Error: Proxy provisioning.build.com has failed to load one or more features (Puppet), check /var/log/foreman-proxy/proxy.log for configuration errors
features: change from ["BMC", "DHCP", "DNS", "Logs", "Puppet CA", "TFTP"] to ["BMC", "DHCP", "DNS", "Logs", "Puppet", "Puppet CA", "TFTP"]
should succeed
root@provisioning:/home/rje/puppet# dpkg-query -l | grep foreman
ii foreman 3.2.0-1 amd64 Systems management web interface
ii foreman-debug 3.2.0-1 all provides support utility foreman-debug.
ii foreman-dynflow-sidekiq 3.2.0-1 all package providing dynflow sidekiq services for Foreman
ii foreman-postgresql 3.2.0-1 all metapackage providing PostgreSQL dependencies for Foreman
ii foreman-proxy 3.2.0-1 all RESTful proxies for DNS, DHCP, TFTP, and Puppet
ii foreman-service 3.2.0-1 all package providing Foreman services running via puma
Ubuntu 20.04
I am installing Foreman and its proxies with the puppet modules. If foreman_proxy::puppet: true
, when I run puppet apply
I get this error:
Error: /Stage[main]/Foreman_proxy::Register/Foreman_smartproxy[provisioning.build.com]/features: change from ["BMC", "DHCP", "DNS", "Logs", "Puppet CA", "TFTP"] to ["BMC", "DHCP", "DNS", "Logs", "Puppet", "Puppet CA", "TFTP"] failed: Proxy provisioning.build.com has failed to load one or more features (Puppet), check /var/log/foreman-proxy/proxy.log for configuration errors
There are no errors in /var/log/foreman-proxy/proxy.log
Reading the proxy’s /vs/features endpoint looks correct.
root@provisioning:/home/rje/puppet# curl -k --cert /etc/puppetlabs/puppet/ssl/certs/provisioning.build.com.pem --key /etc/puppetlabs/puppet/ssl/private_keys/provisioning.build.com.pem https://provisioning.build.com:8443/v2/features | python3 -m json.tool
% Total % Received % Xferd Average Speed Time Time Time Current
Dload Upload Total Spent Left Speed
100 1708 100 1708 0 0 63259 0 --:--:-- --:--:-- --:--:-- 63259
"facts": {
"http_enabled": false,
"https_enabled": false,
"settings": {},
"state": "disabled",
"capabilities": []
"dns": {
"https_enabled": true,
"settings": {
"use_provider": "dns_nsupdate"
"state": "running",
"capabilities": []
"templates": {
"settings": {
"template_url": null
"settings": {
"tftp_servername": null
"state": "running",
"capabilities": []
"dhcp": {
"settings": {
"use_provider": "dhcp_isc"
"state": "running",
"capabilities": [
"dhcp_filename_hostname",
"dhcp_filename_ipv4"
"puppetca": {
"settings": {
"puppet_url": "https://provisioning.build.sea1.j4cap.com:8140",
"use_provider": [
"puppetca_hostname_whitelisting",
"puppetca_http_api"
"state": "running",
"capabilities": []
"puppet": {
"settings": {
"use_provider": [
"puppet_proxy_puppet_api"
"state": "running",
"capabilities": []
"bmc": {
"settings": {},
"state": "running",
"capabilities": [
"ipmitool",
"redfish",
"shell",
"ssh"
"realm": {
"settings": {
"use_provider": null
"capabilities": []
"logs": {
"settings": {},
"state": "running",
"capabilities": []
"httpboot": {
"settings": {
"http_port": null,
"https_port": null
"capabilities": []
"registration": {
"settings": {},
"capabilities": []
