I am having an issue with the Remote Execution plugin that has me
scratching my head. I was running commands yesterday throughout the day and
had no problems. Today the SSH remote command execution is missing and when
I click on a completed job (both successful and failed), I receive “Oops,
we’re sorry but something went wrong undefined method `name’ for
nil:NilClass.” When I select a host and “Run job,” I only see the Katello
category and “Restart Services - Katello SSH Default.” No changes or
updates had been made to the server between yesterday and this morning.
Attempted fixes: rebooting the server
reinstalling the packages and restarting the services manually per the
plugin documentation
re-running “foreman-installer --enable-foreman-plugin-remote-execution
–enable-foreman-proxy-plugin-remote-execution-ssh”
I did not remove the packages specified in the documentation for the manual
install because it wants to also remove the katello package(s) as well.
I am currently running the following:
CentOS 7.3
Foreman 1.14.3
w/ Plugins:
Katello 3.3.2
Remote Execution 1.2.2
Has anyone had this issue or any ideas on how to fix it?
James
James Cicak
Systems Programmer | Information Technology/Enterprise Systems
I click on a completed job (both successful and failed), I receive "Oops,
we're sorry but something went wrong undefined method `name' for
nil:NilClass." When I select a host and "Run job," I only see the Katello
category and "Restart Services - Katello SSH Default." No changes or
From what I see, that template is:
<%= input(:helper).split(",").map {|split| "#{split}" }.join("\n") %>
katello-tracer-upload
Did you make any changes or is that the tample we're speaking about?
re-running "foreman-installer --enable-foreman-plugin-remote-execution
--enable-foreman-proxy-plugin-remote-execution-ssh"
CentOS 7.3
Foreman 1.14.3
w/ Plugins:
Katello 3.3.2
The error, "undefined method name" makes me think that there is some
problem with the Host Operating System or the Host itself. Could you
enable the debug log_level
(Foreman :: Manual) and share what
you see on /var/log/foreman/production.log when you try to run the job?
Probably you see the same issue when previewing the template, e.g:
Could you share the logs of that too? Does it work?
On 12/12, jcicak@fit.edu wrote:
James
James Cicak
You received this message because you are subscribed to the Google Groups "Foreman users" group.
Visit this group at https://groups.google.com/group/foreman-users\.
For more options, visit https://groups.google.com/d/optout\.
Daniel Lobato Garcia
@dLobatog
blog.daniellobato.me
daniellobato.me
Keybase: elobato (Daniel Lobato Garcia) | Keybase
