Remove obsolete smart class parameters
Hello everybody,
I have a small problem with my foreman installation concerning obsolete
smart class parameters. I've upgraded the rkhunter module which changed the
naming of the class parameters. When I set values to the new parameters I
can still see the old, no longer in use parameters:
How can I get rid of the old, obsolete entries?
Regards Thomas
··· -- Linux ... enjoy the ride!
Which version of Foreman are you using? 1.10.1 contains a fix
(Bug #7517: Puppet class parameter not removed from environment after an import - Foreman) that removes obsolete
parameters that have overrides/matchers. In previous versions you'd
need to delete them.
It may also remain if it's listed on another Puppet environment.
··· On 02/02/16 14:02, Thomas Bendler wrote: > Hello everybody, > > I have a small problem with my foreman installation concerning obsolete > smart class parameters. I've upgraded the rkhunter module which changed > the naming of the class parameters. When I set values to the new > parameters I can still see the old, no longer in use parameters:
Dominic Cleal
dominic@cleal.org
Hi Dominic,
I use 1.10.1 on CentOS 6 but shame on me, I should upgrade both
environments … :wink:
Thanks for the link that point me to the environment.
Regards Thomas
··· 2016-02-02 14:05 GMT+01:00 Dominic Cleal :
Hello everybody,
smart class parameters. I’ve upgraded the rkhunter module which changed
parameters that have overrides/matchers. In previous versions you’d
It may also remain if it’s listed on another Puppet environment.
Dominic Cleal
dominic@cleal.org
“Foreman users” group.
performance, security, automation, SAP
cimt consulting ag, Burchardstrasse 17, 20095 Hamburg
fon: +49 (163) 6081 302, fax: +49 (40) 5 33 02-22, web: www.cimt.de
key: FED7C867 at pgp.mit.edu
Sitz der Gesellschaft: Hamburg, Amtsgericht Hamburg, HRB 74173
Vorstand: Christoph Friedlaender, Dr.-Ing. Thorsten Kuhlmann
Vorsitzender des Aufsichtsrats: Christian Gottsmann
Thomas,
Did you solve this issue, I am having the same issue even I upgraded
foreman to 1.10.1, I deleted classes, environment, but the obsolete
parameters are still there.
Thanks
··· On Tuesday, February 2, 2016 at 5:28:59 AM UTC-8, Thomas Bendler wrote: > > Hi Dominic, > > I use 1.10.1 on CentOS 6 but shame on me, I should upgrade both > environments ... ;) > > Thanks for the link that point me to the environment. > > Regards Thomas > > 2016-02-02 14:05 GMT+01:00 Dominic Cleal <dom...@cleal.org >: > >> On 02/02/16 14:02, Thomas Bendler wrote: >> > Hello everybody, >> > >> > I have a small problem with my foreman installation concerning obsolete >> > smart class parameters. I've upgraded the rkhunter module which changed >> > the naming of the class parameters. When I set values to the new >> > parameters I can still see the old, no longer in use parameters: >> >> Which version of Foreman are you using? 1.10.1 contains a fix >> (http://projects.theforeman.org/issues/7517) that removes obsolete >> parameters that have overrides/matchers. In previous versions you'd >> need to delete them. >> >> It may also remain if it's listed on another Puppet environment. >> >> -- >> Dominic Cleal >> dom...@cleal.org >> >> -- >> You received this message because you are subscribed to the Google Groups >> "Foreman users" group. >> To unsubscribe from this group and stop receiving emails from it, send an >> email to foreman-user...@googlegroups.com . >> To post to this group, send email to forema...@googlegroups.com >> . >> Visit this group at https://groups.google.com/group/foreman-users. >> For more options, visit https://groups.google.com/d/optout. >> > > > > -- > performance, security, automation, SAP > cimt consulting ag, Burchardstrasse 17, 20095 Hamburg > fon: +49 (163) 6081 302, fax: +49 (40) 5 33 02-22, web: www.cimt.de > key: FED7C867 at pgp.mit.edu > > Sitz der Gesellschaft: Hamburg, Amtsgericht Hamburg, HRB 74173 > Vorstand: Christoph Friedlaender, Dr.-Ing. Thorsten Kuhlmann > Vorsitzender des Aufsichtsrats: Christian Gottsmann >
Hi Howie,
yes, I solved the problem. I have two environments, development and production. I forgot to update the class in both environments, so I saw the old style and the new style. After upgrading the module in both environments, the old parameters disappear as expected.
Regards, Thomas
··· > Am 03.02.2016 um 20:39 schrieb Howie C. : > > Thomas, > > Did you solve this issue, I am having the same issue even I upgraded foreman to 1.10.1, I deleted classes, environment, but the obsolete parameters are still there. > > Thanks > > On Tuesday, February 2, 2016 at 5:28:59 AM UTC-8, Thomas Bendler wrote: > Hi Dominic, > > I use 1.10.1 on CentOS 6 but shame on me, I should upgrade both environments ... ;) > > Thanks for the link that point me to the environment. > > Regards Thomas > > 2016-02-02 14:05 GMT+01:00 Dominic Cleal <dom...@cleal.org >: > On 02/02/16 14:02, Thomas Bendler wrote: > > Hello everybody, > > > > I have a small problem with my foreman installation concerning obsolete > > smart class parameters. I've upgraded the rkhunter module which changed > > the naming of the class parameters. When I set values to the new > > parameters I can still see the old, no longer in use parameters: > > Which version of Foreman are you using? 1.10.1 contains a fix > (http://projects.theforeman.org/issues/7517 ) that removes obsolete > parameters that have overrides/matchers. In previous versions you'd > need to delete them. > > It may also remain if it's listed on another Puppet environment. > > -- > Dominic Cleal > dom...@cleal.org > > -- > You received this message because you are subscribed to the Google Groups "Foreman users" group. > To unsubscribe from this group and stop receiving emails from it, send an email to foreman-user...@googlegroups.com . > To post to this group, send email to forema...@googlegroups.com . > Visit this group at https://groups.google.com/group/foreman-users . > For more options, visit https://groups.google.com/d/optout . > > > > -- > performance, security, automation, SAP > cimt consulting ag, Burchardstrasse 17, 20095 Hamburg > fon: +49 (163) 6081 302, fax: +49 (40) 5 33 02-22, web: www.cimt.de > key: FED7C867 at pgp.mit.edu > > Sitz der Gesellschaft: Hamburg, Amtsgericht Hamburg, HRB 74173 > Vorstand: Christoph Friedlaender, Dr.-Ing. Thorsten Kuhlmann > Vorsitzender des Aufsichtsrats: Christian Gottsmann
