Introduction
This guide will walk you through the process of securing your Foreman instance in a development environment by setting up SSL for HTTPS access. By encrypting your communications, you can enhance the security of your Foreman development setup.
- A working Foreman installation.
- Root access to your Foreman server.
Step 1: Install step and step-ca from Smallstep:
Follow the instructions from the official documentation to install step and step-ca.
Step 2: Generate CA and Certificate:
Initialize your certificate authority:
step ca init
Run your certificate authority:
step-ca $(step path)/config/ca.json
Install your root CA certificate into your system’s default trust store:
step certificate install $(step path)/certs/root_ca.crt
Get a certificate and private key from the CA for the foreman server on localhost:
step ca certificate localhost srv.crt srv.key
Optional
Please note that default maximum certificate duration is 24 hours. To adjust the global default, minimum, and maximum certificate durations for your CA, add a claims section to the $(step path)/config/ca.json configuration file, under "authority", with the following keys:
"claims": {
"minTLSCertDuration": "5m",
"maxTLSCertDuration": "24h",
"defaultTLSCertDuration": "24h"
This configuration allows you to modify SSL certificate lifetimes as needed. You can achieve this by using the --not-after flag in the step ca certificate command. For example, specifying --not-after=240h will extend the certificate validity to the next 10 days from the current date.
Step 3: Configure HTTPS for Foreman:
Ensure you have the mod_ssl module installed:
dnf install mod_ssl
Disable the default HTTP listener in the Apache configuration:
vim /etc/httpd/conf.d/ssl.conf
Comment out the line:
# Listen 443 https
Ensure that the SSLEngine is set to on:
SSLEngine on
Edit the httpd conf file:
vim /etc/httpd/conf/httpd.conf
Add the following line to enable listening on port 443 for HTTPS:
Listen 443
Step 4: Update Hosts File:
Update your system’s /etc/hosts file with the following entries:
127.0.0.1 localhost your.foreman.domain boot.foreman.domain loadbalancer.foreman.domain
::1 localhost your.foreman.domain boot.foreman.domain loadbalancer.foreman.domain
0.0.0.0 your.foreman.domain boot.foreman.domain
Step 5: Create a Configuration File:
Create a new configuration file for your Foreman domain:
vim /etc/httpd/conf.d/your.foreman.domain.conf
Add the following configuration (adjust paths and settings as needed):
<VirtualHost *:80>
ServerName your.foreman.domain
ProxyPass / http://127.0.0.1:3000/
ProxyPassReverse / http://127.0.0.1:3000/
RequestHeader set X-Forwarded-Proto http
</VirtualHost>
<VirtualHost *:443>
SSLEngine on
SSLCertificateFile /path/to/your/srv.crt
SSLCertificateKeyFile /path/to/your/srv.key
SSLOptions +ExportCertData
RequestHeader set X-Forwarded-Proto https
RequestHeader set SSL_CLIENT_S_DN "%{SSL_CLIENT_S_DN}s"
RequestHeader set SSL_CLIENT_CERT "%{SSL_CLIENT_CERT}s"
RequestHeader set SSL_CLIENT_VERIFY "%{SSL_CLIENT_VERIFY}s"
<Location "/">
ProxyPass http://localhost:3000/
ProxyPassReverse http://localhost:3000/
</Location>
</VirtualHost>
Restart the Apache service to apply the changes:
systemctl restart httpd
Step 6: Foreman Configuration:
Edit your Foreman configuration file foreman/config/settings.yaml and update the following settings:
:webpack_dev_server_https: true
:domain: 'foreman.domain'
:fqdn: 'your.foreman.domain'
Navigate to the settings page on the UI and update the following settings:
Trusted hosts: [your.foreman.domain,localhost]
SSL certificate: /path/to/your/srv.crt
SSL CA file: /path/to/your/certs/root_ca.crt
SSL private key: /path/to/your/srv.key
SSL client DN env: HTTP_SSL_CLIENT_S_DN
SSL client verify env: HTTP_SSL_CLIENT_VERIFY
SSL client cert env: HTTP_SSL_CLIENT_CERT
Step 7: Run Foreman:
Run rails process:
bundle exec rails s -b 0.0.0.0 -p 3000
Run Webpack:
env NODE_ENV=development NOTIFICATIONS_POLLING=99999999 ./node_modules/.bin/webpack-dev-server-without-h2 --config ./config/webpack.config.js --allowed-hosts your.foreman.domain --https --cert /path/to/your/srv.crt --key /path/to/your/srv.key
Troubleshooting:
To find and diagnose errors, you can use the following commands:
Check Apache error logs
tail -f /var/log/httpd/error_log
Check Apache access logs
tail -f /var/log/httpd/access_log
Check Apache configuration syntax
apachectl configtest
Check systemd journal for Apache-related messages
journalctl -xe | grep httpd
SELinux Configuration:
If you encounter SELinux-related issues, follow these commands to address them:
Check SELinux context of certificate files
ls -Z /path/to/your/srv.crt /path/to/your/srv.key
Set the appropriate SELinux context
chcon -t httpd_sys_content_t /path/to/your/srv.crt /path/to/your/srv.key
If access denied errors persist, ensure the SELinux permissions are updated accordingly.
Browser Cache Issues:
Ensure to clear browser cache and test the SSL setup on multiple browsers, as cached certificates in browsers can sometimes cause issues.
Conclusion:
By following these steps, you have successfully configured SSL for running Foreman on HTTPS. Your Foreman instance is now more secure, and communication with it is encrypted.
