Using the offical quick start guide, the command
sudo apt-get update && sudo apt-get -y install foreman-installer
aborts with an error stating that foreman-installer hat unmet dependencies (ruby).
Command should work without error.
Foreman Version 3.9
Foreman Plugins Version 3.9
Debian 11.8
Error Code
Some packages could not be installed. This may mean that you have requested an impossible situation or if you are using the unstable distribution that some required packages have not yet been created or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
foreman-installer: Depends: ruby but it is not installable or ruby-interpreter but it is not installable
Depends: ruby-kafo (>= 7.3.0) but it is not going to be installed
Depends: ruby-kafo (< 8.0.0) but it is not going to be installed
E: Unable to correct problems, you have held broken packages.
my sources.list file includes two entries:
deb Index of /debian-security bullseye-security main contrib
deb-src Index of /debian-security bullseye-security main contrib
Is there any other source that has to be added to the sources.list file?
Thanks in advance!
