Smart Card Authentication to foreman UI
I need some help with the Authentication process. Does anybody enabling smart card autenthication (PKCS#15) to the foreman UI? Is this supported via foreman?
Or is it possible to disable this authentification method?
Thanks a lot for help.
Jazzbo
The 1.24 supports this. Wait for 1.24 stable release and then you can use this,
Here is the PR which adds support for this,
With this there will be documentation on how to use it, I shall comment on this once we have it.
thanks for your support!
