I’m trying to setup openscap on my newly provisioned CentOS8- and 9 servers but ran into this error when trying to run the ansible role “theforeman.foreman_scap_client” from my foreman server (version 3.9.1). Is this a known problem that I can easily fix? Package I want to install (rubygem-foreman_scap_client-0.5.2) is from Foreman-client-EL9 repo (Index of /client/3.9/el9/x86_64) that is using the RPM-GPG-KEY-foreman. According to this link that key is from 2014. Maybe it’s to weak for todays security-policies?
[root@carl-conch rpm-gpg]# cat /etc/redhat-release
CentOS Stream release 9
[root@carl-conch rpm-gpg]# LANG=C rpm --import RPM-GPG-KEY-foreman
warning: Signature not supported. Hash algorithm SHA1 not available.
error: RPM-GPG-KEY-foreman: key 1 import failed.
Regards,
/Fredrik
