I installed the remote execution plugin using the “manual method” at Foreman :: Plugin Manuals.
However, it appears to not have been fully initialized. The job templates are missing when I browse over to https://my-foreman-host//job_templates. And if I try to create a template using https://my-foreman-host//job_templates/new, I get the following error: Oops, we're sorry but something went wrong undefined method job_category’ for #JobTemplate:0x00007efd128bd5b0`
Is there a way to reinitialize the data for the plugin? I haven’t started using it yet.
Should see default job templates and should be able to create a template
foreman 2.0.1
smart-proxy 2.0.1
foreman-tasks 1.1.3
foreman_hooks 0.3.16
foreman_remote_execution 3.2.2
katello 3.15.3.1
CentOS 8
production.log has:
2020-08-11T13:29:44 [W|app|de015124] Action failed
2020-08-11T13:29:44 [D|app|de015124] Backtrace for 'Action failed' error (ActionView::Template::Error): undefined method `job_category' for #<JobTemplate:0x00007efd12ffbf98>
/opt/theforeman/tfm/root/usr/share/gems/gems/activemodel-5.2.1/lib/active_model/attribute_methods.rb:430:in `method_missing'
/opt/theforeman/tfm/root/usr/share/gems/gems/audited-4.9.0/lib/audited/auditor.rb:99:in `method_missing'
/opt/theforeman/tfm/root/usr/share/gems/gems/foreman_remote_execution-3.2.2/app/views/job_templates/_custom_tabs.html.erb:5:in `block in _c4444b144b9b063594eef4c6ed17ea6e'
/usr/share/foreman/app/helpers/form_helper.rb:394:in `block (3 levels) in field'
/opt/theforeman/tfm/root/usr/share/gems/gems/actionview-5.2.1/lib/action_view/helpers/capture_helper.rb:41:in `block in capture'
/opt/theforeman/tfm/root/usr/share/gems/gems/actionview-5.2.1/lib/action_view/helpers/capture_helper.rb:205:in `with_output_buffer'
/opt/theforeman/tfm/root/usr/share/gems/gems/actionview-5.2.1/lib/action_view/helpers/capture_helper.rb:41:in `capture'
/usr/share/foreman/app/helpers/form_helper.rb:390:in `block (2 levels) in field'
/opt/theforeman/tfm/root/usr/share/gems/gems/actionview-5.2.1/lib/action_view/helpers/tag_helper.rb:272:in `content_tag'
/usr/share/foreman/app/helpers/form_helper.rb:388:in `block in field'
/usr/share/foreman/app/helpers/form_helper.rb:387:in `field'
/opt/theforeman/tfm/root/usr/share/gems/gems/foreman_remote_execution-3.2.2/app/views/job_templates/_custom_tabs.html.erb:3:in `_c4444b144b9b063594eef4c6ed17ea6e'
/opt/theforeman/tfm/root/usr/share/gems/gems/actionview-5.2.1/lib/action_view/template.rb:159:in `block in render'
/opt/theforeman/tfm/root/usr/share/gems/gems/activesupport-5.2.1/lib/active_support/notifications.rb:170:in `instrument'
/opt/theforeman/tfm/root/usr/share/gems/gems/actionview-5.2.1/lib/action_view/template.rb:354:in `instrument_render_template'
/opt/theforeman/tfm/root/usr/share/gems/gems/actionview-5.2.1/lib/action_view/template.rb:157:in `render'
/opt/theforeman/tfm/root/usr/share/gems/gems/deface-1.5.3/lib/deface/action_view_extensions.rb:43:in `render'
/opt/theforeman/tfm/root/usr/share/gems/gems/actionview-5.2.1/lib/action_view/renderer/partial_renderer.rb:344:in `block in render_partial'
/opt/theforeman/tfm/root/usr/share/gems/gems/actionview-5.2.1/lib/action_view/renderer/abstract_renderer.rb:44:in `block in instrument'
/opt/theforeman/tfm/root/usr/share/gems/gems/activesupport-5.2.1/lib/active_support/notifications.rb:168:in `block in instrument'
/opt/theforeman/tfm/root/usr/share/gems/gems/activesupport-5.2.1/lib/active_support/notifications/instrumenter.rb:23:in `instrument'
/opt/theforeman/tfm/root/usr/share/gems/gems/activesupport-5.2.1/lib/active_support/notifications.rb:168:in `instrument'
/opt/theforeman/tfm/root/usr/share/gems/gems/actionview-5.2.1/lib/action_view/renderer/abstract_renderer.rb:43:in `instrument'
/opt/theforeman/tfm/root/usr/share/gems/gems/actionview-5.2.1/lib/action_view/renderer/partial_renderer.rb:333:in `render_partial'
/opt/theforeman/tfm/root/usr/share/gems/gems/actionview-5.2.1/lib/action_view/renderer/partial_renderer.rb:312:in `render'
/opt/theforeman/tfm/root/usr/share/gems/gems/actionview-5.2.1/lib/action_view/renderer/renderer.rb:49:in `render_partial'
/opt/theforeman/tfm/root/usr/share/gems/gems/actionview-5.2.1/lib/action_view/helpers/rendering_helper.rb:36:in `render'
/usr/share/foreman/app/views/templates/_form.html.erb:180:in `block in _947416f42b7f026d087a79c2148d8ee8'
/opt/theforeman/tfm/root/usr/share/gems/gems/actionview-5.2.1/lib/action_view/helpers/form_helper.rb:452:in `form_for'
/usr/share/foreman/app/helpers/form_helper.rb:298:in `form_for'
/usr/share/foreman/app/views/templates/_form.html.erb:9:in `_947416f42b7f026d087a79c2148d8ee8'
/opt/theforeman/tfm/root/usr/share/gems/gems/actionview-5.2.1/lib/action_view/renderer/renderer.rb:23:in `render'
/opt/theforeman/tfm/root/usr/share/gems/gems/actionview-5.2.1/lib/action_view/helpers/rendering_helper.rb:33:in `render'
/opt/theforeman/tfm/root/usr/share/gems/gems/foreman_remote_execution-3.2.2/app/views/job_templates/new.html.erb:5:in `_3c0d293c642b7b0ad94530dbcd030f67'
/opt/theforeman/tfm/root/usr/share/gems/gems/actionview-5.2.1/lib/action_view/renderer/template_renderer.rb:54:in `block (2 levels) in render_template'
/opt/theforeman/tfm/root/usr/share/gems/gems/actionview-5.2.1/lib/action_view/renderer/template_renderer.rb:53:in `block in render_template'
/opt/theforeman/tfm/root/usr/share/gems/gems/actionview-5.2.1/lib/action_view/renderer/template_renderer.rb:61:in `render_with_layout'
/opt/theforeman/tfm/root/usr/share/gems/gems/actionview-5.2.1/lib/action_view/renderer/template_renderer.rb:52:in `render_template'
/opt/theforeman/tfm/root/usr/share/gems/gems/actionview-5.2.1/lib/action_view/renderer/template_renderer.rb:16:in `render'
/opt/theforeman/tfm/root/usr/share/gems/gems/actionview-5.2.1/lib/action_view/renderer/renderer.rb:44:in `render_template'
/opt/theforeman/tfm/root/usr/share/gems/gems/actionview-5.2.1/lib/action_view/renderer/renderer.rb:25:in `render'
/opt/theforeman/tfm/root/usr/share/gems/gems/actionview-5.2.1/lib/action_view/rendering.rb:103:in `_render_template'
/opt/theforeman/tfm/root/usr/share/gems/gems/actionpack-5.2.1/lib/action_controller/metal/streaming.rb:219:in `_render_template'
/opt/theforeman/tfm/root/usr/share/gems/gems/actionview-5.2.1/lib/action_view/rendering.rb:84:in `render_to_body'
/opt/theforeman/tfm/root/usr/share/gems/gems/actionpack-5.2.1/lib/action_controller/metal/rendering.rb:52:in `render_to_body'
/opt/theforeman/tfm/root/usr/share/gems/gems/actionpack-5.2.1/lib/action_controller/metal/renderers.rb:142:in `render_to_body'
/opt/theforeman/tfm/root/usr/share/gems/gems/actionpack-5.2.1/lib/abstract_controller/rendering.rb:25:in `render'
/opt/theforeman/tfm/root/usr/share/gems/gems/actionpack-5.2.1/lib/action_controller/metal/rendering.rb:36:in `render'
/opt/theforeman/tfm/root/usr/share/gems/gems/actionpack-5.2.1/lib/action_controller/metal/instrumentation.rb:46:in `block (2 levels) in render'
/opt/theforeman/tfm/root/usr/share/gems/gems/activesupport-5.2.1/lib/active_support/core_ext/benchmark.rb:14:in `block in ms'
/opt/rh/rh-ruby25/root/usr/share/ruby/benchmark.rb:308:in `realtime'
/opt/theforeman/tfm/root/usr/share/gems/gems/activesupport-5.2.1/lib/active_support/core_ext/benchmark.rb:14:in `ms'
/opt/theforeman/tfm/root/usr/share/gems/gems/actionpack-5.2.1/lib/action_controller/metal/instrumentation.rb:46:in `block in render'
/opt/theforeman/tfm/root/usr/share/gems/gems/actionpack-5.2.1/lib/action_controller/metal/instrumentation.rb:87:in `cleanup_view_runtime'
/opt/theforeman/tfm/root/usr/share/gems/gems/activerecord-5.2.1/lib/active_record/railties/controller_runtime.rb:31:in `cleanup_view_runtime'
/opt/theforeman/tfm/root/usr/share/gems/gems/actionpack-5.2.1/lib/action_controller/metal/instrumentation.rb:45:in `render'
/opt/theforeman/tfm/root/usr/share/gems/gems/actionpack-5.2.1/lib/action_controller/metal/implicit_render.rb:35:in `default_render'
/opt/theforeman/tfm/root/usr/share/gems/gems/actionpack-5.2.1/lib/action_controller/metal/basic_implicit_render.rb:6:in `block in send_action'
/opt/theforeman/tfm/root/usr/share/gems/gems/actionpack-5.2.1/lib/action_controller/metal/basic_implicit_render.rb:6:in `tap'
/opt/theforeman/tfm/root/usr/share/gems/gems/actionpack-5.2.1/lib/action_controller/metal/basic_implicit_render.rb:6:in `send_action'
/opt/theforeman/tfm/root/usr/share/gems/gems/actionpack-5.2.1/lib/abstract_controller/base.rb:194:in `process_action'
/opt/theforeman/tfm/root/usr/share/gems/gems/actionpack-5.2.1/lib/action_controller/metal/rendering.rb:30:in `process_action'
/opt/theforeman/tfm/root/usr/share/gems/gems/actionpack-5.2.1/lib/abstract_controller/callbacks.rb:42:in `block in process_action'
/opt/theforeman/tfm/root/usr/share/gems/gems/activesupport-5.2.1/lib/active_support/callbacks.rb:109:in `block in run_callbacks'
/opt/theforeman/tfm/root/usr/share/gems/gems/activesupport-5.2.1/lib/active_support/callbacks.rb:118:in `block in run_callbacks'
/opt/theforeman/tfm/root/usr/share/gems/gems/audited-4.9.0/lib/audited/sweeper.rb:14:in `around'
/opt/theforeman/tfm/root/usr/share/gems/gems/activesupport-5.2.1/lib/active_support/callbacks.rb:136:in `run_callbacks'
/opt/theforeman/tfm/root/usr/share/gems/gems/actionpack-5.2.1/lib/abstract_controller/callbacks.rb:41:in `process_action'
/opt/theforeman/tfm/root/usr/share/gems/gems/actionpack-5.2.1/lib/action_controller/metal/rescue.rb:22:in `process_action'
/opt/theforeman/tfm/root/usr/share/gems/gems/actionpack-5.2.1/lib/action_controller/metal/instrumentation.rb:34:in `block in process_action'
/opt/theforeman/tfm/root/usr/share/gems/gems/actionpack-5.2.1/lib/action_controller/metal/instrumentation.rb:32:in `process_action'
/opt/theforeman/tfm/root/usr/share/gems/gems/actionpack-5.2.1/lib/action_controller/metal/params_wrapper.rb:256:in `process_action'
/opt/theforeman/tfm/root/usr/share/gems/gems/activerecord-5.2.1/lib/active_record/railties/controller_runtime.rb:24:in `process_action'
/opt/theforeman/tfm/root/usr/share/gems/gems/actionpack-5.2.1/lib/abstract_controller/base.rb:134:in `process'
/opt/theforeman/tfm/root/usr/share/gems/gems/actionview-5.2.1/lib/action_view/rendering.rb:32:in `process'
/opt/theforeman/tfm/root/usr/share/gems/gems/actionpack-5.2.1/lib/action_controller/metal.rb:191:in `dispatch'
/opt/theforeman/tfm/root/usr/share/gems/gems/actionpack-5.2.1/lib/action_controller/metal.rb:252:in `dispatch'
/opt/theforeman/tfm/root/usr/share/gems/gems/actionpack-5.2.1/lib/action_dispatch/routing/route_set.rb:52:in `dispatch'
/opt/theforeman/tfm/root/usr/share/gems/gems/actionpack-5.2.1/lib/action_dispatch/routing/route_set.rb:34:in `serve'
/opt/theforeman/tfm/root/usr/share/gems/gems/actionpack-5.2.1/lib/action_dispatch/journey/router.rb:52:in `block in serve'
/opt/theforeman/tfm/root/usr/share/gems/gems/actionpack-5.2.1/lib/action_dispatch/journey/router.rb:35:in `each'
/opt/theforeman/tfm/root/usr/share/gems/gems/actionpack-5.2.1/lib/action_dispatch/journey/router.rb:35:in `serve'
/opt/theforeman/tfm/root/usr/share/gems/gems/actionpack-5.2.1/lib/action_dispatch/routing/route_set.rb:840:in `call'
/opt/theforeman/tfm/root/usr/share/gems/gems/katello-3.15.3.1/lib/katello/middleware/event_daemon.rb:10:in `call'
/opt/theforeman/tfm/root/usr/share/gems/gems/actionpack-5.2.1/lib/action_dispatch/middleware/static.rb:127:in `call'
/opt/theforeman/tfm/root/usr/share/gems/gems/apipie-rails-0.5.17/lib/apipie/static_dispatcher.rb:66:in `call'
/opt/theforeman/tfm/root/usr/share/gems/gems/apipie-rails-0.5.17/lib/apipie/extractor/recorder.rb:137:in `call'
/opt/theforeman/tfm/root/usr/share/gems/gems/apipie-rails-0.5.17/lib/apipie/middleware/checksum_in_headers.rb:27:in `call'
/opt/theforeman/tfm/root/usr/share/gems/gems/rack-2.0.6/lib/rack/tempfile_reaper.rb:15:in `call'
/opt/theforeman/tfm/root/usr/share/gems/gems/rack-2.0.6/lib/rack/etag.rb:25:in `call'
/opt/theforeman/tfm/root/usr/share/gems/gems/rack-2.0.6/lib/rack/conditional_get.rb:25:in `call'
/opt/theforeman/tfm/root/usr/share/gems/gems/rack-2.0.6/lib/rack/head.rb:12:in `call'
/opt/theforeman/tfm/root/usr/share/gems/gems/actionpack-5.2.1/lib/action_dispatch/http/content_security_policy.rb:18:in `call'
/opt/theforeman/tfm/root/usr/share/gems/gems/rack-2.0.6/lib/rack/session/abstract/id.rb:232:in `context'
/opt/theforeman/tfm/root/usr/share/gems/gems/rack-2.0.6/lib/rack/session/abstract/id.rb:226:in `call'
/opt/theforeman/tfm/root/usr/share/gems/gems/actionpack-5.2.1/lib/action_dispatch/middleware/cookies.rb:670:in `call'
/opt/theforeman/tfm/root/usr/share/gems/gems/actionpack-5.2.1/lib/action_dispatch/middleware/callbacks.rb:28:in `block in call'
/opt/theforeman/tfm/root/usr/share/gems/gems/activesupport-5.2.1/lib/active_support/callbacks.rb:98:in `run_callbacks'
/opt/theforeman/tfm/root/usr/share/gems/gems/actionpack-5.2.1/lib/action_dispatch/middleware/callbacks.rb:26:in `call'
/opt/theforeman/tfm/root/usr/share/gems/gems/actionpack-5.2.1/lib/action_dispatch/middleware/debug_exceptions.rb:61:in `call'
/opt/theforeman/tfm/root/usr/share/gems/gems/actionpack-5.2.1/lib/action_dispatch/middleware/show_exceptions.rb:33:in `call'
/opt/theforeman/tfm/root/usr/share/gems/gems/railties-5.2.1/lib/rails/rack/logger.rb:38:in `call_app'
/opt/theforeman/tfm/root/usr/share/gems/gems/railties-5.2.1/lib/rails/rack/logger.rb:28:in `call'
/opt/theforeman/tfm/root/usr/share/gems/gems/sprockets-rails-3.2.1/lib/sprockets/rails/quiet_assets.rb:13:in `call'
/opt/theforeman/tfm/root/usr/share/gems/gems/actionpack-5.2.1/lib/action_dispatch/middleware/remote_ip.rb:81:in `call'
/opt/theforeman/tfm/root/usr/share/gems/gems/actionpack-5.2.1/lib/action_dispatch/middleware/request_id.rb:27:in `call'
/opt/theforeman/tfm/root/usr/share/gems/gems/katello-3.15.3.1/lib/katello/prevent_json_parsing.rb:12:in `call'
/opt/theforeman/tfm/root/usr/share/gems/gems/rack-2.0.6/lib/rack/method_override.rb:22:in `call'
/opt/theforeman/tfm/root/usr/share/gems/gems/rack-2.0.6/lib/rack/runtime.rb:22:in `call'
/opt/theforeman/tfm/root/usr/share/gems/gems/activesupport-5.2.1/lib/active_support/cache/strategy/local_cache_middleware.rb:29:in `call'
/opt/theforeman/tfm/root/usr/share/gems/gems/actionpack-5.2.1/lib/action_dispatch/middleware/executor.rb:14:in `call'
/opt/theforeman/tfm/root/usr/share/gems/gems/rack-2.0.6/lib/rack/sendfile.rb:111:in `call'
/opt/theforeman/tfm/root/usr/share/gems/gems/secure_headers-6.3.0/lib/secure_headers/middleware.rb:11:in `call'
/opt/theforeman/tfm/root/usr/share/gems/gems/railties-5.2.1/lib/rails/engine.rb:524:in `call'
/opt/theforeman/tfm/root/usr/share/gems/gems/railties-5.2.1/lib/rails/railtie.rb:190:in `public_send'
/opt/theforeman/tfm/root/usr/share/gems/gems/railties-5.2.1/lib/rails/railtie.rb:190:in `method_missing'
/opt/theforeman/tfm/root/usr/share/gems/gems/rack-2.0.6/lib/rack/urlmap.rb:68:in `block in call'
/opt/theforeman/tfm/root/usr/share/gems/gems/rack-2.0.6/lib/rack/urlmap.rb:53:in `each'
/opt/theforeman/tfm/root/usr/share/gems/gems/rack-2.0.6/lib/rack/urlmap.rb:53:in `call'
2020-08-11T13:29:44 [I|app|de015124] Rendering common/500.html.erb within layouts/application
2020-08-11T13:29:44 [I|app|de015124] Rendered common/500.html.erb within layouts/application (0.6ms)
2020-08-11T13:29:44 [I|app|de015124] Rendered layouts/_application_content.html.erb (0.3ms)
2020-08-11T13:29:44 [I|app|de015124] Rendering layouts/base.html.erb
2020-08-11T13:29:44 [I|app|de015124] Rendered layouts/base.html.erb (1.4ms)
2020-08-11T13:29:44 [I|app|de015124] Completed 500 Internal Server Error in 64ms (Views: 3.3ms | ActiveRecord: 2.9ms)
