Katello Content Host shows as having applicable updates, but on the host itself, dnf believes the host to be fully up-to-date.
Applicable updates in Katello match what dnf thinks on the host.
foreman-2.5.2-1.el8.noarch
foreman-proxy-2.5.2-1.el8.noarch
katello-4.1.2.1-1.el8.noarch
katello-repos-4.1.2.1-1.el8.noarch
Oracle Linux 8 Katello installation, Oracle Linux 8 Content Host
Example package which shows as an applicable update:
perl-Data-Dump-1.23-7.module+el8.3.0+7716+6ab979be.noarch
dnf output on the host if you attempt to install the above:
All matches were filtered out by modular filtering for argument: perl-Data-Dump-1.23-7.module+el8.3.0+7716+6ab979be.noarch
Error: Unable to find a match: perl-Data-Dump-1.23-7.module+el8.3.0+7716+6ab979be.noarch
dnf module enablement:
perl 5.24 common [d], minimal Practical Extraction and Report Language
perl 5.26 [d][e] common [d], minimal Practical Extraction and Report Language
perl 5.30 common [d], minimal Practical Extraction and Report Language
