I have a need to pass a Foreman Host Group parameter to a Puppet module where it will be used in a template like so:
- Create the component module
class my_module ( $foreman_param, ){ file { 'my_file': ensure => 'file,' content => epp(my_module/my_template.epp, { foreman_param => $foreman_param }), } }
- Create the template
my_value = <%= $foreman_param %>
- Import the class into Foreman and override it’s value with an ERB template containing the Host Group Parameter
Everything up to here works as expected. If my_class is assigned to a node the Foreman ENC inserts a dynamic value for $foreman_param based on the nodes host group.
The issue arises when I add my_module to a profile class. All of my attempts so far have resulted in “Class my_profile expects a value for parameter $foreman_param” type errors during puppet runs on a test node.
- This doesn’t work:
class my_profile { include my_module }
- Nor does this with the Foreman Smart Class Parameter override replicated for my_profile::foreman_param:
class my_profile ( $foreman_param, ){ include my_module }
Any ideas on what my problem is here?
