This is not really a technical problem, just a look and feel thing, even a very minor one. (In case you start looking for repos on a client machine via either dnf or subscription-manager, which nearly never happens)
As well very much a keeping the overview thing, a search and a filter for currently enabled repos would improve that of course, but still that is slower than just having the repos there, you enabled the subscriptions of and being able to see what is enabled or what needs to be enabled to get to the wanted result.
Correct, currently the systems get some repos disabled on the bootstrap via the Activation Key, after changing all repos to being visible to a machine all will be either enabled or disabled by default, the currently already overridden repos will stay the way they are, but the rest… Lots of manual work involved.
Or am I reading this wrong in your #3 proposal? Does it mean that all repos that previously were available but not changed to overridden disabled (so either default or enabled overridden), will be enabled overridden and everything else disabled? (looks like I didn’t think of a automatic migration then )
It wouldn’t remove the need of creating lots of CVs to keep the overview though, but at least it doesn’t have to be done while migrating to SCA, which sounds a lot better than I previously thought!
