Ultimately, my problem is I’m unable to Grub2 UEFI HTTP boot. I think it starts with not having anything listening on port 8000 so I think it may be a good place to start. But, the other issues (that may be downstream from that) are: (1) my host that is configured to use Grub2 UEFI HTTP as its PXE Loader is using tftp (packet trace shows in.tftpd - I think it ought to be using http; and, (2) it’s attempting to contact the HTTPBoot host (my smartproxy) via HTTP over port 8443, which I thought would be a protocol mismatch (http://smartproxy:8443). Again, perhaps all of these issues would clear up if I can determine why foreman-proxy service isn’t listening on port 8000.
I’d like to HTTPBoot UEFI. I was expecting to be able to pull grubx64.efi down via http on port 8000 but nothing is running on port 8000.
Foreman version 1.20
Smart Proxy version 1.24
(There is a mismatch but I am hoping that it doesn’t have anything to do with foreman-proxy starting on port 8000.)
I am unsure. Is listening on port 8000 built in?
Foreman: CentOS 7.6
Smart Proxy: CentOS 7.7
2019-11-13T13:44:12 [I] WEBrick::HTTPServer#start done.
2019-11-13T13:44:13 [I] Successfully initialized 'discovery'
2019-11-13T13:44:13 [I] Successfully initialized 'foreman_proxy'
2019-11-13T13:44:13 [I] Successfully initialized 'dns_infoblox'
2019-11-13T13:44:13 [I] Successfully initialized 'dns'
2019-11-13T13:44:13 [I] Successfully initialized 'tftp'
2019-11-13T13:44:13 [I] Starting allocated ip address maintenance (used by unused_ip call).
2019-11-13T13:44:13 [I] Successfully initialized 'dhcp_isc'
2019-11-13T13:44:13 [I] Successfully initialized 'dhcp'
2019-11-13T13:44:13 [I] Successfully initialized 'logs'
2019-11-13T13:44:13 [I] Successfully initialized 'httpboot'
2019-11-13T13:44:13 [I] WEBrick 1.3.1
2019-11-13T13:44:13 [I] ruby 2.0.0 (2015-12-16) [x86_64-linux]
Certificate:
<...cert info removed...>
2019-11-13T13:44:13 [I] WEBrick::HTTPServer#start: pid=1818 port=8443
2019-11-13T13:44:13 [I] Smart proxy has launched on 1 socket(s), waiting for requests
2019-11-13T15:38:26 72ae0dd5 [I] Started GET /version
2019-11-13T15:38:26 72ae0dd5 [I] Finished GET /version with 200 (5.61 ms)
Looking at what is listening:
[root@smartproxy-hyperv ~]# ss -nap | grep -e 'ruby\|8443\|8000'
u_str ESTAB 0 0 * 27912 * 26969 users:(("ruby",pid=1818,fd=2),("ruby",pid=1818,fd=1))
tcp LISTEN 0 128 [::]:8443 [::]:* users:(("ruby",pid=1818,fd=10))
I don’t see any indicators as to what may be preventing anything from listening on port 8000
[root@smartproxy-hyperv ~]# cat /etc/foreman-installer/scenarios.d/foreman-answers.yaml
# Format:
# <classname>: false - don't include this class
# <classname>: true - include and use the defaults
# <classname>:
# <param>: <value> - include and override the default(s)
# See params.pp in each class for what options are available
foreman: false
foreman::cli: false
foreman::cli::ansible: false
foreman::cli::discovery: false
foreman::cli::kubevirt: false
foreman::cli::openscap: false
foreman::cli::remote_execution: false
foreman::cli::tasks: false
foreman::cli::templates: false
foreman_proxy:
repo: stable
gpgcheck: true
version: present
ensure_packages_version: present
plugin_version: installed
bind_host:
http_port: 8000
ssl_port: 8443
dir: /usr/share/foreman-proxy
user: foreman-proxy
groups: []
log: /var/log/foreman-proxy/proxy.log
log_level: DEBUG
log_buffer: 2000
log_buffer_errors: 1000
http: true
ssl: true
ssl_ca: /etc/puppetlabs/puppet/ssl/certs/ca.pem
ssl_cert: /etc/puppetlabs/puppet/ssl/certs/smartproxy-hyperv.example.com.pem
ssl_key: /etc/puppetlabs/puppet/ssl/private_keys/smartproxy-hyperv.example.com.pem
foreman_ssl_ca:
foreman_ssl_cert:
foreman_ssl_key:
trusted_hosts:
- foreman.example.com
- 10.61.75.9
- smartproxy-hyperv.example.com
ssl_disabled_ciphers: []
tls_disabled_versions: []
manage_sudoersd: true
use_sudoersd: true
use_sudoers: true
puppetca: false
puppetca_split_configs: true
puppetca_listen_on: https
ssldir: /etc/puppetlabs/puppet/ssl
puppetdir: /etc/puppetlabs/puppet
puppetca_cmd: /opt/puppetlabs/bin/puppet cert
puppet_group: puppet
puppetca_provider: puppetca_hostname_whitelisting
autosignfile: /etc/puppetlabs/puppet/autosign.conf
puppetca_sign_all: false
puppetca_tokens_file: /var/lib/foreman-proxy/tokens.yml
puppetca_token_ttl: 360
puppetca_certificate:
manage_puppet_group: false
puppet: false
puppet_listen_on: https
puppetrun_provider:
customrun_cmd: /bin/false
customrun_args: -ay -f -s
mcollective_user: root
puppetssh_sudo: false
puppetssh_command: /opt/puppetlabs/bin/puppet agent --onetime --no-usecacheonfailure
puppetssh_user: root
puppetssh_keyfile: /etc/foreman-proxy/id_rsa
puppetssh_wait: false
salt_puppetrun_cmd: puppet.run
puppet_user: root
puppet_url: https://smartproxy-hyperv.example.com:8140
puppet_ssl_ca: /etc/puppetlabs/puppet/ssl/certs/ca.pem
puppet_ssl_cert: /etc/puppetlabs/puppet/ssl/certs/smartproxy-hyperv.example.com.pem
puppet_ssl_key: /etc/puppetlabs/puppet/ssl/private_keys/smartproxy-hyperv.example.com.pem
puppet_api_timeout: 30
templates: false
templates_listen_on: both
template_url: http://smartproxy-hyperv.example.com:8000
logs: true
logs_listen_on: both
httpboot: true
httpboot_listen_on: http
tftp: true
tftp_listen_on: both
tftp_managed: true
tftp_manage_wget: true
tftp_syslinux_filenames:
- /usr/share/syslinux/chain.c32
- /usr/share/syslinux/mboot.c32
- /usr/share/syslinux/menu.c32
- /usr/share/syslinux/memdisk
- /usr/share/syslinux/pxelinux.0
tftp_root: /var/lib/tftpboot
tftp_dirs:
- /var/lib/tftpboot/pxelinux.cfg
- /var/lib/tftpboot/grub
- /var/lib/tftpboot/grub2
- /var/lib/tftpboot/boot
- /var/lib/tftpboot/ztp.cfg
- /var/lib/tftpboot/poap.cfg
tftp_servername: 10.61.17.254
tftp_replace_grub2_cfg: false
dhcp: true
dhcp_listen_on: https
dhcp_managed: true
dhcp_provider: isc
dhcp_subnets:
- 10.61.179.0/24
dhcp_option_domain:
- example.com
dhcp_search_domains:
- example.com
dhcp_interface: eth0
dhcp_additional_interfaces: []
dhcp_gateway: 10.61.17.1
dhcp_range: 10.61.17.20 10.61.17.240
dhcp_pxeserver: 10.61.17.254
dhcp_pxefilename: pxelinux.0
dhcp_network: 10.61.17.0
dhcp_netmask: 255.255.255.0
dhcp_nameservers: 10.35.35.35
dhcp_server: 127.0.0.1
dhcp_config: /etc/dhcp/dhcpd.conf
dhcp_leases: /var/lib/dhcpd/dhcpd.leases
dhcp_key_name:
dhcp_key_secret:
dhcp_omapi_port: 7911
dhcp_peer_address:
dhcp_node_type: standalone
dhcp_failover_address: 10.61.17.254
dhcp_failover_port: 519
dhcp_max_response_delay: 30
dhcp_max_unacked_updates: 10
dhcp_mclt: 300
dhcp_load_split: 255
dhcp_load_balance: 3
dhcp_manage_acls: true
dns: true
dns_listen_on: both
dns_managed: true
dns_provider: infoblox
dns_interface: eth0
dns_zone: example.com
dns_reverse:
- 17.61.10.in-addr.arpa
dns_server: 10.35.35.35
dns_ttl: 86400
dns_tsig_keytab: /etc/foreman-proxy/dns.keytab
dns_tsig_principal: foremanproxy/smartproxy-hyperv.example.com@EXAMPLE.COM
dns_forwarders:
- 10.35.35.35
- 10.36.36.36
libvirt_network: default
libvirt_connection: qemu:///system
bmc: true
bmc_listen_on: both
bmc_default_provider: ipmitool
bmc_ssh_user: root
bmc_ssh_key: /usr/share/foreman/.ssh/id_rsa
bmc_ssh_powerstatus: 'true'
bmc_ssh_powercycle: shutdown -r +1
bmc_ssh_poweroff: shutdown +1
bmc_ssh_poweron: 'false'
realm: false
realm_listen_on: https
realm_provider: freeipa
realm_keytab: /etc/foreman-proxy/freeipa.keytab
realm_principal: realm-proxy@EXAMPLE.COM
freeipa_config: /etc/ipa/default.conf
freeipa_remove_dns: true
keyfile: /etc/rndc.key
register_in_foreman: true
foreman_base_url: https://foreman.example.com
registered_name: smartproxy-hyperv.example.com
registered_proxy_url:
oauth_effective_user: admin
oauth_consumer_key: *****
oauth_consumer_secret: ******
puppet:
version: present
user: puppet
group: puppet
codedir: /etc/puppetlabs/code
vardir: /opt/puppetlabs/puppet/cache
logdir: /var/log/puppetlabs/puppet
rundir: /var/run/puppetlabs
sharedir: /opt/puppetlabs/puppet
manage_packages: true
dir_owner: root
dir_group:
package_provider:
package_source:
port: 8140
listen: false
listen_to: []
pluginsync: true
splay: false
splaylimit: 1800
autosign: /etc/puppetlabs/puppet/autosign.conf
autosign_entries: []
autosign_mode: '0664'
autosign_content:
autosign_source:
runinterval: 1800
usecacheonfailure: true
runmode: service
run_hour:
run_minute:
unavailable_runmodes: []
cron_cmd:
systemd_cmd:
systemd_randomizeddelaysec: 0
agent_noop: false
show_diff: false
module_repository:
http_connect_timeout:
http_read_timeout:
ca_server:
ca_port:
ca_crl_filepath:
prerun_command:
postrun_command:
dns_alt_names: []
use_srv_records: false
srv_domain: example.com
pluginsource: puppet:///plugins
pluginfactsource: puppet:///pluginfacts
additional_settings: {}
agent_additional_settings: {}
agent_restart_command: /usr/bin/systemctl reload-or-restart puppet
classfile: $statedir/classes.txt
hiera_config: $confdir/hiera.yaml
auth_template: puppet/auth.conf.erb
allow_any_crl_auth: false
auth_allowed:
- $1
client_package:
- puppet-agent
agent: true
remove_lock: true
report: true
client_certname: smartproxy-hyperv.example.com
puppetmaster:
systemd_unit_name: puppet-run
service_name: puppet
syslogfacility:
environment: production
server: true
server_admin_api_whitelist:
- localhost
server_manage_user: true
server_user: puppet
server_group: puppet
server_dir: /etc/puppetlabs/puppet
server_ip: 0.0.0.0
server_port: 8140
server_ca: true
server_ca_crl_sync: false
server_crl_enable:
server_ca_auth_required: true
server_ca_client_whitelist:
- localhost
server_custom_trusted_oid_mapping:
server_http: false
server_http_port: 8139
server_reports: foreman
server_puppetserver_dir: /etc/puppetlabs/puppetserver
server_puppetserver_vardir: /opt/puppetlabs/server/data/puppetserver
server_puppetserver_rundir: /var/run/puppetlabs/puppetserver
server_puppetserver_logdir: /var/log/puppetlabs/puppetserver
server_puppetserver_version:
server_external_nodes: /etc/puppetlabs/puppet/node.rb
server_cipher_suites:
- TLS_RSA_WITH_AES_256_CBC_SHA256
- TLS_RSA_WITH_AES_128_CBC_SHA256
server_config_version:
server_connect_timeout: 120000
server_git_repo: false
server_default_manifest: false
server_default_manifest_path: /etc/puppet/manifests/default_manifest.pp
server_default_manifest_content: ''
server_environments_owner: puppet
server_environments_group:
server_environments_mode: '0755'
server_envs_dir: /etc/puppetlabs/code/environments
server_envs_target:
server_common_modules_path:
- /etc/puppetlabs/code/environments/common
- /etc/puppetlabs/code/modules
- /opt/puppetlabs/puppet/modules
- /usr/share/puppet/modules
server_git_repo_mode: '0755'
server_git_repo_path: /opt/puppetlabs/puppet/cache/puppet.git
server_git_repo_group: puppet
server_git_repo_user: puppet
server_git_branch_map: {}
server_idle_timeout: 1200000
server_post_hook_content: puppet/server/post-receive.erb
server_post_hook_name: post-receive
server_storeconfigs_backend:
server_ruby_load_paths:
- /opt/puppetlabs/puppet/lib/ruby/vendor_ruby
server_ssl_dir: /etc/puppetlabs/puppet/ssl
server_ssl_dir_manage: true
server_ssl_key_manage: true
server_ssl_protocols:
- TLSv1.2
server_ssl_chain_filepath: /etc/puppetlabs/puppet/ssl/ca/ca_crt.pem
server_package:
server_version:
server_certname: smartproxy-hyperv.example.com
server_enc_api: v2
server_report_api: v2
server_request_timeout: 60
server_strict_variables: false
server_additional_settings: {}
server_foreman: true
server_foreman_url: https://smartproxy-hyperv.example.com
server_foreman_ssl_ca:
server_foreman_ssl_cert:
server_foreman_ssl_key:
server_foreman_facts: true
server_puppet_basedir: /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet
server_puppetdb_host:
server_puppetdb_port: 8081
server_puppetdb_swf: false
server_parser: current
server_environment_timeout:
server_jvm_java_bin: /usr/bin/java
server_jvm_config: /etc/sysconfig/puppetserver
server_jvm_min_heap_size: 2G
server_jvm_max_heap_size: 2G
server_jvm_extra_args:
server_jvm_cli_args:
server_jruby_gem_home: /opt/puppetlabs/server/data/puppetserver/jruby-gems
server_max_active_instances: 2
server_max_requests_per_instance: 0
server_max_queued_requests: 0
server_max_retry_delay: 1800
server_use_legacy_auth_conf: false
server_check_for_updates: true
server_environment_class_cache_enabled: false
server_allow_header_cert_info: false
server_web_idle_timeout: 30000
server_puppetserver_jruby9k: false
server_puppetserver_metrics:
server_metrics_jmx_enable: true
server_metrics_graphite_enable: false
server_metrics_graphite_host: 127.0.0.1
server_metrics_graphite_port: 2003
server_metrics_server_id: smartproxy-hyperv.example.com
server_metrics_graphite_interval: 5
server_metrics_allowed:
server_puppetserver_experimental: true
server_puppetserver_trusted_agents: []
server_compile_mode:
server_acceptor_threads:
server_selector_threads:
server_ssl_acceptor_threads:
server_ssl_selector_threads:
server_max_threads:
server_ca_allow_sans: false
server_ca_allow_auth_extensions: false
server_ca_enable_infra_crl: false
server_max_open_files:
foreman::plugin::ansible: false
foreman::plugin::azure: false
foreman::plugin::bootdisk: false
foreman::plugin::chef: false
foreman::plugin::cockpit: false
foreman::plugin::default_hostgroup: false
foreman::plugin::dhcp_browser: false
foreman::plugin::digitalocean: false
foreman::plugin::discovery: {}
foreman::plugin::expire_hosts: false
foreman::plugin::hooks: false
foreman::plugin::host_extra_validator: false
foreman::plugin::kubevirt: false
foreman::plugin::memcache: false
foreman::plugin::monitoring: false
foreman::plugin::omaha: false
foreman::plugin::openscap: false
foreman::plugin::ovirt_provision: false
foreman::plugin::puppetdb: false
foreman::plugin::remote_execution: false
foreman::plugin::salt: false
foreman::plugin::setup: false
foreman::plugin::snapshot_management: false
foreman::plugin::tasks: false
foreman::plugin::templates: false
foreman::compute::ec2: false
foreman::compute::gce: false
foreman::compute::libvirt: false
foreman::compute::openstack: false
foreman::compute::ovirt: false
foreman::compute::rackspace: false
foreman::compute::vmware: false
foreman_proxy::plugin::ansible: false
foreman_proxy::plugin::chef: false
foreman_proxy::plugin::dhcp::infoblox: false
foreman_proxy::plugin::dhcp::remote_isc: false
foreman_proxy::plugin::discovery:
install_images: true
source_url: http://downloads.theforeman.org/discovery/releases/3.4/
image_name: fdi-image-latest.tar
foreman_proxy::plugin::dns::infoblox:
dns_server: <infoblox_server>
username: svc_foreman
password: *******
dns_view: default
foreman_proxy::plugin::dns::powerdns: false
foreman_proxy::plugin::dynflow: false
foreman_proxy::plugin::monitoring: false
foreman_proxy::plugin::omaha: false
foreman_proxy::plugin::openscap: false
foreman_proxy::plugin::pulp: false
foreman_proxy::plugin::remote_execution::ssh: false
foreman_proxy::plugin::salt: false
