Remote Smart Proxy Ansible job run fails with:
ERROR -- : SSL certificate with unexpected serial supplied
Proxy settings.yml
:settings_directory: "/etc/foreman-proxy/settings.d"
:trusted_hosts: [foreman.internal.xyz.net]
:daemon: true
:bind_host: 0.0.0.0
#:http_port: 8000
port: 8443
:log_level: DEBUG
:ssl_certificate: /etc/foreman-proxy/certs/ansible.internal.xyz.net.pem
:ssl_ca_file: /etc/foreman-proxy/certs/ca.pem
:ssl_private_key: /etc/foreman-proxy/ssl/ansible.internal.xyz.net.pem
Proxy Host’s SSL Cert was generated by running the following on the master foreman host:
puppet cert generate ansible.internal.xyz.net
Any help or guidance would be greatly appreciated. Documentation seems a bit vague in this scenario and from what I’ve searched, it just mentions that the certs need to be generated from the same CA.
foreman 1.17.1-1
foreman-proxy 1.17.1-1
foreman-tasks (0.13.1)
foreman-tasks-core (0.2.5)
foreman_ansible_core (2.0.2)
foreman_remote_execution_core (1.1.2)
smart_proxy_ansible (2.0.3)
smart_proxy_dynflow (0.2.0, 0.1.10)
smart_proxy_dynflow_core (0.2.0)
Both hosts (master and proxy) running Ubuntu 16.04.4 x64
