Schedule Remote Job using Salt Run state.highstate is pending forever
Schedule Remote Job using Salt Run state.highstate is pending forever (same for other commands, e.g. “test.ping”)
Job finishes and generates a report that can be imported.
3.2-stable
latest available gems
Using official docker-compose.yml and image crated from Dockerfile at The Foreman · GitHub
I use the “official” Docker containers and the docker-compose file extended by two containers running a Salt master (together with Smart Proxy and plugins) and a Salt minion. The communication between Salt master and minion is fine, also the communication between Foreman and Salt works in most cases:
  • Creating Salt proxy
  • Checking Salt keys
  • Importing states and grains
  • Uploading reports
Yet if I want to start a remote job as documented in Managing Hosts the job is “pending” forever.
In the log of the “app” container the job is started without error messages:
foreman-app-1           | 2022-04-27T11:59:09 [I|app|dc6e5d4d] Started POST "/job_invocations" for 87.177.153.9 at 2022-04-27 11:59:09 +0000
foreman-app-1           | 2022-04-27T11:59:09 [I|app|dc6e5d4d] Processing by JobInvocationsController#create as HTML
foreman-app-1           | 2022-04-27T11:59:09 [I|app|dc6e5d4d]   Parameters: {"utf8"=>"✓", "authenticity_token"=>"7KudPyGJ4DD7JYVaaUi3AN8X3QGKl6Osbv5sG0pXSwAJSPAvX365ngKocrM6O3SmEkmfkZ5HzARMM1xNFq/hLQ==", "job_invocation"=>{"job_category"=>"Salt", "remote_execution_feature_id"=>"", "providers"=>{"Salt"=>{"job_template_id"=>"153", "job_templates"=>{"153"=>{"effective_user"=>"", "execution_timeout_interval"=>""}, "152"=>{"inp
ut_values"=>"[FILTERED]", "effective_user"=>"", "execution_timeout_interval"=>""}, "155"=>{"input_values"=>"[FILTERED]", "effective_user"=>"", "execution_timeout_interval"=>""}}}}, "description"=>"Run Salt state.highstate on host", "description_override"=>"Run Salt state.highstate on host", "description_format"=>"Run Salt state.highstate on host", "password"=>"[FILTERED]", "key_passphrase"=>"", "effective_user_password"=>"[
FILTERED]", "concurrency_level"=>"", "time_span"=>""}, "targeting"=>{"bookmark_id"=>"", "search_query"=>"name ^ (docker-salt-minion)", "randomized_ordering"=>"false", "targeting_type"=>"static_query"}, "fakepassword"=>"[FILTERED]", "triggering"=>{"mode"=>"immediate", "start_at_raw"=>"2022-04-27 13:58", "start_before_raw"=>"", "input_type"=>"daily", "cronline"=>"", "days"=>"", "days_of_week"=>{"1"=>"0", "2"=>"0", "3"=>"0", "
4"=>"0", "5"=>"0", "6"=>"0", "7"=>"0"}, "time"=>{"time(1i)"=>"2022", "time(2i)"=>"4", "time(3i)"=>"27", "time(4i)"=>"13", "time(5i)"=>"59"}, "max_iteration"=>"", "end_time_limited"=>"false", "end_time"=>{"end_time(1i)"=>"2022", "end_time(2i)"=>"4", "end_time(3i)"=>"27", "end_time(4i)"=>"13", "end_time(5i)"=>"59"}, "purpose"=>""}, "commit"=>"Submit"}
foreman-app-1           | 2022-04-27T11:59:09 [D|dyn|] ExecutionPlan 7696a1b3-7475-410c-b23b-77b2fc35c89d      pending >>  planning
foreman-app-1           | 2022-04-27T11:59:09 [I|bac|] Task {label: Actions::RemoteExecution::RunHostsJob, id: 061e9d0f-470c-42ef-a4e9-1b5a0377e4a0, execution_plan_id: 7696a1b3-7475-410c-b23b-77b2fc35c89d} state changed: planning
foreman-app-1           | 2022-04-27T11:59:09 [D|dyn|]          Step 7696a1b3-7475-410c-b23b-77b2fc35c89d: 1   pending >>   running in phase     Plan Actions::RemoteExecution::RunHostsJob
foreman-app-1           | 2022-04-27T11:59:10 [D|dyn|]          Step 7696a1b3-7475-410c-b23b-77b2fc35c89d: 4   pending >>   running in phase     Plan Actions::TriggerProxyBatch
foreman-app-1           | 2022-04-27T11:59:10 [D|dyn|]          Step 7696a1b3-7475-410c-b23b-77b2fc35c89d: 4   running >>   success in phase     Plan Actions::TriggerProxyBatch
foreman-app-1           | 2022-04-27T11:59:10 [D|dyn|]          Step 7696a1b3-7475-410c-b23b-77b2fc35c89d: 1   running >>   success in phase     Plan Actions::RemoteExecution::RunHostsJob
foreman-app-1           | 2022-04-27T11:59:10 [D|dyn|] ExecutionPlan 7696a1b3-7475-410c-b23b-77b2fc35c89d     planning >>   planned
foreman-app-1           | 2022-04-27T11:59:10 [I|bac|] Task {label: Actions::RemoteExecution::RunHostsJob, id: 061e9d0f-470c-42ef-a4e9-1b5a0377e4a0, execution_plan_id: 7696a1b3-7475-410c-b23b-77b2fc35c89d} state changed: planned
I also see something in the log of the “orchestrator” container:
foreman-orchestrator-1  | 2022-04-27T11:59:10 [D|dyn|] ExecutionPlan 7696a1b3-7475-410c-b23b-77b2fc35c89d      planned >>   running
foreman-orchestrator-1  | 2022-04-27T11:59:10 [I|bac|] Task {label: Actions::RemoteExecution::RunHostsJob, id: 061e9d0f-470c-42ef-a4e9-1b5a0377e4a0, execution_plan_id: 7696a1b3-7475-410c-b23b-77b2fc35c89d} state changed: running
The log of the “worker” container does not show anything regarding this job. Also the Salt master and Smart proxy never receive any commands.
It would be nice if somebody could give me any hint on how to debug this further. Please let me know if I can provide any additional information.
Thank you very much in advance and best regards
Jannis
P.S.: Originally I got the error message “The Dynflow world was not initialized yet. If your plugin uses it, make sure to call Rails.application.dynflow.require! in some initializer” when trying to start a job from Foreman. I worked around this by inserting @dynflow.initialize! in function dynflow of config/application.rb.
My problem here was that the dynflow executor in my Foreman Docker container was not running. It can be started manually via
bundle exec rake dynflow:executor
For a solution see this thread.
