBw
h5odXN1p+MDYJ1+7s3fCZLXrxtJ3v41S
-----END CERTIFICATE-----
CA is foreman.example.com and CN is foreman-proxy.example.com
@ahoiroman
What operating system do you use?
@aruzicka
Maybe this error is because the ruby concurrent is not fully compatible with 1.24 version?
Judging by the paths he is on EL*-derivative, which is fine.
That only happens on debian/ubuntu and the error looks differently.
I solved the problem recreating the certificates and restarting the dynflow-service on the foreman-proxy.
Thank you all so much for your help, I really appreciate this :slight_smile:
Ok. Any news about remote execution fully work without error on Debian/Ubuntu OS?
Hey! Same problem here, Foreman 2.1 under Debian 10 with remote plugin execution. If I use the foreman-installer “as-is” works fine. But when I replace Foreman UI’s certificate with my OWN certificate (signed by Geant) Remote execution fails after 10 minutes…
An old bug that has not yet been fixed. I’ve tried everything and I
couldn’t.
:frowning: I was so happy with my Foreman UI with green tick in the browser… Arrggggggg
@informatico ! I think I got it to work!!!
