Restore does not work because --disable-system-checks isn't a valid argument for foreman-installer
First error:
Run installer reset:
\ Installer reset [FAIL]
Failed executing yes | foreman-installer -v --reset-data --disable-system-checks , exit status 1:
2022-11-22 15:58:58 [NOTICE] [root] Loading installer configuration. This will take some time.
2022-11-22 15:59:05 [NOTICE] [root] Running installer with log based terminal output at level NOTICE.
2022-11-22 15:59:05 [NOTICE] [root] Use -l to set the terminal output log level to ERROR, WARN, NOTICE, INFO, or DEBUG. See --full-help for definitions.
ERROR: Unrecognised option ā€˜ā€“disable-system-checksā€™
See: ā€˜foreman-installer --helpā€™
Scenario [Restore backup] failed.
[restore-installer-reset]
Resolve the failed steps and rerun the command.
In case the failures are false positives, use
ā€“whitelist=ā€œrestore-installer-resetā€
Command with same effect:
Workaround (kinda)
foreman-maintain restore katello-backup-2022-11-22-15-32-00/
foreman-maintain restore --whitelist=ā€œrestore-installer-resetā€ katello-backup-2022-11-22-15-32-00/
Second error:
Procedures::Installer::Upgrade: [FAIL]
Failed executing LANG=en_US.utf-8 foreman-installer --disable-system-checks, exit status 1:
2022-11-22 16:21:22 [NOTICE] [root] Loading installer configuration. This will take some time.
2022-11-22 16:21:27 [NOTICE] [root] Running installer with log based terminal output at level NOTICE.
2022-11-22 16:21:27 [NOTICE] [root] Use -l to set the terminal output log level to ERROR, WARN, NOTICE, INFO, or DEBUG. See --full-help for definitions.
Can be avoided by using: installer-upgrade as whitelist, but not ideal
The restore should work withoud any problems, as the backup was created using the same tools (withoud backing up pulp).
foreman-installer-katello-3.4.0-1.el8.noarch
foreman-3.4.0-1.el8.noarch
katello-4.6.0-1.el8.noarch
OS: Rhel 8.6
How i made the backup:
foreman-maintain backup offline -y --skip-pulp-content /var/lib/pulp/backup-test
How i restore the backup:
(i am in the directory /var/lib/pulp/backup-test)
I think --tuning development is the new --disable-system-checksā€¦
I believe so too, however i find it weird that the foreman-maintain uses --disable-system-checks.
I looked on github and just saw this PR:
https://github.com/theforeman/foreman_maintain/pull/661
For now, iā€™ll just keep an eye out on that PR and if itā€™s merged and updated, iā€™ll test it out and close the issue here :slight_smile:
Thatā€™s correct. However, I think we will rather just update foreman-maintain directly to 1.2.1 (see Update foreman-maintain to 1.2.1 by evgeni Ā· Pull Request #8799 Ā· theforeman/foreman-packaging Ā· GitHub) instead of picking that one fix.
(the fix is safe to apply if you need to get going though!)
This is now merged and should be available when we release Foreman 3.4.1, which is planned shortly: Foreman 3.4.1 release process
Thank you for your time for fixing and responding! I actually was wondering when the new version would come out, iā€™ll look forward to it and weā€™ll update to it aswell :slight_smile: !
