also created a file called dns_route53.yml with the key and secret
when i’m restarting the proxy i see he takes the default values
[root@foreman config]# service foreman-proxy restart
Redirecting to /bin/systemctl restart foreman-proxy.service
I, [2015-08-23T09:26:52.505817 #31423] INFO – : ‘pulpnode’ module is
disabled.
I, [2015-08-23T09:26:52.506452 #31423] INFO – : ‘foreman_proxy’ settings
were initialized with default values: :enabled: true
I, [2015-08-23T09:26:52.508469 #31423] INFO – : ‘facts’ module is
disabled.
I, [2015-08-23T09:26:52.508789 #31423] INFO – : ‘dns’ settings were
initialized with default values: :dns_provider: nsupdate
I, [2015-08-23T09:26:52.510814 #31423] INFO – : ‘templates’ module is
disabled.
I, [2015-08-23T09:26:52.513092 #31423] INFO – : ‘dhcp’ module is disabled.
I, [2015-08-23T09:26:52.813941 #31423] INFO – : ‘puppet’ settings were
initialized with default values: :puppet_provider: puppetrun, :puppetdir:
/etc/puppet, :salt_puppetrun_cmd: puppet.run, :use_cache: true
I, [2015-08-23T09:26:52.816140 #31423] INFO – : ‘bmc’ module is disabled.
I, [2015-08-23T09:26:52.816493 #31423] INFO – : ‘realm’ module is
disabled.
someone had that issue before? even with different dns provider?
how did you solved it?
Which version of foreman-proxy do you have installed? DNS providers
added in plugins are only going to be supported from 1.10, so you'll
need to use a version from our nightly repos until that release is out
in a few months.
On 23/08/15 10:32, Eliran Shlomo wrote:
> Hi,
> i installed the smart_proxy_dns_route53
> after that changed /etc/foreman-proxy/settings.d/dns.yml to the
> following values
> [root@foreman settings.d]# cat dns.yml
> # DNS management
> :enabled: true
> :use_provider: dns_route53
> :dns_ttl: 60
> when i'm restarting the proxy i see he takes the default values
> I, [2015-08-23T09:26:52.505817 #31423] INFO -- : 'pulpnode' module is
> disabled.
> I, [2015-08-23T09:26:52.506452 #31423] INFO -- : 'foreman_proxy'
> settings were initialized with default values: :enabled: true
> I, [2015-08-23T09:26:52.508469 #31423] INFO -- : 'facts' module is
> disabled.
> I, [2015-08-23T09:26:52.508789 #31423] INFO -- : 'dns' settings were
When installed from our packages (at least on Red Hats), proxy reads
from /usr/share/foreman-proxy/config directory where we have symlinks
into /etc. Also, check the contents of settings.yaml file where the path
for settings.d dir is defined.
