I import Puppet Modules with class parameters as “Float” and with default values. Foreman correctly sets the type to “Real”, but I cannot modify the decimal places in the values.
class ros2configuration::gnss_fix_position_adapter::fix (
Float $latitude = 49.12345,
Float $longitude = 6.9,
Float $altitude = 250.0,
Integer $rateHz = 5,
Float $speed = 10.0,
Float $heading = 250.0,
When I modify the Smart Class Parameter for a host (e.g. setting latitude == 49.11111), I get the error:
Please select a valid value. The two nearest valid values are 48.12345 and 49.12345
As mentioned, the Smart Class Parameter is “Real” and there are no Input Validators.
Setting the value to whatever Float I want (e.g. 49.345678) should be possible. Especially, editing the decimal places should work.
Foreman: 3.18.1
Puppet smartproxy: 3.18.1
Puppet Agent: 8.10.0
Puppet Server: 8.7.0
foreman_puppet: 9.1.0
Ubuntu 22.04
