I did a fresh install of Foreman with the Katello scenario but didn’t specify the Org name or Location. Once the install was completed I renamed the Org and Location but when I went to do a provisioning of a sever the Published Repository was giving a 404: not found error. I tried to resync and it didn’t fix the issue.
Since it was a fresh install I decided to retry and ended up forgetting to specify the org and location again and ran into the same issue. I then did a fresh install a 3rd time but specified the Org and Location and the repo is displaying properly. However If I rename the org it breaks it again.
The published repo URL still would show the original Organization in the repository details instead of the renamed Org.
Ie: https://foreman-server.com/pulp/content/Default_Org/Library/custom/RockyLinux_8_5/8_5_AppStream_x86_64_os/
Trying the URL with the correct Org name still gave the 404: Not Found error
Additionally I tried deleting and recreating the product and syncing the repository but it still didn’t update to the new Org.
Repository Link should be published with current Organization name.
Foreman 3.1.2
Proxy 3.1.2
katello 4.3.0
Rocky Linux 8.5
I think this is a bug but I am not sure how to report it.
