For Ansible Role : theforeman.foreman_scap_client I need the following package (rubygem-foreman_scap_client).
Because I’m NOT running RHEL 7 but CentOS 7 I found this package in a old version of theforeman in http://yum.theforeman.org/plugins/1.17/el7/x86_64/ but not in the latest version.
Is there another Ansible Role with other packages for CentOS ?
Why can’t we find this package anymore?
Is there already an existing solution for OpenSCAP as an ansible role with CentOS ?
I’m testing out the OpenScap scanner right now against CentOS 8. If the goal is to use Ansible to configure your endpoints to run OpenScap scans, the Ansible role you need to install on your Foreman server or proxy is as simple as
You will need to import the Ansible role, and then import the Ansible variables. Once done, you can configure your OpenScap policy to use Ansible as the configuration mechanism, and then apply Ansible role ‘theforeman.foreman_scap_client’ to the hostgroup or system. After that, run the Ansible role to configure the endpoint, and then you can run an adhoc OpenScap scan of the system.
Note: I’m running Foreman 1.24.2 and Katello 3.14.1. Client systems will need to have the Foreman Client repository configured. Your mileage may vary with other versions.
Hi Mike, Thanks for your help.
Yes, my goal is to use Ansible to configure my endpoints CentOS Servers to run OpenScap scans. I’m using Satellite and theforman Ansible role is already running for my endpoints RHEL Server.
I’m sorry, but something’s not quite clear to me. Did you means that ansiblerole-foreman-scap_client is not the same as the theforeman.foreman_scap_client ?
Do you know from which repo can I find it? or download it?
Best regards, H
ansiblerole-foreman_scap_client.noarch is an RPM packaged version of theforeman.foreman_scap_client, which installs under /usr/share/ansible/roles/
It should be present in the same repositories that Foreman/Katello are packaged in (specifically foreman-plugins).
[root@foreman ssh]# yum info ansiblerole-foreman_scap_client.noarch
Installed Packages
Arch : noarch
Version : 0.0.3
Release : 1.el7
Repo : installed
From repo : foreman-plugins
Summary : Packaging of the foreman_scap_client Ansible role
URL : https://github.com/theforeman/ansible-foreman_scap_client/
License : GPLv3
Description : This package installs the foreman_scap_client Ansibile role.
: Make sure that "/usr/share/ansible/roles" is on your Ansible role_path.
[root@foreman ssh]# rpm -ql ansiblerole-foreman_scap_client.noarch
/usr/share/ansible/roles/theforeman.foreman_scap_client
/usr/share/ansible/roles/theforeman.foreman_scap_client/.flake8
/usr/share/ansible/roles/theforeman.foreman_scap_client/.gitignore
/usr/share/ansible/roles/theforeman.foreman_scap_client/.travis.yml
/usr/share/ansible/roles/theforeman.foreman_scap_client/LICENSE
/usr/share/ansible/roles/theforeman.foreman_scap_client/README.md
/usr/share/ansible/roles/theforeman.foreman_scap_client/defaults
/usr/share/ansible/roles/theforeman.foreman_scap_client/defaults/main.yml
/usr/share/ansible/roles/theforeman.foreman_scap_client/files
/usr/share/ansible/roles/theforeman.foreman_scap_client/files/foreman_scap_client_facts.rb
/usr/share/ansible/roles/theforeman.foreman_scap_client/meta
/usr/share/ansible/roles/theforeman.foreman_scap_client/meta/main.yml
/usr/share/ansible/roles/theforeman.foreman_scap_client/meta/version.yml
/usr/share/ansible/roles/theforeman.foreman_scap_client/molecule
/usr/share/ansible/roles/theforeman.foreman_scap_client/molecule/default
/usr/share/ansible/roles/theforeman.foreman_scap_client/molecule/default/molecule.yml
/usr/share/ansible/roles/theforeman.foreman_scap_client/molecule/default/playbook.yml
/usr/share/ansible/roles/theforeman.foreman_scap_client/molecule/default/tests
/usr/share/ansible/roles/theforeman.foreman_scap_client/molecule/default/tests/test_default.py
/usr/share/ansible/roles/theforeman.foreman_scap_client/molecule/default/yaml-lint.yml
/usr/share/ansible/roles/theforeman.foreman_scap_client/requirements.txt
/usr/share/ansible/roles/theforeman.foreman_scap_client/tasks
/usr/share/ansible/roles/theforeman.foreman_scap_client/tasks/main.yml
/usr/share/ansible/roles/theforeman.foreman_scap_client/templates
/usr/share/ansible/roles/theforeman.foreman_scap_client/templates/config.yaml.j2
/usr/share/ansible/roles/theforeman.foreman_scap_client/templates/cron.j2
/usr/share/doc/ansiblerole-foreman_scap_client-0.0.3
/usr/share/doc/ansiblerole-foreman_scap_client-0.0.3/README.md
Again, it’s necessary to import the Ansible roles from the Foreman Server, and then import the Ansible Variables. After that, you should be good to go.
Sorry for the delay and thanks a lot for your help.
I’ve checkout and I’ve the same version of the ansible role. Command’s output are the same. Import roles and other configurations are also ok.
The ansible role is tried to install the following package on client rubygem-foreman_scap_client and unfortunately CentOS didn’t find this package.
What do you use for your CentOS 8 test? What did you using?
Here’s the issue :
TASK [theforeman.foreman_scap_client : Install the foreman_scap_client package] ***
fatal: [w.x.y.z]: FAILED! => changed=false
msg: No package matching 'rubygem-foreman_scap_client' found available, installed or updated
rc: 126
results:
- No package matching 'rubygem-foreman_scap_client' found available, installed or updated
You need the Foreman Client repository synced and presented to the client systems (if you are using Katello); otherwise, you need to define the upstream Foreman Client on the endpoints.
Note: CentOS 8 only has client packages in Foreman 2.0, so that’s the client repository I’m using with CentOS 8 clients, and the Foreman 1.24/Katello 3.14 master.
I have been very busy experimenting with this function and trying to automate both the client and server side using Ansible. My test machines are Centos 7 and 8 and so I have had to do a lot of other steps in order to upload e.g.
I should also mention that if you are a licenced RHEL-only organisation you can use RedHat-Insights: https://cloud.redhat.com. This enables you to install the insights client software on your RHEL Server and then register directly (or via Satellite) with Insights however all I want is SCAP in a close environment.
Could you elaborate or provide an example with what is not working for you?
You do not need to install the packages on your client. If you run theforeman.foreman_scap_client role on your client host from Foreman, then everything should get configured correctly.
Do you have any suggestions on how the flow could be improved? Or is it just that there are too many steps to get it working?
Go to the Configure-Ansible->Roles menu and select Import: Select all the roles and click Update.
Now select theforeman.foreman_scap_client and import-Variables.
If I manually create the “/etc/foreman_scap_client/config.yaml” file on the client I can run: “foreman_scap_client 1” and partially works but I don’t know the correct path for the actual content to download.
If I run a scan from the host it obviously fails with a similar problem:
File /var/lib/openscap/content/3e1654fd14a5352d65294db555710bfda5cad1a942209e2d787ea7940035616e.xml is missing. Downloading it from proxy.
2:
Download SCAP content xml from: https://foreman.cloudboxservices.com:9090/compliance/policies/1/content/3e1654fd14a5352d65294db555710bfda5cad1a942209e2d787ea7940035616e
3:
DEBUG: running: oscap xccdf eval --profile xccdf_org.ssgproject.content_profile_standard --results-arf /tmp/d20210212-31325-eo5e5a/results.xml /var/lib/openscap/content/3e1654fd14a5352d65294db555710bfda5cad1a942209e2d787ea7940035616e.xml
Step 8: Hostgroup is not needed, but creating it and adding client to it is ok
Step 9: Go to Host → Edit and check that client has openscap proxy and theforeman.foreman_scap_client ansible role assigned, then assign policy in the hosts menu
Step 12: client package should be installed by theforeman.foreman_scap_client ansible role, so this step should not be needed when everything works correctly. The role also creates the config, I am curious why that is not happening. I’ll go over the steps myself to see if I can reproduce, but it seems like the role is not applied to the client at all for some reason.
I managed to get the OpenSCAP reporting running after rejigging my Ansible Playbook. The source of the problem was that the ansiblerole-foreman_scap_client rpm was not signed and caused some of the install to fail. I modified the repo to disable signing and everything works now.
