Hi all,
Is there a way to get Foreman to remove smart variables that are associated
with a module when the module is removed or is there a way to delete more
than one smart variable at a time? I've been adding modules to test, but
after removal I see the variables are still there and they're no longer
associated with any module.
Gareth
Bump - I'm intested in this also.
Thanks.
Le jeudi 17 avril 2014 04:23:42 UTC-4, Gareth Allen a écrit :
> Hi all,
> associated with a module when the module is removed or is there a way to
> delete more than one smart variable at a time? I've been adding modules to
> test, but after removal I see the variables are still there and they're no
> longer associated with any module.
> Thanks,
> Gareth
Any news on this topic?
I need to clean all "orphan" smart variables
Anthony
On Thursday, April 17, 2014 at 10:23:42 AM UTC+2, Gareth Allen wrote:
> Hi all,
> Thanks,
> Gareth
You can go to Configure -> Smart variables search for "puppetclass = "
then delete them one by one. There isn't an option to delete all at once
this way.
Using the API to find and delete all of them might be a better option.
On Wed, May 20, 2015 at 6:58 PM, Anthony Chevalet < anthony.chevalet@gmail.com> wrote:
I need to clean all “orphan” smart variables
Anthony
Hi all,
delete more than one smart variable at a time? I’ve been adding modules to
test, but after removal I see the variables are still there and they’re no
Gareth
"Foreman users" group.
I get 178 pages of orphan variables … So I will write a script that uses
the API
Thank you!
Anthony
2015-05-21 15:10 GMT+02:00 Ori Rabin :
then delete them one by one. There isn’t an option to delete all at once
this way.
On Wed, May 20, 2015 at 6:58 PM, Anthony Chevalet < > anthony.chevalet@gmail.com> wrote:
Anthony
Hi all,
Gareth
https://groups.google.com/d/topic/foreman-users/sJ0RqtfI8UY/unsubscribe.
