# RFC: Dual selector component for organisations and locations
I am looking at alternatives to the Dual List Selector used for e.g. organizations and locations
PatternFly recommends Dual List for long lists. It seems that, on average, there is just a handful of organizations and locations, so the two-pane control is often heavier than the task. Seeing both lists may add cognitive load to orient and see/read which one is actually assigned.
I am exploring a compact PatternFly multi-select typeahead instead: type to find a name, check the items, and see the selection as chips in the field. This would take less space and can combine locations and organisations on the same page/tab/form.
Current implementation
Proposal
Multi-select typeahead
Alternative Designs
Alternatively, instead of 2 components, we can combine these into one.
What do you think?
If you assign orgs/locations in Foreman, I would like to know:
  • Roughly how many organizations and locations do you have?
  • Do you need both lists visible at once, or is a compact select enough?
  • Do you need bulk select for add/remove?
Thank you for your feedback.
Most customers only have one organization, one location. Some have up to 5 or 10. I only know one which has so many that Satellite support told him this are to many to be supported! :wink:
With this numbers I would they having them both together is convenient.
Yes, when systems are added via reports from config management and with multiple organizations/locations are placed in “any”.
  1. Less than five
  2. Compact select should be enough - with a slight preference for second design as more brief
  3. It would still be nice to have
I like the proposal, but can’t we put the selected elements into the drop down to save space? This way we could stuff both Org and Loc into a single pane eliminating one Tab. That is few extra clicks saved.
I understand the real estate within the drop down is not limitless, but we could do something like:
Organizations: MyOrg OtherOrg +2 more
I would really appreciate some shortcut for “Select All” somewhere, it could be actually single instance on the pane. I mean, it would select all organizations and locations which is very often what I want to do.
